I will be looking at running a GTG on Sunday 8 May, starting 2.00pm.  This will be posted in the GTG forum.  PM me for details.  A pair of DWM woofers will be set up for the occasion, courtesy of someone. Limit of 15 attendees.
Would've loved to be there, Peter - to here some 20.7s - but am going away on holiday that day.  Hope it goes well.
No worries Andy.  Enjoy your holiday.  You can always have a listen some other time.
@@generichs,
Have you already tested DWM's being coupled with a pair of Maggies?
If you havent I would suggest you trial first before you commit to purchase if you can.
I have and found little discernable difference. I think a lot more can be achieved with a pair of maggies via other options
than the addition of a pair of DWM's. I honestly think that a decent sub which can get lower than the DWM is a better option
anyhow.
Ozzie
@@generichs,
anyhow.
Ozzie
The DWMs in the GTG will be demo.  I'm sure they will be disconnected at some point to show the difference.
What size room did you hear them in?
Edited by generichs
Just In case I miss the posting of the gtg
I WANNA COME
Guest Sime
Ditto.
I WANNA COME
Edited by Sime
I WANNA COME
i'll put you on the list.  I used to have a Maggie Tympani 1D 30 yrs ago.  Now I know where it is :D
Edited by generichs
Ditto.
Before I post on GTG forum I will deduct the attendees from this thread.
Guest Sime
Try and have it around the hifi show in July, please :)
I considered that but I thought it better to have it when the weather is warmer.  The date will be 8 May. (The date may be changed).  The other problem with having it on during the Hifi show is that going to the show and having a GTG would be too much.
Edited by generichs
Fascinating system @@generichs !! :)
I love the look of the turntable !!
I've only heard the little Magnapan's and would be interested in hearing the 20.7.
Would be interested in coming on the 8th of May. :)
Bill Mcleans shop. If you have ever been there then you would have an idea of dimensions. The listening area would be at a guess something like 4m x 3.5m..
I know Bill has a pair of 20.7's which he couples with a pair of DWM's.
I might see if I can head over to his place for a listen.
I stand to be corrected but I am pretty sure he incorporates a DEQX and PS Audio Amp in the mix.
If I can get over there I will be sure to report back.
Should be easy to perform an A/B comparison of with and without the DWM's. Bill describes the addition of the DWM's as adding
more bass "slam". Its not necessarily the case that adding the DWM will improve SQ either. A lot of this is contingent to the room
dynamics. And if you ask Bill over the years he has set up systems in peoples homes where he thought it would not work and it
does.
Ozzie
If there is enough interest, I can have a GTG over the July Hifi show weekend for those who miss the May GTG.  I don't think the July GTG will have the DWM woofers, but you never know your luck.
PLEASE NOTE the GTG is looking to be set for Sunday 10 April, subject to confirmation.
I can make April 10, Peter - so hope you have a slot left
Edited by andyr
You guys are in for a Concert, choose your performers.
I visited Peter yesterday and was spellbound by the sheer scale of sound.
PS: Get dome music recommendations from him, he's got great taste in music.
April rsvp I'm available
GTG to hear this system has been posted in the GTG section of this Forum.  GTG will be 2.00PM Sunday 10 April.
@@generichs,
Apologies if you have been asked before but what are your room dimensions?
Cheers Ozzie
There's just something about this space, looks to be a great spot to unwind. Well done.
@@generichs,
Cheers Ozzie
The area is open plan.  The distance from front wall to back wall is about 8.5m.  Width of the listen room is probably 14m.
And have you played with toe-in?  Looking at the first pic, the perpendicular from each ribbon seems to be crossing in front of you?  Try flattening the panels a bit (wrt to the front wall), so that the ribbon perpendiculars point to your ears.
@@andyr you are right, toe in plays a big part in the sound of the speakers.  The pic shows an early toe in.  Early in break in treble is too strong.  Once speakers are broken in, I have been using less toe in.  Still tuning toe in.  I have tried your toe in angle and gone past it.  There is a point at which there is a lot of bass and vague imaging.  I think at that point there is not enough imaging.  I then wind back to a spot I like.
I've been doing some tweaking of the system.  I eventually managed to get the speakers on Mye Stands; and I bought more Ikea bamboo cutting boards to rearrange the equipment. Turntable now sits on a couple of cutting boards on the Lead Balloon.  This sounds better than having the TT sitting on the Dekstand.  Bass has more slam and sound is solid and dynamic.
post-154931-0-77524000-1461590172_thumb.post-154931-0-69528800-1461590203_thumb.
Here is a report on the 20.7 with Mye Stands.
The standard supports which come with the current model 20.7i are quite good, so the improvement with the use of Mye Stands is not vital.  There is a slight trade-off due to synergy of the standard support with the 20.7 panel.  On the standard support, a bit of tilt forward will result in an expansion in soundstage width, at the distant seated position.  This does not happen to the same extent with the Mye Stand, perhaps because the panels are lifted about 2in higher on the Mye Stands.  In my room, any tilt on the Mye Stand results in a muddying of the sound.  The 20.7 likes to be vertical on the Mye Stand.
The 20.7i on Mye Stands does sound cleaner, with steadier imaging.  Tone decay is more extended.  Bass has more slam.  Treble is more lush, without being overdone.  You are able to listen more into the sound.  In short, the improvements are all you would expect if the noise floor was lowered.  You get better dynamics and better resolution, without exaggeration at select frequencies.
I filled the struts with sand.  I did make a small improvement.  The sound was more grounded  :P   It's a cheap tweak and worth it.  I already had spare river sand on hand from a previous tweak.
    • By haygeebaby
      Item Condition: Perfect - used Shipping Options: Pickup available and you can audition. Suburb or Town: Perth State: Western Australia Payment Method: EFT, Cash on Pickup Reason for selling: Upgrading
      Re-post - price is negotiable / offers welcome.
      Purchased new from local supplier just over 3 years ago.
      Still using stock tubes with total hour count of 1,625 hours over 3 years.
      Unit is in perfect working condition and is pristine in appearance.
      Unit is complete with manual, QC sheets, power cable, screw driver, remote control, and original box. Remote control has hardly been used at all.
      Also have a full set of spare tubes for the unit which are brand new – Sovtek 1 x 6550WE, and 4 x 6H30.
      Really loved this unit. Very good user interface. Impedance changing on the fly, auto shut off, display dimming, new/current ARC styling, solid metal remote control.
      Fixed gain of 55db. Have used with several cartridges with wonderful sounding results – including Benz Micro Wood S L (0.4mv) and EMT JSD P6.0 (1.05mv).
      Loading range 47k, 1000, 500, 200, 100 Ohms.
    • By Chris Launder
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Bangalow State: New South Wales Payment Method: EFT/Cash on Pickup/Paypal Reason for selling: Not getting enough use. Further information:
      For sale I have an Audio Research DAC 8 in excellent condition , I am the original owner , the unit was taken out of the box , sat on the shelf & left there .
      I have everything except the original box which I put in the recycle bin as I never intended to sell the unit ...
      Currently being used as an outboard DAC for my Oppo Bluray which seems a waste of such a superb unit .
      It will be very securely packed , happy to arrange delivery or meet up within 100klm of Byron Bay .
      Still available , 1st enquirer did not proceed .
      PLEASE READ
    • By Diatone
      Item:intergrated Audio Research Tube amp
      Price Range: 5-10k
      Item Condition: New or Used
      Extra Info: pls give me offers
    • By Yamaha_man
      Item Condition: excellent Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Warrnambool State: Victoria Payment Method: cash, bank deposit. Reason for selling: hasn't been used for years since purchase of current speakers. Further information: For Sale is the Wilson Watch Dog 2 Subwoofer - A passive subwoofer with Watch controller.
      This is one of the finest subwoofers ever built and for this very reason Wilson Audio have kept this the same for over 15 years!
      While they have upgraded and added onto their speakers in some cases twice over. The Watch Dog has remained.
      Perfection cannot be improved on.
      As this is a passive subwoofer it needs a Mono amplifier - I have paired it with an Audio Research DS450m which is an explosive combination.
      Every item has its original box so shipping is certainly not a problem.
      The WATCH Dog is an ultra-high-performance, compact, passive subwoofer. There’s a widespread myth that since subwoofers operate in the low to subsonic frequency range, the sonic quality of the amplifier used to drive them is not critical. Couple that with the fact that FTC-mandated criteria for power amplifier specifications don’t apply to active subwoofers—a loophole which allows manufacturers to wildly inflate performance claims for what are, in many cases (no pun intended) the severely sub-standard amplifiers built into their subwoofers.
      The finish is Wilson ivory which is an upgrade colour.
      I estimate this sub package to have only 150 hours of use since new.
      For the asking price you are effectively paying less than retail for the amp or controller and getting the rest of the package for free.
      RRP of the entire package was around 35k.
      Listed price is exclusive to SNA members.
      A brand new set of original spikes aka "puppy paws" are included.
      https://www.wilsonaudio.com/products/watch-dog/watch-dog-subwoofer
    • By GroovyGuru
      Item:  Magneplanar MG20.7 Loudspeakers (Pair)
      Price:   $13,500 $11,000
      Reason for selling:  Upgraded
      Payment Method: Pickup - Bank transfer Only
      Purchased from Bill McLean in August 2015.
      The price includes:
      1 pair sand filled Mye Stands. (Value $1000)
      4 Synergistic Research speaker jumpers (Value $400).  Do not use the metal clips which come with the speakers, the sound is crap with those.
      1 pair Synergistic Research Red fuses.  (value $200).
      1 pair Telos fuses. (Value $380?  I can't remember the exact price but it is top of the line Telos fuse and equivalent of SR Black fuse.)
      The fuses are essential to get best performance.
      Many have heard these speakers at my GTGs.  You will not find a better speaker package at anywhere near this price.
      Too much is said about these speakers needing a large room to sound best.  That could be said about many speakers.  These speakers will sound good in medium to large rooms.  Some rooms are better than others.  A good medium room will be better than a bad large room.  It's not about size, it's about set up.
