shaky
'Plinth' build?
Hi all,
I was recently the lucky recipient of a freebie Silcron turntable with a Sound ST14 arm and been thinking, just for sh1ts and giggles, I might try and fire it up and see how it goes. It needs a few things, a belt and a Din- RCA cable, but have sourced a headshell so far. I know it's no world beater in turntable circles but just a bit of fun. In the meantime I'm thinking of building a new 'plinth' for want of a better term, something a bit different to the oversized box it is currently in:
post-117460-0-72580000-1452833269_thumb.
Now the tricky part, I was put in my garage looking at all my junk for some plinth inspiration and spied some 90mm HDPE rod. Now I am thinking of cutting it up in appropriate lengths and using under the black 'T' section. Would this work as a plinth material at all or am I too far removed from reality? I guess , and only using the visual clues, similar to Kuzma Stabi style. Would be fairly easy to knock up, and something different. Or should I just stick with tries and true materials? And design?
Go with something different , if it doesn't work you can go with the tried and true , nothing to lose but time . :)
Have some fun with it mate. Take some measueements befor you pull it apart so if you do decide to build a different plinth you have all the info.
You are crazy!
@@Upfront, good idea. Will hang onto top plate of existing plinth so can put all back together. Will fire it up in that first before doing anything else. That is apart from the other projects I've got going at the moment.
@@awty, this coming from a guy who's building...... Ahhh .... Umm... What exactly is it again?!
Another vote for the "try something different" option Tim  :)
Seems the consensus is to raid the junk pile. I'll post up pics as I go. Gonna test TT first as is to see if it's all (or at least a little) worthwhile.
Does anyone reading know what length the belts were for these little turntables? Or happen to have one lying around they don't need?
Edited by shaky
@@Deano_malaysia just did a net search as the Silcron has no model number written on It anywhere, only the brand and the words 'belt drive', ?seems to be a common theme in Internet world with these TTs) but appears to be that model. Can you help me?
With any luck, the JH belt should be the same size (someone with more knowledge please correct me if I'm wrong) around $50 on eBay. A nice thick slab of hardwood (butchers block) makes an awesome plinth for these TT imo 😄
Sent from my HTC_0P6B using Tapatalk
@@Upfront closest VE has is JH reproducers as a brand. Although only one turntable listed in the database.
@@Brad67 thanks for the info. If all else fails I'll try eBay. But trying not to overspend if I can help it on this assist only a bit of fun. So far it only set me back a grand total of $35
@@Deano_malaysia that's a great and handy site. Cheers mate.
Had a bit of a play just now. Motor works but has a scraping noise. Narrowed that down to motor belt pulley touching the metal plate under it. Tightened motor adjust screw up which lifted Pulley and now runs as quiet as a mouse.
Now all you need is a bit of dental floss to find the length of that belt. Maybe a photo of the pulley too?
Great minds think alike. Already had a shot at that this arvo. Got the platter spinning using said dental floss 'belt'.
So how long is it? Whats the diameter???
The piece of dental floss is around 99cm long so by my calcs belt should be around 315mm circumference. I'm sure I can knock something up suitable without to much trouble. After the run on Saturday I'm a little unsure of the motors quality yet. Seems a bit iffy but may have been that scraping pulley or even rudimentary dental belt. We'll see.
Finished yet?
Seems to be taking a long time.
Slow and steady and easily distracted. That's how I roll.
Well what do you know...... It's alive!!:
post-117460-0-38698300-1454326654_thumb.
A few issues to sort out but good to know it's worth having a play with.
Thanks again to @@DutchNote
And it's only set me back $40 to get the old rattler going.
We must be brothers Tim ... :P  :P
    • By Unsound
      Item: Linn Sondek LP12, black plinth (incl. cross member) - completely flat - part of reconstructed Linn - see other listings for Mose Hercules (near new), top plate (original), Majik, Near new armband  original smoked lid,
      Price: $250, if sold with near new motor (already fitted and adjusted) and Top Plate (re-tensioned), $450; plus PayPal and shipping
      Item Condition: Used, plinth good condition, few nicks and scratches - tried to show in photos.
      Reason for selling: Currently being Upgraded Linn by Peter Swain of Cymbiosis - Chris Harbin Woodsong Plinth, Radikal, Krystal, Kore, Trampolin, etc.
      Please see my other listings for: Linn LP12 Black Plinth, Linn Original Smoked Lid, with Hinges, Ortofon 2m Black cartridge, Linn Majik Sub-Chassis, Linn Top Plate, near new Linn Motor, Mose Hercules LP12 power supply.
      Tiger Paw Khan top Plate and Tranquility Base
      Extra Info: Preference given to buyer for the lot!
    • By Setiawan
      Hi guys, there's a Luxman PD-264 I might be buying. It looks good except for some peeling on the plinth's vinyl veneer (see attachments).
      I was hoping that I would simply be able to re-glue it on, but it looks like even the 'unpeeled' parts don't line up with the edge of the plinth perfectly (the edge that meets the top plate).
      Does anybody have any idea how difficult it would be to re-align and glue down this veneer? Also, I was thinking of maybe having a new plinth made and installed, but I can't find anyone online who has a Luxman with a different plinth. Would anyone here be able to tell me what such a process would involve?
      Thanks!
    • By tandaman
      Hi All,
      I am looking to restore my Thorens TD150, so I'm after:
      1. used original plinth in excellent to mint condition or brand new built to spec
      2.used original dust cover in excellent to mint condition or brand new built to spec
      3. SME 3009 arm board
      Can pick up in NSW, and happy to pay for postage as well.
      Thanks in advance,
      Tan
    • By Petit-fou-fou
      I have got bored with building amps.
      So it is time for a new Vinyl spinner, my old Royce is getting an overhaul. I've had this in my TT stash for years and often thought about giving it a new life. Well the time has come for a stripdown and a motor rumble cure. A new plinth for a 9" and 12" arm should see it good for another decade or two. If it's good enough I'll put an ET2 on it.
      For those of you not familiar with this old Aussie TT here's a couple of pics .
    • By migasson
      Hey!
      Ok, so I've obtained one of these:) (The pic is the model, not the actual table!)
      So, this will turn into a long term project, so I'm no rush to build this up:) Mine will come with the motor unit, and the Denon plinth- and I get to choose my tonearm:) Where will this go? Well, I think I'm gonna grab a Jelco 750D, (or unless a SUPER cheap SME comes up here;)) and just bolt it up. But the reason for the post is I may just be tempted to build a custom plinth.
      I wanna know if anyone here has built a custom plinth for this motor unit specifically, and what materials worked best..
      I'm thinking:-
      Layered birch ply
      Super thick MDF (mulitiple layers)
      Corian
      HDF
      Thoughts?
