Graceman
Replacement LP inner sleeves
So is the photographing of toes some secret SNA code? I've seen enough!  :unsure:
MoFi sleeves are the way to go, IMO. :thumb:
Mind you, that Keith fella is a shifty looking character! :D  (@cheeky boy)
Hey, I resemble that remark!! :D And you're right, they are the way to go and we've sold literally thousands of them and not one complaint from any user.
Nope Andy.  personally I hate mofi sleeves in both form and function. :emot-bang:
plain ole u shaped el cheapo poly sleeves for albums that have a cardboard lyric sheet.
covers33 polylined paper for albums with only paper sleeves - slightly cut off on each corner for easy insertion and removal. :thumb:
example of each below and works a treat for my 5000 odd albums.
Hi Shane, it's a good tip to clip the corners off and although personally I don't have a problem with the MoFi inner sleeves, I have cut the corners off a few like in the pic below and it does stop that bunching up at the corners if they're a bit tight to get into the album jacket. :thumb:
Edit: I kinda like the arrows on the MoFi sleeves, not so much so I know where to put the record in, but I can see where to take it out when I pull it out of the album jacket.
Keith
post-105039-0-35611800-1453858522_thumb.
Edited by cheekyboy
Keith
Hi Keith
You should ask MOFI to that with all their sleeves  :)
Hi Keith
Yeah I could ask them to do that, but I'm sure you know what the answer would be! :D
Keith
Keith
Well they're cretins if they don't take your opinions on board Keith, the square corners are a proper pain and cutting them off leaves open the door for foreign matter to get in, those little bits of cardboard and paper floating about inside an album cover.
I like the feel of the MOFI sleeves and once a record is washed and cleaned they do a good job of keeping them that way but I'll not be cutting the edges off mine and I'll not be buying any more while they remain square. Bad design imo.
FFs - you just fold 1 corner in, before you insert the MoFi sleeve ... or sometimes both.  What's the problem?  :P :P
Damn, 5000 albums. No wonder you you stick with the shopping bag sleeves  :P
The overpriced shopping bag sleeves are the mofi sleeves.  They can't seem to do the simple job of fitting an LP snugly. :D
We even have members recommending to cut corners off or fold corners to enable easier insertion. LOL  :emot-bang:     and people seem to like paying extra for these :hiccup
Anyway, I have had my fun. :P
Yeah, you have.....
I'm only a mere mortal like the OP, and only have a few hundred to worry about.
Yeah Lee, each to his own I guess, but I really don't have any problem with the square bottoms, but I don't think MoFi would listen even if I did bother to suggest they round the bottom of their sleeves. I don't have any of those bits of cardboard and paper floating around inside my album jackets, but I suppose it's not beyond the realms of possibility though. The sleeves with the corners removed, still make a very good seal to dust etc, but before we started selling the MoFi sleeves years ago, I bought hundreds of good quality round bottom poly sleeves made in Japan and I'm largely still working through those when I need a replacement sleeve.
Keith
Edited by cheekyboy
There are some Poly-lined ones at Rocking Horse in QLD. http://rockinghorse.net/index.php?route=product/product&product_id=12766
I have visited this store twice to try and get these. They don't have them anymore. I just bought some standard round bottomed poly sleeves instead. The vinyl section in that store is a shambles too. New records and second hand all mixed in together. If there is any logic to the way they've organised it I can't figure it out.
That site doesn't seem to like the Nagaoka 102 sleeves.
I think they are great.
Thin, rounded, fit in cardboard sleeves, antistatic, relatively cheap.
I find them too thin and flimsy. They make me look clumsy.
Guest soundandpictures
agreed jake.
the nagaokas are more expensive than mo-fi ?
i keep a few nagas for those tight and/or undersized sleeves that won't take a mo-fi.
Sorry, I hate the square bottomed ones! I find them annoying and impractical. Have just ordered some 'polyethylene' round bottoms for $11 for 25. Cheapest I've seen Nagoka 102's for is around $38 for 50. Not too bad, and might try them when I'm a bit more financial. ATM, the cheapest non-Nagoka 'anti-static' inner sleeves I've seen is 100 for $38 on ebay. Although I'm not so sure the 'anti static' feature is entirely essential, everyone has a carbon fibre brush these days, and they seem to do a proficient job of removing static prior to play. My two cents worth! :)
Edited by stevoz
Nags can be had for NZD25 for 50 over here.
Instead of throwing away the paper sleeves so prevalent today, I'm now putting the nags inside them. The paper adds support.
Where did you get them from?
The polyethylene ones I ordered were from an Ebay seller in Queensland called 'recordshed'. They also sell 50 for $21, or 100 for $40.90. The non Nagoka 'anti-static' ones I mentioned are from a Victorian seller called 'gugu 1983888' and are actually $32.98 for 100. Sounds pretty cheap! :)
Thanks I just ordered 50 from the recordshed to try.
Guest Muon
When was the last time you were in there?
I ask because Rick from EGG now shares that space (I often bought sleeves off Rick when he was at west end, and when he was in the queen street mall before that), could be a very different situation to what it was if the last visit was some time ago.
Might be worth another visit, It's all downstairs but pretty much where it was before, in that side bit of the mall.
 i used to do that too !
where can you get 50 nagas for $25 ?
they real branded nagas or generics ?
www.southbound.co.nz/shop/shop/anti-static-plastic-sleeves-50/
I used to buy the Nagaoka sleeves many years ago.
IMO, The el cheapo U sleeves are better and actually hold their shape so I no longer buy the Nagaoka sleeves.
Edited by metal beat
agreed jake.
I think I'll go back to just using the "thin and flimsy" Nags without the paper sleeve.
The paper/cardboard just adds thickness. The Nags make it easy to slip the lp into the outer sleeve. They may be thin but I don't see how they are flimsy. They easily slip into the LP without creasing or bending, and I've not had any of them damaged.
Guys, how do you find them "flimsy"?
    • By ThroneofGame
      Item: Original Vintage Knosti Disco-Antistat Record Washing Device
      Price: $70
      Item Condition:  Like new - hardly used - except for the box - it was made about 20 years ago!
      Reason for selling:  I have a VPI record cleaning machine
      Extra Info:  This is the German-made - pre-unification (says Made in W. Germany) - original version of probably the most economical record cleaning device on the market!
      Cleans 7", 10" and 12" Records  All fluids etc are supplied in the box. Manual Record Cleaner. This is a very cost effective wet cleaning system for LP’s. Supplied with Full instructions and 1.0 Litres of Cleaning Fluid Easy To Use Excellent Value Extra Cleaning Fluid Easily obtainable
      Submerges a record in a bath of cleaning fluid.
      The principle is simple, two discs with a 100mm diameter, clamp each side of the record's label, thus protecting it during cleaning, this then rests in a groove at the top of the rectangular cleaning bath, the bath is topped up with supplied cleaning fluid, the record is then rotated around its central axis. As the record passes through the bath, two sets of brushes clean each side of the album. Once you’re happy with the results simply remove the record and centre clamps, and place your clean album on the rack to dry. Because the cleaning solution contains wetting agent, records dry without smears. When cleaning is complete, pour your used cleaning fluid from the bath through a filtering funnel back into you cleaning fluid bottle for re-use.
      Read Marc Rushton's reveiw here:  https://www.stereo.net.au/reviews/review-knosti-disco-antistat-record-cleaner
    • By mrf0ster
      tem: Pro-Ject Spin-Clean Record Washer System
      Price: Price Reduction, 50 bucks. Any one?
      Item Condition: Excellent
      Reason for selling: NLR
      Payment Method: Pickup - Cash, COD Only
      I have used this on all my old and new records and I am quite happy with its result. I have always used distilled water for cleaning and the brushes are in as new soft and unworn condition. There is not much cleaning liquid left (Around 10% or less) and the two provided drying cloths are no longer available. These items can be bought separately on line. I would not worry too much about the drying cloths as any soft cotton or soft microfiber cloth would do the job.
      The full kit, which includes a full bottle of washer and two drying cloths, is available on line for $135.  Pick up only at this stage but if you want it delivered, I would estimate the postage cost to be around $20 to $40 due to its size?
    • By mrf0ster
      Item: Pro-Ject Spin-Clean Record Washer System
      Price: 80.00
    • By EV Cali
      Have been considering purchasing a Record cleaning machine for some time but found the cost of commercial machines quite prohibitive.
      With the dawn of 3D printers, wands for vacuum machines have become cheaper but after much searching of the web, consensus appears to be that the best result is from Ultrasonic baths.
      Ultrasonic baths can now be had for a reasonable price and again consensus appears to be that the 40kh units are ok, with the commercial cleaners using this frequency.
      That led me to look at ways to suspend the records over the bath and turn them.
      The “Vinyl Stack” http://www.ebay.com.au/itm/161402849405?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT is a really neat solution but the machine plus post is around $500, so my next thought was could I make something as good, cheaper.
      My solution was arrived at after looking at what others had done and some trial and error.
      The platform for my machine is made out of an IKEA cutting board and I used three more to complete all the other parts.
      The motor for turning the records is a BBQ Rotisserie motor.
      http://www.ebay.com.au/itm/171563301027?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      The rod for suspending the records is an old tent pole and the brass ferule that holds them in position, originally held the spindle for a Turntable, I just drilled it right through so I could slip it on the rod.
      The discs were cut with a hole saw and the foam is 6mm, self-adhesive, closed cell from Clark Rubber. All the parts are screwed together.
      The Bath came through ebay.
      http://www.ebay.com.au/itm/322171248214?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      I have now cleaned around a dozen LP’s and I am quite happy with the results.
      All up the cost has been around $250
      Motor $28
      Bath   $185
      Foam Rubber $15.50
      Ikea cutting boards $12
      I would probably do some things differently, if I made a second one, find a slightly thicker board for one and I am sure there will be some fine tuning over the next few weeks, plus some experimentation with cleaning solution, time and temperature  but I think it establishes that anyone with a few tools and a bit of time can make a RCM for a reasonable cost.
    • Guest
      By Guest
      I'm floating an idea here for like minding vinyl lovers. Not sure if its workable or not but here goes …….
      I had a set of records cleaned by the Audio Desk Systeme Vinyl Cleaner and the results were amazing. Better than any of my various routines before including vacuum machines.
      http://www.stereophile.com/content/audio-desk-systeme-vinyl-cleaner
      Now one of these machines would set you back 4K. I personally don’t have that kind of money. But, I am just wondering, would there be people out there that would possibly consider going 1/2 1/3 or 1/4? Again not sure how to work out the details of how this would work, but hey I'm putting the idea out there.
      Maybe someone else had done a share arrangement on other equipment and could share there experiences? Any thoughts, pitfalls advice appreciated!
      Cheers, Mark
