3G_ Posted February 2, 2012 Share Posted February 2, 2012 I am building them using Azura horns after weighing up every other option. The rings of mdf are for the drivers to be ousted in, similar to the above design, but different way of getting a solid Tube on the end of the Azura horn. I am looking for a new house currently and will look further into sub 100hz when the horns are in their final location. Thinking IB, Tapped horn or maybe a LeCleach horn stand. Link to comment Share on other sites More sharing options...
ENIGMA Posted May 7, 2012 Author Share Posted May 7, 2012 Hi All, Bit of progress on the horns, they are now all red! I just need to paint the cylinders in a black textured finish and build the frame that holds them togerther. Here are current pictures... 1 Link to comment Share on other sites More sharing options...
PixelPlay Posted May 7, 2012 Share Posted May 7, 2012 Awesome! Link to comment Share on other sites More sharing options...
jaspert Posted May 7, 2012 Share Posted May 7, 2012 Nice paint job, Del. Link to comment Share on other sites More sharing options...
Drizt Posted May 7, 2012 Share Posted May 7, 2012 Hi All, Bit of progress on the horns, they are now all red! I just need to paint the cylinders in a black textured finish and build the frame that holds them togerther. Here are current pictures... Looking good. How long till you are finished? Link to comment Share on other sites More sharing options...
ENIGMA Posted May 7, 2012 Author Share Posted May 7, 2012 Hi guys, thanks. I might have them assemled this weekend, the weather is crap for any hope of painting the black or the stand but i need to put them in th frame as now it is awkward to move them around without scratching them. And then the're is the K horns to build. I think the ceiling of Sistine Chapel was painted in less time than these. Link to comment Share on other sites More sharing options...
Upfront Posted May 19, 2012 Share Posted May 19, 2012 How are the looking E? Any progress? Link to comment Share on other sites More sharing options...
ENIGMA Posted May 19, 2012 Author Share Posted May 19, 2012 How are the looking E? Any progress? Getting there, i built the stands today and about 3/4 of the way. Bit of prep & paint tomorrow - all goes well when dry i'll assemble them and take photos. Link to comment Share on other sites More sharing options...
PixelPlay Posted May 19, 2012 Share Posted May 19, 2012 So looking forward to the results...... Link to comment Share on other sites More sharing options...
Upfront Posted May 20, 2012 Share Posted May 20, 2012 Looking forward to seeing the stand as mine is a similar design. It will be interesting to see someone else's mounting of them. 1 Link to comment Share on other sites More sharing options...
ENIGMA Posted May 21, 2012 Author Share Posted May 21, 2012 Looking forward to seeing the stand as mine is a similar design. It will be interesting to see someone else's mounting of them. No photos yet - paint was too wet to assemble. The stand is looking reasonably good, i also have the mid horns fully painted - red horn with black tube. They look fantastic .The midbass horns are about to have their tubes painted black . I have to paint one of the midbass horns in red again, i wasn't too happy with the first result , blocked it back painted it again - this time it was really good, took it outside to air dry and a gust of wind blew big specs of dust over it . I tried to fix it and completley stuffed it :mad: :mad: :mad: f%@#*&@! . So back to blocking it back and painting it red again. Link to comment Share on other sites More sharing options...
Upfront Posted May 21, 2012 Share Posted May 21, 2012 Poor bastard. I know the feeling with that. Painting is one of my pet hates. One of these days I'll buy another house with a garage so I do it properly. Link to comment Share on other sites More sharing options...
ENIGMA Posted May 21, 2012 Author Share Posted May 21, 2012 I love painting when you get a good result. These horns, being so big, they take a bit of focus to get right and then you have to hope there are no runs of patchy areas. you need an open area, the amount of overspray floating around and settleing needs to be in a confined space and the fumes - my goodness i'm so glad i use a respirator. And then you are at the mercy of something happening like the wind. I could not believe it, the wind was calm before hand and it was like it did it on purpose. This is my horns, don't forget i have two more for someone else waiting in the corner for a coat of paint! Link to comment Share on other sites More sharing options...
ENIGMA Posted May 27, 2012 Author Share Posted May 27, 2012 Busy weekend; I have an Uno Trio that is a bit of a Duo without its tweeter (if that makes sense). I have to work a bit more on setting up the mid horn and making it more solidly secure. Once this is done i start assembling the other one after i repaint its midbass horn. Cheers. 2 Link to comment Share on other sites More sharing options...
MichaelWC Posted May 27, 2012 Share Posted May 27, 2012 Great work Enigma, It looks very nice. Just one question, how did you get the back part of the horn so smooth ?. Cheers, Michael. Link to comment Share on other sites More sharing options...
3G_ Posted May 27, 2012 Share Posted May 27, 2012 Looking amazing. What volume is the rear chamber for the Fane, around 6 liters? Great job and I look forward to seeing what you do upto 100 hz Link to comment Share on other sites More sharing options...
Mick35 Posted May 27, 2012 Share Posted May 27, 2012 Been keeping an eye on this thread, and DROOLING!! Coming along very nicely Del It's gunna sound MAGIC!! Link to comment Share on other sites More sharing options...
ENIGMA Posted May 27, 2012 Author Share Posted May 27, 2012 (edited) Great work Enigma, It looks very nice. Just one question, how did you get the back part of the horn so smooth ?. Cheers, Michael. Thanks, the answer is allot of sanding/filling/sanding/filling/sanding/hifill/sanding/hifill/sanding............. My pair (big horns) are litle bit more rippley around the back edges than the other pair i have also built. Those came out heaps flatter around the edje because i spent more time on them and they were for my mate which meant that i had to do a better job! When i did mine, i did them in half the time and i wasn't too fussy about it having some 'ripples' arone the rear edge. the main surface on the back is fine and the join between horn and cylinder came out really nice. The face of the horn was already perfect, the hard part was painting them. Edited May 27, 2012 by ENIGMA Link to comment Share on other sites More sharing options...
jaspert Posted May 28, 2012 Share Posted May 28, 2012 Nice job Del. Hats off to you. Link to comment Share on other sites More sharing options...
pulinap Posted May 28, 2012 Share Posted May 28, 2012 Love the colours!!!! Link to comment Share on other sites More sharing options...
tuyen Posted May 28, 2012 Share Posted May 28, 2012 Looking mighty fine. Good stuff! Thanks for sharing Link to comment Share on other sites More sharing options...
Paul Spencer Posted May 28, 2012 Share Posted May 28, 2012 Looks fantastic! Nice choice of colour too. Link to comment Share on other sites More sharing options...
Upfront Posted May 28, 2012 Share Posted May 28, 2012 Nicely done mate! Nice use of the LCD bracket Link to comment Share on other sites More sharing options...
Ando Posted June 1, 2012 Share Posted June 1, 2012 Looks great. Like everyone else I love the colour. Cheers Mike Link to comment Share on other sites More sharing options...
Dr Good Vibe Posted June 2, 2012 Share Posted June 2, 2012 Ok E well done nice colour mate are you making the TT the same colour ? you will need some wire and stuff to make the sing Link to comment Share on other sites More sharing options...
