oinksta
Alternatives to class A?
I am looking to replace some class A amps, not because I don’t like them but for practical considerations. But, having been spoilt by them, am struggling with where to go next.
The issue – we have one living space that is used for listening to music, watching TV/movies but also provides background/ambient music during the evening. It is the later that causes the issue.
Being class A (well first 50 watts) they produce a bit of heat, and while they don’t get overly warm to the touch they do heat up the room over time. As summer approaches again (in Perth) we have found that we are turning the stereo off, and only using it for more critical listening, and this somewhat defeats the purpose – particularly as off means no music!
So I am seeking some thoughts on alternatives, I am looking (hoping) for that liquidness in the highs one gets with class A, but without so much heat. Have tried a class A/B amp but it is not quite as good – although I would probably be happy with it I had not owned the others :unsure:.
Are there class A/B amps that people would recommend in this regard and what about class D - or is that a step to far?
I brought an amp off a local guy who is a bit of a wiz and it is a fantastic sweet sounding amp.
Does not draw much power at normal listening levels but I think it is 190w/ch into 8 ohms.
I will chase up the details later if you like.
He builds many types of amps and does repairs and upgrades.
Edited by rocky500
Do you have a budget? Are you able to do or know someone who can diy? I use Hypex nc400 mono blocks and am very happy with them but you could also use the cheaper yet almost as good Hypex UCD amps. A dac that has pre amp ability connected directly into these makes a very listenable simple system if you don't want to use a pre amp.
There are other brands of class d ready made but you would have to look online for these. Red Dragon is one that comes to mind.
Personally I'd suggest not having preconceptions about amp topology.  It's all in the execution at the end of the day.  Go out and have a listen, or better yet try and arrange some home demos.
Arcam class G amps definitely worth having a look at in your situation.
I have the same problem, im actually thinking of moving on my Luxman as a result.
I have a Bel Canto running next to it at them moment. If you was you, i would definitely check one of those out. I think they are fantastic.
You could always look at going with more efficient speakers and moving to a lower (heat/power) output class A amp.
I gave up and just live with the tube heat.
Then again I'm only in Sydney.
IMHO there is no substitute for class A, and once you've been used to it you will miss it.
A good compromise would be to seek out an amp that offers high and low biasing,  That way you can use low biasing during hot weather and high biasing the rest of the time,
Edited by bronal
I have a Vincent 994 50w class A 300w a/b switchable via one button,if I'm not running a/c I leave it on a/b. Valve pre stays on but doesn't seem to get that hot.
Another well regarded amp is the Gato which @ was selling. Perhaps still available. http://www.stereo.net.au/forums/index.php/topic/92316-fs-gato-dia-400/#entry1485863
Thanks mate but its gone to its new home. Great amplifier.
Yes, I think Davidro & Bronal are correct  - if you like Class A, then stay with it, and install/pay for the air con. I find all designs have their pro's and cons.
My domestic constrains mandate smaller amps that run cool. I am running AHB2's at the moment - the so called "Class G". They are a very detailed and a super clean amplifier. Not overly clinical like Devialet but certainly not like tubes at all. No meat on the bones, that tubes give you.
BTW Devialet is out - you can fry and egg on them once they have been running for 5 minutes. I couldn't live with the heat they made. The PassLabs Int 60.5 I demo'ed ran alot cooler than the Devialet, but like all PassLabs, was a monster.
What about a pair of X30.5/8's ? they don't run especially hot for class A. Luxman also run very cool for class A, but, and it is a but, they are VERY thick sounding.
Edited by andrew_stenhouse
Hi Oinksta,
Why compromise your lovely Class A SQ? :unsure:  :(
Just turn up the A/C. :)  :thumb:
Just tried turning my Amp off and it looks like it uses 12 to 13W idle.
Goes up to 25 watts at a ambient listening level.
This amp runs very cool and sounds wonderful. Seems to sway more towards a Class A type of sound. Very sweet.
Local guy puts them together LINK
post-107190-0-26426800-1449133229_thumb.
Hi @@oinksta,
I had the same problem as you as I have no air conditioning. I can recommend Modwright KWA 100SE amps. I bought one of these based on reviews and use it in the summer months instead of my 805 valve amps which produce heaps of heat.
The Modwright is a great amp, I can easily swap it with my valve amps as the sound quality is very similar. The Modwright runs very cool and has been a pleasant surprise, I think Modwright is underrated.
Guest BobbyD
I have lots of hot glowing glass........ I'm with Andrew.... Crank the air cond up.....sounds like you love your amp :-)
Get some JC1's, you can switch between high and low level bias-
Bias Level Switch
The Bias Level switch offer s two bias setting for the output transistor s. In its Low (left) position, extremely
generous bias idle current and class A operation mak e crossover and higher-order odd harmonic
distortion inaudible. In its High (right) switch position, bias idle current is increased to perfectly match
the characteristics of the JC 1s output devices. This all but banishes these distortions. With its Bias Level
switch set to High, the JC 1 will run quite warm and consume more AC power when it is idling or playing
at low listening levels. If your JC 1 is VERY well ventilated, you may find the high bias offer s a sonic
improvement. If your JC 1 is mounted in a cabinet, or ventilation is restricted in any way, we recommend
you leave the Bias Level Switch in its Low position.
And I was worried I wouldn’t get much of a response!
Quite a bit to check out there.
Budget is probably around the 5K mark.
Current amps are a couple of Emotiva XPR-2, speakers are Pioneer S-1EX. The speakers are definitely staying.
Thanks for all the help, from what has been said so far, will probably check out Arcam (Perth dealer?), “the local guy†and may look at Hypex.
Wrt Hypex how similar in sound are the UcD vs nc400, may give the UcD’s a go and if I don’t love them they would be sufficient for driving surround speakers.
Again, thanks for all the help.
At around your budget, Bakoon may be worth a look.
I concur......arguably very underrated product......
I briefly compared the UCD that OffTrackSound bought over and if anything the ncores are perhaps a bit smoother with slightly more resolution and better bass? Since then they have updated the UCD's and from what I have read online they are improved.
speakers
:thumb:    ... are more than critical to consider when thinking about an amplifier.
To do otherwise would be like asking what type of engine should I put in my vehicle?   (motorbike?  aeroplane?  lawnmower?  tank?)
Sorry but those Emotiva amps aren't class A design and there is absolutely no way they are running 50 watts per channel class A. Don't care what the marketing mumbo jumbo says from Emotiva either.  To run 50 watts per channel true class A you'd need enormous heat sinks and completely different chassis design.  Check out below design for a 50 watt per channel class A amp from Shanling (and even this is not a true class a design)
379941-shanling_slm_a40_mk_ii__class_a__
That's a class A/B amp by any definition, and sounds like you are happy with the sound.  Just keep them!
    • By muzzworld
      Item: Yamamoto HA-02
      Price: $690
      Item Condition: Excellent
      Reason for selling: Not used
      Extra Info: For sale is my gorgeous headphone amplifier hand crafted in Japan. It just doesn't get the use it deserves.
      It is in wonderful condition, and has heaps of glowing praise bestowed upon it by the doyens of the internet. Look it up!
      Happy to demo or answer any questions. Its probably easiest to sell it locally with pickup but could quite easily be well packed for shipping.
      Happy listening.
      Photos: Advertisements without photos of the actual item will not be approved.
    • By thejt
      Item: Shanling MC-30 Music Centre (Valves)
      Price: $625 or $650 with Logitech Harmony 650 universal remote
      Reason for selling: Too much gear
      Payment Method: Pickup - Cash, Shipped - Direct Deposit
      I am the second owner of this locally delivered 240V unit and I am sure I will regret selling this later. Ask anyone who has ever come across one of these and they will back me up with how they were blown away by this little unit. The build quality is excellent, thick aluminium body and heavy transformers. The design is well thought out with the feet all featuring levelling. The sound it makes is lush and although it seems like it would not create a generous amount of sound at 3W (Class A) I can fill a lounge room with gorgeous sound without even going half way on the dial. This is without even using easy to drive speakers, I had used Quad 11L and Dynaudio Contour 1.32E which are both only about 86dB. It has a pre-out should you want more power, but I tried using a Quad 909 and preferred it direct. The unit actually provided more bass on its own. Feature wise, CD player, FM and AM radio, 3.5mm input and RCA input which should cover everything you could want.
      The original owner lost the remote but the unit can be operated from the controls on the device itself. Volume adjustment is a bit of a chore like that though so I picked up a Logitech universal unit which I can include for an extra $25 (cost $70). A common issue with many Shanling CD players is the occasion pause during cd playback but this is occurs only very occasionally and lasts about 1 - 2 seconds before resuming. The MC-30 has been otherwise faultless. I have the original double box so can ship at buyers risk if desired but note it is fairly heavy. Great chance to get into valves or Class A amplification without too much outlay. Questions welcome and I will try to answer best I can. Donation on sale to SNA. Please look at all the glowey bits in the pictures!
      Praise:
      https://www.stereophile.com/integratedamps/308shan/index.html
      http://www.charismaaudio.com/products/shanling/mc30.htm
    • By Mitchell Albert Reyes
      Item: Marantz PM7200
      Price: 450
      Item Condition: Great
      Reason for selling: Moving O/S
       Excellent condition.
      Beautiful amp with a beautiful tone.
      Moving OS and needs a new home.
      DESCRIPTION:
      95 watts per channel power output (into 8 ohms)
      155 watts per channel (into 4 ohms)
      25 watts pure class A operation
      HDAM (High Definition Amplifier Module) fully discrete copper-shielded output stage
      Premium-quality parts and construction for superb sound quality
      Seven source inputs including moving magnet (MM) phono input
      Full marantz description and manual available here:
      https://www.marantz.co.uk/uk/products/pages/productdetails.aspx?catid=hifi&subcatid=amplifier&productid=pm7200
      Reviews can be found here
      https://www.hifiengine.com/manual_library/marantz/pm7200.shtml, and
      http://www.audioreview.com/product/amplification/integrated-amplifiers/marantz/pm7200.html
    • By Rhien23
      Item: Vincent SA-T1 Stereo Pre-Amplifier and Vincent SP-331 Hybrid Power Amplifier
      Price: $1340 local sale or $1400 posted anywhere in Australia
      Item Condition: Great!
      Reason for selling: Decided on another Amp
      Payment Method: Pickup - Cash, Paypal, COD, Posted Aus wide
      All in boxes and ready to ship if needed!
      Vincent SP-331 Hybrid Power Amplifier Input signal incorporates two 6N16 valves each. There are 12 TOSHIBA transistors provided for the power in each case. The SP-331 can also be operated at 2 Ohm without difficulties. This is a hybrid tube and solid state power amplifier.
      Nominal Output Power RMS/8 Ohm: 2 x 150 Watt
      Nominal Output Power RMS/4 Ohm: 2 x 300 Watt
      T.H.D.: < 0.1 % (1 kHz, 1 Watt)
      Input Sensitivity: 1,2 V
      Signal-Noise Ratio: > 90 dB
      Input Impedance: 47 kOhm
      Inputs: 1 x Stereo RCA
      Outputs: 4 x 2 Speaker Terminal
      Tubes: 2 x 6N16B
      Colour: Black
      Weight: 19 kg
      Dimensions ( W x H x D): 430 x 160 x 450 mm
      Vincent Audio SA-T1 Stereo Pre-Amplifier
      Frequency response: 20 Hz - 50 kHz +/- 0.5 dB, Output voltage: 2 V, Total harmonic distortion: < 0.1 % (1 kHz, 1 Watt), Input sensitivity: 280 mV, Signal-Noise ratio: > 90 dB, Input impedance: 47 kOhm, Inputs: 6 x Stereo RCA, Outputs: 2 x Stereo RCA, 1 x Stereo RCA Rec Out, Tubes: 1 x 612AX7B, 1 x 12AU7, 2 x 6N4 Colour: black/silver, Weight: 8 kg, Dimensions (WxHxD): 430 x 95 x 390 mm
    • By ArneS
      Item: YANAHA A-S2100 integrated
      Price: $2100
      Item Condition: Virtually new
      Reason for selling: moving to the valve side
      Payment Method:  Cash, Paypal
      Extra Info: comes with original box
       This is a stunning amp. Full of detail and grace. Wide soundstage. Main Direct allows home-theatre by pass.
      Expressive power that conveys even the subtlest nuances which the artist pours into the music. A realistic sensation that you are directly in front of the performer. According to Yamaha, these are the goals and overriding philosophy behind the sound and sophisticated technologies built into this system. And I would say they have achieved this.
      Has a high quality on board phono pre-amp. Really highly regarded headphone amp.
             Floating and Balanced Power Amplifier with MOSFETs
             All-stage fully discrete construction, balanced transmission and low impedance design
             Superior quality electronic volume control for optimum sound
             Large capacity power supply unit delivers energetic, dynamic sound with fast response
             Symmetrical design in pursuit of ideal stereo reproduction
             Discretely configured phono amp
             Headphone amp with fully discrete configuration
             Level meters visually reflect the dynamics in the music
             Original speaker terminals combine ease of use and beauty with high sound quality
             An airy, open sound in which the most minute sounds reach the listener.
