mrpato
Opinions on Rotel 1095
Hi guys
Would anyone have any feedback on the Rotel 1095? I found one selling at $1200 in mint condition.
However I've already got the 1075 and occasionally I need to turn the volume to -18 to get to the level I wanted.
Tell me your experiences and thought on this beast. Please :)
big balsy amp...this thing is a tank ! both good amps....$1200 would be a down right bargain...am not sure anything else would compete at that sort of money !
How's Emotiva XPA 5 or Elektra Theatron 7 compare to Rotel 1095?
Edited by mrpato
How's Emotive XPA 5 or Elektra Theatron 7 compare to Rotel 1095?
the elektra theatre 7 was the no 1 replacement amp for many whom had the 1095/1080 as combination for 7.1 systems. my intro to elektra was actually going in to demo the rotel and not being totally satisfied and then hearing elektra... though I dont think you'll find elektra at that sort of pricing. a mint 1095 rotel is a down right bargain and should be grabbed at that price.
emotiva...sorry in quality build fit finish and components doesnt even come close ....
Hi Mrpato.
                        I`ve had a 1095 for about 11yrs now, used to use it for double duty HT, 2ch. now it`s only as HT.
                        It`s never had a problem, sounds great, has a bucket load of power, for 1200 grab it, just don`t drop it on your foot.
                        to only reason I don`t use mine anymore for 2ch is I have converted to class A.
        Enjoy.                     Ian.
    • By SoundGuy
      Price: $12,000 $10,500 $9300
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By MattyW
      Ok, now that I've had my Wavebourn Edelweiss-3 for a few months and it's nicely burned in it's time for me to prepare writing my review of it which I'll post here over the coming month. I'll post my impressions and experience purchasing this wonderful amp from Anatoliy Lisovskiy, who will be releasing the production series of the Edelweiss-3 power amp, an integrated amp and separate preamp over the course of this year.
      As I understand it the current production version of the power amp and integrated will all be EL34 though allow and pin compatible tube to be used right through to KT120, possibly even KT150. My own amp on the other hand uses WW2 vintage CV1127 radar sweep tubes.
      The reason I initially started looking into a lower powered amp was that 6 months ago I built my first pair of DIY speakers. A pair of shallow cabinet open back speakers which share the performance characteristics of U frame open baffles. Unfortunately the copy darTZeel NHB-108B power amp I was running at the time was far too powerful making my 101db sensitive speakers too loud for regular use so I started investigating lower powered tube amps.
      While looking into various solutions someone on AudioKarma pointed me in the direction of Anatoliy's Wavebourn amps and I got in touch via the Wavebourn facebook group. Over the next month or so I had an interesting discussion with Anatoliy about his amps, and their suitabillity to drive my DIY speakers (Lii Audio FAST-10 full range, Aurum Cantus G3Si ribbon, Skar Audio VX1ST bullet & Lii Audio W-15 woofer) and this led to discussions of his amps variable damping factors allowing suitabillity with a wide range of speakers. A feature which I believe may well be unique to the Wavebourn amps.
      Overall details of the amp are as follows:
      Input: 0 dB (0.775V) RCA, 50K stereo.
      Outputs: low ohm for 4-6 Ohm and high ohm, for 8-12 Ohm load.
      Power: at least 6W for <1% total harmonic distortions.
      Soft asymmetric saturation (inaudible clipping), negative output resistance for damping of woofers (servo-control of speakers).
      Bandwidth: 10 Hz-90 KHz -3 dB, from 20 Hz full power.
      Tubes:
      Raytheon VT127 (CV1127) radar sweep power tubes.
      8CB11 driver/preamp tube (twin video pentode – filament powered from rectified DC for zero audible hum.
      VR150 / Russian SG4S voltage regulator (purple glow).
      VR tube and solid state MOSFET voltage regulation.  The “Edelweiss” series derives it’s name from this. A beautiful flower which grows amongst hard mountain rocks.
      Selectable speaker damping
      In order to support different speaker design types such as open baffles, horns, closed and ported boxes, there’s a damping factor switch that controls output resistance of the amplifier.
       Position 1 is the first on the left.
      1.       High output resistance (like pentode output with no feedback), sometimes referred to as "Current driving mode".
      2.       Similar to SET with no feedback.
      3.       SET with some feedback.
      4.       Negative output resistance for active servo-damping of woofers.
      With a little experimentation I soon found that I prefer the negative output resistance setting, which is actually Anatoliy's own preference. Probably the least tube like sounding setting giving tight, accurate bass where other modes seem a bit looser. This is what I've continued to use since the first week I received the amp.
    • By vik74au
      Item: Emotiva XPA-5 Gen 1 Power Amplifier
      Price: $1,000
      Item Condition: Excellent, perfect working condition
      Reason for selling: Upgraded
      5 x 200w RMS @ 8 Ohms (all channels driven), see below photo for more specs
      Excellent working condition
      Sole owner since new
      Been nowhere near pets nor anybody smoking throughout its life.
      Although I still have the original box, it is for pick up only as this amp is very heavy.
    • By mlw
      Item: Concert Fidelity ZL200 monoblocks (price reduced)
      Price: $8500
      Item Condition: Excellent 8/10 on Audiogon scale
      Reason for selling: Reconfiguration of system (for balanced operation)
      Extra Info: purchased second hand around 5 years ago. Rarely used and always used with PS Audio conditioner. New price for these were $48,000 US ($70,000 AUD!) - very expensive (and heavy) mono blocks. You will not find any power amps of this quality near this price. This amp received the Absolute Sound 2012 Editor's Choice Award.
      The unique sound of the ZL-200 is aptly described by Mr. Harry Pearson: "These monoblocks are the first solid-state amps I've heard that sound like a tubed unit, and by that I mean a very good tubed unit, on the order of say, the best conrad-johnson amp (vide, the ART III) but lacking the golden glow of the CJ sound, thus rather more uncolored than most, if not all, of the transistorized competition. It has the dynamics of good tubed unit, the focus on instruments and the sense of an ambient field that is characteristic of the old William Z. Johnson design for Audio Research.
