Eisener Bart
Tuning Room of Eisener Bart
Well, let me start from 2 general view photos.
Rack (assembled from IKEA tables, thread is here):
698817ff8cf306c65cc0884ba49ee9462eafa322
Speakers and power amp:
1cf941b8b96cfef254393e33867b7e682eafa322
Guest Misterioso
Nice T+A amp. Unfortunately, the brand is pretty much absent from Australia. I always liked their R series.
Edited by Misterioso
Valve Phono Pre-Amp - Abbas Esoteric Audio (Ukraine), entry level model - I called it "Treble Clef".
3811adaa2da0f0bf051820a57dea4e212eafa322
9afc44d60c3056bb21fe8e32704c3f5f2eafa322
b778130e5983249db3c66cf7fff978c92eafa322
Yeah, I've been impressed when I removed from System original preamp of T+A (model P 1200 R) and used AMR DP-777 as preamp.
Sound of System became much more transparent.
I also tweaked this power amp by AMR fuses, result was great.
Self-made gallows for Headphones with my Cans' Zoopark.
From lef to right:
Shure SRH-840 - cans of entry level, by the way, it sounds very interesting on almost all kinds of .... heavy music (all kinds of metal and heavy).
Audeze LCD-X - pre-top cans of Audeze, I am recabling it now - separate thread in Headphones section will be done. Original cable is real **** which doesn't permit to show even 50% of abilities of this cans. LCD-X is also one of the best cans for heavy music.
Sennheiser Momentum (1st version) - I use it at sea and as portative cans on long distance during travels.
HiFiMan HE1000 - flagman cans of Hong Kong brand, you may find my small review here
Sennheiser PX-100 - only for portative in City, also I use for looking of american TV serials.
2607e9f642784ad034b6e53fed8582372eafa322
Headphone Amp.
Well, it is very interesting device actually.
Form-factor: smaller than midi (90mm(H) Ñ… 228mm(W) Ñ… 380mm(D), weight is 4 kgs about.
Output power: 5 Watt on channel in Class A (!) on nominal 16 Ohm.
2 capacitors of british AeroVox are located in PCB, each one - 10 000 mkF.
Amp was made in 1 copy, so I have full exclusive.
Name of Amp: hybrid Hi-Power/Hi-Dynamic.
Manufacturer: Peeves (Ukraine, Lugansk City).
Head Amp of such level costs about 3 5000 USD (just apply any famous brand logo on face panel).
de339bc0b3be34d7a265ac74993947e02eafa322
Edited by Eisener Bart
Inside:
Transformator r-core 30W
Schottky diodes
Capacitors ClarityCap ESA, RIFA Evox
Capacitors electrolityc AeroVox, Sanyo OS-CON, SIC-SAFCO
Resistors TAKMAN carbon films
Var resistor (РГ) TKD
Transistors Toshiba, Hitachi
Solder Cardas
Signal cabling AudioQuest
Connectors RCA Yarboo
Connector 1/4" stereo jack silver Shadow (Germany)
69fe84a50df17dd44bff18ddc31bd1d45fd72414
44fcc2dfbab49793846163b005608a4c5fd72414
020b17a062ffbec70c473b341b9007b75fd72414
Good to see another owner of an Abbas Audio part. I regularly buy his diy stuff for cd transports. Inexpensive and big sound (probably because he mostly uses Military NOS parts from Ukraine and Russia).
Digital Processor AMR DP-777 (it's not just DAC) - I use it as Pre-Amp as well. It has valve output stage, more tranpsarent than T+A preamp which I used before. It's first version, AMR released "SE" a months ago.
1074efcd3bbd5a53c2f12f241583ccf52eafa322
I guess it's mostly Soviet valves.  :)
AudioLot ALF-2500R - power conditioner from Ukrainian brand AudioLot (Vinnitsa City). This brand is manufacturing valve amps as well.
ec72667dcc125ccc0a2aa863d6a04d3c2eafa322
