Item: Manley Labs Mahi-Mahi monoblock power amplifiers
Price: $2,500
Item Condition: Excellent (see below)
Reason for selling: Trade In
Payment Method: Cash, All major card's excluding Diners, Paypal or Direct Deposit
Extra Info: Extremely well looked after as you can see from the pictures very little dust!
Specifications:
  • Input Tube: 1 x 12AT7EH large plate Eletcro-Harmonix Russian
  • Driver Tube: 1 x 6414 JAN NOS GE or Raytheon branded
  • Output Tubes: 8 x EL84 Ships with Russian NOS EL84M (aka 6Pi14Pi-EB) We are out of Ei 6BQ5.
  • Output Tube Quiescent Standing Current: 25mA
  • Set Bias for 250mVDC measured across each 10 Ohm cathode resistor
  • Input Impedance: 110 kOhm
  • Negative Feedback: MIN= 3dB; STD=6dB; MAX=10dB of global NFB
  • Gain:
    • TRIODE/UL
    • FB MIN: 30.7 dB 32.1 dB
    • FB STD: 28.5 dB 29.1 dB
    • FB MAX: 26.1 dB 27.1 dB
  • Input Sensitivity for Maximum Output Power: defined as input voltage required in order to produce maximum power output reaching 1.5% THD @ 1KHz
    • TRIODE/UL
    • FB MIN: 175mV 155mV
    • FB STD: 312mV 340mV
    • FB MAX: 480mV 566mV
    • Input Sensitivity for 1W into 8 Ohms: 61mV 53mV
  • Maximum Output Power: defined as power output reaching 1.5% THD @ 1KHz into 5 Ohms: TRIODE UL FB MIN: 18W 20W FB STD: 27W 42W FB MAX: 28W 46W into 8 Ohms: TRIODE UL FB MIN: 14W 24W FB STD: 24W 40W FB MAX: 25W 41W
  • Signal to Noise Ratio Ref. 1W: Typically 82 dB A-WGT 20-20K
  • Noise Floor: Typically 150µV = -74dBu A-WGT
  • Noise Floor: Typically 650µV = -62dBu unweighted
  • Will Scratch Your Floor: Use coins under pointed feet to avoid marring cabinetry. Try $2 coins if you are in upper tax brackets. The bargain performer would be 5c pieces. Paper currency does not function as well.
  • Dynamic Range: 83dB
  • THD+Noise @ 5W: less than 0.15%
  • Frequency Response at full power UL mode w/MAX NFB: 20 Hz to 20 kHz FLAT
  • Frequency Response at 5W into 5 Ohms: 10 Hz to 30 kHz FLAT, -3.75dB @ 100KHz
  • Recommended Speaker Load: Optimized for 5 Ohms
  • Output Impedance:
    • TRIODE / UL
    • FB MIN: 2.43 Ohms TRIODE; 3.10 Ohms UL
    • FB STD: 1.47 Ohms TRIODE; 1.67 Ohms UL
    • FB MAX: 0.90 Ohms TRIODE; 0.95 Ohms UL
  • Damping Factor:
    • TRIODE / UL
    • FB MIN: 3.29 TRIODE; 2.58 UL
    • FB STD: 5.45 TRIODE; 4.78 UL
    • FB MAX: 8.90 TRIODE; 8.43 UL
  • Power Consumption (idle): 102 Watts
  • Maximum Power Consumption (at Full Power): 168 Watts
  • Operating Mains Voltage: 220-240VAC
  • Mains Fuse 220-240VAC operation: MDA 1.5 Amp SLO-BLO Ceramic Time-Delay fuse
  • B+ Fuse: MDA 400 mA SLO-BLO Ceramic Time-Delay fuse
  • Badge Illumination: LED illumination
  • Dimensions: 127 x 254 x 279mm (HxWxD)
  • Shipping weight each: 8.2kg
$2,500 the pair
Contact Sydney Hi-Fi Castle Hill
02 9899 9079
Shop 7 19 Victoria Avenue Castle Hill
Edited by SHF Staff
39 minutes ago, muriwai said:
Did these ever sell ?
You would hope so
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By alexb
      Item: Little Dot Mk II Headphone Amplifier
      Price: $SOLD
      Item Condition: Mint
      Reason for selling: Selling head-fi rig
      Payment Method: Pickup, EFT, Cash, Paypal (buyer pays all transaction fees & postage)
      Great condition and one of the best value headphone amplifiers available. Australian variant with 220v power supply. Upgraded Value Electronic CV4010 KQDD/K and 6H6 VIII tubes.
      The device has a single volume knob on the front along with a blue LED and of course, the 6.3mm port. At the back you can find the input and output RCA pots as well as the power button. The specifications of the amp are as follows:
      Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Driver Tubes: 6JI Power Tubes: 6N6 Frequency Response: 20HZ - 50KHz (-1dB) THD+N: 0.1% (50mW into 300 ohms) Suitable Headphone Impedance: 32 - 600 ohms Pre-Amplifier Output Impedance: 10K ohms Power Output: 300mW into 300 ohms 200mW into 120 ohms 100mW into 32 ohms Average Power Usage: 28 watts Dimensions: 210mm (length) by 110mm (width) by 130mm (height) Weight: 2.5 kg or 5.5 lbs.
      The Little Dot MK II boasts a SEPP (single ended push pull) circuit (in similar vein to the rest of the MK-series tube amplifiers) greatly increases sound quality, dynamic range, output impedance, and harmonic distortion. The Little Dot MK II also provides gain control of 3, 5, and 10 via internal DIP switches for fine-tuning so you can maximize synergy with almost any headphone you have, whether it be 32 ohms or 600.
      Some cheap tube amps have what is called a hybrid design, where the power is provided by a transistor based circuit and the driver circuitry is tube based. Examples of these designs are the headphone amps with only a single vacuum tube (the driver tube). Not only does the Little Dot MK II have a fully tube based design (both power and driver elements are tube based) it actually has independent circuitry for the left and right channels.
      So essentially, you have 1 power tube and 1 driver tube for the left channel and 1 power tube and 1 driver tube for the right channel. This is called an SEPP design (think of it as 2 + 2 design).
    • By Yogus
      Item: Bottlehead Crack with Speedball Upgrade and Tube Upgrades (Chatham 6080WA, Brimar CV4003)
      Location: Melbourne, VIC. Will ship ($20AUD Australia wide)
      Price: $700 ono
      Reason for selling: Upgraded to Crackatwoa
      This headphone valve amp was built by myself in December 2018. I've used it up until November 2019 when I upgraded to a Crackatwoa. An excellent amp for high impedance cans such as Sennheiser HD650/600, Beyerdynamics and ZMFs.
      This will come with the stock tubes (RCA 6080s and GE input tubes) as well as tube upgrades for both the output and inputs: Chatham 6080WA and Brimar CV4003, all NOS when purchased. This combination of tubes gives a punchy and musical sound with a little bit of sparkle, yet losing none of the rich mids that valve amps are known for. The Chatham 6080WAs are sonic equivalents of Tungsol 6080s, which are ridiculously hard to find and are one of the most popular tubes used on Bottlehead Cracks.
      The finish is a Scandinavian Oil with a spray painted dark grey metal top plate. (There are some imperfections in the spray painting).
      I have other tubes that can be sold either together with the amp or separately (not included in the purchase price). All NOS and used briefly for testing.
      GEC 6080 - +$200 - a much warmer, sweeter tube than the Chatham 6080WA Tungsol 5998 +$200 - enough said...  Tungsol 6080 +$100 - punchy, musical
    • By timelord9
      Item: Vincent Audio SV237. Black.
      Price: 1300 dollarydoos.
      Reason for selling: Raising capital for domestic transducer development.
      Extra Info: Purchased 2nd hand last year, this amp has seen very little use. I have the original box, but its super heavy and (at this stage) would prefer not to post. The amp is in perfect working order and buyers can demo with my Focals. Pick up from Thornbury or Abbotsford.
      Specs:
      Frequency Response: 20 Hz - 20 kHz +/- 0.5 dB, 20 Hz - 50 kHz +/-2 dB Nominal Output Power RMS / 8 Ohm: 2 x 150 Watt Nominal Output Power RMS / 4 Ohm: 2 x 250 Watt Nominal Output Power Class A / 8 Ohm: 2 x 10 Watt Harmonic Distortion: < 0.1 % (1 kHz, 1 Watt) Input Sensitivity: 300 mV Signal-Noise Ratio: > 90 dB Input Impedance: 47 kOhm Inputs: 4 x Stereo RCA, 1 USB Outputs: 1 x Stereo RCA Pre Out, 1 x Stereo RCA Rec Out, 4 x 2 Speaker Terminal, 2 x 3.5 mm Jack (Power Control) Tubes: 1 x 12AX7; 2 x 6N1P-EV Colour: Black  Weight: 20.4 kg Dimensions (WxHxD): 430 x 152 x 435 mm
      Comes with remote.
      Note: This is the original SV237. The link below is with the updated digital input.
      https://www.vincent-tac.de/en/product-lines/tubeline/sv-237mk.html
