migasson
Denon DP2000 plinth options...
Hey!
Ok, so I've obtained one of these:) (The pic is the model, not the actual table!)
So, this will turn into a long term project, so I'm no rush to build this up:) Mine will come with the motor unit, and the Denon plinth- and I get to choose my tonearm:) Where will this go? Well, I think I'm gonna grab a Jelco 750D, (or unless a SUPER cheap SME comes up here;)) and just bolt it up. But the reason for the post is I may just be tempted to build a custom plinth.
I wanna know if anyone here has built a custom plinth for this motor unit specifically, and what materials worked best..
I'm thinking:-
Layered birch ply
Super thick MDF (mulitiple layers)
Corian
HDF
Thoughts?
post-120746-0-92833600-1434282068_thumb.
Ironically enough, over the last week I've been looking into doing the exact same thing with a Denon DP80 motor unit.
From what I've read on the matter at the Vinyl Engine forum, and the DIY Audio forum, apparently going for a ultra heavy high mass plinth made of a single type of material is not recommended.
Corian was one of the first materials to be warned off, according to those who have tried it, the bass can sound slow and plodding, deep but no definition....the Jelco arm is ultimately supposed to have the same attributes, so mating those to would be a pretty disastrous result.
Thick, multiple layers of MDF weren't given a much better rating [pity as it's much easier to cut / shape], reasoning for the disappointing resulting sound with this sort of construction was that it basically ends up, like the Corian, one large mass that doesn't do the bass frequencies in the best way.
Using layers of Birch ply got a better rating, but apparently best sound is gotten by constructing the plinth by layering the grain of the ply one way, then the next layer the other way, etc.
It was also recommended to use different Ply's of the Birch ply in the one build, as this breaks things up even more.
I suppose if you could get a hard plastic coating put over the whole thing, it would sort of be like a mega Rega TT.
If you look at Denon's top of the line DK-300 Panzerholtz ply plinth, you will see it is constructed in a similar cross layering construction.
post-103973-0-85920900-1434444058_thumb.
I looked into sourcing Panzerholtz ply [bullet proof plywood] - forget it, it costs a fortune and is a total PITA to shape without very expensive tooling.
Then, when doing further research I hit a blog that got into the high end build for Technics SP10's etc.
I'll just give you the links to that as it better describes the process , similar to above - different material - more like multilayer ply, with a Aluminium layer and a Basswood layer [basswod is very light,used to build Electric Guitars ]
http://www.soundfountain.com/amb/sp10plinth.html
So I'm still in research mode ATM, early days as I'm in no hurry to build till I know exactly what will suit me best.
By the way, I think most of the Denon motor units use pretty much the same cutout for the plinths.
You can download the template from the Vinyl Engine under the DP80 model [not sure if you need to be a member to get it - I am]
http://www.vinylengine.com/library/denon/dp-80.shtml
Edited by Tweaky
It sounds like we're heading for a build-off @@Tweaky !
Good chunk of info. I've been looking for that magic bullet.. "..use this and this= great sound" but it looks like trial an error will bring results. I'm heading down that ply route, but I did see one thing. This geezer built a solid maple base, and topped it with 3/4 inch slate.. However what I'm trying to do is do most of it at home, kinda get involved with it.
Cheers, didn't know the DP-80 had the same mounting template. I've downloaded it, and will compare when my Denon arrives.. P
In the meantime, looking out for a tonearm. Some of the older Graces are tempting...
Maple is very a very hard wood, also very dense, subsequently heavy per Cub cm.
Not exactly cheap building material either, even if sourcing the Queensland maple variant.
That Geezer might of built a brick, that could have easily have been built out of MDF considering the materials used.
Using a heavy dense top of slate might of made the sound slightly different, but I wouldn't go down that High Mass route..... seems like a Corian base result, without using Corian IMHO
What we both need to achieve in plinth design for this project is, rigidity over mass, inertness over weight.
Rega found a cheap solution to updating the P3...that was a small hard brace that ran along the top of the turntable to give it rigidity...it worked.
We, Thankfully, are not intending to build a TT to a budget, nor to one that needs to fall into a specific weight constraint for shipping purposes.
Thus, we can go full steam ahead and use better materials.
My thoughts ATM are to use multiple layers of birch ply, then use 0.5mm Brass sheet bolted both as a Top and a bottom of these ply's, to compress together.
Face the sides with similar Brass sheet.
This will give the stiffness requires, without undue mass, at a acceptable cost, and with great latitude as to finish.[i've got this book at home on how to patina various metals ;) ]
http://www.amazon.com/The-Colouring-Bronzing-Patination-Metals/dp/0823007626
EDIT: Just re reading your last post again....don't take the plans for the DP80 as gospel "Suitable" for your TT motor, they could be different mounting holes.
Suggest going  to the Vinyl Engine and asking owners of your motor unit.
Edited by Tweaky
Maybe Duc (Lovetube) can build you one?
It deserves a great plinth. :)
Out of what?
Something special?
Please be more specific.
I've been a forum member here since year dot, can you link me to any previous posts that relate to the subject we are talking about, OR to LoveTubes expertise ,I'm not familiar with it.
Cheers. :)
Looks like birch ply is the go!
I was thinking of cross running the grain. What I'll do is build it up in layers as I go, till I achieve the sound I want- so kick off with, say, 4 layers, 24mm thick, (or 6 x 12mm) and take it from there- with the top layer having an interchangeable armboard. Then, if I need to, brace the top and bottom....
Have my spbreak coming... I'll start soon and post the result:)
go for it.
Russian Birch is my first choice for plinth build unless you want to solid hardwood .
4 layer of 24mm birch is good start and i think that all you need .
have funs.
Duc
Out of what?
Something special?
Cheers. :)
My mistake was not quoting or addressing the OP.
Don't give a damn either how long you have been a member, what's that all about?
In fact I have been here longer. But so what?
To the OP..... I realize you did state that you might build your own plinth, I just wanted to give an alternate option.
Edited by soundfan
Oh for Christ's sake.
Ok , you didn't specify who you were replying to
I wasn't having a go, or stating some missed perceived, by you, higher ground, based on how long I, or you for that matter, have been posting here....you totally missed read my question, and the point of the question.
All I wanted to know was what LoveTube had posted, and what interest it would have, to this thread.
The first I've heard of LoveTube was your posting in this thread ....Hence my original, quite civil and proper question to you about it.
You only mentioned his name, no links given to any relevant threads or posts by him, or about him concerning this project, or how and what he could contribute to it.
Of your 7000+ posts, how many have been so uninformative?
go for it.
have funs.
Duc
What are the specifics of "Russian Birch" construction ?
Who, in Aus deals in Russian Birch Ply?
What are the properties of this ply that makes it preferable for TT building?
Do you have to dance like Bear standing on hot coals to get a sheet of primo Russian ply ;)
@@Tweaky..
I did an Internet search on Russian birch ply suppliers in Melbourne, and about five popped up- coincidently, one around the corner from me!!! I reckon if you do the same, you'll find plenty in Sydney. I don't know the reasons why it seems to be better, but for the relative low expense versus other materials, it's worth the punt to see if it works. I can can a sheet cut up, 12mm thick, so I'll end up with four sheets of 600 x 450 mm, 12mm thick for $150.
Lovetube gives it the thumbs up, and he builds plinths, so it's an encouraging approval:) im building it over the next few weeks, I'll post the results
Hi Tweaky.
Plyco in Melbourne supply them .you can go to they website for more info .
why do i choose or why is it good material to built turntable plinth ?  it is heavy , it is not too dead , it is not too damp but not too live either and that is a what make it a good choice for plinth .
there is plenty of infos in the web about this material . so take sometime to read and you will know more.
Duc
    • By kramered
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Blue Mountains State: New South Wales Payment Method: EFT, COD Reason for selling: NLR Further information:
      Michell Engineering Orbe SE Turntable with full Stage 3 Gert Pedersen upgrade featuring dual-level machined acrylic and flagship suspension system.
      Everything in perfect working order and given full bill of health in mid-February 2020 by Sydney turntable setup specialist Mark Busby.
      Additional Package Items:
      Famous Trans-Fi Terminator Linear Tracking Air Bearing arm (cartridge not included) provided with air pump and long air tube.
      Trans-Fi Tomahawk wand.
      Includes silver interconnect cable.
      Includes Optional Upgrade Origin Live Motor Drive Ultra controller (33/45rpm).
      Includes Optional Upgrade external Balanced Transformer Motor featuring large high current power supply.
      Includes Michell Engineering Record Clamp.
      Miscellaneous spare parts
    • By EricL
      Item Condition: Mint condition (9/10) Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Greensborough State: Victoria Payment Method: Cash on Pickup, EFT, PayPal + 3% Reason for selling: NLR
      This is an award winning integrated amplifier from Denon with Australian power specifications. It is made in Japan.
      You can read the summary review: https://www.hifichoice.com/content/awards-2010-amplifiers-£1000
      The Denon catalogue also featured it as an award winning amp from EISA 2010-2011.
      It works beautifully and even has MM/MC phone stage.
      It can drive my Audio Technica MC flagship OC model AT-OC9XSL cartridge (0.4mV) and sounds great via my Paradigm Studio 20 speakers.
      It can be used as integrated amp, power amp and pre-amp. See photos for various setup in the manual.
      Specifications of the amp: Refer to photo.
      I bought in early 2011 (RRP - Around $1700) and used it for a year and then upgraded to Luxman amp.
      It has been sitting in the Hi fi room all this time.
      There are two very minor hairline scratches on the front. They are not noticeable unless you examine in close scrutiny. Please see photos.
      This amplifier is rather heavy -15.5kg so I prefer local pickup.
      It comes with the original manual, power cable, unused remote and original box.
      Will include the Denon catalogue featuring this amp.
      I can ship interstate if buyer is keen and there will be additional shipping costs.
    • By audioaddict78
      Item Condition: Cartridge Excellent. Stylus will need re-tipping Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Dulwich Hill State: New South Wales Payment Method: PayPal, Cash on Pickup, EFT Reason for selling: Trying something new Further information:  Bought this cartridge when I purchased a MoFi UltraDeck turntable less than 2 years ago.
      The cart and cantilever are in excellent condition. The stylus will need re-tipping. It's had about 900hrs of use and starting to show.
      This cart goes for around $899RRP. $190 is very reasonable. Retipping will cost around $160 - $220
      UltraTracker Highlights
      UltraTracker extracts immense amounts of detail, dynamics, tone, and texture from LPs. Literally made to live in records’ grooves, the configuration gives this cartridge innate advantages few others can claim at this price. MoFi cartridges are designed by looking at where a record starts: On a cutting lathe like the model used at Mobile Fidelity Sound Lab. UltraTracker features a V-Twin dual-magnet generator that mirrors the layout of the cutting head that originally makes a record’s grooves. Employing two low-mass, powerful magnets aligned in a V formation parallel with the record grooves, this cartridge features excellent tracking ability.
      V-Twin dual-magnet generator Nude Elliptical stylus Well-damped billet aluminum body 3.5mV output WELL-DAMPED BILLET ALUMINUM BODY
      The well-damped billet aluminum body controls resonances for tight, accurate bass reproduction. UltraTracker delivers finely tuned wide-bandwidth audio, with extension at both frequency extremes and no smearing of detail.
      NUDE-ELLIPTICAL DIAMOND STYLUS
      By using a nude-elliptical diamond stylus, UltraTracker easily tracks complex dynamic passages. You’ll hear superb detail and experience musical emotionalism that will send shivers down your spine.
      Specifications:-
      Type: Dual Magnet Stereo Frequency Response: 20 to 25,000 Hz Recommended Load Impedance: 47,000 Capacitance: 100pF Output Voltage: 3.5 mV Tracking Force: 1.8 – 2.2grams Stylus Construction: Nude eliptical Weight: 9.7 g To see more of the MoFi range
    • By bard61
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Marrickville State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Not being used Further information: I bought this a couple of years ago. Sounds great, I put about 40 hours on it then got a good deal on a Garrott P77i. I was keeping it as a spare, but as the Garrott has a replaceable stylus there’s no need to hang onto it, so out it goes.
    • By nedrum
      Last minute edit - I haven't tested if it still works or not, but am happy to do so for straight stereo if that matters
      Item: Denon AVC-A11SR (a beast back in it's day!) - review here
      Price Range: Free to a good home! StereoNet donation appreciated
      Collection Option: In-person pickup from Thornbury (Victoria) with limited personal contact
      Item Condition: Used
      Served me well for quite a while, until I moved onto a newer amp and it's been collecting dust ever since. A few things to note:
      Sound turns on and off in what appears to be the amp continuously engaging/disengaging the headphone jack. Might be an easy fix but who knows?!? as per the photo's, the two main caps are bulging. Not sure if that's an issue or if they are easily replaceable for someone in the know.
      Comes with remote, power cable and manual (of which the English part is a whopping 42 pages). Shipping isn't an option as it weighs 20.5kg. From what I remember, it's a typical Denon sound - neutral and smooth. Somewhat better than my mid tier surround amp, but without the room correction.
