Gieseler Audio
Klein DAC owners thread
I have a question...
So I have a (second hand) Klein, mainly for the Squeezebox, but I thought I'd try it with my Marantz CD5003 CD player to see if that'd improve its sound.  The CD5003 has both optical and coax out connections, but neither work with the Klein.
I've switched on the digital output as per the user manual for the Marantz, but the only thing that happens is that when I adjust the volume on the amp, one of the speaker's cones moves in and out.  :wacko:  I can't remember whether that was with the optical or coax though, it only happened with one.
The optical cable produces sound from the telly to the DAC, and the coax produces sound from the Squeezebox to the DAC, so both DAC inputs work that way.
Am I missing something?  I know I tend to hook my stereo stuff up while I'm drinking, but I thought it should have been simple enough.
Does sound great with the Squeezebox though!  :)
FWIW, I have the coax output of my bluray player connected to the DAC, just made sure that it's set to stereo.
The CD5003, I used to own that model, there's nothing much you can set up really, is there? Just curious, is it an MP3 or FLAC or so CD? I'm pretty sure the Klein supports only PCM. Just ticking boxes is all.
Alberto
Hi Monk,
that  is odd especially as the coax & optical inputs are working with your other units.
I did notice in the Marantz manual that the pitch control needs to be on zero otherwise the digital output is disabled
Maybe check that.
https://www.manualslib.com/manual/650918/Marantz-Cd5003.html?page=29
Also looks like Audio EX2 disables digital out.
Thinking about it more it would appear the DAC’s digital inputs are working fine but the Marantz
is not outputting a digital signal - some setting not quite right.
Thanks Alberto for your help.
Clay
Edited by Gieseler Audio
On 12/07/2018 at 5:53 AM, Gieseler Audio said:
Hi Monk,
Maybe check that.
Clay
Well.  Someone is a dumbass.
I still had Audio EX 2 set.
I had to check the manual in the first place to see how to turn on digital output too.  And that is mentioned right next to it.  Damnit.  Oh well, it works now, and has certainly improved the sound from the CD player.
Thanks Clay.
