craka 140 Posted October 8, 2017 Share Posted October 8, 2017 Its a very powerful Headphone Amp as well. Thanks to Eric Chan. Link to post Share on other sites
sum1 17 Posted October 31, 2017 Share Posted October 31, 2017 On 05/03/2017 at 11:02 PM, Gieseler Audio said: All Klein DAC's have maxium output 2 v RMS except for some of the very early ones which were higher at 3 v RMS. I'm playing with a Klein SE and Klein 2 with me now and i could've sworn that the SE sounds louder than the Klein2 but it seems like they are both supposed to be 2V output. I'm guessing its just the difference in the presentation of the sound that makes the SE sounds louder. Its definitely more upfront on the SE and as opposed to the laidback Klein2. Makes me wonder if the upfront sound is specific to SE edition or its part of the Klein dac 1 design. Just curious if there is anyone else here playing with the SE and Klein2??? 1 Link to post Share on other sites
Gieseler Audio 2,470 Posted November 1, 2017 Author Share Posted November 1, 2017 All the Klein's have been 2v out for a while but it is possible that some early ones were a bit higher. OK I have just checked the Klein SE pcb & it looks like it was higher - probably 3v so that would definitely make it sound louder. The post DAC filter components on the SE were slightly different to the other Klein's so that could be giving the slightly more upfront sound. 1 Link to post Share on other sites
michaelp2 70 Posted December 5, 2017 Share Posted December 5, 2017 (edited) Hi ,the Klein DAC look interesting - can anyone tell me if it works with JPLAY /Hibernate mode?? Thanks, Michael Edited December 5, 2017 by michaelp2 Link to post Share on other sites
Gieseler Audio 2,470 Posted December 25, 2017 Author Share Posted December 25, 2017 Hi Michael, I have not personally tried but I would think it should work fine. The Jplay/hibernation mode is mainly a software PC thing rather than DAC related. As long as the PC is still outputting a digital audio signal the DAC will decode it. Link to post Share on other sites
Monk 2,643 Posted July 11, 2018 Share Posted July 11, 2018 I have a question... So I have a (second hand) Klein, mainly for the Squeezebox, but I thought I'd try it with my Marantz CD5003 CD player to see if that'd improve its sound. The CD5003 has both optical and coax out connections, but neither work with the Klein. I've switched on the digital output as per the user manual for the Marantz, but the only thing that happens is that when I adjust the volume on the amp, one of the speaker's cones moves in and out. I can't remember whether that was with the optical or coax though, it only happened with one. The optical cable produces sound from the telly to the DAC, and the coax produces sound from the Squeezebox to the DAC, so both DAC inputs work that way. Am I missing something? I know I tend to hook my stereo stuff up while I'm drinking, but I thought it should have been simple enough. Does sound great with the Squeezebox though! Link to post Share on other sites
betocool 1,857 Posted July 11, 2018 Share Posted July 11, 2018 FWIW, I have the coax output of my bluray player connected to the DAC, just made sure that it's set to stereo. The CD5003, I used to own that model, there's nothing much you can set up really, is there? Just curious, is it an MP3 or FLAC or so CD? I'm pretty sure the Klein supports only PCM. Just ticking boxes is all. Cheers, Alberto Link to post Share on other sites
Gieseler Audio 2,470 Posted July 11, 2018 Author Share Posted July 11, 2018 (edited) Hi Monk, that is odd especially as the coax & optical inputs are working with your other units. I did notice in the Marantz manual that the pitch control needs to be on zero otherwise the digital output is disabled Maybe check that. https://www.manualslib.com/manual/650918/Marantz-Cd5003.html?page=29 Also looks like Audio EX2 disables digital out. Thinking about it more it would appear the DAC’s digital inputs are working fine but the Marantz is not outputting a digital signal - some setting not quite right. Thanks Alberto for your help. Cheers Clay Edited July 11, 2018 by Gieseler Audio 1 Link to post Share on other sites
Monk 2,643 Posted July 12, 2018 Share Posted July 12, 2018 @betocool @Gieseler Audio thanks gents. Will have another look tomorrow. Link to post Share on other sites
Monk 2,643 Posted July 14, 2018 Share Posted July 14, 2018 On 12/07/2018 at 5:53 AM, Gieseler Audio said: Hi Monk, that is odd especially as the coax & optical inputs are working with your other units. I did notice in the Marantz manual that the pitch control needs to be on zero otherwise the digital output is disabled Maybe check that. https://www.manualslib.com/manual/650918/Marantz-Cd5003.html?page=29 Also looks like Audio EX2 disables digital out. Thinking about it more it would appear the DAC’s digital inputs are working fine but the Marantz is not outputting a digital signal - some setting not quite right. Thanks Alberto for your help. Cheers Clay Well. Someone is a dumbass. I still had Audio EX 2 set. I had to check the manual in the first place to see how to turn on digital output too. And that is mentioned right next to it. Damnit. Oh well, it works now, and has certainly improved the sound from the CD player. Thanks Clay. 1 Link to post Share on other sites
