harmo_hammer
Paradigm Studio centre speakers, cc-490 vs cc-590 vs cc-690
Hi All,
This is perhaps an odd time to be asking this, since the Studio line is being phased out. I have a Paradigm Studio v.5 setup, (Studio 100s, and 20s for surrounds)... but I'm asking now because I've got an opportunity to buy the CC-690 for a reasonable discount before they entirely disappear. Before I "jump the gun" I've been looking for an auditioned comparison between the three centre speakers, and it's nigh-on impossible to find online.
Has anyone compared the three centres against one another? Would anyone like to share their thoughts?
I've heard the CC-590 (at length.... thanks to a friend's gracious hospitality and willingness to loan me his) and I found it to be articulate, and very good match for the 100s, it's certainly not a slouch, but it had a little less impact at higher volumes in my somewhat cavernous living room.
What are the sonic differences between the models? I'd expect better bass from the 690, I don't know if the 490 would work as nicely with the floor standers. From what I've read online, the 490 was aimed for folks running the non-floorstanders as fronts/surrounds.
Does anyone have the 690? I'd like to hear your thoughts, and why you chose that one. I can get the 590 a little cheaper, but I don't want to regret my purchase.. but if I do buy the 690, it would be extremely difficult to audition before purchase.
All help will be greatly appreciated! All the best!
Hamish.
Hi Hamish,
I ran a CC590 with 100's for a couple of years. The only reason I didn't get a CC690 originally was its size and I could only fit a 590 in my entertainment unit. I moved into my own place recently and was able to wall mount the TV, so placing a 690 wasn't such a problem.
In my experience it's worth it. When I heard that the studio series was being discontinued I went out of my way to source a 690. Why? because I'd researched upgrade paths and numerous people would say that the 690 was a noticeable upgrade from a 590.
What I found was the difference between the 590 and 690 is the 690's ability to blend seamlessly with the Studio 100's and match their bottom end. When I first compared the 690 at home the thing that stood out was the balance of sound coming from the front stage. It was no longer missing something between the 100's and it presented a consistent wall of sound from the front stage. The 690 is similar dimensions to a studio 100 and is able to dig as deep in the bass. Instead of crossing the centre over higher for the 590, I was able to match it across all three speakers for which improved the integration. I noticed improved clarity in the dialogue also (but this could have been helped by the fact the 690 was now higher and on top of my entertainment unit, closer to ear level)
Originally my focus was home theatre but over the last few years i'm listening to more music. I made a point to get hold of some 5 channel music to see how it sounded. This is another area the 690 shines. The vocals and sound stage are noticeably better and packs more punch since it's able to go deeper.
Edited by Leftaudionut
Hi Leftaudionut,
Thanks for the input, I also noticed that many who had tried the 590 upgraded afterwards. As a side note, I'm glad to see another ACT person here... I've only had sporadic dealings with them! I tried to get a few others out for a get together, but it seems the  average Canberra audio enthusiast is a tough nut to coax out of their audiophile nest. :~)
You're right about the 690! I just acquired one (albeit not in the colour I had hoped), and I really did notice the increase in bottom end. I had to make some modifications to the TV unit to house the beast. Out of curiousity, how far have you placed the 690 from the wall? Given that the depth of the speaker is significantly bigger than the 590. It does seem a little big to be placed near the wall, and thus more challenging to position.
Multichannel audio sounds intriguing, it seems that there isn't a lot of multichannel music for sale these days. Could you please tell me where you source your music? JB Hi-fi's music section seems either absent, or utterly miniscule in range.
Thanks for your info!
Hamish.
Hi All,
Just a quick update for anyone who's interested. I've recently obtained some multichannel music, and I'd like to share a quick story with you.
I've also recently added a separate amp to power my front left and right channels, and was tidying up the cables behind it. During that process I switched the power amp off using the physical switch, finished my task and then went to work. I came back and put some music on and started cooking dinner.
It took me a full 20 minutes after sitting down to realise that the 690 was doing all the work of the fronts, and that I'd forgotten to activate the power amp again. Naturally there was a lack to the sound stage, but with the surrounds augmenting the other channels very very well it's wasn't very obvious. It's this similarity in sound to the 100s with the detail, depth, and power that makes the 690 an amazing centre.
Now I know a dedicated music setups would use all floor-standing speakers, or all similar bookshelves, but I am honestly surprised how nice a horizontally arranged multi-driver centre can be.
If you have the ability to match 100s with the 690, I heartily recommend it.
All the best!
Hamish.
Hi Hamish,
Yep, plenty of people in Canberra but a lack of a social community it seems. I know Sean at Audiotech tried to get some people together last year but it never got off the ground.
My 690's about half a meter off the wall measuring from the port. Ideally I'd like to mount if on a stand an free up the area but that will have to wait until I can build a dedicated room.
Obviously 5 channel SACD has been around for a while and you can pick up classics pretty easily online but there's a few decent recordings available on bluray and bluray pure audio. JB's a bit of a lucky dip. Nothing really of interest most of the time. Best bet is online retailers to get what you want. Unfortunately not many artistis have embraced bluray so your options are limited and record companies are only releasing older classic albums on pure audio so it looks like it's going the way of SACD.
whats the best center to match the 60s? currently have the 490 and sounds. ok.
would like another studio 60 to use as the center but don't like my chances of finding a single speaker of the 60s.
There was a single studio 100 for sale a few months ago in the classifieds, (it was miss titled as a Studio 60).
The CC490 has matched cabinet and driver size for the Studios 60's so is the intended match. The CC590 and CC690 cabinet and driver size match the Studio 100's. Although any of the Studio centres would work fine with the Studios 60's as you receiver calibration would level match them.  If anything a bigger centre would add some bottom end to the sound stage.
I personally was not a fan of the CC centre range. I started with a CC490 then a CC690 and found them very "boxy" sounding in performance. When I upgraded to a C5 this issue I found greatly diminished. It also (at the time) gave me the motivation to upgrade from Studio 100's to S6's. But I have B&W now.
    • By Rolland
      Hi everyone its been a little while since writing on these forums, however I have had the privilege to be able to officially get hold of a paradigm defiance subwoofer and review it for over a month and see what it has to offer for its price. so here I go.
      Paradigm is known for there great sounding speakers, I've personally listened to them and have always commended their sound quality, however I was courious to see how their subs would perform given a price tag of about $999, that's where the defiance V10 comes in. This subwoofer is the latest generation of subs that paradigm has to offer which is part of the 'V' series of subwoofers in the defiance range, paradigm also offers an upgraded series of subwoofers in the defiance range called the 'X' series, in which those subwoofers feature more power and includes a bigger 15" subwoofer model in the range.
      Features:
      The Defiance V10 features a front firing 10" driver (hence the name 'V10') in a ported enclosure, however unlike some subwoofers such as the Krix Seismix 3 MK7 or the SVS PB-1000 which features the port in front, the V10 features it on the bottom of the sub making it a down ported configuration which usually means that the type of floor can affect the way this subwoofer would perform. On the back of the V10 is a 120 watt rms/ 240 watt peak amplifier, it features two low level rca inputs with one of them being an LFE input ( this input bypasses the sub's internal crossover to allow full crossover control from an AV Receiver/Processor), the V10 also features high level speaker inputs as well, however it only accepts banana plugs and not just bare wire. The V10 has a power mode switch and a setting to switch between local and app control for the V10, speaking of apps, the V10 is app controlled via the "Paradigm Subwoofer Control" app, which allows full control of the subwoofer on a smart device from your seat and because the V10 features Anthem's ARC room correction via a separate app ("Anthem ARC Mobile"), you have the option of either using your phone as the set-up microphone or you can get the optional dedicated microphone.
      Setup:
      I had the V10 setup with my Polk Signature speakers which is configured as a 5.1.2 Dolby atmos/ DTS X, I had the S20 bookself speakers as my fronts, the S30 as the centre and two pairs of S10's in which one pair does surround and the other pair does the height Dolby atmos/ DTS X effects. the AV receiver powering up the whole system is a Yamaha RX-V1083 (same as RX-A1070) with the Sony UBP-X700 as the media source. As far as crossovers go, I had the front three speakers set to 80Hz and the surrounds and effects channels set to 90Hz. I connected the V10 via the LFE input and had the sub placed between the left and centre speaker as that was where the V10 like most of my subs performed best. I did the rest of the set-up for the V10 using the apps and ran the Anthem ARC room correction via "Anthem ARC Mobile" using my Samsung Galaxy A20 mobile device as my set-up microphone (not the most accurate way to set-up the sub, but it was good enough), then I went into the " Paradigm Subwoofer Control" app where I had the level set to '-12" (the range is -40 to +8 I believe) and the phase was at 0 degrees, I didn't set the crossover as I already connected the sub to LFE.
      Performance:
      After the setup and calibration, I decided to play some music content (in stereo mode 2.1ch) starting with "Phil Collins live at Montreux 2004" on standard Blu-ray to see how well the V10 can reproduce the sound of drums and see how well it can handle the complexity of two drum sets, overall the V10 performed very admirably, thanks to the Anthem ARC room correction, each kick drum was reproduced clean and tight without any noticeable overhang and complexity of the drums was handled nicely with each hit sounding well defined without sounding like a one note wonder, it doesn't have as much kicking energy as the Krix Seismix 3 MK7, but it still remains cleaner than the SVS PB-1000. When playing "In the air tonight" and the bass played, the V10 gave a very satisfying performance where it made a nice transfer of bass energy into my listening area almost giving the impression that I was there, once again the V10 still playing clean but smooth, I played other music content as well such as; Nils Lofgren (bass and drum solo), Dire Straits (money for nothing), Bee Gees (live by request: massachusetts) and Lifehouse (hanging by a moment). Throughout listening to music the V10 performed consistently well and I didn't feel that the V10 needed any further adjustment for improvement in its music playback, so that's a big thumbs up to Anthem's ARC room correction. After finishing with music, it was movie time and for that I started with "BumbleBee" on Ultra HD Blu-ray, I watched the whole movie and all the while observing how well the V10 can handle 'LFE' effects. The V10 produced some satisfying effects, rumbling effects sounded quite convincing with some good punch and soundtracks sounded nice and cinematic and it was quite exciting to listen to, particularly the fight scene between BumbleBee and Dropkick and Shatter, punches and kicks as well as blaster fire shots were reproduced solidly and they didn't sound like the same bass thud, they sounded separate making it easy to tell the difference between a blaster gun and a punch. I then moved on to "Finding Nemo" to where Marlin and Dory are inside a whale, in this scene are some aggressive rumbles when the whale stops and when the whale is talking to Dory, this scene has plagued some subs that I've had in the past sometimes producing a lot of port noise or the woofer would bottom out, however the V10 handled it pretty good, I did have my ear near the port as well to see if there was port noise and I couldn't detect it. I did also play some other movies such as; Transformers (the last knight), Kong Skull Island, Godzilla (king of monsters), Star Wars (the phantom menace) and Tron (Legacy). In all those movies the V10 performed quite solidly, however it wasn't without issue though and this is probably due to the 120wrms amplifier, it doesn't handle dynamics as well as some of the more higher powered competitors in the same price range, this is especially the case when playing "Transformers (the last knight)" and "Godzilla (king of monsters)" where big explosions at times can sound a little underwhelming and if you push the sub level any higher to hear those big explosions to a more satisfactory level it will compress and it is noticeable.
      Competition:
      Krix Seismix 3 MK7: this is currently the sub that I own and have always been impressed by its overall performance, so how does it compare to the Paradigm Defiance V10? well in terms of features, the V10 is the way to go if you want app control capabilities and a good range of inputs including high level inputs, which the Seismix 3 MK7 does not have and the V10 has room correction whereas the Seismix 3 MK7 doesn't have that, however if great overall power and performance is what you are looking for then the tables do turn in favour of the Seismix 3 MK7, it has 350 watts rms whereas the V10 only has 120 watts rms and despite the advantage of room correction the Seismix 3 MK7 did better overall, while the V10 did well in music playback, the Seismix 3 MK7 did it better, it had more energy to give and was more engaging, but at the same time its clean and tight. when it came to movies the Seismix 3 MK7 did way better than the V10 mainly because of the power difference which means Seismix 3 MK7 didn't compress at high volume or with high dynamic effects like the V10 did.
      SVS PB-1000: being a previous owner of a PB-1000, I know that If great movie performance is what you are looking for then it has to be the PB-1000, it has more power then the Paradigm Defiance V10 (300 watts rms vs 120 watts rms) and due to this power difference the PB-1000 like the Seismix 3 MK7 would not compress at higher volume like the V10 did and the PB-1000 does go a bit lower as well, but once again if high tech features, room correction and musicality is what you are after then between the PB-1000 and the V10, its going to be the V10, it plays cleaner and tighter than the PB-1000 and has a bit better definition as well.
      Yamaha NS-SW300: I use to own the NS-SW300 and in terms of looks it does make a statement for itself, this subwoofer covers all the basics well in terms of features, it even has high level speaker inputs and outputs, but Paradigm Defiance V10 does once again have app control and room correction and it does show when come to the sound, it sounds way cleaner and tighter than the NS-SW300 which translate to better musical performance. When it comes to movies as well the V10 does better than the NS-SW300, its more cinematic and sounds goes a bit lower as well whereas the NS-SW300 sounds like its struggling to hit lower frequencies at high volume below 35Hz and starts rattling pretty badly when trying to hit those lower frequencies.
      Conclusion:
      Overall the Paradigm Defiance V10 is quite a nice subwoofer, it has some great features and  I'd definitely called it a smart subwoofer given that it has smart device app control and an excellent Anthem ARC room correction system which in turn made the V10 a solid musical performer and it does quite well in movies, however for almost the same price you can more powerful offerings from other brands that may be better especially for movie content that has a heavy demand in the LFE effects.
      Pros:
      > App control
      >Room correction
      >Solid music performance
      >High level inputs
      Cons:
      > Only 120 watts RMS
      > struggles with movies at high volume and high dynamics
      > competition offers more power for similar price
    • By krusto
      Item: Paradigm Monitor 10 SUB
      Price: $700
      Item Condition: Excellent/Mint
      Reason for selling: NLR
      Extra Info: Lightly used for music, very nice, smooth subwoofer. Incredibly small (sealed) cabinet. Not only awesome for musical applications, but deep and powerful enough for any home theatre enthusiast.
      Original box etc for safe delivery.
      DESIGN Single driver, acoustic suspension, built-in advanced Ultra-Class-D™ amplifier, USB port for PBK?equalization, removable grille AMPLIFIER 900 watts Dynamic Peak; 300 watts RMS Sustained AMPLIFIER FEATURES Auto-on/off, soft clipping, thermal protection ROOM CORRECTION Anthem Room Correction (ARC®) (sold separately) LOW FREQUENCY DRIVER 254-mm (10 in) carbon-loaded polypropylene cone, Active Ridge (ART) Technology surround, 38-mm (1-1/2 in) 4-layer copper-clad aluminum voice coil. Nomex® spider, 4.5 lb ferrite magnet, AVS™ die-cast heatsink chassis FINISHES Black Ash WEIGHT 30 lbs. (13.6 kg) DIMENSIONS HXWXD (33.0cm × 28.3cm × 32.4cm) LOW FREQUENCY EXTENSION 17 Hz (DIN) LOW PASS FILTER FREQUENCY Variable 35 Hz - 150 Hz; Bypass Option SUB / SAT PHASE ALIGNMENT Variable 0° - 180° INPUTS Two RCA (L/R-Mono) for L/R lineout or Sub-Out/LFE-Out of receiver/processor or other line-level source COMPATIBLE PRODUCTS PT-2 Wireless Transmitter (sold separately)
    • By Mironyousuf
      Hi All,
      I’m planning to buy a pair of surround speaker and a pair of Ceiling speaker.
      I have now Paradigm  Premier 800F front and Paradigm Premier 500C centre. For surround I have now pair B&W M1 speaker and ceiling I have pair of Canton 445. Subwoofer I’m using SVS SB3000. Amplifier I’m using Marantz SR6013.
      I’ve upgraded fronts centre subwoofer amplifier between 6months to a year ago. Now I’m ready to upgrade surround and ceiling speakers.
      I’m not sure if I must use paradigm surround and ceiling to complement my front and centre or should I go other brand with better crossover and better value.
      my budget $1000-$1500 for both surrounds and ceiling speaker.
      Thanks in advance for all suggestions.
    • By myryad
      Item: Paradigm Seismic 110 Subwoofer
      Price: $1700
      Item Condition: Excellent (Mint)
      Reason for selling: NLR - selling on behalf of family member
      Paradigm Seismic 110 Subwoofer purchased in April this year from a Sydney retailer. The sub is in mint condition as can be seen from the photos.
      The Sesimic 110 sub is an absolute beast. The small footprint can fool people but this thing can get very low and has amazing speed.
      It is a fantastic sub to use with a 2-channel music system due to its incredible agility and also perfectly suited to movies/home theatre duties as well, especially in small/medium sized rooms. The compact footprint also makes it great for dual sub setups.
      Significant saving from RRP on a sub that is only a few months old. It is also still under warranty.
      Full specs here: https://www.paradigm.com/en/sealed/seismic-110
    • By Keza_punk
      Item: Cambridge Audio azur 340r and 5.1 speaker setup.
      Price: 450
      Item Condition: All items as new condition.
      Every speaker works perfectly. AVR comes with remote control.
      Reason for selling: Change to 2.0 setup.
      Up for sale my music and ht setup.
      Sale incudes
      ****  4 star What HiFi review.
      1 x Cambridge Audio azur 340r receiver
      Very musical amp, perfect for music listening.
      ***** 5 star What HiFi review.
      2 x Cambridge Audio Siccoro s30 speakers
      2 x Mourdand Short speakers
      1 x Paradigm centre speaker
      1 x Cambridge Audio Active Subwoofer
      If you're after sound quality this setup will be perfect. Sound is crisp with plenty of details and low end.
      Demo and inspections welcome.
      Buy only if you're happy with sound quality.
