Cafad
Integrated Amps: An Addicts Guide Part, The Third.
43 minutes ago, Cafad said:
TACT S2150
Time to take a trip back in time to the source of all things good about class D amps.  Back in 2003 TACT was doing some ground-breaking work that the better class D amps of today have clearly benefited from.  Many class D amps are dynamic to a fault while sacrificing top end listenability and mid range sweetness, in some cases this “standard class D personality” works but in others it very much does not.  It can depend a great deal on the genre of music being played and the system it is played on.  Class D amps can make small systems sound bigger and more punchy than they usually do and I suspect it is this very trait that has made them so popular in the world at large.
However TACT took the traditional class D topology and refined it, embraced it to the point of removing the whole idea of a separate DAC.  Instead they performed a signal conversion on the PCM signal, converting it to a PWM signal that is then used to feed into the class D module directly.  I’ve heard several cheaper amps that do this, the QLS QA-100, the later QLS model QA-690, the Wadia 151, the POPU D5 and Venus models, the Nuprime IDA-8, though the IDA-8 has a conventional DAC (and the Nuforce DA-100, which was the least impressive of all of them to my ears).  All of these are decent amps in their own right (and at their own price points) but none are close to a match for the TACT.  The Classe Sigma 2200i is a similar design and it plays to its strengths a little more, the 2200i is, in my opinion, a better amp than the TACT S2150 but since it came along 13 years later and likely owes much of its design to the work done by TACT then that is no real surprise.
The big thing about the TACT S2150 is that it up samples to 384KHz, it is true that there is some gear out there that does this now but back in 2003 this was massive.  It also controls volume differently, I’m not sure I fully understand this but it seems to drop the voltage of the power supply in order to drop the volume.  Normally the volume is controlled by decreasing the voltage of the music signal while the power supply voltage is constant (or as near to constant as it can be kept) so this is different.
TACT also had some kick-ass room correction tech, some of which is usable with the S2150.  To get the most out of it though you need to use multiple amps as you can adjust both gain and crossover settings.  I believe the dedicated preamp was something of a legend in the area of signal control and gave you a load of choices if you were a bi or tri-amper.
The S2150 is a good amp, and it is not an amp that sounds like a class D design.  Its vocals are top notch and slower music is so resonant and poignant that you would swear you were listening to a $5K amp produced by a niche design house.  It does well on faster music but on fast and hard music with multiple instruments and vocals it isn’t as impressive as it is on the slower stuff.  It is far from alone in this regard, many amps have issues with separation and soundstaging when more than 4 sounds are competing for attention.  If I were reviewing the S2150 15 years ago I would have been very impressed, possibly even astounded, today I look at it and think thoughts like, “So that’s where the ideas that carried class D forward started.  You know, even by todays’ standards, it’s very good.”
It does have an eccentricity or two however, but I’ll get to those later.  Time to start the details and such.
As is usual I was using my YBA Herritage cd100 as a transport, coax cable was from Geoff at Aurealis, speaker cable was standard old Ugly cable, 10AWG, with banana plug connectors sourced from Jaycar (although I did use the TACT with Redgums speaker cables for several days, I could not detect a significant difference so I don’t believe the TACT to be very fussy when it comes to cables).  And speakers were, as always, my Lenehan S2R stand mounts.
Highs:
Triangles sound almost crystalline and shiny, not really similar to any other amp I’ve heard.  I’m going to have to listen to them 4 or 5 times to get a grip on them I think.  Don’t get me wrong, they sound very good just not metallic enough.  Trumpets are nice and brassy but a little sweet as well.  Crisp metallic sounds seem to revel in their crisp-ness.  Can sound a touch dry when swamped with several instruments at once.   All in all, very good, 7.75.
Mids:
Depends greatly on what is going on.  On lighter music the mids are damn good.  Single instrument plus vocals and the TACT is up there with the best of the best, two or three instruments and it’s still very good but throw in four or five and it starts to lose that magic.  8.5 on slower music with a minimal number of instruments down to 7.25 with 4 instruments or more plus vocals.
Bass:
The class D “Big Bass Effects” are dialled down with the bass region correlating in with the highs and mids very well.  Impact and follow through are good but they could be a little fuller and deeper.  I don’t think this level of bass would keep a true bass head happy.  I realize it is this slight lessening of the bass that allows the mids to behave as well as they do but since I evaluate them separately I’m afraid the bass score is going to suffer.  Not suffer badly as it still does a good job, but it really isn’t up to the usual class D expectations.  Of course since this is a TACT the fact that it doesn’t sound like a stereotypical class D is the whole point.  7.5
However, as with the mids, if you play music with less instruments involved then the bass is much more satisfying.  Joe Satrianis’ “Hill of the Skull” for instance has excellent bass.  I’d be willing to go up to about 8.25 for that song.
Vocals:
TACT have really nailed the vocal side of things.  Female vocals are deep, resonant and sweet and Male vocals are clean and smooth with just a touch of gruffness when needed.  8.25 for both.  Nancy Wilson sound so good I’m going to pull out all my Heart albums tomorrow and spin them up.  I may even pop Freddie Mercury’s solo album in too, although the production values on it aren’t top notch so it may not do Freddie justice, worth a try though.
Sound staging:
Interestingly enough the vocals image extremely well, instruments in the mids almost as well and then instruments in the highs less and the bass lesser again.  There is a 3D soundstage (which is good news, many class D amps I’ve heard don’t seem to understand what a 3D sound stage is) but it is a little on the shallow side.  I have the distinct feeling that if my room were twice the size then the sound stage would integrate much more effectively, sometimes it felt like each speaker was trying to fill two thirds of the room.  I’m going to give it a 7.0 as a minimum, and up to a 7.75 in the mids and an 8.0 for the vocals.
Overall Performance:
Lighter styles of music are an absolute delight to listen to, lighter strings and woodwinds are excellent as are smaller drums, larger drums don’t feel quite as large as they could (unless they are the only instruments in use at the time).   I could certainly live with the TACT, but I think it would skew my listening more to the lighter styles in my collection.  I would probably keep another amp for the heavier stuff.
Ability to Emote:
7.5 on lighter styles, 7.5 to 7.0 on faster rock, 7.0 to 6.5 on rock with lighter (or boosted) mid bass.  I was definitely not feeling as much love for the Dire Straits remasters as I usually do (but the originals were pretty good).  Dynamic range crushing is even more evident than usual.
Electric Guitar Test:
8.25, very satisfying combination of growl and rumble with just a little edge to it.
80’s Rock Test:
7.5 with harder rock, 8.0 with lighter and/or softer rock.
In short, an informative and rather impressive, trip down memory lane.  Capability mixed with nostalgia.  That’s what the TACT S2150 is.
Now I guess  I need to put a Lyngdorf on my target list.
My first proper audiophile amplifier was a TACT Millenium MK2. (Which later went to the Lyngdorf brand)
It was a very good sounding amplifier and being pure digital in it was very much ahead of its time.
The build quality was exceptional too.
Edited by Martykt
Thanks Cafad for that excellent review of one of my favourite amps.  I was an early adopter of TacT gear and bought my first room correction preamp in around 2004.  It's still in perfect condition and serves as a handy spare pre.  Given that it has both digital and analogue inputs and digital and analogue outputs, it's incredibly versatile and it's built like a tank
In around 2006, I upgraded to the RCS 2.2XP (keeping the original RCS 2.0) and added the 2150.  Although I could never really come to terms with the room correction (probably just too complex for this old dinosaur!), I've always found this combo to be very useful, versatile and competent performers.  Boz was the epitome of the "flawed genius" and it appears to me he tried to be all aspects of his business instead of leaving the commercial aspects to someone with the appropriate skills.  The "divorce" from Peter Lyngdorf was always going to see Boz and TacT founder and, sadly. it did.
Anyway, the RCS 2.0 gets occasional use as a back-up preamp and the RCS 2.2XP and 2150 combo is in continuous, ongoing use in the family room and makes a pair of the ubiquitous NS1000M's sound  pretty much like I think NS1000M's should - ie superb within certain inherent limitations in the bass area.  We had some rellies for lunch today and the family room system has gradually climbed up to enjoyable volumes (it's still very sweet at background listening levels) and it's sounding gorgeous to me ATM.
Might snap a couple of pics to illustrate this post::)
I really disagree with those who assert "All class D sounds like crap"  I wish they could hear what I'm hearing right now!
Thanks again for giving this lovely gear a rare bit of exposure.:thumb:
It was my absolute pleasure Tony.  I had not heard of TACT as such but once I was made aware of their story I just had to hear one.  They are a piece of audio history, in both the fact that they are a technological first and that the company stands as an example of how a company can fail in the industry even though they have a series of products that are original and excellent quality.  It is a pity that they don't exist any more but at least they did exist and can still be found if you look hard enough.
Edited by Cafad
FWIW, I should mention there is quite an active International forum (TactAudioUsersGroup) at yahoogroups.com
It's a fantastic resource sharing info, software, service tips and selling and buying leads.  You can download encyclopedia-sized manuals to assist with room correction etc.  I did so, but I have yet to find the time and inclination to master it as it's pretty complex.
There are quite a few real enthusiasts around the world  keeping the brand alive.
Where abouts are you located Tony?
I have the RCS and TCS and have found little to touch them. I have Tip and Hans-Martin very helpful when advice is needed!
Sorry, I just saw this post.  I'm at Hahndorf, in the Adelaide Hills - quite a few audio enthusiasts around here.
I totally agree the support of those guys on the TacT forum is fantastic.  Just one example was the analogue (or was it digital - just can't remeber for sure ATM which it was) input board of my 2.2XP failed.  From the symptoms, they were able to tell me that 4 small SMC caps neede to be replaced.  I was able to take the board out, drop it into a local computer repair shop and get it fixed by asking them to replace  specific caps.  Totally modular design is just great - no need to take the whole unit in.  I think it cost something like $50!
I have high hopes of keeping my Tact gear fully funtional for a long time
Thanks for the reply, had some friends over tonight and ended up in the music room!
I've been enjoying my Classe Sigma 2200i lately on my ML2 Limited speakers.  The Classe being my favourite amp of all time (or possibly "so far") on the S2Rs.
It was pretty good, and I enjoyed it quite a bit for about a fortnight.  But on Saturday I felt the urge to change amps once again.  I was temped to change back to the Sansui 907 NRA (or any other Sansui) but I'd already listened to it on the ML2s so instead I went with Simons Zeus Integrated.  My oh my am I glad I did!
The Zeus has the grunt needed to make the ML2s produce bass and in fact when compared with the Zeus the Classe sounded a bit on the thin side.  I liked the Zeus  on the S2Rs, while it wasn't in my top 3 it was certainly in my top 5 or 6, but on the ML2s I think it will do considerably better in its placing.  It doesn't have the detail or the soundstaging of the Classe (I think I need a bigger room, something I am regularly reminded of with the larger amps) but damn it has some addictive dynamics and such smooth, easy bass when compared to the Classe.  I'll have to do some back to back comparisons at some point in the near future but for now I think the Zeus is certainly in the running for best ML2 integrated in my lounge room.
I love integrated amplifier themed Sundays, I really do.
I've had the Classe Sigma 2200i in use, and replaced it with the Zeus and found I liked the Zeus more and that's given me the motivation to go ahead and do some comparing.
The Zeus plays to several of the strengths of the ML2s, one is the smooth presentation, another is the deep feel that the background has and a third is the deep bass (but only if the amp is up to the task).  The Zeus does all of these things well.  The only thing I miss is the soundstage as (as I've said before) it is too big for the room once you give it some volume.  I am prepared to live with this as I consider it only a minor inconvenience.
The ATC SIA2-150 is a slightly faster sounding amp than the Zeus, slightly more focused on impact and slightly less on follow through (this is not a surprise at all when you look at the power comparison, 150 watts for the ATC and 250 watts for the Zeus, 20,000 uF filtering capacitance per channel for the ATC and 44,000 uF for the Zeus).  Also there is a bit more of an edge to the ATC, not really a hard edge more of a difficult-to-explain differently textured edge.  It works as a minor positive for some songs and a minor negative for others, it can add a little sparkle to piano and strings but it can also add a little bit of twang to steely guitar and brass.  Not a deal breaker, I could live with it, but in the longer term I'd probably be playing around with interconnects in an effort to either minimize it or better understand it.
The Sansui 907 NRA, when used via its "power amp direct" inputs (which are not actually power amp direct inputs as they still pass through a volume control) the sound is polite, pure and highly polished.  There is a bit less detail than the ATC but just as much presence, slightly less impact too but those vocals more than make up for it.  Vocals from the other amps were both very good but the NRA continues to dominate when playing hard sung vocals at high volumes.  There is a slightly less exciting feel to the NRA when compared to the other two amps but that polished, slightly laid back shine is just a joy to listen to.
When used via its integrated inputs the NRA gains detail and impact, this works well at lower volume levels but if you crank it up past about 10 o'clock it starts to get a bit peaky and harsh.  Too much gain in the system I expect.  I've only had it up to 3 o'clock via the "power amp direct" inputs but it doesn't get harsh at all, just louder, full bodied and amazing.
So which one is the winner?  Good question!
I'm leaning towards the Zeus as a general all round winner but if I get the urge to take an extra-long trip down female vocals lane I think I'd change over to the Sansui.  The ACT does not exactly disappoint, I've happily had it running in the system for a week or so prior to yesterday, but it does lose out (even if only just) on sheer power delivery to the Zeus and on the quality of the final finish to the Sansui.
So there you have it, Zeus first, Sansui 907 NRA second and ATC SIA2-150 third.  Close enough that if it was a horse race only the people seated on the finish line would have known who won without the assistance of a photo finish.
There is more to come, but it belongs elsewhere.
Edited by Cafad
The Zeus has actually got 8 of these 22000uf 100v caps in it. Total of 176000uf in the power supply. And another 2000uf each on the amplifier boards.
Terribly sorry, make that 88,000 uF filtering capacity per channel for the Zeus.  So almost 4.5 times the capacitance of the ATC, not 'only' 2.2 times.
I found your other topic about finding an integrated amp for the LS50's, Curious if you still have the LS50's and what would your opinion/recommendation be on an integrated amp second hand under $2k for the LS50's ?
Hey mate.  I'm afraid the LS-50's moved on over 12 months ago.  They had to eventually or the audio cycle of life could not continue.
If you've read the LS-50 thread then you'll know that several amps were stand out performers, two of my favourites being the Burson PI-160 and ME-240.
I've had a lot of overtime this last fortnight and much of it was spent sitting around waiting to be needed (yeah, it's sort of lucky because I get paid for it but it's dull as hell so I have a bit of a love/hate relationship with it) so of course I spent at least some of that time surfing ebay.  And I found this.
WWW.EBAY.COM.AU
Large output power: When class A output exceeds 20W, it will automatically extend to 200W Class AB to drive speakers, in order to maintain a very good state and offer better listening pleasure...
This looked interesting so I sent a link to my personal email address for later research and got on with being bored until I was required to do stuff.
Later I did some deep googling on it and started to get a little excited.  Here's a Chinese manufacturer that is making a high powered amp, supposedly based on an old Accuphase design, for a fairly reasonable price.  I needed to know more.  20 watts in class A prior to switching to class B and then on up to 200 watts, dual mono power supply and (although they only show pics of the power amp version) it was also available as an integrated.
I've felt my enthusiasm for amps decreasing markedly lately but this reignited it, I could feel my love of amps returning... until I found a post on amazon by the manufacturer.
That 20 watts in class A is total, so only 10 per channel, as is the 200 watts in class B, so only 100 per channel.  And, I expect, that means that the supposedly 800VA dual power supplies are actually only 400VA each.  That's reasonable, but not exactly special.  Also, the Accuphase amp that they claim to have copied the design of is actually quite different.  For one it's a MOSFET amp and this one isn't, it is also not a dual mono design and has a different number of output devices per channel.  That's enough info for me to develop a serious level of doubt regarding the manufacturers claim of "based on the design of".
They also claim to use Toshiba 2SA1943/2SC5200 transistor pairs, in my opinion these are one of the great audio products of recent years but they have also been out of production for a while now so these will most likely be copies, and given all the other info above I'm just not interested enough to buy one just so I can find out if it sounds decent or not.
So, one javelin to the chest later my love of amps (and of the audio industry in general) was in dire need of medical aid...  again!  I thought maybe this amp would be the one to get me back into the saddle (so to speak), but no, just another product that has been marketed in such a way as to make me throw up in my mouth a little.
Yes I know marketing serves a purpose in this world, I just wish it didn't.  I'm going to go and be cranky while I clean out my guttering now.  The cranky bit won't help, but maybe I can get it out of the way so I can be less cranky later.
@Cafad, maybe opening the front door, shouting " SANSUI FOREVER" three times will ease the mind, ohmmmmmmmmmmm.............
Edited by wen
Heh heh, and Accuphase have just released a new model, the E-800 integrated.
Mmm, 50w class A into 8ohms, doubling down to 1ohm,  etc. That 50w extends to 90w before it starts to clip...
And of course that's _each_ channel with _both_ channels driven.
Fully balanced from go to whoa (of course).
I'm salivating just writing about it 🤑🤑🤑.
How are the gutters? 😁
Yeah I saw the thread on that Accuphase, it does look nice.
The gutters are still full, it's hot and I'm not feeling that energetic.  Maybe next weekend...
Hot? Time to move to Cambodia for a reality check! 😂😆😎
Anywhere above body temp is hot, regardless of geography.
And I don't need to travel to be lazy, I can do that at home.
I think it's time to start the signing off on this little integrated amp tangent of mine.  Over the last 9 to 10 years I've been a bit of an overly enthused advocate for integrated amps.
I have been asked why on several occasions and my answer was basically why not.  Why would I not be more interested in a product that takes more effort to get right than separates?  It takes more skill to jam both a pre and  power section into the same chassis and not have them interfere with each other so why shouldn't I be interested in how various companies try to get it right.
And now that digital circuitry is often in the mix as well, that makes things even harder.  It can be done of course, just not by lazy engineers and not without putting in at least a little effort in the area of power supply separation and signal shielding.
Anyway, enough of that, I was starting to sign off.
Yeah, that's right guys, I've about had enough.
I still like integrated amps but my enthusiasm for the solo reviewing and comparing side of things is waning so I'm putting the whole voluntary reviewing thing to bed.
I'll probably still do one here and there (still have several on hand that I have yet to get around to, in fact) and I still have some work to do with Terry on the amp comparing front but for the most part, I'm done.
I hope all you SNA'ers have a happy and cheerful Christmas season and I  hope your family and friends take just enough interest in your hobbies to get you an album or T-shirt or some other audio themed pressie to unwrap on Christmas day.
Cheers Everybody.  And here's looking forward to the 2020's.
Thanks for your efforts have enjoyed reading your impressions.
i think you have done  very well to inform prospective integrated amp purchasers with insights at a grass roots level, the honesty and calibre of your reviews have been refreshing, i feel privilaged to have been part of this process and look forward to any further reviews. Hoping your 2020 is prosperous, cheers wen
@Cafad, a veritable wealth of information from your part mate. Shared unbiasedly with anyone who cares to read. Well done for your efforts. And thanks for your impressions.
Edit: you know you can never leave it alone. 😉
Edited by bob_m_54
insight
Guest Muon N'
Yes, you did really well, Cafad............remarkable commitment :thumb:
much appreciated,
your technical knowledge and approachability both how you went about the reviews and interactions with us all here
i got more out of a good read on your threads than most of the other sources out there on the subject
cheers! have a fab summer holiday
    • By DrMikeOz
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Wollongong State: New South Wales Payment Method: Paypal (buyer pays fees), EFT Reason for selling: quarantine upgrade fever Further information:
      Willsenton R8 tube amp - integrated amp, power amp and headphone amp.
      One of the new darlings of youtube audio reviewers and a very well made piece of Chi-fi!
      Takes KT88, EL34, 6CA7, KT77 or 6550 output tubes.  Specced with the optional PSVane EL34-PH output tubes.  Paid 2100AUD in April and arrived on my doorstep on May 5th 2020, so less than a month old. Save $400 and a significant wait as these things seem to be in high demand - price is firm 230V model Still have original box and outer box so no issues with Australia wide postage (est $50-80)
      More information here: https://www.china-hifi-audio.com/en/willsenton-tube-amplifier-c-77/willsenton-r8-kt88-el34-x4-tube-integrated-amp-power-amplifier-headphone-p-2268?zenid=6b48d2b2cedb2141b62d652c97b1fae7
      This in-depth review covers all the features well - i never thought i'd say this but read the comments as well to learn more about the headphone amp (supposed to be fantastic) and speaker pairings.
    • By Jing
      Item Condition: used Shipping Options: Pickup available but audition is not available. Suburb or Town: 3133 State: Victoria Payment Method: COD Reason for selling: too many amps Further information:
      This AMP was modified according to Richard McDonald by myself the year before last year when I had time playing with things.
      I think the mods result is very similar to the famous Hugh Dean Aksa 55, which, without wonder,  was a product by Richard and Hugh as you can read the story here.
      http://www.aesmelbourne.org.au/wp-content/media/THE AKSA STORY.pdf
      The  modified circuit shares high similarity with AKSA circuit, which is said to be the most tubey...
      Only difference is that A2760 is much better looking amp than a original AKSA 55 as you can see from the picture .   Aksa 55 amps don't have speaker protection circuits and kindof dual mono transformer either. And also, I used fancier capacitors such as metal films and Nichicon Muse series, etc.
      Anyway, I used it to drive my Yamaha NS1000M and did look anywhere else.
      I actually had two of them, with one added remote volume control, source select and even a phono stage as the retired preamp power supply is actual very good for addon things like those.
      This one has been my in my video shelf as AV amp, but now I have started to try surround system.
      These is also a VSPS, very simple phono stage, designed by RJM Audio to come with it or the next owner to play with it.
    • By Col1553552771
      Item Condition: Good Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Auckland State: New Zealand Payment Method: Paypal Reason for selling: System Overhaul Selling my beautiful New Audio Frontiers Supreme 300b Special Edition integrated amp. Has been lovingly cared for by an obsessive audiophile.
      Dead silent operation and has been 100% reliable since owning.
      Sweet sounding integrated with a gorgeous mid-range that the 300B tubes are known for with great dynamics and harmonic richness.
      Auto-bias and has been completely trouble free to own, and no preamp required.
      Currently the cheapest price I can find globally for a new model is 15,800 USD
      https://www.usatubeaudio.com/brand/new-audio-frontiers/
      Here’s a great review below from Clement Perry of Stereotimes and plenty more online.
      http://v2.stereotimes.com/post/new-audio-frontiers-supreme-300b-special-edition-integrated-amplifier/
      This amp also comes with an array of tubes as I have researched, and tube rolled the best options available. These include:
      1 x pair ECC83 TESLA (not new JJ) – These are the framed grid tesla that come out of the same factory as the famed Telefunken ECC803S. I was recommended these by the NAF agent in Germany. Amazing harmonics with a dark juicy sound. 1 x pair ECC83 Telefunken (original boxes) – Huge dynamics with a very linear sound. My preferred ECC83 currently.  1 x pair ECC83 – Original Yugoslavian pair that came with the amp 1 x pair 5687 RCA – Tung-Sol Black Grid 2 x pair (one unused) of the Sperry Raytheon 5687 tube. These are my firm favourites, huge soundstage and very dynamic. I liked them so much I purchased another pair 300B – 4 x matched TJ Full Music Tubes – These have been in use for the past 5 years. No issues and still going stronG. I also have 4 of the standard 300B tubes the amp came with,  these can’t be guaranteed however will include with amp
      This is the 230v model.
      Amp will be sent in original packaging and comes with remote.
    • By PRAGON
      Item Condition: New in box Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Sunnybank hills State: Queensland Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Need money Further information:
      Marantz PM-KI Ruby Ken Ishiwata Signature Reference Integrated Amplifier in GOLD
      This is one set Brand New Marantz PM-KI Ruby Ken Ishiwata Signature Reference Integrated Amplifier in Gold Panel. MADE IN JAPAN in 230V.
      Marantz has been designing and making amplifiers for more than 65 years, and for 40 of those the products have reflected expertise of Ken Ishiwata. Now, to mark his four decades with the company, the PM-KI Ruby amplifier has been developed and tuned by a highly experienced engineering team led by KI himself. . Features a fully discrete two-stage design with separate power supplies for the pre-amplifier and power amp — plus, a moving coil/moving magnet phono stage complete with Marantz Musical Premium Phono EQ circuit and Marantz HDAM technology for signal purity and exceptional audio quality. PM-KI Ruby is built on a vibration-resistant double layer chassis with thick aluminum panes for rigidity and features a laser-engraved Ken Ishiwata signature to commemorate his legacy.
      Key Features
      Engineered and extensively tuned legendary Marantz sound master Ken Ishiwata and his team, drawing on more than 65 years of Marantz amplifier design knowledge
      Marantz high-resolution preamplifier stage with proprietary HDAM technology
      Switching power amplifier design derived from flagship PM-10 amplifier
      Generous output: 100W 100W (into 8ohm), 200W 200W (4ohm)
      Fully-discrete, two-stage design for signal purity, with separate power supplies for preamp and power amplifier sections to reduce interference
      Toroidal transformer dedicated to preamp for clarity and powerful sound
      Current feedback design with newly-developed wide-range circuitry
      HDAM® SA3 circuitry for clean signal and optimal dynamics
      MM/MC Phono input with new discrete Marantz Musical Premium Phono EQ circuit
      Thick nickel-plated copper independent input terminals for CD and Phono, plus Marantz-original high-quality/high-purity copper-plated speaker terminals
      Linear volume control with new electric volume system
      High-quality construction with double-layer chassis, 5mm thick aluminum top lid, solid aluminum front and copper-plated chassis
      High-grade, carefully selected audio parts: ultra-low leak current Schottky diodes, low noise complementary transistors, high-grade resistors, newly developed custom electrolytic capacitors, audio grade film capacitors and mica capacitors.
      Laser-engraved Ken Ishiwata signature and Ruby motif, marking Ishiwata’s 40-year Marantz legacy
      Celebrating 40 Years of Passion
      Designed to celebrate the 40-year anniversary of legendary Marantz sound master, Ken Ishiwata, PM-KI Ruby features pinnacle performance that’s synonymous with Marantz excellence. Complete with thoughtful engineering, painstaking tuning and extensive listening sessions, PM-KI Ruby achieves the elevated output worthy of its name. Elegantly shows Ishiwata’s laser-engraved signature to commemorate the design and heightened listening experience that honors the decades-long partnership between him and Marantz.
      Extensive Sound Tuning
      Led by Ken Ishiwata’s extensive, meticulous approach to tuning, the larger Marantz engineering team applied more than 65 years of experience and HiFi knowledge to create PM-KI Ruby, resulting in a final product that is a testament to Ken Ishiwata and the Marantz legacy.
      Marantz HDAM Technology
      Marantz developed its own discrete circuit boards called Hyper-Dynamic Amplifier Modules, or HDAMs, to replace the chip-based amps used elsewhere. Using discrete surface mount components with short mirror-image left and right signal paths, HDAMs outperform the regular integrated Op-amps dramatically in Slew Rate and noise level. The result is much more dynamic, accurate and detailed sound. Over the years, Marantz has developed different HDAMs to fit the particular requirements of players and amplifiers. The PM-KI Ruby uses the latest high-grade SA3 version. Combined with optimized circuit design layout and carefully selected components, the PM-KI Ruby provides exceptional sound quality and performance.
      Designed to deliver optimal sound quality by simplifying the signal path, the Marantz Musical Premium Phono EQ stage in the PM-KI-Ruby amplifier can be used with both moving magnet and low-output moving coil cartridges, thanks to a built-in MC head amplifier. Distortion is reduced by using two-stage amplification in the phono stage, and Marantz HDAMs are combined with JFETs (junction gate field effect transistors) in the input stage, giving high input impedance. The exclusion of coupling capacitors further simplifies the design, reducing signal distortion and enhances signal purity.
      High Quality Volume Control
      Newly developed electric volume control uses the latest volume control IC to realize better channel separation, dynamic range and distortion-reduction, while retaining the operational feel of an analog volume control device. The amplifier employs new Marantz-designed electric volume control for high linearity and best-in-class channel separation.
      Current Feedback Amplifier
      Current Feedback amplification is a well-known, Marantz-original circuit technology, thoughtfully designed to match the requirements of Super Audio hi-res music for wide-bandwidth, high-speed reproduction. The impedance at the Current Feedback point is limited, generating a very low phase shift. Marantz Current Feedback amplifiers reduce the need for phase compensation by minimizing Negative Feedback (NFB). This simplifies the signal path and results in a high through-rate, excellent transient response and superb sonic transparency across the full bandwidth. Unlike conventional Voltage Feedback topology, Current Feedback also makes the power amplifier insensitive to difficult loudspeaker loads.
      Balanced Power Amplification
      Drawing on design elements of the PM-10, the PM-KI Ruby is built to leverage enhancements, maintain the purest possible sound and support the power needed to drive the most demanding speakers. The amplifier output stage of the PM-KI Ruby allows a large power output, delivering 2x100W into an 8ohm load, and easily copes with high-impedance speakers thanks to a 2x200W output into 4ohms. The amplifier module connects directly to the rear panel PCB on the PM-KI Ruby to maintain signal purity and sound stability.
      Pure Analog Design
      The purely analog design of the PM-KI Ruby contributes to its noise-reduction structure and clean build. Rather than build the DAC into the amplifier, which would add noise within the chassis, Marantz built the PM-KI Ruby without one and then implemented the DAC in the SA-KI Ruby Super Audio CD Player. This eliminated interference with the delicate analog signals passing through the amp, maintaining an analog environment that’s as pure and clean as possible.
      Carefully Selected Components
      Marantz has a steadfast reputation for choosing the best-possible components for its Premium Series products. The Marantz alternative to the “amplifier on a chip” IC components, the HDAM, is a miniature amplifier module built entirely of discrete components. Marantz engineers selected and optimized the HDAM through extensive listening in dedicated Marantz facilities in Europe and Japan. Extensive, painstaking and meticulous tuning has long been the secret of exquisite-sounding Marantz amplifiers. During the development stage, every part is carefully selected, tested and validated by Marantz audio engineers to ensure audio perfection every time you listen.
      Multiple Analog Inputs and Outputs
      In addition to phono and CD analog inputs, the PM-KI Ruby features two line-level inputs and two pairs of recorder input/output jacks that enable the connection of multiple sources and recorders. Use the PM-KI Ruby as a standalone stereo power amplifier for additional system configuration versatility with the included power amp input, or connect the PM-KI Ruby to an external power amplifier via the stereo pre-amp outputs.
    • By Tom Dougherty
      Item Condition: Good used condition, in original box. Remote, power cord and manual included. Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Adelaide State: South Australia Payment Method: Paypal, EFT, cash on pickup Reason for selling: Upgraded to new amplifier Further information:
      Purchased brand new in 2010. Was used as my main amplifier for 3 years before upgrading to a more powerful amplifier (for new speakers).
      Kept in storage in original box ever since, I intended to use it for a second system but with first child on the way I have decided to part ways with it.
      Brilliant 40Wpc (into 8 ohms or 55Wpc into 4 ohms) amplifier.
      This got some great reviews when they were released:
      https://www.stereophile.com/integratedamps/marantz_pm5003_integrated_amplifier/index.html
      Postage can be arranged.
      Note: Listed elsewhere
