gourmetsaint
Sony STRDB2000 Receiver
I have been offer a Sony STRDB2000 receiver for $600 (new). Should I take it?
Key features
120W x 6 Surround Mode
120W x 2 Stereo Mode
Dolby Pro Logic II Decoding
Dolby Digital EX and DTS-ES Decoders Built-In
DTS NEO:6
DTS 96/24
6 Channel Digital Signal Processing with 9 Acoustic Environments
32-Bit DSP (Digital Signal Processing)
Sony's Exclusive Digital Cinema Soundâ„¢ System (6 Modes)
Multi brand Pre-Programmed Remote Control
Component Video switching
Composite Video switching
Electronic Bass and Treble Controls
Balance Control
Headphone Jack
30 AM / FM Station Presets
Station & Input Naming
Speakers A ,B A+B switching
Subwoofer Output
RS232 Control Port
Speaker binding posts (speakers A)
Available in Black and Silver
Audio Features
Surround Mode: 120W x 6, 8 Ohms, 1kHz, 0.7% THD
Stereo Mode: Stereo Mode: 120W x 2, 8 Ohms, 20-20,000 Hz, 0.09% THD
S Master Pro Digital Amplifier:
Dolby Pro Logic II Decoding:
Interfaces
Total of 9 connectable sources & Phono stage: Yes
Front AV & Optical Input: Yes
Component Video switching : Yes
DTS 96/24:
32-Bit DSP (Digital Signal Processing) :
Composite Video switching: Yes
S Video switching: Yes
Tape loops: x 4
5.1 channel analogue input: x 1
6.1 channel analogue input: x 1
Optical Digital Inputs : x 3
Coaxial Digital Input: x 1
Optical digital output: X 1
Subwoofer Output : Yes
I have only just started on these forums as well and am finding it hard to get much of a reply.
In reference to your Sony Reciever for $600.
It depends what you want to run with it how big the room is and how much you are concerned about the sound quality.
The Sony, Pioneer's tend to be well over rated when it comes to Watts and they tend to distort at higher volumes, compared to a dedicated amplifier or A Denon or Rotel or higher end Receiver.
Don't take to much notice of Watts as the difference between 120watts and 100watts is only about 1.5db, which unless you have a great ear is not really noticeable. The other thing is that the Sony will be prety bright at the top end when playing 2 channel music, it will be quite noticeable up against a dedicated Amplifier.
It also depends on how big your room is, what sort of speakers you are using, whether you want a 2 cahnnel for just CDs or full 6.1 surround for movies?
The main thing is and for me too, is how much is your buddget is and what are your plans for the system in the future.
Compatiability
Pre outs for separate amps
HDMI (which I don't think is that important)
Room size
How many speakers
What sort of speakers
Movies, CD's %
YOu may be able to get a Denon for a $1000 if your budget allows and the difference will be very noticeable, even a 2 channel AMP could be an option for that sort of money.
Just my 2cents worth. Now I hope to get some answers on my question.
Philo
Sorry Gourmet, didn't answer because I have no experience of that model.
and i wouldnt buy sony at any price..... after two efforts with them the first they couldnt fix and wouldnt replace and the second 1, month out of warranty parted company with this earth. i tell EVERYONE that will listen that i think SONY is shiet.... but that is just my opinion
80% Music, 20% HT
Digital HD set top box (Coaxial connection), 5 carousel Yamaha DVD player (optical connection).
2 x Wharfedale 2 way towers for front.
80W small centre, RR and LR.
Home made subwoofer/coffee table - audiophile design (see http://www.gourmetsaint.com.au/Subwoofer)
Large open-plan room.
Mark
I would try and get something like a cheaper Denon or Yamaha and completely forget about the Sony, but that's me.
You have some good Wharfedale speakers there, they need to be heard, so you may have to bite the bullet and spend a little more on a receiver, or a dedicated Amplifier, which would be much better, but that would cost a little more.
You could possibly take your speakers into a Home theatre shop and try a few of the Receivers and find out what sounds best for your budget. You will find most of the major Home theatre places will not stock Sony receivers.
Good luck with your system and let us know what you end up doing?
Philo
You have a couple of conflicting requirements here.
If your nominated split of 80% music and 20% HT is accurate then the receiver will be a significant comprimise over a dedicated 2 channel amp in terms of music output quality.
If $600 is all you have to spend and want/need the HT functions then the Sony is probably a reasonable value for money receiver. The other options at entry level would be Yamaha 457 and pioneer.
If you want a HT receiver that sounds better at music, then you probably need to spend a bit more and look at Denon, Marantz and HK.
All IMHO of course
Key features
DTS NEO:6
DTS 96/24
Sony's Exclusive Digital Cinema Sound™ System (6 Modes)
Balance Control
Headphone Jack
Subwoofer Output
RS232 Control Port
Audio Features
Interfaces
DTS 96/24:
Tape loops: x 4
NO!
Sorry to be so blunt,but for a little more outlay-{Keep a upgrade stash,I do,you never know what will turn up at either the forums -for sale threads-or Ebay} you could get an upsampling video unit-then all your outmoded video gear can be fed IN via component to any NEW display without having to change cables}
Or-Question-How long do you intend to use the proposed unit for?
Is it just a stop gap purchase till funds allow?
What is your proposed path of upgrade going to be over-say the next 2 years-Video?,Audio?
When thinking about a purchase of an AV amp,it's best to factor in any sort of upgrade path,just so you don't sell yourself short,technology wise.
Well I trialled the Sony STRDB2000 and am happy with it. Musically it's quite good and the digital amp delivers well. For $600 I cannot complain and it looks like my old receiver will get nearly $300 on eBay - so cheap upgrade.
Since upgrading to the DB2000 I have also upgraded the speaker cables (420 strand 12 AWG OFC) to all speakers (including biwired Wharfedale fronts).
I also managed to pick up a pair of matching Wharfedale bipolar HT rear speakers on eBay which are much better than old cheapies.
I'm on the lookout for a matching Wharfedale centre now to complete the work. WAF is intact too.
Mark
