betty boop
Marantz 2015 AV processors
got an notification of upgrade available tonight ...which I accepted..34 min and all went without issue. apparently minor bug fix ups etc...what ever they might have been.
also notification for auro 3D popped up available as "add a feature"
http://www.auro-3d.com/blog/denon-and-marantz-to-support-auro-3d-upgrade-available-in-december/
http://upgrade.marantz.eu/eu/marantz/pages/upgradedetails.aspx?uid=auro3d5
but I might hold off on that for now :)
Guest Sime
My 8801 has never been firmware upgraded, don't get it hooked up to the network.
I would recommend doing the FW upgrade for the 8801. One of the benefits is an enhanced surround experience. I noticed it on my 4520 and as an owner of the 8801 which already had it when I bought it  other forum owners had noticed exponential improvements in multi channel performance.
Guest Sime
What firmware version do you have?
Mine 8801 was purchased in Jan.
Firmware version 3525-8853-5400
Guest Sime
Ok thanks, I've got 3325-3843-4420
Is it as simple as hooking it up to the network and it upgrading itself?
If like the maranta 8802 and if you have update notification turned on. Hooked upto the network,on switching on it will come up with available updates. Matter if just accepting by saying ok. Can take 30min or so an update :)
Guest Sime
Ok, I'll have to take it out of the caravan and wire it up to the router in the house.
Correct Provided notification option turned on
But you can prompt it by Set up Menu> General>Firmware>Update>Check for update
Guest Sime
Thanks, I saw it on by default.
Edited by Sime
or run a long cable :)
Have done the auro 3D update, just matter of buying the license via the portal, paying via paypal. and that registers your unit.
I then switched on my 8802 and it automatically said I had the update for auro3D I said ok and was done in 35 min or so. havent had a chance to play with but option definitely there to upmix with auro3D now...looking forward to experiencing particularly with 2.0 material either TV or music as to how upmixes to 7.1 :)
Great to read Al and that your enjoying the "frontier" tech :)
ok time for some very early first impressions...
The marantz has none of that with subs theres really only one choice LFE or LFE+main. With LFE +main suggested for 2.0 cpm material. Theres no way to setup 3 subs for instance with 2 as L & R sub and one for LFE only as you can on the denon. Now this isn't an issue for me as purely intend using marantz for AV but for others planning on stereo use this might be of concern (usual caveats of there is no such things as stereo subs etC
Thats very disappointing about the sub config. I had a Marantz SR-18 years back and it's config options for the sub were the same. No progress in 15 years? I found it very irritating and I didn't go Marantz when the SR-18 died because of this limitation. Don't understand why you would make a supposedly top shelf pre/ pro with such an important constraint. IMO Subs are hard to get right so you need more flexibility with the sub than any other channel. Maybe they just think audessy will fix it? Unimpressed - so just as well I am happy with my old 4308.
Edited by Steam
the denon avp-a1hd has a massive amount of flexibility for subs as I indicated earlier. but the marantz 8802 doesn't quite follow in that vein. am unaware of any other processor on the market currently any better. but who knows whether this is a priority for makers or not. the focus as I see it for subs definitely seems in the LFE/av or plain 2ch (non stereo subs) which will probably satisfy most bu unlikely all..
hehe how cool is this …to see the final assembly and testing of the marantz av8802
as per the US dealer who posted it,
"Here is a recent short video inside of the Marantz production facility in Japan. The workers are putting together the 8802A (HDCP2.2)"
also confirmation from him on hdmi 2.0(a)
"A few customers were concerned that the brand new AV8802A would not support HDMI2.0(a). I'm specifically addressing the version (a) on this post.
In short, the answer is YES. That is because the 8802 hardware/chipset supports HDMI ver.2.0a, rec.2020 and HDR. HDR or High Dynamic Range is tech talk for the highly touted new 4K UHD TVs. HDMI2.0(a) will also be featured in the future Ultra HD Blu-ray hardware.
What I can verify though Marantz's head product guy who is in charge of the 8802 is that the 8802A's boards factually passes signals via a test signal generator. HOWEVER, there is no capability to test real world source and displays today because they do not exist yet. Therefore, the 8802 may need some firmware fixing once these real world products start to ship.
In short, the AV8802A supports HDMI2.0(a).biggrin.gif"
Guest Sime
Awesome.
I want those swivel shelves in my entertainment cabinet...that would be cool!
What's the plan with your current Denon, I assume your probably going to sell it, how does the Marantz compare to the Denon for general usability and overall sound quality especially for 2ch music assuming you are not using a dedicated 2ch pre.
JDH
Purchased my AV8801 9 months ago. Loving it, but interested to hear the new models. I'm kinda wishing I waited now. Buggar. Might have to check out the AV7702 and trade in.
JDH
hi JDH, check my post earlier in the thread, I posted an extensive early impressions. probably not much more to post on that as a further update, probably not for the next month or two :) at this stage the denon not going anyplace. just not in a position to say any further one way or the other with regard the marantz vs canon avp, thats all, dont read any more into it :)
I know some have traded the 8801 to 7702. I personally dont see this as a good move, if upgrading from the 8801 go the 8802 as the 8802 is THE only future proofed processor at the moment. with marantz's commitment to make sure they have an upgrade for it for the new 4k blu-ray format thats to be launched in matter of months. so at end of it comes down to whether want something future proofed...as future proofed as things can be right now :)
Guest Sime
I'd like a future proofed Processor, especially for my TV, but being as I live in a caravan, and the biggest TV I could stretch to is 46inches, I dare say I'll be wating quite awhile till a 42-46 UHD TV comes out.
size will be a factor if wanting 4K, unless sitting close enough to resolve. but I dare say the other benefits of UHD with the e.g. wider colour gamut and wider dynamic range is likely what people will be chasing and I dare say will be quite apparent even if cant resolve 4k :)
Hi all. Besides atmos and 3d. Where everyone is saying the sound is that much better, are we talking about in a lab bench
??? I've heard a few higher end pre amps Costing many times more, and could not say they sounded better, more so, sounded different, which at the end of the day is a personal preference only, not of one being better than the other.
    • By Battler009
      Price: $1000 Item Condition: Excellent Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Sutherland Shire State: New South Wales Payment Method: Cash, EFT Reason for selling: Upgrading This pre-amp / processor requires very little introduction. Was Marantz flagship processor and supports the recent codec, such as DTS-HD MA and Dolby True HD. Has the ability to map height or width channels however it doesn't support the latest Atmos, Auto & DTS-X object sounds.
      I have the original box and Auddessy mic, remote is working, but isn't perfect, however I have always controlled the unit via Marantz App.
      Will serve someone looking for a great experience with surround / 2 channel sound not looking to move into the new object audio.
      Note supports both XLR and RCA connectivity which can be mixed based on your configuration. Also offers 2 channels for subwoofer connections and eq.
      I do have the original box, my preference is pickup, but will ship if new owner is willing to pay arrange / pay courier and take risk of shipping damage
      While I have requested $1000 I would also be open to a straight swap for a panasonic DP-UB9000 4K player
    • By Battler009
      Price: $1000 Item Condition: Excellent Shipping Options: Pickup is available Suburb or Town: Sutherland Shire State: New South Wales Payment Method: EFT or Cash on Pickup or swap Reason for selling: Upgrading Further information: This pre-amp / processor requires very little introduction. Was Marantz flagship processor and supports the recent codec, such as DTS-HD MA and Dolby True HD. Has the ability to map height or width channels however it doesn't support the latest Atmos, Auto & DTS-X object sounds.
      I do have the original box, but would prefer not to ship it.
      While I have requested $1200 I would also be open to a straight swap for a panasonic DP-UB9000 4K player
    • By thejt
      Price: $825 Item Condition: Excellent Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: noranda State: Western Australia Payment Method: Cash, EFT Reason for selling: Surplus to needs Further information:
      I picked this off another member not long ago (absolute gentlemen!) but after getting my Rotel RX-802 recapped it is 75% of what I need for the 5% of time I can listen to anything. I can verify that the reviews are accurate, this is a lush full sounding amp. The unit has a very premium look and feel. The controls are weighted and switching has a solid reassuring click that is oddly pleasurable. Copper chassis and just about the nicest speaker terminals I have ever seen are icing on the cake. Just asking for what I paid which I think was a bargain. Has manual and remote. Pick up is preferable.
    • By craka
      Price: $390 Item Condition: New in box Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Brisbane State: Queensland Payment Method: Cash on pick up,Paypal+3%,Bank deposit Reason for selling: I have to much Gear and a number of streamers Further information:This NA6005 IS Silver in colour,I used this in my system for a very short time and it went back into its box.Its is as new. Price is Plus Postage.
      This NA6005 IS Silver in colour,Ive used this in my system for a very short time  and it went back into its box.Its is as new.
    • By Lego Man
      Item: MARANTZ ND8006 Network CD player
      Price: $1400
      Item Condition: As new
      Payment Method: Pickup - Cash | Shipping - PayPal (F&F) or bank transfer.
       This CD network player is in excellent condition being only 18 months old and is still covered by manufacturers warranty. It's easy to use with HEOS built in allowing you to stream music directly into your system - you can even use it as a preamplifier!
      Any questions let me know.
