betty boop
Marantz 2015 AV processors
I'm sure the 8802A being in the list isn't out of the goodness of their heart. It's because they are still trying to sell them today. The 8805A won't be here till next year.
Actually the jury was already in about HDCP2.2/HDMI2.0 - some vendors offered HDCP2.2 and HDMI2.0 but limited to 10Gbps. Others like Marantz offered full 18Gbps but without HDCP2.2 - back when the 8802 was released.
As kazz linked to on dtv, looks like D&M have decided to make available the DV update to ALL 2015 avrs and av processors. Good on em ! :)
Originally Posted by Schwa
At the bottom of Scott Wilkinson's article about Dolby Vision he claims that the 2015 D+M receivers will eventually get updates to allow DV & HLG passthrough. Does he know something we don't?
Quote:
Originally Posted by Mashie Saldana
I spotted that too, my guess is fat fingers unfortunately, would be nice if true though.
Strange though that he would list all of the 2015 D+M models separately though so I contacted my D+M rep and it turns out that yes, they have decided to update all of the 2015 D+M models with the DV + HLG update as well.
Ok, iam slow with this stuff. What is dv and hlg and why do we need it?
Really more for flat panel market or eg  if run dual screens like I do
Dolby vision don't need for projector :)
hlg
https://en.m.wikipedia.org/wiki/Hybrid_Log-Gamma
Only application is BBC streaming and only limit use
maybe for projectors but our jvc don't support
by the way, noted an update available this evening
for
"better performance and stability"
takes about 21 min and have just applied. all good.
Note from jd over on Avs no doubt our update locally should be around same time or slightly after would think :)
Dolby Vision and HLG update to be released
This update has been confirmed to be released to the AV8802A and X7200WA March 2018.
wow had this come up on the marantz with a firmware update available !
as per above as promised they have come through in march with the Dolby vision and HLG update
is that it a firmware update ?  I was seriously thinking need to take the unit in and have to pay for a update or something.
but no its here thats it. a 20min update. and what is a 3 year old unit in a av8802a is now bang upto current spec. just like that
the gift that keeps on giving literally... even after being superseded :D
marantz I am super impressed !
A bit late in the game, but I picked up my new Marantz AV8802a from a Sydney HiFi dealer today at a reasonably compelling price. I’ve upgraded from my 6 year old Rotel RSP1572 AV pre-amp.
The Marantz should give me an opportunity to try Atmos surround, My current setup is 5.2 surround, likely will transition to 5.2.4 I’m also currently using a DSPeaker anti mode 2.0 to EQ. My dual subs, will eventually compare it to the Marantz inbuilt speaker EQ. And decide which one I’ll continue to use.
Setup includes Paradigm Signiture v3 speakers, Elektra Audio 7ch HD2 and 2ch HD Reference Amps and an Oppo 205, using a 70in LED TV for general viewing and future 4K projector to replace an existing Epson 720P projector is still undecided.
Apparantly there is is only one remaining new AV8802a with the Aust. distributor to buy, after it is gone it will be the AV8805 or runout AV7703 or new AV7704 which I also considered before deciding to go with the AV8802a
JDH
Edited by jdh500
Typos
Hey guys,
I’ve got a marantz SR7010 and using Krix Neuphonix, Epicentrix and Dynamix speakers. I am using an Anthem PVA 5 for the front 3 and side surrounds so the Marantz is only powering the rear surrounds. It is repeatedly turning itself off and flashing red every half a second or so. I have changed the ohm setting to 6 ohm and to get it loud enough for me i am having to turn it up to about 70 or so. Is that too loud? Is t underpowered for my speakers? Unsure on what is going on. Have I done something wrong in the process?
Thanks Cameron
Check for:
Wiring shorts at AVR and speaker connections, especially stray wire filaments - also check for wire damage from pets chewing etc
Is the AVR adequately ventilated
Are the surrounds set to small in set-up and crossover set to suitable level e.g. 80Hz
Otherwise sounds like a warranty job.
Thanks quark,
I have 2 of these one for the home theatre and one for the rest of the house so may try to switch them. I only installed yesterday so no chewing and all connectors are bannana plugs that i terminated recently. Have checked and none touching. Ventilation is very good the unit isn’t getting hot. I’m unsure on the crossover and size set so will check that aswell. Should i have to have the volume so high?
Thanks again
Edited by Camo1151990
7 hours ago, Camo1151990 said:
Thanks quark,
Thanks again
The 6 Ohm setting works by reducing power, so that may be part of the issue with the volume needing to be so high.
My recollection is that the Mk1 Neuphonix wasn't a very efficient speaker (Mk11 less so), so again may be part of the issue.
Setting the surrounds to small and the crossover correctly is vital - if you overdrive the surrounds at bass frequencies the bass drivers may have shorting rings to protect them - that will trip your AVR. I had the same issue when some visitors played with my crossover settings and sent a full range of frequencies to my surrounds causing my elektra amp to trip on bass heavy material.
Also, once you have this sorted, get rid of the 6 Ohm setting unless you're the type who gets tipsy and turns the volume up to 11.
Thanks again Quark,
I ended up swapping amplifiers and putting my second one on the theatre and set it all up the same. Watched a movie and had no issues. So I think it may be the reciever itself. I’ll test it again and see how i go. Thanks again
Hey guys,
I have an issue with my HDMI Out on my Marantz SR7010. I decided to clean up my AV cupboard and moved around my recievers and afterwards i am getting no HDMI Out at all. It was going through a HDBaseT from Blustream and thought it was that so attempted to my Samsung tv and still nothing. I have tried a Reset and says it is on the setup screen but I have no picture to do anything. Any ideas what could be wrong with it? Anywhere else to go now. I was getting sound out but now I have factory reset i now have nothing at all just the setup assistant.
Please help finally sat down after working in there all day and this happens.
Thankyou in advance.
Cameron Sampson
You have 3 hdmi outs Cameron ; one has ARC so maybe CEC issues ;  try the other one and if that's no good try another hdmi cable  ;) Some one with a Marantz should know more .
Thanks mate,
I have tried all 3 and 3 seperate HDMI Cables. All of which work with other devices. Only thing I could think of is the HDMI board has gone bung but no idea on how to test that theory.
Finally got Monitor 2 to work. But that won’t work with my blustream. Can’t get monitor one with arc to work but that wouldn’t bother me aslong as i could get it to thw projector. Thanks for your help mate.
    • By Battler009
      Price: $800 Item Condition: Excellent Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Sutherland Shire State: New South Wales Payment Method: Cash, EFT Reason for selling: Upgrading This pre-amp / processor requires very little introduction. Was Marantz flagship processor and supports the recent codec, such as DTS-HD MA and Dolby True HD. Has the ability to map height or width channels however it doesn't support the latest Atmos, Auto & DTS-X object sounds.
      I have the original box and Auddessy mic, remote is working, but isn't perfect, however I have always controlled the unit via Marantz App.
      Will serve someone looking for a great experience with surround / 2 channel sound not looking to move into the new object audio.
      Note supports both XLR and RCA connectivity which can be mixed based on your configuration. Also offers 2 channels for subwoofer connections and eq.
      I do have the original box, my preference is pickup, but will ship if new owner is willing to pay arrange / pay courier and take risk of shipping damage
      While I have requested $800 I would also be open to a straight swap for a panasonic DP-UB9000 4K player
    • By Battler009
      Price: $1000 Item Condition: Excellent Shipping Options: Pickup is available Suburb or Town: Sutherland Shire State: New South Wales Payment Method: EFT or Cash on Pickup or swap Reason for selling: Upgrading Further information: This pre-amp / processor requires very little introduction. Was Marantz flagship processor and supports the recent codec, such as DTS-HD MA and Dolby True HD. Has the ability to map height or width channels however it doesn't support the latest Atmos, Auto & DTS-X object sounds.
      I do have the original box, but would prefer not to ship it.
      While I have requested $1200 I would also be open to a straight swap for a panasonic DP-UB9000 4K player
    • By thejt
      Price: $825 Item Condition: Excellent Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: noranda State: Western Australia Payment Method: Cash, EFT Reason for selling: Surplus to needs Further information:
      I picked this off another member not long ago (absolute gentlemen!) but after getting my Rotel RX-802 recapped it is 75% of what I need for the 5% of time I can listen to anything. I can verify that the reviews are accurate, this is a lush full sounding amp. The unit has a very premium look and feel. The controls are weighted and switching has a solid reassuring click that is oddly pleasurable. Copper chassis and just about the nicest speaker terminals I have ever seen are icing on the cake. Just asking for what I paid which I think was a bargain. Has manual and remote. Pick up is preferable.
    • By craka
      Price: $390 Item Condition: New in box Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Brisbane State: Queensland Payment Method: Cash on pick up,Paypal+3%,Bank deposit Reason for selling: I have to much Gear and a number of streamers Further information:This NA6005 IS Silver in colour,I used this in my system for a very short time and it went back into its box.Its is as new. Price is Plus Postage.
      This NA6005 IS Silver in colour,Ive used this in my system for a very short time  and it went back into its box.Its is as new.
    • By Lego Man
      Item: MARANTZ ND8006 Network CD player
      Price: $1400
      Item Condition: As new
      Payment Method: Pickup - Cash | Shipping - PayPal (F&F) or bank transfer.
       This CD network player is in excellent condition being only 18 months old and is still covered by manufacturers warranty. It's easy to use with HEOS built in allowing you to stream music directly into your system - you can even use it as a preamplifier!
      Any questions let me know.
