Sansui77 1,544 Posted October 19, 2020 Author Share Posted October 19, 2020 On 26/09/2020 at 7:09 PM, Luc said: Got any blacker? 😉 Black faced Sansui's..... I do 😉 Link to post Share on other sites
pete_mac 3,987 Posted October 19, 2020 Share Posted October 19, 2020 (edited) If you intend to use the 517 as a preamp, you can use either option as these options only apply to the "power amp in" connections when using the amplifier as a power amplifier. The "Capacitor Coupled" setting sits two small capacitors in the signal path to remove the DC before the signal reaches the amplifier circuit. This is mainly relevant if the pre-amplifier or source has DC voltage on the output, which could trigger the 517's power amp protection circuit, or result in excessive DC at the amplifier's output. The "Direct Coupled" setting connects the pre-amplifier or source directly to the amplifier circuit. The snips from the user manual below may help, and this diagram below might help if you are schematically inclined. The red arrows indicate the signal path flow, S01a is the connected/separated switch on the rear panel, and the two 'eyes' in the top left of the diagram are the RCA input and output connections. Edited October 19, 2020 by pete_mac 6 Link to post Share on other sites
Luc 10,155 Posted October 21, 2020 Share Posted October 21, 2020 On 19/10/2020 at 7:40 PM, Sansui77 said: Black faced Sansui's..... I do 😉 I've seen the pics😎...lovely lovely things! Link to post Share on other sites
sloper 495 Posted October 21, 2020 Share Posted October 21, 2020 Goodaye all Summer is here and we are locked down locked down, been working in the carport instead of the garage. No Sansui, just a old Onkyo and Tannoy speakers on the decking. Having bad thoughts (again) need another Sansui and dont have a spare, there all in use. So need another one, will be out on the decking so dont want to put a big $$$ one there, but l could shuffle others. Could there be better in summer drinking beer and playing tunes for the whole neighbourhood. At least thats all we are allowed to do. As for emans 517 recapp it and then see how you feel about using it as a preamp. regards Bruce 1 Link to post Share on other sites
eman 1,249 Posted October 21, 2020 Share Posted October 21, 2020 1 hour ago, sloper said: Goodaye ....... As for emans 517 recapp it and then see how you feel about using it as a preamp. regards Bruce I've a few problems with doing that. Only possible if there's someone who can do it in Canberra and pickup and deliver. Link to post Share on other sites
eman 1,249 Posted November 15, 2020 Share Posted November 15, 2020 Well that didn't last long. I've used this AU 517 for less than 6 months and the left channel has stuffed up on speakers A & B. I'm presuming it's something on the output side. Was thinking of using it as a pre amp anyway and I've got a custom hybrid Tube/D class integrated on the way too. Watch this space for a possible Sansui AU 517 sale, (especially if you're in Canberra ). Link to post Share on other sites
muon* 2,713 Posted November 15, 2020 Share Posted November 15, 2020 39 minutes ago, eman said: Well that didn't last long. I've used this AU 517 for less than 6 months and the left channel has stuffed up on speakers A & B. I'm presuming it's something on the output side. Was thinking of using it as a pre amp anyway and I've got a custom hybrid Tube/D class integrated on the way too. Watch this space for a possible Sansui AU 517 sale, (especially if you're in Canberra ). It's definitely worth getting fixed. Has it been recapped ect? Link to post Share on other sites
eman 1,249 Posted November 15, 2020 Share Posted November 15, 2020 6 hours ago, muon* said: It's definitely worth getting fixed. Has it been recapped ect? Pretty sure it's all original. Only got it this year. So it might be mate, but I've got mobility issues so I won't be hauling this around town to post it somewhere. If someone in Canberra can pick up and deliver it might get done, otherwise .... Link to post Share on other sites
pete_mac 3,987 Posted November 15, 2020 Share Posted November 15, 2020 8 hours ago, eman said: Well that didn't last long. I've used this AU 517 for less than 6 months and the left channel has stuffed up on speakers A & B. I'm presuming it's something on the output side. Was thinking of using it as a pre amp anyway and I've got a custom hybrid Tube/D class integrated on the way too. Watch this space for a possible Sansui AU 517 sale, (especially if you're in Canberra ). What are the symptoms? First port of call with the 517/717 is the connected/separated switch on the rear panel. Work it back and forth 30 times or so and see if it comes good. If it does, it will require a proper clean with a lubricating contact cleaner to stop it happening again. 2 Link to post Share on other sites
eman 1,249 Posted November 15, 2020 Share Posted November 15, 2020 1 hour ago, pete_mac said: What are the symptoms? First port of call with the 517/717 is the connected/separated switch on the rear panel. Work it back and forth 30 times or so and see if it comes good. If it does, it will require a proper clean with a lubricating contact cleaner to stop it happening again. Hmmmm...... ok thanks, I can wiggle a switch. Symptom is very low volume on left channel. 1 Link to post Share on other sites
muon* 2,713 Posted November 15, 2020 Share Posted November 15, 2020 2 hours ago, eman said: Pretty sure it's all original. Only got it this year. So it might be mate, but I've got mobility issues so I won't be hauling this around town to post it somewhere. If someone in Canberra can pick up and deliver it might get done, otherwise .... 2 hours ago, pete_mac said: What are the symptoms? First port of call with the 517/717 is the connected/separated switch on the rear panel. Work it back and forth 30 times or so and see if it comes good. If it does, it will require a proper clean with a lubricating contact cleaner to stop it happening again. Oi! Doctor in the house 1 Link to post Share on other sites
pete_mac 3,987 Posted November 15, 2020 Share Posted November 15, 2020 59 minutes ago, eman said: Hmmmm...... ok thanks, I can wiggle a switch. Symptom is very low volume on left channel. Time to get your wiggle on!! 1 Link to post Share on other sites
eman 1,249 Posted November 17, 2020 Share Posted November 17, 2020 On 16/11/2020 at 10:58 AM, pete_mac said: Time to get your wiggle on!! Wiggled that pre/power switch a decent amount and there's no difference. Wouldn't it be both channels if that was the problem. My Right side is fine. Left is very low in speakers A & speakers B. Link to post Share on other sites
pete_mac 3,987 Posted November 17, 2020 Share Posted November 17, 2020 5 minutes ago, eman said: Wiggled that pre/power switch a decent amount and there's no difference. Wouldn't it be both channels if that was the problem. My Right side is fine. Left is very low in speakers A & speakers B. Not necessarily - the switch can cause intermittent issues in one or both channels. Bugger that the wiggling hasn't resolved it. It could be any number of things. I'd also suggest cleaning all switches with a lubricating contact cleaner and working them through their range of motion to ensure there's no oxidation causing the issue. This incudes the tape play switches - they can also cause drop-outs. If this doesn't fix the problem - unfortunately it could be any number of things, and input from a tech will be required. 2 Link to post Share on other sites
eman 1,249 Posted December 7, 2020 Share Posted December 7, 2020 On 17/11/2020 at 2:29 PM, pete_mac said: Not necessarily - the switch can cause intermittent issues in one or both channels. Bugger that the wiggling hasn't resolved it. It could be any number of things. I'd also suggest cleaning all switches with a lubricating contact cleaner and working them through their range of motion to ensure there's no oxidation causing the issue. This incudes the tape play switches - they can also cause drop-outs. If this doesn't fix the problem - unfortunately it could be any number of things, and input from a tech will be required. Both channels gone now. Doesn't work as a pre amp and doesn't work by using a RCA cable across the Pre Out and Power In either. Is the connect/separate switch easy for a complete amateur to access? Link to post Share on other sites
pete_mac 3,987 Posted December 7, 2020 Share Posted December 7, 2020 (edited) 16 minutes ago, eman said: Both channels gone now. Doesn't work as a pre amp and doesn't work by using a RCA cable across the Pre Out and Power In either. Is the connect/separate switch easy for a complete amateur to access? Bugger! If it doesn't work as a preamp, it sounds like something else is awry. The pre-outs on the rear panel do not go through the connected/separated switch, so if the preamp is functioning properly, you should get signal at the pre-outs and be able to use the amp as a pre-amp. This means something is wrong with the pre-amp circuitry or the power supplies for the pre-amp. This could include dirty/oxidised switches and controls. The connected/separated switch is mounted on the PCB circled red. It is fiddly to access properly and clean unless you remove it from the rear panel, and in doing so, you need to use new plastic rivets to re-affix the PCB afterwards. Here's the diagram showing where the switch sits. Switch S01a is the one, and the red arrows indicate the flow of the signal from the pre-amp to the power amp. I should add that if the switch is badly corroded, adding RCA jumpers or cables often won't solve the issue, as the switch is in the signal path as shown in the image above (i.e. jumpers don't bypass the switch). Edited December 7, 2020 by pete_mac 2 Link to post Share on other sites
Powerglide 702 Posted January 12 Share Posted January 12 Found this orphan needing a home. I've never seen one come up and not sure how good they are as a tuner but it looked so lonely got my moneys worth already just seeing the union I feel like Ancestry.com 5 2 Link to post Share on other sites
Luc 10,155 Posted January 12 Share Posted January 12 (edited) 23 minutes ago, Powerglide said: Found this orphan needing a home. I've never seen one come up and not sure how good they are as a tuner but it looked so lonely got my moneys worth already just seeing the union I feel like Ancestry.com I had this combo. Very Nice. Now it's time for you to get serious and chase up the Au-6900 I had them all a few years ago. Edited January 12 by Luc 1 Link to post Share on other sites
Luc 10,155 Posted January 12 Share Posted January 12 4 minutes ago, Luc said: I had this combo. Very Nice. Now it's time for you to get serious and chase up the Au-6900 I had them all a few years ago. The 6900 is the rare one. Link to post Share on other sites
Zedamon 5 Posted January 12 Share Posted January 12 (edited) @Luc How do the 6900, 7900 differ? Currently the proud owner of a 7900 that @Powerglide picked up for me a few months ago and I love it. Edited January 12 by Zedamon Extra detail Link to post Share on other sites
Luc 10,155 Posted January 12 Share Posted January 12 19 minutes ago, Zedamon said: @Luc How do the 6900, 7900 differ? Currently the proud owner of a 7900 that @Powerglide picked up for me a few months ago and I love it. It's hard to quantify to be honest. All of the above amps bar the 6900 I had refurbished(if needed) and the guy I purchased the 6900 from in the Netherlands had already done a complete rebuild, I deeply regret selling it. It was a stupid thing to do and still stings when I think about it. I held onto the wrong amp(the 7900) as it happens. How do they differ? Mainly in output with the 6900 poking out 60 watts per channel into 8Ω (stereo) and a damping factor of 80. The 7900 has the same damping factor but has more grunt at 75 watts per channel into 8Ω (stereo). But there's no denying that the 6900 is the rare beast of this model/series run. I've slowly sold all the models I had in this series with only the recapped 7900 done by Skippy to be sold now(It's on Gumtree as I'm trying to sell it locally to not have to package it to send) and a TU-3900. I'll keep the last of my 2900's (they bred like rabbits at one stage when no one wanted them on eBay..7 I think I had...lol) So if you see a 6900 for sale then jump on it and get it recapped and serviced. Because of it's rarity I'd price it above a 7900 recapped or not. 1 1 Link to post Share on other sites
pete_mac 3,987 Posted January 12 Share Posted January 12 (edited) 44 minutes ago, Zedamon said: @Luc How do the 6900, 7900 differ? Currently the proud owner of a 7900 that @Powerglide picked up for me a few months ago and I love it. The 7900 is the big pappa - slightly more power and more features/switching options as shown on the front panel vs the 6900. Sonically they are cut from the same cloth: Edited January 12 by pete_mac 1 1 Link to post Share on other sites
Powerglide 702 Posted January 12 Share Posted January 12 Do you think these Amps were sold new as a set or were the tuners an optional extra? Should there be as many TU's as AU's floating about, like I said I've never seen a TU 5500 previously. 1 Link to post Share on other sites
Luc 10,155 Posted January 12 Share Posted January 12 @Powerglide They were sold as a set if you wanted a set. Salesman might try to sell you a tuner along with the amp and a CDP. They were certainly set up in shops back then in big black stacks( nice eh! lol). I think it was Brashes in Bourke St Melb(or possibly Myers) where I saw my first stack of Sansui in the early 70's. Of course I totally ignored them and purchased a full Onkyo system instead... Link to post Share on other sites
Reidy12 5 Posted Friday at 08:15 AM Share Posted Friday at 08:15 AM My first amp, tuner and deck, in the 70's were Sansui AU-3900, TU-5500 and a TEAC 3300SX......listening to and overnight recording of ABC FM's "Rocturnal", epic source of all things Rock 😃 This thread is taking me back....way back........Cheers all. 5 Link to post Share on other sites
