Spetz
AC Outlet on Receivers - Always live or not?
Hi guys,
I noticed that a few receivers have an AC outlet on the back.
Can someone tell me whether this is constant or only live when the receiver is turned on?
The reason I ask is to see whether I can run a small active sub that does not have auto on/off?
is it a denon/marantz. in which case the outlet is switched on when the unit is on. and off on standby.
I use the one on my denon to run a couple of silent ventilation fans…very convenient ….switches on when unit is on and off when off…which is handy :)
keep in mind the power draw limitations on these outlets :)
It is an Onkyo.
It has 100w capability which is more than I need for a sub + a fan
This is what the owners manual says:
The TX-SR701/701E/601/601E is equipped with AC mains outlets
for connecting the power cords from other devices so that their
power is supplied through the TX-SR701/701E/601/601E. By doing
this, you can leave the connected device turned on and have the
STANDBY/ON button on the TX-SR701/701E/601/601E turn on
and off the device together with the TX-SR701/701E/601/601E
a sub :O and a fan ?
a fan depending on what it is ..eg a little pc silent fan ok.
but a sub ? no way !  I can't imagine any sub only drawing 100 watts.
I am looking at a Sony SA-W10 which draws only 30W.
Even larger Yamaha subwoofers fall under 100W.
The audio setup is for my mom, and to be honest I think she would not want a sub (if she knew what it was), so I just want it to add that tiny little bit of depth/bass, not to rumble anything as then she'll ask me to get rid of it.
Bump...
Can anyone say whether the AC outlet on an amp is constant or only on when the amp is on?
Bump...
The instructions you quoted suggest that the power outlet is a switched one.
Bump...
It depends on the exact model of amp - some are switched outlets and some are constantly powered. Some amps have a combination of the two!
It is an Onkyo.
Judging by this description, it is a switched AC outlet rather than being permanently powered.
Any connected devices are switched on simultaneously when you switch the amplifier on.
one way to check if want to confirm....just plug a small low wattage table lamp into the outlet. switch the amp on and off see if the lamp goes on and off with it or stays permanently on :)
