Stygian
Metal: Currently Spinning
I've slightly changed the cleaning method, now using one of those 'Magic Eraser' sponges.  I've used them many times for household cleaning and find them very effective.  They do have a tendency to wear quickly and break apart on rougher surfaces, and that has prevented me using them on my records before.  But, I thought, what the hell - give it a go and see what happens.
I have the Studebaker bath from the P.O.  I give them a run through the bath, leaving them in for a soak and turn a few times.
Draining the excess water off by standing them, and then placing flat to wipe with the sponge.  I give them quite a good wipe over ( with the groove ) using a fair bit of pressure, then to the sink for a rinse ( label and all ).
Back to the table for drying off with a lint free, micro fiber wipe.
Then glue application.  I assume that the glue should remove any sponge or fibers.
Hey Ant,
Out of interest how do you use the magic eraser to clean the record?  I use one of the small cubes and clean my stylus by just dabbing the stylus onto it a few times every record or so but i've not heard of it being used to clean a record.
I must admit, I am a culprit of record spray and a lens cloth every so often but I also have the Knosti Disco Anti Stat which i use periodically.  Never tried the glue method but the magic eraser has me puzzled!
can you share your method with us?
39 minutes ago, BuzzzFuzzz said:
... and another...
'Metal Massacre'  Compilation 1982 Metal Blade Records, USA.
2032455964_MetalMassacreCompilation1982MetalBladeRecordsUSA..JPG.0a9e2cea2bc6f3b82ca1125137875983.JPG
the highly regarded and spoken of metal massacre that introduced the world to that little band MetallicA.
nice album to have man.  Who would have though you'd see Metallica on the same album as some of the NWOBH style acts as well as RATT!!! awesome.
Hey @08Boss302 - Yo Bro.
No worries mate...
After a bath and soak in the Studebaker to loosen up the gunk, which i did in the sink before I had the Studebaker, I lay the record flat on a towel or lint free cloth.
With a wet sponge, which I rinse after every side, I wipe back and forth with the groove, with quite a bit of pressure.  You can feel the sponge want to follow the groove which indicates to me that it's getting well into it.
Be careful with the label, I have had some discoloration on the sponge from wiping them.  I don't mind that at all, but I'm sure many would be horrified by that.  I've also damaged a couple of labels with the glue by getting too close.  But I think that is due to not letting the label dry enough before applying the glue.
After the sponge I rinse under running water, then dry with a lint free micro fiber cloth.  I now stand them to dry for half an hour or so before applying glue, mainly for the label.
That's it my man.
There is a whole thread on the glue cleaning method for more info there.
Initially I was very concerned about washing records in a sink where the label is fully immersed.  I watched a few youtube clips and saw others doing it.  I tested on a few Op Shop throwaways before tackling any treasures.
After cleaning 500 records, I have probably damaged 10 labels.  Most of them were already damaged with a crease or some other production fault.  So now I avoid those.  A few independent record labels ( more rough paper like ), also don't seem to like getting wet.  Most labels are fine and fully dry in five to ten minutes.
I would recommend a bit of trial and error with some garbage records if you have any lying around, or hit your local Op Shops.
Black Sabbath  'Sabbath Bloody Sabbath'  1973 Vertigo Records. A W.W.A. Record, Made in Aust.  Oz 1st press.
856282982_BlackSabbathSabbathBloodySabbath1973VertigoRecords_AW.W.A.RecordMadeinAust..JPG.5b11764329ea8d86d82cf656b5daf565.JPG
Nice one @Darren69
I see yours and raise you an original...
No idea why that turned sideways.
Yours looks like a new arrival, is it a re-issue?  Edit - I see the numbers match, must be original too.
Awesome!! 😁 I have no idea what it is, a gentleman here gave it to me, would you believe? I am ashamed to say I cannot remember the mans member name.
No worries mate...
That's it my man.
thanks bud, thanks for taking the time to share your cleaning method.
i've got a few old LPs here I might try it with.
cheers.
This is not merely a comeback album, its a resurrection!!!!!
Celtic Frost - Monotheist
Time for some black metal:
Dark Funeral - Where Shadows Forever Reign....Dimmu Borgir sounding vocals coupled with fantastic drumming as usual by Nils "Dominator" Fjellstrom 👍
An old favourite to Kickstart the day 🤘
Edited by Capone
Original Elektra release which unfortunately omits black lodge which the CD has.
The DBL LP reissue puts the song on it tho 👌
Lee Aaron - Metal Queen, not quite metal but she looks the part.
I have never even sighted this on record, not when it was released, not ever. It's a sick album, one of my mates a few years ago opined it was their best - to which my response was that's a big call...but for me STD, ATL and this one are the winners
Cheers man.
Yeah its a ripper album.
This vinyl version of SOWN is pretty rare, not as rare as Stomp 442 on vinyl though, thats the one missing in my collection but at $500 (usually) its going to be missing a bit longer.
The re issue of SOWN is pretty easy to track down though if youre interested in it. Cover is different, it resembles the CD.
As you may have guessed by my avatar, they're my fav band, have been since I was about 12 I reckon.  Got a whole bunch of collectable and rare stuff of theirs.  Seen every one of their Australian tours and met them a few times and had stuff signed etc. I would struggle to choose a clear standout album as I cant fault their catalogue but I am very bias to them haha
Friday morning was a struggle, so went completely the opposite direction than I did at the start of the week and went heavy.
Started with Asva.  Probably should check out of some of their other albums, but got this one back in the day because of Trey Spruance playing on it.  Wasn't a bad start.  Drone, doom, sludgeyness.
https://music.southern.com/album/what-you-dont-know-is-frontier
Then stepped it up a notch with Sunn O))) - Pyroclasts.  I like this more than Life Metal.  Great drone album.
 https://sunn.bandcamp.com/album/pyroclasts
Then added some vocals with Hope Drone - Cloak Of Ash.  That first song is just epic.
https://hopedrone.bandcamp.com/album/cloak-of-ash
And finished with HYPNO5E.  French band.  Just as metal, but with more quiet pieces and a bit of spoken word sampling.
https://hypno5e.bandcamp.com/album/shores-of-the-abstract-line
Time for some Blackened Death Metal tunes:
Belphegor - Conjuring the Dead....their best album in my opinion!
I think I’ve entered a parallel universe, WTF, Danzig doing Elvis songs, not heavy versions either.
Yep mind blown. @Tubularbells was just about to post this myself.
Know of  somewhere I can order the vinyl for less than $100? Bloody expensive....
My ST gateway drug.
Suicidal Tendencies - How Will I Laugh Tomorrow......
Lots of great memories for me.
Edited by Tubularbells
spelling
Hey dudes
Some of you might have the book that came out the other year but just a heads up the documentary Murder in the Front Row is now on Amazon Prime.
(If you dont have Amazon Prime, just sign up for the 30day free trial, then watch the doco and then cancel.)
The doco is great, it centres totally on thrash and the bay area so if you are looking for a definitve thrash doco this aint it but if you're a bay area fan you'll enjoy it. Not much we probably dont know but its still awesome.
Couldn't help myself so have placed a pre-order with Discrepancy Records ...OUCH!
Brave man, I streamed the album and could only get through 2 songs, not an Elvis fan so that didn’t help.
Brave indeed as im also no Elvis fan so dared not listen to it before placing the order 🤣
@Yamaha_man
  • Recently Browsing   1 member
