acg
Deep End DIY - My first speaker project
Nothing to see here...move along...
Those ML1's look tiny.  Brought my wife up yesterday to have a look and I had some BB King playing very loudly through the standmounts and this was the entire conversation:
Meg to Anth: Is that music playing through these horns?
Anth to Meg: No, these won't have sound for months.
Meg to Anth:  Well these little ones do sound very ok.  Why do you need these big ones?
Silence
Anth to Meg:  You'll see one day.  I hope.
In real life I love the look of the horn stack thus far.  There is the right balance of strength and beauty and the different textures of the powdercoated steel and hammered paint on the horns looks fabulous.  As soon as I put up the horns and stood back I made my decision as to how I will treat the 30mm aluminium rods that hold the horns.  I had been tempted by brass, a black patina, brushed aluminium but I think that once the rods are the correct length (at the moment I hope they are a bit long) I will polish them.  That will give the setup just a tiny bit of bling but only if you look for it.
Happy days!
I also sincerely asked my wife, who has medical training, if there was any such organ as the 'poofoo', because I think I very nearly had popped mine getting those top horns into the stack.
Seriously though, I could not get the top horn into the stack while the stack was standing...you don't have a lot left over when you are holding 20-30kg above your head.  In the end I lay the entire stack down on the floor, installed the last horn and then proceeded to lift the thing back upright.  That was heavy and to get it from waist high to upright I had very little strength in reserve, but thankfully a very straight back.  Two blokes would be able to get that horn in and out of an upright horn stack, but if I am to do it myself the rod lengths have to be finalised before I install the amplifier.
No.
There has actually been a big discussion about angling of horns (or making them non-parallel) on Romys site and the quite firm opinion is that it does not work as we think it would.  The opinion was firm enough that I did not consider it in my design.  Saying that, even sitting very close to the horns as I will be I can see the driver in all of the horns.  Ear height is exactly at the level of the centre of the small midrange horn
No.
Interesting. Will need to check it out. Less likely to be necessary as you go up in the frequency range?
Those RAALs will sound so much better once you slide the covers off ;) (actually you haven't left yourself any room top or bottom to slide them off. You will need to do it very carefully from the side)
Edited by Silent Screamer
Everything is there from 1kHz up...but I am working on the Bass Cannons.  Current thoughts are that once the steelwork is finished that I return to the lathe and finish the upperbass horns.  That will leave the building of the amplifiers for spring if I have a good run at things.
No.
Where is that site? Might as well have a look. IIRC you have quoted it once or twice as the source of -- slightly unusual -- statements. [emoji41]
I like the idea of finishing the horns first, you can always provide another amp source temporarily. Also probably not a bad idea to hear them in case you want to make sonic changes to the amps.
7 minutes ago, Newman said:
Where is that site? Might as well have a look. IIRC you have quoted it once or twice as the source of -- slightly unusual -- statements. emoji41.png
Here 'tis.
I cannot remember where the angled horns discussion was but you may be able to find it in the "Horn Loaded" section of the site.
As a five-way system owner with 4 channels of horn load like yours, I have actually experimented with angling horns and preferred them straight. It may work when you need to sit closer then you should with a big horn system, but it becomes a singular point and has wider variations when you move around. It also effects the main sound you listen at the spot. This is maybe because of different reflections coming to add to the main sound, I do not know. There is also the problem of more hf energy and a db more attenuation is needed with mine, the spl also becomes a little more ragged. With them straight, and with the right distance, they sound better to me and this is not a guess. This is from experience :) When they are straight, you can also enjoy the system when you sit behind the sweet spot for two more rows (though we look ridiculous sitting as if we are on a train)
Thanks Okan.  I remember reading that Jessie (at GSC) did similar experiments with this 5 way horn system and had similar experiences.  It was just not an experiment that I thought I had to spend my time planning and doing.
13 hours ago, acg said:
Here 'tis.
OK thanks. At least now I understand the philosophy behind the thinking generally. I didn't manage to chase down the angled horns discussion, but that's okay, I was more generally interested.
Anthony, have you tried the bitumen pads they sell for cars to dampen your bass cannons. They generally work well, maybe you can cover the inside of the pipes with this material. If you haven't tried, I suggest you give it a go :)
Possibly a dumb suggestion, but could you coat the inside of the cannons with a two pack type of deadening compound (or a slow setting compound) and leave them rotating slowly in the lathe until the compound is set to obtain an even coating ........?????
I have some on order and hopefully I will see them some time next week.
That is actually a pretty good idea...a bit time consuming but doable.  I could make up a jig and would get a few done per day.  If the automotive damping sheets don't work I may have to give that a go.
Some rollerblade wheels, a motor and a belt and your away!
Yes - I tend to agree in this type of system to not angle the horns being the best balance of compromises.    Typically you would (could) angle them, but with such a large separation distance, and overlap of frequencies - then better not
Edited by davewantsmoore
HAH.   Enjoy.   I don't think you'll find it at all to your liking.   :-p
Just now, Happy said:
Hmm I should try not angling my horns
Modifying the angle, will drastically change everything....  You may or may not enjoy the outcome.... but don't let that disguise a complex happening.
    • By leqt1969
      Item: Avantgarde Acoustic UNO speakers
      Price: $8,500 ONO.
      Item Condition: Used but in great condition, superb sonically.
      Reason for selling: Going different direction
      Payment Method: Pickup - Cash
      Extra Info: Advertise on behalf of a friend in Bexley NSW who doesn’t have SNA account.
      Grab your chance.
      Avantgarde speakers are rarely seen on second hand market. These speakers are in great condition and sound superb. Still have original box but pick up preferred due to weight.
      Audition can be arranged for serious buyers.
    • By La scala
      Item: Klipsch La Scala speakers
      Price:  $3500
      Item Condition: Great for their age, 1978 ish Alnico
      Reason for selling: Told to shed some gear
      Payment Method: Pickup - Cash,  Bank Tranfer COD Only
      Extra Info: East coast buyers, can do live video demo via FaceTime
      These have the favoured Alnico Magnets, serviced X Overs and updated Mundorf Capacitors, some body bracing to tighten bottom end.
      All drivers work spot on.
      Sound wise, these have a uncanny ability to project a very large wall of sound with fine detail and dynamic authority.  Impressive as I am normally into Electrostats, Planar and Ribbon speakers. Very versatile and allow use of Set Valve Amps due to their 100db efficiency.
    • By MarcAL
      Item: Altec Lansing MR II 564 Large Format Mantaray Horns
      Price: $220 the pair or $125 each
      Item Condition: Used, good original condition, see pictures
      Reason for selling: NLR
      Extra Info: Altec Lansing MR II 564 Mantaray Constant Directivity Horns for large format 1.4" compression drivers.
      PM me if you require large compression Altec drivers to suit.
      Nominal Dispersion Angle: 60 x 40 degrees.
      Useable Low Frequency Limit: 500Hz.
      Construction: Heavy duty, weather resistant polyester/fiberglass.
      Finish: Standard Altec grey with a few minor scratches, can be resprayed another colour for an additional cost.
      Suitable Drivers: Many 1.4" throat compression drivers or Altec Lansing Large Format Compression Driver models 288, 290, 291, 299 etc.
      Small format compression drivers can also be used with the use of an adapter.
      Data Sheet: http://pdf.textfiles.com/manuals/STARINMANUALS/Bosch - EV/Archive/Altec/MRII 564.pdf
      Weight: 2.1kg each.
      Shipment: Will send interstate at purchasers expense, free delivery within Sydney.
    • By MarcAL
      Price: $225 for the pair
      Payment Method: Pickup - Cash, Paypal Only
      Weight: 2.1kg each.
    • By Alpine Electrocats
      Item: Altec 802-8D Horns and Compression drivers
      Price: $1000 neg
      Item Condition: Cosmetically a bit rough but should be fine
      Reason for selling: Not needed
      Extra Info: These came from the recording studio at the Canberra School of music. I am not sure how to text them as I presume I need a crossover so as to send the right frequencies through.
      This seems a fair price, they have been listed for up to $4000 on eBay (although that might be an optimistic seller)
      I can bring them to Sydney or post them - going to SydneyAugust 3-10
