acg
Deep End DIY - My first speaker project
Thanks guys for the pendulum stroke explanations.  All I know is that it works a charm, along with those extra watts.
Upperbass horn:                 167kg each
:blink:
What is the height as they are standing now
They would be taller than most people by the looks of them
Don't let one of those roll down the stairs Anthony!
Or the top of the Toowoomba Range ...
50 x 32mm = 1.6m tall.  Just showed my wife and the first thing she asked was "will they fit in the room?".  "Affirmative" was my reply "I've checked it all out in CAD"
Got to get them up 16 stairs so who knows what will happen!!
I should add that I modelled the horns in HornResp and used the export function to import the profile into AutoCAD where I fitted a spline and modified the mouth so that it terminated properly at square to the centreline (HornResp does not quite get this right). I believe that the mouth termination could be of some importance, especially considering JMLC's efforts.
I don't quite follow what you did with the horn contour near the mouth.  Could you explain this a bit more please?  More importantly, how did you go about checking the directivity over the desired bandwidth of each horn?
Same blades. Looked up the specs: the Makita is 450w with 18mm stroke; Bosh is 620w with a fancy pendulum stroke (whatever that means).
Ahh that makes sense. Reminds of the old bogan car sticker "If you want more inches, stroke it". Speakers are looking awesome. Can't wait to see the size of this lathe.
Simon
I would not mind seeing these speakers, but no way will I be close when they need to go up the stairs!
Your preparations are excellent and I don't want to sound negative, but can your study's floor handle the weight?
Fascinating project !
@@svenr ... have a look at the attached PDF file...hopefully that will clear things up a little.  I will answer the directivity question later on.
Horn Mouth Modification.pdf
Hi Anthony, I hope you have invested in a very good dust mask! MDF isn't harmless.
Looks like a great project and I don't envy your task of machining all those rings on the lathe. I've used that kind of process in the past on a much smaller scale and it definitely needs to be a labour of love.
I find that Bosch tend to provide more useful features for a given price point than Makita. I've used a couple of Bosch Jigsaws and the pendulum option is very handy. I also like the Bosch variable trigger which other don't typically provide around the price point.
Good luck with your project!
Hi Paul,
Yep, I have a good dust mask. The lathe work is a little daunting, mainly because I have little experience and secondly because I have now verified that I will eventually be turning about 150kg. I have done plenty to minimise the amount of material to remove with the lathe but am now considering a more flashy arrangement to turn the big horns because I now have two mates that have put up their hands for some horns and the lathe will get many more hours than initially intended. May as well get it right from the start.
Anthony
Guest guru
turning 150kgs on a lathe would scare me stupid. something's just aren't worth the potential risk. good luck
I see your point guru, but each of us has to pick our poison I suppose.  For instance I am more comfortable with a large moving mass that I can monitor by eye than I am playing with mains voltage (or higher - like in valve amplifiers) that I cannot see.  The horns will not be spinning very fast and 90% of the job can probably be done spinning them by hand, so they should be very much under my control.
Hi @@svenr, by directivity I assume you mean minimising honk or beaming?
Tractrix profiles are "known" to have less extension at the lower cutoff frequency, compared to say an exponential curve, so it is generally advisable to set the crossover points somewhere above the lower octave of the horn in question, and then leave some room in the horns upper octave as well.
The Upperbass horn is limited by a diameter of 1m so that I can get the midrange horn immediately above it at ear height, and is therefore limited to about 115Hz. The UB is also the only horn that I anticipate that I will try to grab every hertz of lower frequency extension and with a bit of floor gain perhaps I can get below 100Hz before it starts to sound wrong. The crossover point to the 250Hz Fundamentals Horn will hopefully be about 600Hz so the bottom octave of the FH will not be required except at attenuated volumes determined by the crossover slope. Likewise the 400Hz Midrange Horn will be crossed into at about 1000Hz so the bottom octave of the MH will not be used but also only the middle octave will be used in the FH horn (600Hz - 1000Hz). The MH will extend to about 10kHz before signing over to the ribbon tweeter so there will be some direct radiation involved, so we will see how that goes.
So I hope this explains the choices to minimise honk or beaming by keeping the horns operating comfortably within their 3 octave ranges, with only a couple of exceptions that hopefully will not prove to be too detrimental. Otherwise, if I do not know how to explicitly model directivity.
Anthony
@@acg - with directivity I was referring to beaming, i.e. the decrease of the spatial angle of radiation with rising frequency.  This is a very important aspect for the selection of crossover frequencies as well.  An uneven directivity profile will cause a spectrally unbalanced reverberant sound field and cause coloration of the perceived sound.
Honking in contrast is due to resonances in the horn and you would have seen this in Hornresp as very narrow peaks in the on-axis frequency response.  They should of course be avoided during the horn design or by attenuation in the crossover design.
Will be good to see the on-axis measurements of the horns once you are ready.  Great project btw - five way systems are hard to design but will perform very well if done properly.
Thanks svenr, you've just given me a little "key point" in my understanding of honking, which is a subject that I have not overly tried to find out too much about.
You know JV that you are welcome anytime at castle ACG, especially and particularly on the day the big horns go up the stairs.
My measurement gear turned up today and I could not help myself but pull out my Fane Studio 8M's to see how well the drivers match impedance wise.
What I ended up is as follows (using DATS):
post-139669-0-32635000-1421639927_thumb.
Here is the datasheet:
post-139669-0-00556100-1421639978_thumb.
Impedance wise it looks to me as though the two drivers are well matched.  However, even though the T-S measurements of the drivers seem to match they do not correspond particularly well to the datasheet. The biggest surprise for me is the free-air resonant frequency: measured 106Hz;  datasheet 81Hz.  I will have to do a bit of reading to try and figure out why they would be so different.  Can anybody offer a clue?
The drivers are brand new genuine 2004 production (not from the 2011 group-buy).  To measure I set a roll of packing tape on my desk, then placed the driver face-up with the magnet centred on a roll of tape so that the vent was not blocked.  Vas was measured using the "Added Mass" method whereby I added a plastic cup to the cone (which perhaps should have been something that did not enclose a volume of air over the dust cap).  All input welcome.
Anthony
driver "break in" .... as you use the driver its moving parts like the surround and spider will soften or loosen up ... and the Fs can drop by quite a lot.
Applying power gently at the drivers current Fs is a good way to break the driver in.     (Produces the most movement for the least power/heat .... stick to perhaps 1/2 of xmax)
EDIT:  only read half your post.    Forget VAS for now, and also play around with your mounting method of the driver to ensure that your "roll of tape" isn't doing anything to the measurement....   also keep in mind that very high sensitivity drivers are affected more (than lower sensitivity) drivers by poor mounting, vibration, external noise, etc. etc. when sweeping them.    (So you do need to be quite careful).    I typically make sure I can at least repeat my sweep reliably with the same result.
Also, "click on stuff" in DATS until you can get the graph to show the curve in more detail (it will help you evaluate it) ....  although FWIW - from what I can see they look as expected.
Edited by davewantsmoore
Thanks Dave.  Driver break-in...of course!
Perhaps I should set up a rig to run these Fanes in while I build the Upperbass Horn for them.  That way I could tune the backchamber with run-in drivers rather than having to wait some time listening to sub-optimal upperbass.
rig
Don't go overboard.... it won't take long, and you don't have to be precise.     Just keep the power at approximately Fs.    Don't go too close to xmax.    I'd be remeasuring them after only a few 10s of minutes.
I thought drivers need around 100 or more hours to break in.
Nar.
    • By mwhouston
      To get a grasp of where I’m am going with this thread you need to of read or have read  this article.
      https://www.stereophile.com/content/gramophone-dreams-34-salt-cellar-system
      If you go no further at the least it is in interesting read. Some will go “meh” others will take it on board to search for better reproduction. Maybe even build there own SC. The challenge I have given myself and would like to throwout to others is can you build or hobble together a “Salt Cellar“ (SC) system. The core of a SC system is purity of sound, dynamics and immediacy.
      These are the constrains/opportunities I’m am pursuing;
      a monaural system high efficiency speakers - horns where possible a tube low power Class A mono power amp or even tube integrated amp vintage tubes mono vinyl phono playback from mono cart or mono wired phono stage  ultra short non shielded interconnects and speaker leads of Silver plated wire wrap wire ?
      Ive been tossing this temp system around since I read that article and now have  (in my head) a whole SC system. So cutting to the chase I’m going to build a mono integrated wine box tube amp based on some vintage 807 and RCA 6SN7. Half the 6SN7 will be a single stage preamp and the other half the driver for a Suncalc designed 807 amp.
      Speakers will be my Beyma 12” concentrics with a Altec 511B horn and FatalPro driver. The horns will handle mid-range and the tweeter in the horns super tweeters. Overall efficiency about 98db.
      Im current working three other projects but now taken on a forth for a true SC system. Any other takers out there.
    • By gypr1961
      Item: Avantgarde Zero 1 XD Active Speakers DSP
      Price: $17,500 ONO
      Item Condition: Mint
      Reason for selling: Time for a change
      These are the top of the line model, above the pro model and come with DSP, digital and an analogue (A/D card) for turntables etc.
      They are incredibly dynamic! They sound just as good when theyre shaking the house or playing whisper quiet.
      I have all original packing so transport is not an issue
      As im going to need a complete new system Im happy to look at trades
      Specs can be found here https://www.avantgarde-acoustic.de/en/products/zero-serie/zero-1-xd.html
    • By leqt1969
      Item: Avantgarde Acoustic UNO speakers
      Price: $8,500 ONO.
      Item Condition: Used but in great condition, superb sonically.
      Reason for selling: Going different direction
      Extra Info: Advertise on behalf of a friend in Bexley NSW who doesn’t have SNA account.
      Grab your chance.
      Avantgarde speakers are rarely seen on second hand market. These speakers are in great condition and sound superb. Still have original box but pick up preferred due to weight.
      Audition can be arranged for serious buyers.
    • By La scala
      Item: Klipsch La Scala speakers
      Price:  $3500
      Item Condition: Great for their age, 1978 ish Alnico
      Reason for selling: Told to shed some gear
      Payment Method: Pickup - Cash,  Bank Tranfer COD Only
      Extra Info: East coast buyers, can do live video demo via FaceTime
      These have the favoured Alnico Magnets, serviced X Overs and updated Mundorf Capacitors, some body bracing to tighten bottom end.
      All drivers work spot on.
      Sound wise, these have a uncanny ability to project a very large wall of sound with fine detail and dynamic authority.  Impressive as I am normally into Electrostats, Planar and Ribbon speakers. Very versatile and allow use of Set Valve Amps due to their 100db efficiency.
    • By MarcAL
      Item: Altec Lansing MR II 564 Large Format Mantaray Horns
      Price: $220 the pair or $125 each
      Item Condition: Used, good original condition, see pictures
      Reason for selling: NLR
      Extra Info: Altec Lansing MR II 564 Mantaray Constant Directivity Horns for large format 1.4" compression drivers.
      PM me if you require large compression Altec drivers to suit.
      Nominal Dispersion Angle: 60 x 40 degrees.
      Useable Low Frequency Limit: 500Hz.
      Construction: Heavy duty, weather resistant polyester/fiberglass.
      Finish: Standard Altec grey with a few minor scratches, can be resprayed another colour for an additional cost.
      Suitable Drivers: Many 1.4" throat compression drivers or Altec Lansing Large Format Compression Driver models 288, 290, 291, 299 etc.
      Small format compression drivers can also be used with the use of an adapter.
      Data Sheet: http://pdf.textfiles.com/manuals/STARINMANUALS/Bosch - EV/Archive/Altec/MRII 564.pdf
      Weight: 2.1kg each.
      Shipment: Will send interstate at purchasers expense, free delivery within Sydney.
