acg
Deep End DIY - My first speaker project
What I love about modern valve amplifier builds is the possibility and benefits of mixing old and new technologies.  Lately, I've been sneaking an hour here and there to advance the electronics projects and have managed a few small milestones.  Have a look at the photo below...
That is the RIAA correction filter for one channel of my upcoming LCR phonostage.  Two handsome Slagle inductors on mumetal cores, some Jupiter copper foil caps and some custom cut TX2575 Z-foil resistors that should make a frequency response flat line out of the very wobbly riaa cut of the records.  It all sits on a 4mm thick aluminium plate that in turn sits inside an off-the-shelf EMI/RFI box which in turn will sit inside a 4mm thick steel sarcophagus in an effort to maintain a very low noise floor in the circuit.  It sits between a pentode first stage and triode second stage.
So, above is a nice example of the old-school purists method of sacrificing resources and real-estate with rats-nest wiring.
So the tubes have to be supplied 6.3vdc and I had alook through my pcb box to find a challenging build using paralleled LT3042 ultralow noise LDO's.  These things are tiny...0.5mm pitch MSOP.  I've never soldered them before so decided to order the parts and give the little psu a go.  See below, it worked...
That green pcb has two 6.3V 1A power supplies including all rectifier diodes, filter caps and heat sinking (later two items under the board).  I hand-soldered the little bugger and it took a couple of hours but it worked first time!  Those big (haha) yellow 1205 caps make the LT3042 look tiny.  What is not shown is that little green pcb is going to be connected to two relatively huge EI filament transformers.
Anyway, that is my rather extreme example of modern and vintage electronics used in the same component, a RIAA phonocorrector.  Can't wait to get it finished.
    • By La scala
      Item: Klipsch La Scala speakers
      Price:  $3500
      Item Condition: Great for their age, 1978 ish Alnico
      Reason for selling: Told to shed some gear
      Payment Method: Pickup - Cash,  Bank Tranfer COD Only
      Extra Info: East coast buyers, can do live video demo via FaceTime
      These have the favoured Alnico Magnets, serviced X Overs and updated Mundorf Capacitors, some body bracing to tighten bottom end.
      All drivers work spot on.
      Sound wise, these have a uncanny ability to project a very large wall of sound with fine detail and dynamic authority.  Impressive as I am normally into Electrostats, Planar and Ribbon speakers. Very versatile and allow use of Set Valve Amps due to their 100db efficiency.
    • By MarcAL
      Item: Altec Lansing MR II 564 Large Format Mantaray Horns
      Price: $220 the pair or $125 each
      Item Condition: Used, good original condition, see pictures
      Reason for selling: NLR
      Extra Info: Altec Lansing MR II 564 Mantaray Constant Directivity Horns for large format 1.4" compression drivers.
      PM me if you require large compression Altec drivers to suit.
      Nominal Dispersion Angle: 60 x 40 degrees.
      Useable Low Frequency Limit: 500Hz.
      Construction: Heavy duty, weather resistant polyester/fiberglass.
      Finish: Standard Altec grey with a few minor scratches, can be resprayed another colour for an additional cost.
      Suitable Drivers: Many 1.4" throat compression drivers or Altec Lansing Large Format Compression Driver models 288, 290, 291, 299 etc.
      Small format compression drivers can also be used with the use of an adapter.
      Data Sheet: http://pdf.textfiles.com/manuals/STARINMANUALS/Bosch - EV/Archive/Altec/MRII 564.pdf
      Weight: 2.1kg each.
      Shipment: Will send interstate at purchasers expense, free delivery within Sydney.
    • By MarcAL
      Price: $225 for the pair
      Payment Method: Pickup - Cash, Paypal Only
      Weight: 2.1kg each.
    • By Alpine Electrocats
      Item: Altec 802-8D Horns and Compression drivers
      Price: $1000 neg
      Item Condition: Cosmetically a bit rough but should be fine
      Reason for selling: Not needed
      Extra Info: These came from the recording studio at the Canberra School of music. I am not sure how to text them as I presume I need a crossover so as to send the right frequencies through.
      This seems a fair price, they have been listed for up to $4000 on eBay (although that might be an optimistic seller)
      I can bring them to Sydney or post them - going to SydneyAugust 3-10
    • By MRG
      Item: Horns (Autotech 600Hz JMLCe) and SOLD Faital Pro Compression Drivers (HF108)
      Price: Further reduced to $325
      Item Condition:Excellent lightly used domestically
      Reason for selling:Trying other stuff
      Payment Method: Pickup - Cash, Paypal, Bank Transfer
      Horns are beautifully made in Poland.Very solid. As used in Redefy models. Constant Directivity.  With a 600Hz cut off.
      Faital Pro HF108 hardly used.  These have an extended range to 20kHzHorn pics
