acg
Deep End DIY - My first speaker project
No need Matt, keep it going here.
2 hours ago, 125dBmonster said:
:) Well I'd like to see them driven to 125db of earth shaking terror with a 4 ohm output Z.  More like something with 0.01ohms at 80 volts with 25A on tap.
Heard of Ohms Law Dave and I2R loss ?
Hold on.    We were talking about accurate drive.     ie. the  accuracy, or the "control", of the cone.    ie. like how they said in the article whether the bass is "tight" ... or whether the cone "flaps about".
  • You don't need a low output impedance to ensure the "cone moves accurately"
  • You don't need a feedback loop (although it IS convenient to use one) to even achieve low output impedance.
  • Your chosen example driver (low cms / high rms, in a sealed box) is about as extreme as you can get of a driver which requires no extra electrical damping  (as it is already highly damped mechanically).
Hence my flat "No".
.... but you've jumped over to something else P=I^2.R  (and sure, I've herd of it a few times before).... If you had an amplifier which such an internal impedance, a quick sim in winisd shows that once the frequency responses have been EQed to the same result .... then you get half (-3db) the SPL.    So you'd need double the drivers.
.... but remember we weren't talking about this.   We're talking about whether the cone is "under control".... "grip" .... whether it is "tight", or it "flops about uncontrollably" ..... that a completely different thing from what you've just jumped to.
Edited by davewantsmoore
1 hour ago, 125dBmonster said:
Dave, those 2 statements don't sit well with me in my mind as they contradict a few laws of Electricity.
You may have to explain this in detail
It is very cumbersome to do on a forum like this.
You can kinda approach it from two angles.     Either can start from zero, and build up all the explanations, ifs and buts ... which lead to the complete picture.
... or can approach it from the disproving a 'fallacy' angle and ask take a flawed explanation (like in some of those articles) where they say that low amplifier output impedance supplies "grip" or "control" .... and demonstrate how it's wrong.
The "whiteboard" is important....  because it helps to actually engage with people.    "What do you mean by 'grip'?" .... How does it do that? .... What about this?
Wirtting walls of text is a bit one sided, and if the other person doesn't follow, then the critical bits can easily be lost.    If you were standing right in front of me, and I said X, it is much easier for me to see if you've understood ... and if not explain slightly differently, or whatever.
12 hours ago, 125dBmonster said:
Will concede that DF is not actually a "real" thing
Well, it IS a real thing ..... it just doesn't have the effect that all the "articles" out there say it does.     It's effects are a lot more complicated .... and after we look past the simple fact that replacing an amp with another (that has a different damping factor) might produce a different (and maybe undesirable) frequency response for a speaker .....   we see that the rest of what high 'damping factor' does is negative.
The root of the problem with the 'conventional wisdom' on damping factor is it's the story from the perspective of amplifier manufacturers ..... and it largely ignores the basics of how a speaker operates.
That all being said.... most people need to use an amp with 'enough' damping factor .... becuase that's the way their speaker was designed.
Damn L-Pads.  Was a bit rainy yesterday arvo so I  thought I would have a crack at one of the amplifier jobs that I was least looking forward to...soldering up the ladder attenuators for the tweeters.  Previously, I had soldered up a pair for another channel, but this pair had some nice pcb's that made the assembly very quick and easy, maybe a couple of hours for the pair.  Those switches were unused second-handers from fleabay and Elna no longer supply the pcb's and no matter how hard I looked I could not find another pair so had to buy the current version with solder tabs.  Soldering them up was a job I was really not looking forward to so it was best to just jump in and get it done.
My, oh, my...the first one (far right) is a bit ugly but it works.  The second one (middle) is in better shape but would still not win any beauty contests...lucky these are out of sight.  Anyway, that was half a day of my life I am not getting back!  How I wish I had fond some more of those nice discontinued pcb versions.
That is nearly 200 resistors soldered up in the two pairs of attenuators...by far the great majority of resistors in the entire project.
Edited by acg
That's a looooooottt of work mate. Well done. I can appreciate the effort in trying to get them right.
A bit surprised that you did not enter into making new PCB's for these? :thumb:
Would have added that extra skill set?
I know how difficult that sort of soldering is to get right let alone something that looks good as well.
I think you will need a large appointment book once you have this system finished, I am sure that many of us following the thread would like to have a listen.
Well done, keep up the good work.
I did actually look into that.  I've had pcb's made for other parts of this project (the bleeder circuits and diode bridges) but in the end it was either spend half a day soldering them up or spend half a day designing the pcb...I chose the path of least resistance.
    • By stever
      Item: Altec 802-8D Horns and Compression drivers
      Price: $1000 neg
      Item Condition: Cosmetically a bit rough but should be fine
      Reason for selling: Not needed
      Extra Info: These came from the recording studio at the Canberra School of music. I am not sure how to text them as I presume I need a crossover so as to send the right frequencies through.
      This seems a fair price, they have been listed for up to $4000 on eBay (although that might be an optimistic seller)
      I can bring them to Sydney or post them - going to SydneyAugust 3-10
    • By MRG
      Item: Horns (Autotech 600Hz JMLCe) and SOLD Faital Pro Compression Drivers (HF108)
      Price: Further reduced to $325
      Item Condition:Excellent lightly used domestically
      Reason for selling:Trying other stuff
      Payment Method: Pickup - Cash, Paypal, Bank Transfer
      Horns are beautifully made in Poland.Very solid. As used in Redefy models. Constant Directivity.  With a 600Hz cut off.
      Faital Pro HF108 hardly used.  These have an extended range to 20kHzHorn pics
    • By Tax
      Item: Avantgarde Acoustic Duo (Horn) Speakers
      Price: now REDUCED to $11,000
      Item Condition: Very good
      Reason for selling: Downgrading due to business investment opportunity
      Payment Method: Pickup - Cash, Paypal (with fees), Direct Bank Transfer
      Extra Info: I am selling these on behalf of a mate who is looking to raise some funds for a new business venture. No original packaging/shipping crates so pick up in Sydney preferred. Price reduced to accomodate this.  Interstate buyers will need to get a mate to pick the speakers up in Sydney and sort out shipping for you. Again reduced sale price reflects this inability of the seller to deal with packing and shipping.
      These are 1st generation Avantgarde Duo horns, 8 ohms, approx 101dB  sensitivity and have powered subwoofers. Lots of specification info is available on the web. The horns are Blue in colour. The speakers have not seen any use in the last 2+ years as I have been storing them in my home office for my mate.
    • By aertex
      Item: GOTO SG-370DX mid range compression drivers and matching S-600 horns
      Price: $5550
      Item Condition:  excellent
      Reason for selling: dont want too but need to consoildate drivers and $
      Extra Info:     consecutive numbers on drivers, forgot to take pics of plywood driver boxes but will do so later. Drivers have been very lightly used by myself and previous owner. They have a very special extremely natural organic tone I have not heard elsewhere in any cd's
