Tax
Duelund RS DC capacitors
Has anyone had a play with the Duelund RS capacitors?
I am going to install a couple of these in the first stage of the Lamm LP2. I already have VSF's in the second stage.
Can they be installed upside down on on their side, will this cause any leakage issues?
Is there a preferred orientation with the leads to signal/impedance etc?
t
For the lords sake dont get young Mario excited and frothing at the mouth with this sort of enthusiastic enquiry :) :). Especially the D word
Alan
Edited by aertex
I have used Dueland resistors with great results so I have confidence that the capacitors will not disappoint
And I will be watching as well
Edited by Full Range
Are you replacing Electrocubes Tax?
I got them in my upgraded Leak.
They seem to be slightly closer to the Cast than the older VSF Copper.
Does that make them better - who knows - some people prefer the Coper to the Cast - I prefer the Cast personally.
Mike Lenehan mentioned he may do a formal comparison with Cast, RS, VSF, and the new Jupiter copper on some new wild speakers he in building me - but we need to wait and see - he is really really busy right now.
One thing I can say is for smaller values the new Jupiter copper is much better value - and it is reputed to be close to the RS in quality.  Larger values however are about the same price.
Bill
No! Mundorf SGO bypassed with a Vcap cutf
Bill
Thanks Bill!
Partsconnexion have a xmas sale on at the moment on Duelund RS and Cast caps. I have ordered a pair of RS 0.47uF for approx $88 USD each. The equivalent Cast cap is now $189.
Can you recall what the value (uF) of your caps were and what the physical size of each is?
Also how are they mounted (upright, on its side etc).
I have read some posts on Agon that some CAST users found their CAST caps leaking.
I may have to mount mine upside down or on its side so I can fit them in.
Edited by Tax
Thanks Bill!
ellent a
Hi Tax.
I use the new RS on my phono stage in the output and it replace the Mcap silver/gold/oil . excellent sounding cap .
Duc
They were .25uf.  They were glued upright to the underside and wire used to connect them to where they would normally be.
Bill
Hi Tax.
Duc
Thanks Duc!
I intend to use them in the first stage of my phono. Second stage has VSF. I might have to swap them around depending on space.
Can you recall the physical size of each?
t
Bill
Thanks Bill!
Pretty sure they will operate in any orientation.
They are a potted copper alloy foil, so everything is held securely in place by the potting resin.
Cheers, Earle.
Cheers, Earle.
Thanks Earle!
They are leaving PCX today.
I was getting a bit concerned about orientation after reading about CAST caps leaking.
t
Hi Tax.
Duc
Duc,
Is the sound of the RS forward compared to the Mundorf SGO?
Duc,
Hi Tax.
no it not any more forwardness compare to the Mcaps SGO . but it is bigger size in the same value . i have to use the common Electrolytic clamp to mount those RS caps .
Duc
Edited by lovetube
Hi Tax.
no it not any more forwardness compare to the Mcaps SGO . bit it is bigget size in the same value . i have to use the common Electrolitic clamp to mount those RS caps .
Duc
Ok, thanks Duc!
Pretty sure the RS is for Radial Stacked foil.
Google is your friend.
Sorry, late entry to this thread....
Nealy all film caps have orientation for outer/inner foil.
I think the Duelund RS have outer foil indicated by outermost leadout wire.
It's best to orientate outer foil to the lowest impedance side of the cct - for best shielding & usually best sound - dynamics, bandwidth, etc..
ie. to Gnd in a shunt situation or to the driving source end when coupling.
Except in lspkr xovers, when it's best if the signal 'exits' the outer foil side.
Merry Xmas ;-)
Cheers, Owen
Dark Lantern blog - http://darklanternforowen.wordpress.com/
Merry Xmas ;-)
Cheers, Owen
Aah, but how do you determine the outer foil when it's not marked, Owen?
Regards,
Hi Andy,
I believe that the Dueland RS have Outer Foil indicated by the lead wire that is outermost, ie. the one closest to the outer case edge.
It is mentioned & pictured in Humble Homemade Hifi's test here.
If not marked, then...
1. You need an oscilloscope to check the orientation which gives lowest induced noise eg. when you grab the cap with your hand, or...
2. By ear! Which is the best way at the end of the day. The difference is not subtle.
A few film/foil caps are not wound in conventional inner/outer foil manner - Duelund's VSF, CAST (I think), Russian MBGO...
Ate & drank a lot today  ;)
Cheers, Owen
    • By Somethingclever
      Item: Pair of Duelund 3.3uf 630 vDc CAST Pure Copper Foil
      Price:  800 ono ( Happy to post at buyers expense )
      Item Condition: Very Good
      Reason for selling: Change
      Extra Info: To quote Benjet who sold something similar..."If you know what these are then you don’t need me telling you all about them. If you don’t know them you probably don’t need them."
      Currently in use, will demount them when sold.
      These top of the line Duelunds were worth about 600 to 700 each when new as far as I can tell.
    • By Benjet
      Item: Duelund VSF 2.2uf 400v Capacitors
      Price: $475 for the pair
      Reason for selling: Surplus
      Payment Method: Pickup - Cash, Paypal (buyer pays fees)
      Extra Info: If you know what these are then you don’t need me telling you all about them. If you don’t them you probably don’t need them.
    • By Bill125812
      Item:  Duelund twisted pair Speaker Cable 2.5m
      Price: free.  Nothing inc postage
      Item Condition: perfect
      Reason for selling: NLR
      Extra Info: I made these up just as trial.  Very good but not quite what I was looking for.  They have Straightwire bananas   I also sheathed then in tech flex
    • By mcb
      Item: Pair of Arion HS-500 Mono Block Amplifiers fitted with Duelund VSF capacitor each and upgraded valves.
      Item Condition: Excellent
      Reason for selling: Now running big valve mono blocks
      Price: $3500, Pick-Up (freight can be arranged at purchaser’s expense)
      Payment Method: Cash on Pickup
      The HS-500’s are a Vacuum Tube / Class-D Hybrid Monoblock Power Amplifiers.  Further spec’s below.
      I purchased these amps new from Lenehan Audio in February 2014, fitted with VSF Duelund capacitors.  I have since added a matched pair of Cryoset treated Electro Harmonix  6H30Pi EB Gold Pin valves in lieu of the standard valves.
      These amps where purchased to replace a highly modified Mingda MC34AB amp and have been used to drive my Lenehan ML2’s. They would have continued to remain in my system, had I not taken up the opportunity to try a pair of 200 watt monster valve monoblock room heaters.
      Includes original packing boxes and manuals.
      The current replacement price is US$6295 + freight + 10% + other import costs.
      Happy to demo in Perth metro area.
      Comments from SNA members on HS-500’s - http://www.stereo.net.au/forums/topic/46896-arion-hs-500-amp/
      External Review - http://www.enjoythemusic.com/magazine/equipment/1010/arion_audio_rs_500.htm
      HS-500 Amplifier Specifications
      Rated Power @ 8 Ohms : 500 Watts
      Rated Power @ 4 Ohms : 1000 Watts
      Sensitivity : 1.8 Vrms
      Gain : High gain (approx. 29dB) and low gain (approx. 25dB) settings. Currently set on low gain.
      Frequency Response: 20Hz – 20KHz +/-0.5dB
      Input Impedance : 200K Ohms
      Damping Factor : 900 Ref @ 8 Ohms
      Maximum Output Current : 35 Amps
      Tube : 6H30
      Dimensions : 9.75 in W x 4.75 in H x 14 in D (24.8cm x 12.1cm x 35.6cm)
      Weight : 22 Lbs (10kg) each
    • By mcb
      Price: $3750  $3500, Pick-Up (freight can be arranged at purchaser’s expense)
      Tube : 6H30
