Guest jakeyb77 Posted September 14, 2019 Share Posted September 14, 2019 They are his mum’s old speakers. She is 102. I kid you not. It’s her Consonance amp for sale also. She upgraded her whole system. The eclipse are reference with the lead and felt lining. Great speakers. Link to post Share on other sites
Guest jakeyb77 Posted September 14, 2019 Share Posted September 14, 2019 I’m almost considering just hitting the buy it now. Link to post Share on other sites
Guest jakeyb77 Posted September 14, 2019 Share Posted September 14, 2019 The foam on the midrange in my Epitome went yesterday so they are off to Atilla to be refoamed. This should give them another 15 years. Expect some wear on the older drivers and as @gat474 mentioned you cannot get these drivers anymore so expect repairs when getting on 10+ years. Link to post Share on other sites
gat474 1,579 Posted September 14, 2019 Share Posted September 14, 2019 The midrange in Osborn speakers using Focal drivers doesn’t have a high pass so they get all the bottom end, must have been running them hard @jakeyb77! Link to post Share on other sites
Guest jakeyb77 Posted September 14, 2019 Share Posted September 14, 2019 (edited) 34 minutes ago, gat474 said: The midrange in Osborn speakers using Focal drivers doesn’t have a high pass so they get all the bottom end, must have been running them hard @jakeyb77! 15 year old foam. Not hard really at all. If they aren’t crossed over then that’s a serious design flaw. Why would you run all all the signal into that into a 7” driver when you have 4 x 10” bass drivers? @aussievintage had the same issue. Maybe they aren’t the speakers for me 😳 Edited September 14, 2019 by jakeyb77 Link to post Share on other sites
aussievintage 3,828 Posted September 14, 2019 Share Posted September 14, 2019 41 minutes ago, gat474 said: The midrange in Osborn speakers using Focal drivers doesn’t have a high pass so they get all the bottom end, must have been running them hard @jakeyb77! It isn't a mid-range speaker in the 3 way speaker sense. These are classed as 2.5 way speakers aren't they? Link to post Share on other sites
aussievintage 3,828 Posted September 14, 2019 Share Posted September 14, 2019 22 minutes ago, jakeyb77 said: @aussievintage had the same issue. Maybe they aren’t the speakers for me 😳 Yes. It's just age. Mine did well to live 17 years. foam should be here in a week Will post pictures of repair if I am successful in fixing them. Link to post Share on other sites
Guest jakeyb77 Posted September 14, 2019 Share Posted September 14, 2019 10 minutes ago, aussievintage said: Yes. It's just age. Mine did well to live 17 years. foam should be here in a week Will post pictures of repair if I am successful in fixing them. Yeah to be fair the foam peeled off like tissue paper. It was well due for change on mine. Link to post Share on other sites
aussievintage 3,828 Posted September 14, 2019 Share Posted September 14, 2019 While I wait for my new foam surrounds to be delivered, I didn't want to keep using the old drivers in case they damaged themselves, so I did this. I removed them to prep for the fix, and put in these cheap Jaycar Response brand drivers (about $35 ea from memory) that I had in another set of tower speakers. They have similar specs, just a bit less efficient than the Focals. They fit in a way that doesn't damage the OSborns, and the screw holes will not be visible when the original drivers are put back. You can see the alan key screws I put pack around the outside so I wouldn't lose them. The sound isn't so bad, it's quite acceptable in fact. Certainly has enabled me to keep listening. Link to post Share on other sites
Guest jakeyb77 Posted September 14, 2019 Share Posted September 14, 2019 Bidding has started on the Eclipse. I had to kick it off. Why not. Interesting mod there @aussievintage. I have two spare NS-1000 mids that seem to slot right in. Maybe I should try it. 🤔 I get my Tannoys back tomorrow so I’ll probably just use them Link to post Share on other sites
aussievintage 3,828 Posted September 14, 2019 Share Posted September 14, 2019 Just now, jakeyb77 said: Interesting mod there @aussievintage. If I screw up the Focals, I could even live with these until I get something better. Link to post Share on other sites
Guest jakeyb77 Posted September 14, 2019 Share Posted September 14, 2019 4 minutes ago, aussievintage said: If I screw up the Focals, I could even live with these until I get something better. I’ve been looking at drivers with the same footprint and better specs. If you can find the 7W2 it’s rated at higher wattage. But also too hard to find. Your purchase price helps also compared to mine. 😳😝 Link to post Share on other sites
Moderators joz 5,687 Posted September 14, 2019 Moderators Share Posted September 14, 2019 2 hours ago, jakeyb77 said: Bidding has started on the Eclipse. I had to kick it off. Why not. Interesting mod there @aussievintage. I have two spare NS-1000 mids that seem to slot right in. Maybe I should try it. 🤔 I get my Tannoys back tomorrow so I’ll probably just use them Real enjoyed the eclipse when I heard them years ago, really sweet and nicely balanced. But they go lack the authority of their bigger siblings. Link to post Share on other sites
aussievintage 3,828 Posted September 14, 2019 Share Posted September 14, 2019 (edited) 10 minutes ago, joz said: Real enjoyed the eclipse when I heard them years ago, really sweet and nicely balanced. But they go lack the authority of their bigger siblings. The highs are very "sweet" - it's the same word I used. The subwoofer digs in for some fairly tight bass when playing some acoustic double bass in jazz, and orchestral stuff. Not sure about authority. Have to listen to my brother's Epitome towers a bit more Edited September 14, 2019 by aussievintage Link to post Share on other sites
aussievintage 3,828 Posted September 16, 2019 Share Posted September 16, 2019 (edited) Today I started to prep one of the Focals for re-foaming. Just thought I'd post a few pics This is one of the drivers. You can just make out the cracks in the foam where it is ready to fail. (about 8 oclock) Firstly I scraped the outer edge with a small screw driver. You can see the thin foam is a gooey mess, partly disintegrating and partly turning to glue. Here's the driver after carefully removing the rubbery mess from the edge of the cone. The cone material is called Neoglass by focal. It feels and bends like thin plastic. Feels more robust than I thought. (good ) I need to find out what will remove the gluey remains, maybe alcohol, maybe one of those citrus oil based removers. Edited September 16, 2019 by aussievintage Link to post Share on other sites
Guest jakeyb77 Posted September 16, 2019 Share Posted September 16, 2019 I’d use isopropyl on the baskets. Not sure about the Polyglass cone though Link to post Share on other sites
aussievintage 3,828 Posted September 16, 2019 Share Posted September 16, 2019 31 minutes ago, jakeyb77 said: I’d use isopropyl on the baskets. Not sure about the Polyglass cone though I used De-solve-it then isoprop. Found the best tool for cleaning the edge of the cone was my fingernail. I'd spray a bit of cleaner on it, use my fingertip to spread it along the edge, then with the fingers of my other hand supporting the cone edge, I'd scrape the top with my fingernail. Link to post Share on other sites
Guest jakeyb77 Posted September 16, 2019 Share Posted September 16, 2019 1 hour ago, aussievintage said: I used De-solve-it then isoprop. Found the best tool for cleaning the edge of the cone was my fingernail. I'd spray a bit of cleaner on it, use my fingertip to spread it along the edge, then with the fingers of my other hand supporting the cone edge, I'd scrape the top with my fingernail. Looks good! Keep the updates coming. 👍 Link to post Share on other sites
davewantsmoore 6,570 Posted September 16, 2019 Share Posted September 16, 2019 On 14/09/2019 at 1:08 PM, aussievintage said: It isn't a mid-range speaker in the 3 way speaker sense. These are classed as 2.5 way speakers aren't they? Semantics. It's "right" to call it the "midrange" seeing as it handles from 200hz (or wherever) up to the tweeter. Link to post Share on other sites
aussievintage 3,828 Posted September 16, 2019 Share Posted September 16, 2019 9 minutes ago, davewantsmoore said: Semantics. It's "right" to call it the "midrange" seeing as it handles from 200hz (or wherever) up to the tweeter. But that's not the case according to the post to which I was replying. They were saying it handled everything from the bottom end up, because the crossover (at 125Hz btw) did not include a high pass filter for it. I don't know if that's true, but that was why I ventured that it was 2.5 way and the speaker was really the woofer of the 2 way part of the system. Link to post Share on other sites
davewantsmoore 6,570 Posted September 16, 2019 Share Posted September 16, 2019 17 minutes ago, aussievintage said: But that's not the case according to the post to which I was replying. They were saying it handled everything from the bottom end up, because the crossover (at 125Hz btw) did not include a high pass filter for it. Ahh... I see. It's still right to call it the "midrange driver"..... or the "bass/mid". It doesn't include an electrical high pass filter .... but the driver and the box themselves act as high pass filters 17 minutes ago, aussievintage said: why I ventured that it was 2.5 way and the speaker was really the woofer of the 2 way part of the system. Depends on how you want to use the terminology. 2.5 usually refers to two identical woofers, where on has a low pass filter. eg. two woofers which play from 40 to 1400Hz ....but one has a low pass filter stopping it from playing above 200Hz. Here, it's really just a mid/bass driver, which doesn't have/need an electrical high pass filter. Link to post Share on other sites
aussievintage 3,828 Posted September 17, 2019 Share Posted September 17, 2019 The foam surrounds arrive today. Looking good. Fit is as expected, not quite as big on the outside diameter, but looks like plenty wide enough to attach. Just sitting in place - not glued yet 1 Link to post Share on other sites
ray4410 767 Posted September 17, 2019 Share Posted September 17, 2019 (edited) all looking good,how are you centering the voice coil,i have rick cobbs self centering cd if you would like to use it. Edited September 17, 2019 by ray4410 Link to post Share on other sites
aussievintage 3,828 Posted September 17, 2019 Share Posted September 17, 2019 Speakers packed up with paper and shimmed. By raising the cone, the surround will sit nicely into the cone for gluing the inside edge. Probably don't need to shim yet, but I did it anyway. Gluing using a small bottle of glue I bought with the surrounds. I suspect it's just normal PVA white glue. Both surrounds glued to the cones, but sitting raised above the outer edge while they dry. I used the cotton bud to stroke along the edge to seat the foam edge to the cone properly. Link to post Share on other sites
aussievintage 3,828 Posted September 17, 2019 Share Posted September 17, 2019 28 minutes ago, ray4410 said: all looking good,how are you centering the voice coil,i have rick cobbs self centering cd if you would like to use it. I was hoping to just let the shims give me enough clearance all round. They are a firm fit (just cut from an old record sleeve) 1 Link to post Share on other sites
Kaynin 3,782 Posted September 17, 2019 Share Posted September 17, 2019 Has anyone compared the Eclipse towers to the Epitome towers? Also, anyone compared the Epitome Towers standard with the Reference? Link to post Share on other sites
aussievintage 3,828 Posted September 17, 2019 Share Posted September 17, 2019 8 minutes ago, Kaynin said: Has anyone compared the Eclipse towers to the Epitome towers? Also, anyone compared the Epitome Towers standard with the Reference? I have heard the new Epitome Reference towers at my brother's place, but only for about half an hour. I plan to visit for a longer listening session. How to compare with the older Eclipse Reference (non-tower) that I have now? Bigger and better springs to mind. Very big and heavy to move about. The bass sort of fooled me. On one record I thought it sounded a bit light, but on the next the bass blew me away. I would say it's a case of not introducing any false bass if the recording is lacking, but making it shine if it is there. I guess that's what is nice about having that extra subwoofer in the tower version. The high-end is harder to compare, as it's a very different tweeter to mine which have the early focal tweeter that you can't get any more (that some say was a very special tweeter). Overall they are highly detailed and very resolving of individual sounds. 1 Link to post Share on other sites
Guest jakeyb77 Posted September 17, 2019 Share Posted September 17, 2019 There is also 20kgs of lead inside that help to stop any resonance. Although if you see inside the cabinets you’d wonder if there would be any cabinet resonance anyway. I was asked not to take a photo of the cabinets inside which is fair enough. Link to post Share on other sites
Kaynin 3,782 Posted September 17, 2019 Share Posted September 17, 2019 8 minutes ago, aussievintage said: I have heard the new Epitome Reference towers at my brother's place, but only for about half an hour. I plan to visit for a longer listening session. How to compare with the older Eclipse Reference (non-tower) that I have now? Bigger and better springs to mind. Very big and heavy to move about. The bass sort of fooled me. On one record I thought it sounded a bit light, but on the next the bass blew me away. I would say it's a case of not introducing any false bass if the recording is lacking, but making it shine if it is there. I guess that's what is nice about having that extra subwoofer in the tower version. The high-end is harder to compare, as it's a very different tweeter to mine which have the early focal tweeter that you can't get any more (that some say was a very special tweeter). Overall they are highly detailed and very resolving of individual sounds. Thanks Aussie, good to hear your thoughts. Yeah I've heard the Epitome towers a few times before, but only the old tweeters. I won't get too caught up in the finite differences between models, so may look closely at the standard towers vs the reference and elite. Maybe even the eclipse towers because they're still a fantastic speaker, but saving some money. I doubt I'll spend on the Elite upgrade... @Quark what towers do you have? I remember listening to those and loved them... Link to post Share on other sites
Kaynin 3,782 Posted September 17, 2019 Share Posted September 17, 2019 4 minutes ago, jakeyb77 said: There is also 20kgs of lead inside that help to stop any resonance. Although if you see inside the cabinets you’d wonder if there would be any cabinet resonance anyway. Very true, well worth the extra $$$ though for the lead lining, IMHO. Link to post Share on other sites
Quark 870 Posted September 17, 2019 Share Posted September 17, 2019 3 minutes ago, Kaynin said: Thanks Aussie, good to hear your thoughts. Yeah I've heard the Epitome towers a few times before, but only the old tweeters. I won't get too caught up in the finite differences between models, so may look closely at the standard towers vs the reference and elite. Maybe even the eclipse towers because they're still a fantastic speaker, but saving some money. I doubt I'll spend on the Elite upgrade... @Quark what towers do you have? I remember listening to those and loved them... I've got the Eclipse reference towers. No longer running the Stereoknight valve pre and mono blocs - I've gone with an Elektra Pnyx pre and HD300 amp. Link to post Share on other sites
Kaynin 3,782 Posted September 17, 2019 Share Posted September 17, 2019 1 minute ago, Quark said: I've got the Eclipse reference towers. No longer running the Stereoknight valve pre and mono blocs - I've gone with an Elektra Pnyx pre and HD300 amp. That's very interesting. I loved them, maybe a better price point for me. 1 Link to post Share on other sites
aussievintage 3,828 Posted September 17, 2019 Share Posted September 17, 2019 20 minutes ago, Kaynin said: Very true, well worth the extra $$$ though for the lead lining, IMHO. Both versions I have heard were lead lined. You can barely feel a vibration on the outside when they are working. 1 Link to post Share on other sites
Moderators joz 5,687 Posted September 17, 2019 Moderators Share Posted September 17, 2019 17 hours ago, Quark said: I've got the Eclipse reference towers. No longer running the Stereoknight valve pre and mono blocs - I've gone with an Elektra Pnyx pre and HD300 amp. Being a longtime fan of the Elektra combo myself, just wondering what sonic changes you experienced going to the Pnyx HD combo from the Stereonight? Link to post Share on other sites
Quark 870 Posted September 17, 2019 Share Posted September 17, 2019 22 minutes ago, joz said: Being a longtime fan of the Elektra combo myself, just wondering what sonic changes you experienced going to the Pnyx HD combo from the Stereonight? It's been a bit of a journey Joz. With the Eclipse towers and their beryllium tweeters I found the sound too bright initially when moving to the Pnyx. I've since changed out the crap Electroharmonix valves for some NOS ones and am much happier with the sound now. The NOS valves also have a much, much lower noise floor. The Stereoknight Enigma was also a little bright for my tastes until I swapped out the Electroharmonix valves for NOS ones. I know Arthur reckons he built the Pnyx to suit the Electroharmonix sound, but I've always found them harsh sounding, noisy and unreliable junk. 2 Link to post Share on other sites
Moderators betty boop 15,811 Posted September 17, 2019 Moderators Share Posted September 17, 2019 1 minute ago, Quark said: I've since changed out the crap Electroharmonix valves for some NOS ones and am much happier with the sound now. thats the great thing about valve s can just change out like that to find a better fit. @joz no harm in rolling some in to see what think.. can always change them back out if not really your thing 2 Link to post Share on other sites
Quark 870 Posted September 17, 2019 Share Posted September 17, 2019 In case anyone's wondering, I'm running : Valvo PCC88 7DJ8 in the rear sockets (these are a 7V heater) Siemens A-Frame ECC88 in the front sockets Running the Valvos in the front sockets was way too dull. 1 Link to post Share on other sites
aussievintage 3,828 Posted September 17, 2019 Share Posted September 17, 2019 55 minutes ago, Quark said: With the Eclipse towers and their beryllium tweeters I found the sound too bright initially when moving to the Pnyx. I've since changed out the crap Electroharmonix valves for some NOS ones and am much happier with the sound now. The NOS valves also have a much, much lower noise floor. The Stereoknight Enigma was also a little bright for my tastes until I swapped out the Electroharmonix valves for NOS ones. My Eclipse Reference have the same tweeter, but I run all sorts of valves, especially 12AX7s in my various phono preamps. In one I have an Electroharmonix in first position, then a Mullard (original, not one of those new copies). In another I have two Electroharmonix. In a third, I just discovered, I have an unknown thing in first position. Must have left it there last time I was trying out spares - looks like a Ruby of all things, followed by an Electroharmonix. In my line preamp I have two lovely AWV 12AU7s. Haven't found the sound to be overly bright on any of those combos. Maybe they work better in phono preamps. 1 Link to post Share on other sites
aussievintage 3,828 Posted September 18, 2019 Share Posted September 18, 2019 Job finished AND successful. Glued the outer edges of the foam down yesterday, and installed them this morning. Working like new!! 1 Link to post Share on other sites
Guest jakeyb77 Posted September 18, 2019 Share Posted September 18, 2019 2 minutes ago, aussievintage said: Job finished AND successful. Glued the outer edges of the foam down yesterday, and installed them this morning. Working like new!! Great job! Are the new surrounds co trolling the extension better? Link to post Share on other sites
