Ancientflatulence Posted July 13, 2014 Share Posted July 13, 2014 violin and cello is best served live unamplified What size and type of vehicle do you need to fit a string quartet ............... maybe one of the early 60's American tanks .......... and if you can fit the string quartet, where do you sit to be in the suite spot? Link to comment Share on other sites More sharing options...
Lenehan Audio Posted July 16, 2014 Share Posted July 16, 2014 @ Hi Mike Did you do any comparisons with stainless steel screws? Cheers Pete Hi Pete stainless are the same as mild or HT steel screws ! no good . All I can say is the reasons for the intrinsic superiority of brass ,copper and cast grey iron has to do with what I can only describe as mechano thermal transmission ! some materials do it and some don't . Regards Mike Lenehan Link to comment Share on other sites More sharing options...
Addicted to music Posted July 16, 2014 Share Posted July 16, 2014 What about glue? Link to comment Share on other sites More sharing options...
Addicted to music Posted July 16, 2014 Share Posted July 16, 2014 (edited) Hilarious video. Thanks for posting. Somehow I can't come to grips with the news Mario has sold all​ his gear (or did I misread that bit???). After spending a small fortune on modifications, specialised parts and no doubt thousands of hours of tweaking he is now systemless????? Sanity check please.......... Cheers, Alan What do ya expect from someone who uses a clapping joker as an avatar and drops one liners on SNA...doh! Edited July 16, 2014 by pchan Link to comment Share on other sites More sharing options...
Guest DFZ Posted April 26, 2015 Share Posted April 26, 2015 How can B-O-S-E stand for Buy Other Sound Systems? B-O-S-S? Perhaps - Buy Other Sound Equipment - would be a better fit? ( My car audio equipment is BOSE and it's not too bad. ) Link to comment Share on other sites More sharing options...
Guest Muon Posted April 29, 2015 Share Posted April 29, 2015 Damn! Now I need to change again, from Brass to Copper screws :blink: If It's better so be it Link to comment Share on other sites More sharing options...
Guest Muon Posted April 29, 2015 Share Posted April 29, 2015 Hi Dave Yup it was bloody hell getting a copper Allen Head screw to handle even the low tensions we use ( 3 prototypes were sent from the factory) the tension is quite critical and quite low. Tensioning the screws too tight produces an amazing reduction in performance . If the screws are unequal or incorrectly tensioned against the baffle the woofer basket rings and it's audible. Using a tension driver also produces better basket damping and concurrent 3D resolution(BELIEVE IT Oooooooor NOT ! Where did I put that bloody packet of placebo's? ). Regards. Mike Lenehan Got to get myself a torque driver, i still haven't checked mine to make sure things are correct. Link to comment Share on other sites More sharing options...
DoggieHowser Posted April 29, 2015 Author Share Posted April 29, 2015 Buy Other Sound Systems.pngHow can B-O-S-E stand for Buy Other Sound Systems? B-O-S-S? Perhaps - Buy Other Sound Equipment - would be a better fit? ( My car audio equipment is BOSE and it's not too bad. ) Everybody's a critic Yeah I was aware of the typo when I reviewed it later but didn't think it warranted another edit and reuploading the video Link to comment Share on other sites More sharing options...
