zog
commercially available low power class A solid state amplifiers?
I've been reading about the various DIY plans and kits that implement this kind of amplifier (PASS, Hiraga, JLH 1969, which I have made) i.e. 8 - 20W range - but which commercially sold amplifiers fit into this class, or would be comparable?
Just curious - and my usual googling hasn't shown up a great deal.
Except this: http://www.ebay.com.au/itm/251547958309 which doesn’t count :D
Not sure if you were after DIY, but commercially completed amps with that spec are very short on the ground. I thought there was maybe a sugden that fit the description, this was the closest (more power than requested @50 watts), the rest are Integrated's;
http://sugdenaudio.com.au/?p=64
This is the only one. I know of Within your spec, but it is not cheap....
http://www.telluriumq.com/iridium-20/
Edited by Ray H
Yes there are lot's of DIIY/kit type options, was just curious about the commercial ones in a similar class (if any).
also this one, also not cheap:
http://www.firstwatt.com/sit2.html
If you want a low power "fully built" amp (ie. not DIY) ... why wouldn't you go for a tube amp?
I already have (DIY) examples of both here I'm playing with, this is more about finding similar amps out of curiosity.
Valvet Class A E1r monos - (10 w/ 8 ohms)
http://www.highend-electronics.com/16.html
Aha.. also while googling for more info on that one I found:
Audioprojekte CA10
http://www.audioprojekte.de/html/ca10en.html
The diy amps you have there from opc might become commercially available yet ;)
(No idea when but its certainly on the cards)
Edited by hochopeper
Garry Cawsey has designed a solid state Class A amplifier incorporating new topology and improved components.It has passed the prototype stage and is currently being manufactured  in small production runs for field testing.Certainly not having to use an expensive output transformer and pre war inefficient valves is very much in favour of the solid state vs the vacuum designs.
I build only SE class A valve amps but it would be nice to compare them with a commercial SS Class A. Mine are a lot cheaper. Lol.
There are very few genuine Class A amplifiers. Most manufacturers lie about the ratings, in order to gather more sales. The Musical Fidelity A1, for instance, was rated 20 Watts Class A. It's actual Class A power was somewhere less than 2 Watts Class A. Not that there is anything wrong with that. 2 Watts Class A is a very substantial amount of Class A power for any amplifier. More than sufficient for most situations. The other issue is that of sound quality. There is no evidence to suggest that a Class A amplifier sounds better than a PROPERLY designed Class A/B one.
If you really must look to a Class A amplifier, then the Silicon Chip 20 Watt Class A amplifier is one of the best. It is a genuine 20 Watts Class A and sounds very fine indeed. Altronics stock the DIY kit.
http://www.altronics.com.au/p/k5125-20w-class-a-amplifier-full-kit/
Yup all crap - please send to me and I'll dispose of them properly. :)
The circuit is most unconventional and the designer Tim de Paravicini states it provides 20W class A - looking at the schematic I can't argue with his reasoning.  Mark Hennessey's page http://www.markhennessy.co.uk/mf_a1/ is probably the best out there if you want to do some homework.
Now all the other MF "A" amps do not produce anything like this amount of class A and some are completely conventional AB amplifiers.
Yes, I'm aware of the Silicon Chip 20 Watt Class A, it looks great, but it's DIY. Just curious as to what similar non DIY products are there. My next likely amp I'll build will be Class AB -
I've also got OPC LPUHP pcbs waiting for when I get around to it as the next possible amplification upgrade - they are 15W class AB. Would be great if he made them available as assembled units.
What about Nelson Pass ,First Watt series of amps .  I don't really know if theyre class A .
all of them are class A, ...or they were until they left and go to B :D
I never suggested that the A1 was crap. Far from it. It is one of the nicest, small SS amps ever made. It is not even remotely close to 20 Watts Class A, however.
I've measured several A1 amps. Class A power is around 1.75 Watts. The method MF chose to arrange the heat sinks prevents any more Class A power to be available.
Sure. Some time ago, I worked on an MF A370. It was claimed to be 185 Watts Class A. It was not. It was around 12 Watts Class A. Certainly, a healthy amount of Class A, but not what it was claimed to be. Just like the A1.
Edited by Zaphod Beeblebrox
All single ended MUST be Class A. The First Watt is a single ended design.
I think the F5 is a push-pull, some of the other First Watt amps are single ended... not that I'm an expert :-)
SS
Edited by Sub Sonic
I think the F5 is a push-pull, some of the others are single ended... not that I'm an expert :-)
SS
what do you think of the F5? i think i remembered you built one.
How so?
Edited by thoglette
How so?
The heat sink can only operate as a radiator, rather than a convection cooled one. Convection cooling is vastly more efficient.
In fact, I plan to present an experiment I will be performing with the most popular cooling systems in a week or two. I will include a radiative heat sink, despite the fact that no designer uses such a system, due to it's low efficiency.
Hi Henry,
It's still in the works, one of the many projects which make this hobby so much fun! :-)
Regards,
SS
The heat sink can only operate as a radiator, rather than a convection cooled one. Convection cooling is vastly more efficient.In fact, I plan to present an experiment I will be performing with the most popular cooling systems in a week or two. I will include a radiative heat sink, despite the fact that no designer uses such a system, due to it's low efficiency.
Yes, the A1 always struck me as having a most inefficient heatsink design for "Class A".
SS
I'm no expert in the area of design but I can see that this amp at least has decent sized Torroidals.
http://www.cattylink.com/page380.html
I've got the A/B version, the S200 and it's a decent piece of kit.
And?   Why does this stop the amplifier operating as designed ?
Others report a standing current of c. 700mA  per side and a static consumption of c. 80W.  Which is entirely consistent with ten or twenty watts of class A output.
What was the standing current you measured? How did you determine that the amplifier was either shutting down or otherwise leaving class A at below 2 watts?
A friend of mine has built a number of F5s. The bottom end is extremely extended. But apart from that I think they are ordinary.
    • By thejt
      Item: Shanling MC-30 Music Centre (Valves)
      Price: $625 or $650 with Logitech Harmony 650 universal remote
      Item Condition: Excellent
      Reason for selling: Too much gear
      Payment Method: Pickup - Cash, Shipped - Direct Deposit
      I am the second owner of this locally delivered 240V unit and I am sure I will regret selling this later. Ask anyone who has ever come across one of these and they will back me up with how they were blown away by this little unit. The build quality is excellent, thick aluminium body and heavy transformers. The design is well thought out with the feet all featuring levelling. The sound it makes is lush and although it seems like it would not create a generous amount of sound at 3W (Class A) I can fill a lounge room with gorgeous sound without even going half way on the dial. This is without even using easy to drive speakers, I had used Quad 11L and Dynaudio Contour 1.32E which are both only about 86dB. It has a pre-out should you want more power, but I tried using a Quad 909 and preferred it direct. The unit actually provided more bass on its own. Feature wise, CD player, FM and AM radio, 3.5mm input and RCA input which should cover everything you could want.
      The original owner lost the remote but the unit can be operated from the controls on the device itself. Volume adjustment is a bit of a chore like that though so I picked up a Logitech universal unit which I can include for an extra $25 (cost $70). A common issue with many Shanling CD players is the occasion pause during cd playback but this is occurs only very occasionally and lasts about 1 - 2 seconds before resuming. The MC-30 has been otherwise faultless. I have the original double box so can ship at buyers risk if desired but note it is fairly heavy. Great chance to get into valves or Class A amplification without too much outlay. Questions welcome and I will try to answer best I can. Donation on sale to SNA. Please look at all the glowey bits in the pictures!
      Praise:
      https://www.stereophile.com/integratedamps/308shan/index.html
      http://www.charismaaudio.com/products/shanling/mc30.htm
    • By sufioz
      Item: NAD 375BEE Integrated amplifier
      Price: $775
      Item Condition: Very good, sparingly used over last six years but i dont have the packaging. However the amp is in great condition as is the remote.
      Reason for selling: NLR, thinking of changing to tube integrated amp to have a change!
      Payment Method: Pickup - Cash, i think shipping will be cost prohibitive.
      Extra Info: This is a great integrated amplifier just below the NAD Master Series, very solidly built , with seven inputs, bass and treble settings, and with a clean sound.  Works like a treat with with Bluesound Node 2i and Synology NAS (for those that stream or have digitised music) in my setup.
      It is still sold in the USA for USD 1750 which is about AUD2600 ex GST. You can read its reviews here.
      The NAD C 375BEE features a sophisticated design and beefy construction to bring out the best in all your music — from the lowest, wall-shaking pedal notes of a pipe organ to the delicate reverberation of a solo acoustic guitar. This integrated amp delivers 150 full-bandwidth-rated watts to each of your stereo speakers for powerful, undistorted sound, even during your music's most demanding passages.
      Specs
      150 watts x 2 channels into 8 ohms (20-20,000 Hz) at 0.009% THD 150 watts x 2 channels into 4 ohms (20-20,000 Hz) at 0.009% THD 4-ohm capability allows use with a wide range of speakers signal-to-noise ratio: 102 dB PowerDrive™ circuit with automatic speaker impedance sensing delivers maximum dynamic power output regardless of speaker load switchable Soft Clipping™ circuit gently limits amplifier power output to reduce risk of speaker damage due to prolonged high volume operation distortion-canceling circuit for high-accuracy sound toroidal power transformer all-discrete circuitry with four pairs of high-wattage output transistors per channel rotary bass and treble controls with defeat switch for tone control bypass 7 RCA audio inputs including 2 tape in/outs optional NAD PP375 phono preamp module allows upgrading for turntable connection front-panel minijack input for connecting a portable music player main-amp input and 2 preamp outputs for connecting a powered subwoofer or separate amplifier for bi-amping full-size headphone jack front-panel switching for 2 pairs of speakers two pairs of custom gold-plated speaker binding posts bridged mode for mono operation (330 watts x 1) RS-232 port for operation with third-party controllers 12-volt trigger output IR input/output detachable AC power cord <1W Standby Power Consumption free of lead and other environmentally dangerous substances remote control weight: 33.7 lbs. 17-1/8"W x 5-15/16"H x 17-1/2"D
    • By Highpower
      Item: Denon PMA-880R Class A Integrated Amplifier
      Price: $300
      Reason for selling: Accumulated too much hifi gear and about to move to a new house
      Extra Info: This Denon PMA-880R Optical Class A Integrated Amplifier complete with RC-156 remote control and Operating Instructions is in mint condition. This amplifier was made in Japan in 1993.  Amps made by Denon in this era were considered to be the best amps that Denon ever made. These amps hardly ever come up for sale.
      I have owned this amplifier from new and it has been very well looked after. The amplifier and remote control still look brand new and are unmarked. It's whole life has been in a cabinet behind a glass door, which is why it still looks brand new.
      This Class A integrated amplifier has a very clean, detailed and powerful output that is impressive for both analogue and digital sources. There are no crackles or hums present and it performs just as well as the day I purchased it.
      The PMA-880R has a solid power supply that uses a shielded toroidal transformer, and a pair of large 12,000uF capacitors for voltage smoothing and a very substantial heat sink. It features a source direct switch for tone controls bypass and optical connection between amplifier stages for detailed sound. Speakers can be connected via A, B, A B front switching. The speaker binding posts accommodate bare wires or banana plugs. The power rating is 2 x 75W RMS at 8 ohms or 2 x 120W at 4 ohms. The Denon PMA-880R uses an Optical class A circuit design for optimum sound quality. Source Direct can be used to bypass tone controls. The Denon PMA-880R accommodates both MM moving magnet and MC moving coil Phono options via front switching.
      The Denon PMA-880R has the following RCA inputs: Phono, CD, Tuner, Aux, DAT/Tape-1, DAT/Tape-2. The amp also has a Record Out Selector a headphone jack, and a loudness button.
      The specifications are as follows:
      Power output: 75 watts per channel into 8Ω (stereo)
      Frequency response: 20Hz to 20kHz
      Total harmonic distortion: 0.02%
      Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 76dB (MC), 94dB (MM), 110dB (line)
      Output: 150mV (line)
      Dimensions: 434 x 160 x 353mm
      Weight: 8.2kg
      Accessories: RC-156 remote control
    • By tominmelb
      Item: Unison Research Unico Secondo Hybrid Tube Amp
      Price:  $1800.00
      Item Condition: Mint
      Reason for selling: To fund other purchases.
      Payment Method: Pickup - Cash, Paypal.
      Extra Info:  Beautiful Italian made hybrid tube amp in mint condition.  Has optional phono card installed ($RRPP $4400).  Comes with all original packaging and remote.  From a smoke and pet free home (and a child free room)
    • By ZOOTYtooty
      Item: Threshold S200 power amplifier
      Price: $1200 Sale Pending payment
      Item Condition: Used
      Reason for selling: Need a matched pair for speakers with active 2-way crossover
      Extra Info: Here is a stunning Threshold S200 Stassis power amplifier. Rare and beautiful!
      It is in absolutely lovely condition and has just come out of 10Years storage, brought up to voltage slowly and is sounding superb!
      The manual is included and postage is possible at buyers expense.
      The voltage on the rear has a sticker from the UK 220V, but the transformer has 120v and 120v primary thus clearly a 240v transformer (picture included).
