Guest atilsley
Open Baffle Speaker Pics
Guest atilsley
I think the simple clean lines of this OB are very good....good pricing also.
Here's some pics of OB's I found....quite nice.
post-103876-0-70698700-1399464914_thumb.
post-103876-0-78192200-1399464923_thumb.
post-103876-0-92421700-1399464934_thumb.
post-103876-0-09685700-1399464949_thumb.
post-103876-0-46986900-1399464957_thumb.
post-103876-0-47216300-1399464977_thumb.
post-103876-0-83732300-1399464992_thumb.
Guest atilsley
Now, what about OB AND horn...?!?
Ooh.
post-103876-0-43429200-1399465982_thumb.
post-103876-0-91151300-1399466001_thumb.
It strikes me that a lot of these open baffles are too small to support low bass.
Plenty of width coupling to the floor, helps too in this regard.
And central/symmetrical driver placement tends to reinforce/concentrate front/rear cancellations at specific freqs.
Otherwise, very pretty designs! :)
Cheers, Owen
Dark Lantern blog - http://darklanternforowen.wordpress.com/
Edited by Owen Y
Narrow OBs are fine, they just need a correctly designed crossover/EQ
and high xmax woofers if qts less than 0.6
Guest atilsley
Bert Doppenberg's OB....way cool. Uses x4 15-inch BD woofers/side.
I've started to build the half version...thinking about using x2 Altec 416's/side. Project stalled. Frames built.
post-103876-0-35920200-1399609062_thumb.
post-103876-0-42413300-1399609076_thumb.
post-103876-0-74214100-1399609092_thumb.
Any links for more info on this?
Always more excursion or additional/larger drivers   ;)
The Qts isn't relevant to xmax at all
....  but a component of it, Qes can be relevant to power handling.     In the case where you have a high Qes driver, and an amplifier with >> 0 output impedance.   This produces extra efficiency at system resonance, which may help if Pe (power handling) is your limit.    I posted a picture of this in another thread of your recently.
Wings or H frames can be very effective at extending the baffle of a bass dipole speaker.... but they do detract from the style of a traditional 'OB'
yeah sure, but we are discussing about flat baffle, no U, H nor W baffle was mentioned.
Sure... I know they weren't....  until I bought them up at the end of my post as a way to help excursion/power handling    (because aside from EQ, or more drivers, it's about the only other option)
The main point of my post, was that the Q of a driver has no bearing on how much Xmax you will need.      If we had 3 drivers, same size, all with very different Q .... then they still need to move the same amount to make the same output.   Thave all have identical excursion
