I'm considering adding a power amplifier such as a Rotel RB-1562 to handle the front left and right channels of my 5 channel set up. Receiver is a Denon AVR-1313 and front pair of speakers would be either Kef LS50 or Dynaudio Excite X12. Would this be a worthwhile upgrade or should I head in a different direction?
can't imagine it not being a step up from the denon for power amp side. personally though I would go with a nice 2ch integrated with htbypass instead. this will give you a 2ch pre and pwr upgrade over the denon receiver. and would still act as a power amp for driving your fronts to the benefit of av/ht side of things.
when demoing the kefs or dynaudio be sure to check out what amps there are as well you can demo with them with the htbypass functionality :)
Any recommendations for a suitable integrated with HT bypass?
whats your budget ?
About $1500
that should buy something pretty decent. theres m3i going here at $1895 (including a $300 cable). could tell them to keep the cable and could be on budget,
http://www.ebay.com.au/itm/Musical-Fidelity-M3i-Integrated-Amp-Includes-Free-Chord-Cable-Valued-at-300-/121316991676?pt=AU_Electronics_Audio_Amplifiers&hash=item1c3f0e62bc&_uhb=1
naim nait 5i with some arm twisting could be in reach too
http://www.targahifi.com.au/nait5i2.htm
peach tree nova, cambridge 851A, yamaha AS1000/2000
some older models but crackers ! try looking out for musical fidelity A308 or A5 integrated superb numbers. also an a3.5 all with ht bypass
there also the arcam A19 or A28 in their fmj series, pretty sure the creek models have ht bypass as well.
probably other options too. but consider only what can check out :)
Thanks al that gives me a few options to look out for.
Just wondering if you need a integrated with htbypass ?
Would an integrated amp with power amp function also work ?
I don't have experience with it so correct me if I'm wrong.
but if an integrated has a poweramp option couldn't you use that instead ?
As far as I know , the power amp option will bypass the pre-amp, and will disable volume control.
If I use the avr's pre out for the front, and connect them to via rca to the power amp direct in.
Wouldn't the avr control the sound output that goes to the power amp ?
Edited by Damhooligan
essentially your using the integrated as a power amp I gauge. or is it used as integrated for 2ch as well ?With a button for power amp function ? Which might be another name for htbypass...
which type of integrated is this damh, something OP might be interested in. keeping in mind the reason for the recommendation of 2ch integrated is a pre and power upgrade for the op for 2ch. os the integrated has to operate as an integrated i.e. pre an power sections for 2ch. and for ht only the power section is utilised. the htbypass by effect is doing just what your saying for ht. but for 2ch when disengaged the pre
The amp i was referring to is Marantz pm7004.
But also goes for older models,as the amp itself doesn't change much.
I think the newer/latest is the pm8005.
But it's hard to find in aus, i found one in 'valuebasket.com' for just under 1600.
But not sure what to make of this shop, as don't know much about them .
Hi Damo, that's just same as htbypass, just another name for it. those marantz amps should be added to ops list to check out
Awesome, that's good news for me to, if i go multi channel one day.
But the rrp is over 2k, so outside the op's budget.
    • By Max Headroom
      Item: NAD C 275BEE Stereo Power Amplifier - does not include Integrated in picture, see my other sale
      Price: $600
      Item Condition: Perfect
      Reason for selling: Looking at upgrading to NAD Master Series
      Extra Info: This stereo amplifier is a proverbial iron fist in a velvet glove.
      If you can never have enough power, match this brilliant power amp with the matching integrated, and switch them both to bridged mode, sit back and revel in the awesome scale and control that this amp has. This amp has performance that simply must be heard to be fully appreciated.
      This integrated has lots of trickle down technology from the NAD Masters Series M3 Amplifier. These include application of Bjørn Erik Edvardsen’s Distortion Canceling Circuit in the output stage and BEE Clamp in the power supply, with distortion and noise reduced down to unprecedented levels.
      The C275BEE is the same Power Amplifier circuitry as used in the C375BEE Integrated Stereo Amplifier and can be connected to form a truly prodigious combination. As a two-channel amplifier, the possibilities are numerous. Experience room-filling sound with impressive musical detail and transparency. The NAD C275BEE features a sophisticated design and beefy construction to bring out the best in all your music from the lowest, wall-shaking pedal notes of a pipe organ to the delicate reverberation of a solo acoustic guitar.
      What HiFi loved this amp: "If you're looking for a powerful but subtle amplifier, then the NAD C275BEE power amp, paired with the matching C165BEE preamp does the trick"... "A likeable brute of an amplifier. For those who want plenty of sonic muscle without having to sacrifice subtlety too much.
      https://nadelectronics.com/product/c-275bee-stereo-power-amplifier/
      This amp will drive just about any load down to 2ohm, and can hit 800w at 8ohm in bridged mode.
      2 x 150W Continuous Power into 4 Ohms and 8 Ohms
      250W, 410W, 600W IHF Dynamic power into 8, 4 and 2 Ohms, respectively
      PowerDrive™ circuit
      Holmgren Toroidal Power transformer
      All discrete circuitry
      Class A Voltage Stages
      BEE Anti-saturation Clamp
      Copper bus bars
      Short signal path from input to output
      All sockets Gold-plated
      Soft Clipping™
      This amp has run beautifully without a hitch, and works incredible well with the matching C 375BEE integrated that I'm selling - the power amp in the integrated is meant to be the same as this standalone power amp.
      I have a box that I received the amp in, so it will be packed well, but I don't have the original packaging.
    • By Supe_3057
      Item: Rotel A12 Intergrated Amplifier, 12 months old
      Price: $900 ono $720.00 inclusive $20 Donation
      Item Condition: Excellent
      Reason for selling: Change in direction
      Extra Info: Item is in excellent condition minus a little dust. Have box and I think all the original packaging.
    • By glams
      Being new I’m not sure if I’m supposed to start a new topic or tag onto an old one, so here I am.
      We have a wonderful, if not old, stereo set-up with Rotel AMP and pre-amp, Yamaha multi CD player, an old turntable and Dali bookshelf speakers. I love using it, but the rest of the family just grabs the portable Bluetooth speaker and connects to their phones! In an attempt to use the digital technology and get a better sound than a portable Bluetooth speaker, I purchased an audio pro Addon C10. Much better sound – may need to get a second one!
      Anyway, the point of all this, apart from lamenting my old system, was to see if anyone knows of a sound bar for the TV that is compatible with audio pro gear. I cannot seem to find one. Audiopro have a gadget called a’Link 1’ but a person at one particular  store was not sure it would connect to a soundbar or a TV.
      Any ideas welcome! Maybe it’s as simple as using the Link 1?
    • By audio_file
      Item: Rotel RA-820
      Price: $150
      Item Condition: Scratched
      Reason for selling: Replaced
      Payment Method: Pickup - Cash, Paypal, Bank transfer
      Specifications from https://www.hifiengine.com/manual_library/rotel/ra-820.shtml:
      Power output: 25 watts per channel into 8Ω (stereo)
      Frequency response: 10Hz to 40kHz
      Total harmonic distortion: 0.4%
      Damping factor: 20
      Input sensitivity: 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 75dB (MM), 95dB (line)
      Speaker load impedance: 4Ω to 16Ω
      Dimensions: 430 x 66 x 271mm
      Weight: 5.5kg
      This was used for PC desktop speakers driving KEF Q1 speakers.
      I tried it on my Spendor SP2/3R2 and it had no problem driving these.
    • By leqt1969
      Item:  Roksan Caspian M1 Power Amplifier
      Price: $750.00 ONO
      Item Condition: Excellent used condition
      Reason for selling: NLR
      Extra Info: Advertised on behalf of a friend in Sydney. This is in excellent used condition.
      Caspian M series-1 Power Amplifier Spec
      Input Impedance: 38 kΩ
      Input Sensitivity: 700mV RMS
      Signal Inputs: Left & Right channels
      Signal Outputs: Chain Output L & R Channels
      Power Outputs: Loudspeaker, L & R
      Output Power:> 85 Watts continuous, into 8ohm; both channels driven; 120 Watts continuous, into 4ohm; both channels driven
      Power Supply: 330VA Ultra Low Noise Toroidal Transformer
      Current Output: 50 Amps Peak to Peak
      Damping Factor: & gt; 140 (8ohm)
      Frequency response: -3dB, <1Hz -> 100kHz
      Gain: 30.7dB
      Harmonic Distortion: <0.003% 1 kHz - 8 ohm <0.003% 1 kHz - 4 ohm Signal to Noise Ratio:>116dB (ref 70W, 8ohm)
      Dimension: 432 x 330 x 70 (W x D x H) mm 432 x 330 x 85 (including feet)
      Weight: 10 Kg
