Thought it was about time I posted a thread about my recent speaker acquisition
Speakers - Klipsch La Scala - Highly Modified
3 way Horn
Originally built by fellow SNA member Sootshe and purchased by me Jan 2014
These speaker cabinets are built to Klipsch blueprint plans with added bracing and double wall back and sides for extra strength and dampening
Built in plywood and wood veneer with added Timber Eliptrac 400 Mid Horn
And a bass bin under
For my part in this build - I have continued to tweak and modify on the fringes to get the best sound possible for my listening room and after many tweaks and lots of listening and 3 months later I believe I have achieved Nirvana
More on the tweaks in following posts
Here is a cutaway view drawing of the speaker and bass bin construction
post-112724-0-88068000-1397345079_thumb.post-112724-0-10770600-1397345096_thumb.
Edited by Full Range
  • Like 7
  • Replies 284
Popular Posts
I suppose you are all wondering what do these Klipsch La Scalas look like all set up Well I will post some photos for you to look at while I continue to post specs of the build also drivers and comp
Thought it was about time I posted a thread about my recent speaker acquisition Speakers - Klipsch La Scala - Highly Modified 3 way Horn Originally built by fellow SNA member Sootshe and purchas
I had the pleasure of visiting Paul today to hear these speakers. Firstly, thanks for the hospitality and the great coffee. These are even more physically impressive in the flesh. The finish is supe
Well I will post some photos for you to look at while I continue to post specs of the build also drivers and components used in this construction
post-112724-0-06186200-1397345589_thumb.post-112724-0-91491700-1397345614_thumb.post-112724-0-95835900-1397345679_thumb.
  • Like 12
  • Love 1
Although the construction is to Klipsch spec it has been modified to enhance its performance and flexibility
First mod was to add extra bracing by way of using a double layer of ply on the sides and back and braces to the bass horn side walls
Second mod was to separate the single cabinet construction to a double separate cabinet configuration
Drivers used as as follows
Woofers - Crites - CW1526C 15 inch cast alloy
Mid Range - Great Plains Audio - GPA 399 Compression driver ( These are made by Altec Lansing )
Fitted to a pair of Eliptrac 400 timber mid range horns
Tweeters - JBL 2404H “Baby Cheeks†tweeters.
Crossovers used are
ALK Universal crossovers with tweeter attenuators
post-112724-0-21481400-1397346590_thumb.post-112724-0-67897700-1397346638_thumb.post-112724-0-65885700-1397346686_thumb.
  • Like 5
My tweaks were experiments in
Hook up wire, insulation, sound-wave optimisation in the dog box section ( bass ) , separating & coupling of the two cabinet sections
The two cabinet sections of the base and mid range were originally placed on top of each other (timber to timber )
I elected to separate and couple them with some Made in Germany - Alto Extremo feet - 3 per Mid range unit
post-112724-0-32436000-1397348345_thumb.post-112724-0-74193400-1397348375_thumb.post-112724-0-34147900-1397348397_thumb.post-112724-0-92587100-1397348428_thumb.
I went through a few but simple dog box ( bass ) tweaks
And after many many hours of listening and getting second opinions I settled for this
Normally unnecessary but due to the addition of the bass box section I felt it prudent to help the sound waves as much as I can
First I sourced from Spotlight (a craft type shop) some styrofoam cones of a suitable size to fit inside the cavity and attached them to the back of the driver magnet ( think aerodynamics )
At first I wasn't sure if this tweak would work but listening tests confirmed that it made a difference in a wholesome way to the sound and especially tighter bass
post-112724-0-02607600-1397349501_thumb.post-112724-0-63498700-1397349524_thumb.post-112724-0-77816500-1397349560_thumb.post-112724-0-79124900-1397349581_thumb.
  • Like 4
I then proceeded to rework the insulation inside the bass bin section
The previous owner had it fully lined with fabric covered fibreglass insulation
This was carefully removed and vacuumed cleaned to give me a blank canvas to work with
Sound testing without insulation was first tried to get a ball park idea of what was required and it displayed some reverberations in bass output
I used my go to motor room insulation that I have had success with on my other speaker builds
The only sections that were insulated was the - sides, back and top ceiling area with the bottom and front left bare
Also a couple of insulation strips at the port pipe entrance and finally added recently some 400mm X 200mm plastic air balloons 3 per tube
The difference this mod has done to bass delivery and definition is nothing short of amazing
First photo is the before tweak
post-112724-0-93063500-1397351014_thumb. post-112724-0-31373200-1397351049_thumb.post-112724-0-82161900-1397351072_thumb.post-112724-0-39175100-1397351200_thumb.
  • Like 3
I have recently purchased from another SNA member a set of ALK Design AP12-600 + AP15-6000 Crossovers http://www.alkeng.com to give me some flexibility in tweaking the mid range driver and tweeter with separate hard wired selectable attenuators
And of course ( knowing me :) ) I had to tweak these as well - but only a small one for now
The tweak was an upgrade from standard resistors to a set of hand made Duelund Cast graphite silver resistors http://www.hificollective.co.uk/components/duelund_cast_resistors.html
Photos of before and after
post-112724-0-93067400-1397352389_thumb.post-112724-0-96161000-1397352422_thumb.
For my next tweak I need to enlist help from a local Brisbane SNAer that has electronics experience to be paid in superb award winning coffee and conversation ;)
Help is required to rebuild the the ALK design universal crossovers to ALK AP12-500 & AP12-6000 configurations
I have all the parts and schematics - all the parts from capacitors to hand wound coils are of superior quality and will finish off the speakers to the highest standard
PM me if you are up to the challenge
post-112724-0-52754500-1397353685_thumb.post-112724-0-78319700-1397353729_thumb.post-112724-0-96489500-1397353769_thumb.
  • Like 4
Impressive stuff mate,
Always liked the Klipsch and am fascinated with the changes you've made to the original design. If I ever get to Qld, I'll be coming for a listen.
M
Now I am ready to field all your questions
But before that here are a few photos of the components that drive these speakers just for good measure
post-112724-0-60343000-1397354139_thumb.post-112724-0-12325100-1397354166_thumb.post-112724-0-72201300-1397354273_thumb.
  • Like 3
M
I also like you're builds - and give me a shout if you visit the Sunshine State
Guest atilsley
Way cool project...everything I love about horns.
The eliptrac horns are one of the very best...the ALK xovers also top notch.
Well done.
Well done.
There is a new larger Eliptrac Horn now available the 240 and I was thinking how it would suit your horn build
Here is a photo of the two the Eliptrac 400 on top and the 240 below
I have been contemplating on an upgrade - but Dave ( the builder/designer ) said that he wouldn't change a thing about my set up
post-112724-0-48635500-1397356973_thumb.
I hope all can see the rear of the timber horn as it is fitted inside the cabinet
The horn exterior has bituminous paint applied to it for sound deadening
It started its life as cut panels on a CNC machine
Here is a link of the assembly / build process - http://mysite.verizon.net/res12il11/id111.html
Just a few photos for members to use as a visual reference
post-112724-0-94788900-1397357574_thumb.post-112724-0-12032300-1397357586_thumb.post-112724-0-91245100-1397357614_thumb.
Guest atilsley
I have the 340hz azura, which I love. I came close to buying dave's eliptrac earlier.
With the bigger horn, you could even use a small paper driver for a lowish 300hz.
How's the bass with the extended bottom cab?
The soundstage of the Eliptrac Horn coupled to the other components is brilliant - the speakers are lost and the whole room is enveloped in sound - This horn is a brilliant design
Re Bass cabinet
Although I don't have measuring equipment to give you a definitive number
My ears and senses tell me that it easily gets to below 30 htz ( The Crites bass driver is rated @ 26 htz )
However after the cab tweaks - the bass produced is so crisp & fast, very defined without muddiness
Guest atilsley
Re Bass cabinet
Thanks...great to hear.
Before I embarked on the large mid bass 'azura', I looked at a few other bass options, including the La Scala.
I took the grills off and have taken the opportunity to take a few photos of the horn mouth and the bracing
Just to paint a picture for the minds eye of some bass ( dog box due to its shape ) build details
The driver faces towards the back and the sound waves are compressed in a small internal rectangular chamber before exiting past a cut slit at the rear
The sound waves are then directed to the horn chamber via triangular baffles top & bottom to exit towards the front to the listener - I have found a photo of this on the internet to post for visual reference
post-112724-0-26834900-1397450626_thumb.post-112724-0-47960100-1397450645_thumb.post-112724-0-98304400-1397450660_thumb.post-112724-0-37494900-1397450688_thumb.
  • Like 4
Re Bass cabinet
Awesome looking project, Paul! I bet it sounds fab ...
Good to see that you have taken a different approach (Bass Reflex loading) with the bass bin, than the original Klipsch La Scala, and that yours produces below 30 Hz. When I had an original pair of Klipsch Belle which is a La Scala in a nicely finished cabinet, the most annoying thing about it was the poor bass that it produced. A sort of one-noted 50-60Hz bass that intruded on the vocal range in an unpleasant boom-y way. I tried room treatments and adding a subwoofer to give it a lower range, but the annoying one noted bass from the horn bass still remained.
Is the Eliptrac mid horn basically an elliptical Tractrix Horn? I might be interested in one for my Edgar Horn set-up.
Steve.
Steve.
Hi Steve the building work on these speakers was performed or commissioned by SNA member @@sootshe
For my part I have tweaked them to suit my components and room
The Eliptrac horn was developed over on the Klipsch forum by a couple of enthusiasts and help from Klipsch
I am not sure how they would compare to the Tractrix Horn but @@sootshe opted for the Eliptrac Horn after trying one or two other types ( see photo )
When I spoke to him he basically said that the Eliptrac surpassed the previous horns
post-112724-0-73919800-1397455499_thumb.
I have them sounding superbly at present
With only the high spec crossover upgrade still to go - This I believe will kick it up a notch even though the sound is superb now, and I can't complain
Very impressive project, thanks for sharing. My initial thought was that this is not a La Scala, nor will it sound like one. Not any more. It should be much better.
Yes, thanks for sharing Paul, I too am very impressed.  Would like to hear these one day.
Anthony
Thanks Paul, your photo at Post #21 is showing the Tractrix horn that I use in my Edgar Horn set-up. Sounds hopeful that the Eliptrac exceeds that, how much is the 400Hz Eliptrac and where do you get them from?
Steve.
Edited by Steve M
Steve.
Have a look at Daves site - http://mysite.verizon.net/res12il11/id144.html
This will give you all the options on the kits available
I found a photo during the build that @@sootshe supplied
This one is of the bass horn cabinet back panel area prior to the back being installed
Notice the slit from where the sound waves are forced out towards two horn exits on the left & right
You will also see the triangle diverters and side bracing
post-112724-0-79340000-1397690827_thumb.
Hi Paul,
Interesting project, I'm wondering what's the goal for having front mouth and reflex loaded? is it for extra sensitivity for the midrange? since its very small box comparing the size of the woofer and using 2 big ports means tuned quite high, whats the expected LF for this?
sorry for a lot of questions :) as I'm not familiar with La Scalas (or any other Klipsch :P )
EDIT: i just realised that the whole upper section before the horn is actually the enclosure. cool :)
Henry
Edited by henry218
Guest atilsley
Hi Paul,
Henry
Henry
I'd say it's purely to extend the bass response from around 50Hz to 35Hz.
The height of the bass cabinet is 260 mm internal height & the ports are 100 mm diameter & 180mm long.
And it would be 612 mm square internal measurements
Not sure of the Dog box volume - but I can source it and get back to you
with these parameters
FS is 26.3, Re is 3.36, VAS is 506.3 Liters, BL is 12.49, QM is 9.93, QE is 0.27, QT is 0.26. Sensitivity is 97 db. Coil is 1 mH
the ideal box should be around 165-195L with fb from 35hz to 30hz.
it looks like a great bass driver :)
post-120534-0-06153400-1397742819_thumb.
post-120534-0-88387900-1397742868_thumb.
Edited by henry218
  • 2 weeks later...
On 27/04/2014 at 7:10 PM, Milos said:
Hi Paul,
great to see what you've been up to!!
A few more photos of Earles Amps would be great!
Miles
Here are some more photos Miles ;)
Both built by Earle Weston
This is the main amp
post-112724-0-38494000-1398592424_thumb.post-112724-0-63561100-1398592436_thumb.post-112724-0-95486000-1398592454_thumb.
And this is the preamp with inbuilt DAC + Headphone amp
post-112724-0-85998700-1398592470_thumb.post-112724-0-30336400-1398592483_thumb.post-112724-0-55047700-1398592496_thumb.
I have had an offer from a fellow SNAer - thanks @green-wagon to build the crossovers for me for a small cost and the promise of getting that " weak in the knees feeling when he has a listen on the system when it's all connected up
The Crossover design is based on the ALK gentle slope type AP12-500 & AP12-6000 configurations
However ALK has made these crossovers as a two piece system as that fits the Klipsch Heritage range
Green Wagon and I have come to an agreement & based on Troels Gravasens observations and the available space
We have designed this build as a single board - all coil distances are to Troels recommendations
Green wagon has simplified the connectivity of all three driver sections on the crossover and has drawn up a new schematic
(I won't post the schematic as ALK the designer has removed them from the web site due to plagiarism)
First we did a basic layout of the components on the floor with the view to tweak as needed for best performance and fit
post-112724-0-82327800-1399531881_thumb..
A close up of the tweeter attenuator - This component will allow me to tweak db volume to suit speaker placement and room sise
post-112724-0-62531400-1399531937_thumb.
We chose a good speaker colour match plywood board - and started the component fit
You will see a set of wire cutters and the tape measure @ 500mm to judge scale
post-112724-0-61560500-1399532091_thumb.
post-112724-0-53432000-1399532287_thumb.post-112724-0-42762900-1399532321_thumb.
Very nice FR :-)
Thanks @@Malcolm
Wait for more posts as the crossovers progress into the build and then the testing phase
While that is happening I will choose the finish of the surround area - I currently have approx 6 different styles to choose from
Anyone care to help with side finish ideas
Keep in mind the crossovers will be approx + 3 kg each and will need some sort of incorporated handles or grab points for easy lifting
Min clearance height required is 30 mm
    • By Rolland
      Item Condition: New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Bellevue State: WA Payment Method: PayPal, EFT, Cash on Pick up. Reason for selling: Don't have a use for them. Further information:
      These speakers are in brand new condition, only opened and taken out for pictures, will suit any music or home theatre set up.
        Details about the Klipsch R-41M can be found in the link below:
        https://www.klipsch.com.au/products/r-41m-bookshelf-speaker-blk-gnm?_ga=2.11379056.554094311.1622014613-1158050196.1622014613?_ga=2.11379056.554094311.1622014613-1158050196.1622014613
      PLEASE READ
    • By Phil sydney
      Item Condition: Good Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Sydney State: NSW Payment Method: Bank/paypal Reason for selling: Not Using Further information:
      Beautiful pair of Jamo Danish speakers 7.4 ..Amazing sound for not much $$
      They are very smooth and natural sounding speakers.
      ALL drivers are made by Seas. They are 3 way including a super tweeter for those high extended frequencies.
      They can be bi-wired but if you feed them a clean amp they will sing as is.
      Condition is very good for age  and all drivers work perfectly.
      They will be packed professionally with heavy duty bubble.wrap and heavy duty cardboard.
      Postage is included in the price.
      Thanks for looking
      PLEASE READ
    • By olegau
      Item Condition: Very good Shipping Options: Pickup available and you can audition. Suburb or Town: Melbourne State: VIC Payment Method: Cash on Pickup Reason for selling: Downgrade Further information:
      Paid $12500, one owner, like new, no scratches, all papers
      One speaker terminal screw is not very tight but I use banana plugs.
      Klipsch  Palladiums P-F37's are a small brother of the famous P-F39F's.
      The speakers are high sensitivity so that a 10 - 15W amplifier  will work fine.
      https://www.areadvd.de/hardware/2008/klipsch_palladium.shtm
      Klipsch Palladium P-37F Floorstanding Speakers (Natural)
      As the ``smallest`` floorstanding loudspeaker in our high-end luxury Palladium Series, the P-37F features the flagship P-39F`s technology and gallery-like appearance in a slightly more compact but equally stunning package.
      The P-37F’s carbon-infused, thermoset composite dual-horn configuration is unique to the Palladium family. It consists of a proprietary tweeter design, combining a chambered phase plug and Tractrix® Horn for extended high-frequency response; a second 90º by 60º acoustically damped Tractrix Horn is coupled to the midrange driver, resulting in precise performances.
      Features:
      ·                           Modern design, incomparable craftsmanship and proprietary technologies
      ·                           Exotic zebra-grain Linia wood veneer cabinet
      ·                           0.75-inch horn-loaded tweeter, 4.5-inch midrange and triple 7-inch woofers
      ·                           Bass-reflex design via triple rear-firing ports
      Specifications:
      ·                           Frequency Response:43Hz-24kHz +/-3dB
      ·                           Low Frequency Extension:31Hz
      ·                           High Frequency Extension:30kHz
      ·                           Power Handling: 275W continuous / 1100W peak
      ·                           Recommended Amplifier Power: 50 - 600W
      ·                           Sensitvity: 96dB @ 2.83V / 1m
      ·                           Nominal Impedance: 4 ohms
      ·                           Mid-Frequency Crossover: 550HZ
      ·                           High Frequency Crossover: 3400Hz
      ·                           Maximum Acoustic Output: 120dB (2 speakers in-room)
      ·                           High Frequency Driver:0.75`` (1.9cm) (titanium diaphragm compression driver mated to 90° x 60° Tractrix® Horn)
      ·                           Mid-Frequency Driver:4.5`` (11.4cm) (aluminum diaphragm compression driver mated to 90° x 60° Tractrix® Horn)
      ·                           Low Frequency Drivers: Three 7`` (17.8cm) (high-output, aluminum / Rohacell® /woven synthetic fiber hybrid cone woofers)
      ·                           Enclosure Material:Constrained layer MDF(medium density fiberboard)
      ·                           Dimensions (H x W x D): 118.1 x 50.2 x 49.5 cm EA
      ·                           Weight: 44.5kg EA
      ·                           Enclousure Type:Bass-reflex via triple rear-firing ports
      PLEASE READ
    • By favouriteheadache
      Item Condition: Used but as new in box Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Glebe State: NSW Payment Method: PayPal, EFT, cash on pickup Reason for selling: Upgrading to floorstanding speakers for a larger space As new in box with all original documentation is the Award winning Klipsch Reference Premier RP-600M standmount bookshelf speakers.
      Purchased 25/11/2020. Reason for selling is upgrading to floorstanding speakers for a larger space.
      Pickup from Glebe NSW 2037.
      Description
      Klipsch rp-600mredesigned from the ground up, the all-new Reference Premiere Series leverages over 70 years of Klipsch signature acoustic expertise With cutting-edge technology to deliver the ultimate home theater solution.Leveraging a 1" Titanium tweeter matted to our proprietary Hybrid Tractrix horn - the rp-600m bookshelf speaker delivers incredible acoustics to fill your home with loud, crystal-clear sound and robust bass that no ordinary bookshelf speaker can.Hybrid Tractrix hornhorn loading maximizes efficiently and increases detail while focusing high frequencies towards the listening area. Proprietary Tractrix geometry provides the most efficient transfer of high frequency waves into the listening area. The phase plug and compressed molded silicon face ensure smooth frequency response. When combined, the cleanest, most natural sound possible is created.Linear travel suspension titanium diaphragm tweeter the exclusive linear travel suspension minimizes distortion for enhanced, detailed performance. Lts tweeters are a hallmark of previous Reference lines, making it a core component of some of the best speakers in the world.Vented tweeter design the new vented tweeter Housing reduces standing waves that create unwanted harmonics, resulting in enhanced detail and clarity in high frequency reproduction.Spun copper cerametallic woofers a signature feature on the Reference Premiere Series, cerametallic woofers are exceptionally rigid and lightweight for minimal distortion and maximum efficiency. When paired with the Tractrix horn-loaded lts tweeter, it provides the highest speaker efficiency in its class.
      Features & details
      1” titanium lts vented tweeter with hybrid tractrix Horn
      6.5" Spun copper cerametallic woofers
      Bass-reflex via rear-firing tractrix port
      Dual binding posts for bi-wire/bi-amp
      Strong, flexible removable magnetic grille
    • By Phil sydney
      Item Condition: Good Shipping Options: Pickup available and you can audition. Suburb or Town: Parramatta State: NSW Payment Method: Bank,cash Reason for selling: Not required Further information:
      Boston Acoustic VR-2 Speakers
      Beautiful sound and present in good condition for age.
      lots of details and separation from these boston's as they are true 3 way with twin woofers.
      can't beat for the price!
      price is firm as it's already cheap. Pickup preferred but will post if I have no local interest.
      pickup in Parramatta 2150
      thanks for looking
      PLEASE READ
