the CPU clock to lowest figure BIOS accepts, lowering the MEM clock etc. But XXHE will lower the CPU clock down further. If you look at PeterSt's signature: Core i7-3930K is running at 0.43GHz only.
Do you know what the power draw would be on such a system with 2 ssd at startup.
There is an interesting thread going on about the Keces liniear power supply. http://www.stereo.net.au/forums/index.php?/topic/65016-great-big-power-supply-shootout-teddy-pardo-diy-wallwart/
It can give 19v with 6a, but I don't know what number I needfor an underclocked PC.
In combination with the pico, it could be an affordable PSU.
http://www.mini-box.com/picoPSU-160-XT
http://ppaproduct.blogspot.tw/2014/02/clock-upgrade-module-for-main-board.html
This little thing has cought my interest. An upgraded clock for your motherboard.
I wonder how good or stable this clock will be.
If I can find the clock on my test motherboard I'll give it a go.
I have an USB card from him with the same clock and transformer and I am wondering if it would be beneficial if you feed the MB and the USB card with the same clock.
Very interesting.
The clock always looks the same.
It's usually the only thing that looks like it on the board.
Guys, while you're doing some comparative listening to the various systems and tweaks any chance ytou could throw a Wandboard Squeezebox into the mix and let us know how it goes?
I'm tempted to feign illness and stop building my stairs to put my new SSD in and reload a new O/S!
I've loaded Win 8.........upgraded to 8.1 and Opera 20.
I'm not liking it much...................even though I've used 8 since it came out.
I might go back to 7 ultimate and try it then.
Think acg would be much more competent to reply on this as he made thorough investigation / measurements on power draw on each MBD rail (his combination MBD/CPU/MEM/HDDs).
It is interesting to mention that most power is needed at PC shutdown (think all measurements were made under W8) Let's say that measurements showed something like 110W needed.
With my previous MBD/CPU (Z77 + i7-2600S) I used dc-dc PSU. Not 'Pico' one but 'Morex' - similar in construction to well regarded 'Winmate'. I had to open PSU 'brick' to remove the small
vent inside and mount 2 heavy heatsinks instead, as vent kicked in very frequently, spinning w/ high revs, producing unbearable hf 'whistle'  :)
PicoPSU you linked (160-XT) could have some advantage if you give it linear 12V PS of adequate amperage. Other options are the same with Morex/Winmate etc: you still have SMPS PSU.
@@LogicprObe
Re-install W8 and disable any upates. Conclusion on W8.1 is 101% correct.
But I use the Classic Shell anyway...............so I may as well go back to 7!
It's not 'Classic Shell' you are just using Win7 'Windows Explorer'. Just as I do :)
There are some advantages in W8: there is support for hi-res audio output and it seems W8 is 'less distorting' than W7. It's really hard to explain. I was thinking to go back
to W7 as well, it is much easier to get 'wide stereo stage/image' but at the same time I frequently get (with W7) the sense of say drum-player having 3 meters long hands
hitting hi-hats on both sides of his drum-set :D So, no, W8 is giving much more realistic, firm image width. More details.
Have a look at this thread I started about building a full ATX Linear Power Supply (that project is progressing slowly).  I don't have time to go through the thread fully to dig out the info you asked for, but it should be in there.  The heaviest overall load for a music PC is experienced when it is shutting down, closely followed by when it is starting up.  The trouble is that the total load is significantly reduced when o/s optimisations are done but you still need to be able to start and stop the computer without any optimisations, so the power supply does need to be substantial.
    • By **ZEP**
      Item: Chord Electronics QBD 76 USB Bluetooth DAC
      Price: $4,150 ono
      Items Condition: Great condition, no scratches or marks, fully functioning and sounding sublime. This is a non smoking, pet free house
      Reason for Sale: Upgrade....its a passion for me!! Im looking for a DAVE if there is a part exchange anywhere??!!
      Payment Information: Cash on Pick up, Paypal, Direct Transfer
      Extra information: I’ve had this remarkable DAC for a few years now and it’s never disappointed me. It replaced a Wavelength USB DAC, which was also very capable, but the clarity and the extended detail that was achieved with this Chord DAC was astounding. Although it’s always about the sound, you should also remember that this is a piece of artwork. It’s beautifully crafted, shimmers Blue hues from the corner of the room and at a couple of KGs it has presence.....this is not just another generic black box!! There’s masses of connectivity, optical, USB, co-axial, and Bluetooth. I stream to it, run a transport into it and USB my Digital Media.The manual is http:// https://www.manualslib.com/manual/899220/Chord-Qbd-76.html
      Question welcome, and I’m happy to audition it to any serious party!
    • By prwiseman
      Item: Pro-Ject Phono Box USB V
      Price: $150
      Item Condition: like new
      Reason for selling: no longer required
      Extra Info: This unit hasn't been used as it wasn't suitable for my purposes.
    • By BioBrian
      Item: Slim tray-load Optical drive Blu-Ray burner for laptop or desktop
      Price: $110 (paid $149 plus postage, 31/5/18).
      Item Condition: Mint, new, box opened though, so no return was allowed
      Reason for selling: Should have ordered slot-drive, not tray-loader
      Payment Method: Pickup or post - Cash, Paypal
      Extra Info: I'm building another server, this time with slot-loading drive. I mistakenly ordered a tray-loading drive, and PCCG won't take a return because I've slit the paper seal on the box. All is mint, not even finger-marks, so as-new. Includes untouched "slim" cable (normal SATA cables won't fit "slim" drives - should be called "narrow"). This would suit desk-top or laptop. It's the latest Blu-Ray burner. See on PCCG site:
      https://www.pccasegear.com/products/41299/silverstone-tob03-internal-slimline-blu-ray-dvd-drive
      Can post in double-box, about 0.3 kg.
    • By Ugly
      Various cables for sale
      Item: Audio Principe 75 ohm digital interconnect – 1 metre
      Price: SOLD
      Item Condition: Excellent.
      Reason for selling: using USB now
      Payment Method: Bank deposit or paypal  (add 4% for paypal unless paying as gift.)
      Extra Info: Great value digital interconnect. http://audioprincipe.com.au/interconnects/single-75-ohm-digital-interconnect/
      Item: Balanced XLR cables with Neutrik connectors 58cm. I think they are silver plated copper (no guarantees) – unknown brand
      Price: $40 plus postage
      Item Condition: Good
      Reason for selling: No longer needed
      Extra Info: Great value interconnect. I purchased these from another SNA a few months ago but am no longer using because my preamp is not balanced.
      Item: Furutech ADL Formula 2-B  USB cable – 1.2 meters
      Price: SOLD
      Reason for selling: Not long enough for my current config
      Extra Info: Great value USB cable
      Pictures
    • By nickt
      Item:
      Supra EFF-IXLR Interconnect Cable: 2 Metre SOLD
      Supra DAC-XLR Digital Interconnect: 1 Metre
      Supra Anco Digital Co-axial Cable RCA: 1 Metre
      AudioQuest Cinnamon USB Data Cable: 0.75m
      Location: Toowong or Fortitude Valley, Brisbane, Queensland
      Price:
      Supra EFF-IXLR Interconnect Cable: $140 SOLD
      Supra DAC-XLR Digital Interconnect: $40
      Supra Anco Digital Co-axial Cable RCA: $25
      AudioQuest Cinnamon USB Data Cable: $40
      Or all for $220
      + Shipping if necessary
      Item Condition: All in good condition
      Reason for selling:  Have all ended up surplus after some changes to my system
      Payment Method: Paypal, EFT, COD, etc.
      Extra Info: All great cables, well reviewed solid performers. Looking for a good home.
