cooleagles
FS: Audio-gd C-2.1 Headphone Amp/Preamp - Final price drop!
Item: Audio-gd C-2.1 Headphone Amp/Preamp
Price: $230
Item Condition: Excellent
Reason for selling: Surplus
I am selling my Audio-gd C-2.1 Headphone Amp/Preamp. It is in excellent condition, with no marks or scratches. It's going as I have upgraded to the NFB-6. This HP amp delivers a clear (neutral) and faithful sound and won't muddy the source. Comes with an Australian charger.
More info from the Audio-gd website - http://www.audio-gd.com/Pro/Headphoneamp/C-2new/C2.1EN.htm
Postage available at extra cost.
I'm also selling my DAC - http://www.stereo.net.au/forums/index.php?/topic/62194-fs-audio-gd-nfb-2-dac/
post-119580-0-35112200-1393046829_thumb.
post-119580-0-23724900-1393047017_thumb.
post-119580-0-60406300-1393047072_thumb.
Edited by cooleagles
    • By olegau
      Item: HiFi stereo system
      Price: 1200
      Item Condition: very good
      Reason for selling: too many stereo systems
      Carefully selected Hi-Fi stereo system. All in good condition and working order.
      Separated sale:
      1. ROTEL RA-980BX Integrated Amplifier $390
      The amp was checked and serviced recently.
      It has OP amp sockets, DIYer could change the OP amps to get different sound. Open the the top cover and then change the OP-Amp you like.
      There are three pairs of Ops: original AD712 (vintage sift sound, JRC4558 (modern  more clean and detailed sound) and LM4562 (bit more detaied). Currently installed LM4562. Many other OP-Amp suits for this amp..
      Dimensions: 440 x 121 x 347mm
      Weight: 10.1kg
      Example:
      2. Speakers: Ascension Woodfox Ribbon 822SRTL Bookshelf Speakers. $890
      Dimentions: 500 H, 270mm W and 315mm Depth. Weight is approximately 18kg each. High quality woofer using an Papyrus cone, ribbon tweeter, Rose Mahogany Veneer.
      Two years old.
      Power 120W
      8 ohms
      Sensitivity 91db
      3.  Sold.  Subwoofer: Infinity Primus PS-8 $170
      See spec attached
    • By Fcleph
      Item: Chord Mojo DAC
      Price: $400
      Item Condition: Very good
      Reason for selling: Too many DACs
      Payment Method: Pickup - Cash preferred
      Extra Info: The Mojo needs no introduction. I've had this one for a while but didn't use it much. The battery is still good as new. I'll consider posting or meeting in person in Melbourne CBD. Please PM me then we can talk.
    • By AJL999
      Item: Copland CVA306 Preamp
      Price: $1,050
      Reason for selling:    NLR
       This seems to be a pretty rare beast.   6-channel valve preamp by well know Danish HiFi company, Copland.      I’ve had it for a few years – it’s a great performer, and built like a tank.       To be honest, I can find very little about this model on the Net, but it seems it’s still available from at least one US outlet – for US$ 3,995!
      I’ve used this in straight 2-channel mode, using the Stereo output L&R + the multichannel  Sub output.  But the intriguing aspect is that it will handle 5.1 surround inputs, and run them to a 5.1 power amp.    If you have (say) a Blue-Ray player that will decode and has analogue 5.1 analogue outputs, then this Preamp is way to put some “tube sound” into your system.  But at the same time you could use a 2-channel DAC / streamer (as I did) into the stereo inputs.      The unit has 6 Sovtek 12AX7LPS valves – all working fine, so far as I can tell.     So I guess a good opportunity for some level of tube-rolling.
      I have no box, so would prefer local pickup, but I could probably repurpose another box and mail it, if required – though it’s surprisingly heavy!  I could also leave it Sydney North Shore for pickup.
      http://www.divertech.com/coplandcva306.html
      I also found a copy of the manual online - but it's pretty basic.         https://www.manualslib.com/manual/752864/Copland-Cva306.html#manual
    • By Karel
      Item: Cambridge Audio Azur 540A
      Price: $100
      Reason for selling:  No longer used
      Payment Method: Pickup only
      Old favourite, great sound for little money.  No remote. Very good condition.
      Manual & specs:  https://techsupport.cambridgeaudio.com/hc/en-us/article_attachments/205263809/Azur_540A-640A_User_Manual_-_English.pdf
    • By synthz
      Item: Primaluna Dialogue Premium Pre-amplifier
      Price: $2,550 (RRP $4,195)
      Item Condition: Great
      It's pretty hard for me to let this go, but rather than being unused it's probably better to have a new home. My power amp is using XLR/Balanced only connection so I had to use my other preamp. All tubes are standard stock primaluna tubes. It's going to be hard for you to get this quality gear at this price, it's almost half price from the RRP of $4,195.  I'm the 2nd owner. Still have the original box.
      The PrimaLuna brand has been making waves in the High end Audio industry for producing premium built products that perform to a standard well beyond their peers at the same price point. The PrimaLuna Dialogue Premium Pre-Amp is a wonderfully detailed and warm sound with plenty of treble extension and air. The soundstage that this tube pre-amp presents is huge! This is an excellent valve pre-amp that is super quiet/low noise, a nice dash of the famous tube warmth all with fabulous frequency extension both in lowest bass power and highest, airiest treble. Featuring dual pre-outs, Home Theatre bypass functionality and an awesome sound here is your chance to save a bundle.
      Website:
      http://www.primaluna-usa.com/dialogue-premium-preamplifier
