steve u
Oldies vs Newies...Opinions please
Having a vinyl collection laying dormant for many years and with the forced upgrade of a pre amp last year, I took the plunge and decided to get back into vinyl.
I now have a Sound Reference turntable which to my ears plays very well, is easy to use and seems to do everything right.
I have upgraded the cartridge to a Benz Micro Glider and I am blown away by the dynamics. A much more immediate and involving presentation than my CD player and I couldn't be happier.
But I have this itch. The upgrade itch. I am considering buying another turntable. I will probably hang on to the SR turntable, but that could change depending on what I end up with. I will obviously keep the cartridge to use in the new turntable.
I never knew there was such a passion for "old" turntables until I joined this forum. The workmanship in restoring and upgrading some of these beauties is incredible.
And then I see the technical advances of the "newies" like the Kuzma, the Avid and the Pro-Ject RPM10 , I wonder will these "newies" outplay the oldies? Or are the oldies still doing the basics right and they also have the added attraction of being a piece of the past and still stand up and play with the best of them today. I do have a leaning towards bespoke products and could really see myself with a couple of turntables set up in the lounge room and just spinning away and thinking life is good....glass of red :rolleyes: ....sorry about that, back on topic.
So if I am looking towards an upgrade and considering what I am using now, what would be the next best step forward in my turntable evolution? As I am prepared to consider new and pre-loved, my budget is flexible and is between$1000 and $3000 for turntable and arm. I have trawled the classifieds here and there are some that catch my eye and some that I think are probably sold but still listed as FS. But again, I am looking for an upgrade so I am not really sure which ones would fall into that category.
I really have a lot to learn about turntables in general and hope that I could get a range of opinions from the learned vinyl lovers and turntable "experts" in this forum. Maybe "upgrade" is the wrong angle and I should be looking towards a different flavour, a different sound, a different look.
Thanks in advance for any advice.
Steve
Steve
Steve,
What is that floats your boat??...what do you want from your vinyl??
In reality only you can answer that. so if I was you that's where I would start.
A suggestion would be to spend your budget upgrading on what you already have....a better arm, cabling, support, phono stage etc.
Alternatively go and audition products in your price range making comparisons....all good fun! :)
If you are not familiar with "old school" decks I would steer clear as that can lead to all sorts of late nights getting the gear back up to spec....still all good fun tho!! :P
Hope this helps
Tase
Edited by Tasebass
Steve,
Hope this helps
Tase
Thanks for the reply Tase, I want my vinyl to sound good and be engaging to listen to. I also want it to look good.
My phono stage is about as good as Conrad Johnson can make them and I have Nordost cables, but I could definitely look at better support. The Sound Reference arm is very good and an upgrade to this model probably isn't practical, but I am not sure.
You're right this is a fun process and I am enjoying playing the oldies and loving the quality and art work of the new vinyl I have picked up.
I would like to try something different though, but it's not that easy to hear or compare the "old school" and the investment in something good, is significant, so I was hoping to hear opinions from those that have them and maybe get a bit of guidance. I don't mind a bit of wood as can be seen from my system set up, so that is a bit of a guideline.
Steve
post-142611-0-50750200-1392333404_thumb.
$1K-$3k would buy a pretty nice cartridge....... :) ...or a Record cleaning machine. This will be my next purchase!!!
ATB
Tase.
Hi Steve,
Re an upgrade, I have one word, which I think is highly relevant and that is 'synergy'. You are putting together an awesome system, and it all takes time, and it should all be fun. So far as suggestions, I agree with Tasebass a cartridge would be great, although I noticed you have ready upgraded. I've heard a few turntables and settled with the Clearaudio Performance DC. In Australia it comes with a Virtuoso MM cartridge, which is a really nice cartridge. But does not come close to a good MC cartridge. Hence,
So so far as a turntable I suggest a Clearaudio or a VPI. So far as a cartridge I suggest the Clearaudio Concerto v2 MC,, which you can pick up for about 2900 Ozzie dollars or less. Before you undertake any upgrade you Need to consider what you wish to achieve and if it's a more natural true to life concert/pub band sound then 'Go down the upgrade side., and enjoy.
Hi Steve,
Thanks C, I think the CJ Gat would go a long way to making most things sound pretty special. I will be very interested on your reports of your new phono stage when you get it.
The Druids deliver a very life like "live music" presentation and I like that. The Benz cartridge works very well in this set up, I hope to get out and audition some more TT's soon.
Steve
    • By cordlessmatt
      Item: Rega Exon 3's, with pre or without
      Price Range: Negotiable
      Item Condition: New or Used
      Looking for a pair of Exon 3's, hopefully in Melbourne, in as good condition as I can find. If there's a pre with them, will consider, but without is just fine 🙂
    • By Special K
      Price: $2200 Item Condition: Immaculate Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Glen Waverley State: Victoria Payment Method: Cash on pick up Reason for selling: NLR Further information: Selling a few items on behalf of my friend as his personal circumstance have changed.
      Items are pretty much new with as little as 50 hours of use on them.
      Preference to sell them all to the one person, however happy to break up if there are buyers for all of the items. Items are based in the south East  of Melbourne and could possibly be dropped off as well as they need to be gone ASAP. Keen to see how low some of the prices go, however please don’t be offended if I don’t responded for ridiculous offers.
      Looking for someone locally, however have the boxes for the TT and therefor can ship if no local buyers are found.
      1. Project 2Xperience SB Turntable (Walnut) including Ortofon 2M Cartridge
      2. Rega Fono MM
      3. Wireworld Luna 7 RCA
    • By 81Vintage
      Item: Custom Rega Style Turntable, AudioMods Tonearm, IsoDrive PSU
      Price: $3300 Price Drop $2850 inc shipping Australia Wide, can do a little less if you can collect in person to save packing and freight.
      Item Condition: Excellent, Used
      Reason for selling: New Project/Custom Build
      This is a complete custom build from the ground up based on a Rega P series design. Raw cost of materials and items was over $6000.
      Plynth milled from single block of billet alloy on CNC router (around 15kg) Finished in red automotive paint Followed same dimmensions as a Rega P3 plynth. 5x Maglev feet (tried with 3, 4 and 5 configurations and 5 was the best) IsoKinetic IsoDrive Power Supply with 33/45 speed selection IsoKinetic 25mm Acrylic Platter IsoKinetic IsoSub Groovetracer Machined Subplatter IsoKinetic Phosphor Bronze Bearing Sleeve IsoKinetic Ruby Bearing + Spindle Oil (lifetime supply left in bottle) IsoKinetic Puck/Stabiliser IsoKinetic Red Thing Silicone Belt + Spare New One in Packet IsoKinetic MTB-D Motor Thrust Bearing + Motor Isolation Mod for Premotec Motor Premotec 50hz Synchronous Motor Audiomods Series 4 Tonearm with Series 5 bearing, lift and arm hold. Full VTA Adjustment - no VTA adjuster.  All original weights and headshell weights/spacers included to adjust to any cart. Custom Acrylic Dust Cover to accomodate arm height No cart included, but I did have an Ortofon MC25e on it and it was stunning.
      *I have covered the hole bottom left corner where a power button would have gone if I didnt use the external motor PSU and controller with a samurai silver coin from WA mint. So the turntable is dubbed "The Samurai"
      For interstate buyers, it will be professionally crated and foam lined for shipping with tonearm back in original transport box. Shipping Australia wide with insurance included.
      For those that want to know where to from here - my next build will be in the similar vein...but using the MK6 Audiomods tonearm for primary, 200mm monster delrin platter,  ceramic bearing sleeve, larger billet plynth with 2 armboards for future arm addition and external motor and controller.
    • By 81Vintage
      Price: $3300 including shipping Australia wide - Price Drop $3100
      Item Condition: Excellent, but used
      *I have covered the hole bottom left corner where a power button would have gone if I didnt use the motor PSU with a samurai silver coin from WA mint. So the turntable is dubbed The Samurai.
    • By Artnet
      Item: Rega Planar2 (circa 1985)
      Price: $280.00
      Item Condition: Good for its age
      Extra Info: Original owner of this Planar 2,  have used more recently with upgrades but selling as original,  no cart, original 240volt motor, replaced the standard belt 18months ago. Acrylic cover cleaning swirls only as pictured.
      Groove tracer upgrades are for sale on another add if interested.
