zog
JLH 1969 10W Class A amplifier
OK I've wandered off the "Class D" reservation and started building this old, simple Class A design from a Chinese kit.
I was going to post this in the "Cheap EBAY Class A" thread but my ebay order vanished, so I ended up getting the same kit from Alieexpress.
Enclosure is re-purposed from a crappy old busted Korean amp I found in the skip.
1779916_10202953529739158_1587315134_n.j
I just got one channel built and working, I have a big chunky Altronics Aussie made heat sink but I havent drilled it yet, so I'm using the heatsink from CrapAmp for test purposes - I had to pile some old PC heatsinks on top to stabilise the temp. The mutimeter is in temperature mode so it has stabilised @ 54 degrees.. and it's a HOT day today.
Link to the original reference docco, hosted on Elliot Sound Products site: http://sound.au.com/tcaas/index-1.htm
Another link: http://swansonc2012.blogspot.de/2012/05/jlh-class-amplifier-1969.html
This amp fairly easy to power, as it uses a single ended 24DC power supply. In fact a lot of people report very good results using a SMPS, so I got the best specced 120W SMPS I could find at reasonable price, an Altronics unit. This has made the build massively easier than it would have been.
I thought I'd try a Class A amp after borrowing a (very well made DIY) 5W SET amp and trying it on the HF section of my active speakers. Was pleasantly surprised as I didn’t expect much - but it's the only bit of gear I've swapped in that my wife has made a positive comment about the sound (and I matched EQ and levels exactly with miniDSP and measurement mic)... so seeing what I can do for a low cost solid state Class A amp to try.
1554473_10202953528539128_1320127824_n.j
I've left the kit "stock" except for the coupling capacitors, replaced the 1uF "Spirit" brand caps with ERO MKT8122 2.2uF caps.
I'll shorten the leads to the power transisters, ultimately I'll use one of these mounted across the front of the enclosure:
http://www.altronics.com.au/index.asp?area=item&id=H0545
Hoping the total build cost to come under $200 - plus a lot of fun fiddling with it.
I havent adjusted the voltage or resistors to bias it, although it appears to come with parts chosen for exactly 24VDC which is what I'm feeding it.
Exact same output at speakers... can pick the difference?   You could earn $10,000.   Heh.  Just kidding.
As you'll know... this is a big part of what happens when you're feeding a 100w amplifier such a small input V required for only < 0.5w   (noise and distortion suffer).
I'll fully confess it wasn't double blind or scientific at all - but I think I have heard differences between various different class D modules I've tried in the 30-50W range and the $6 class AB chipamp I've also been playing with.. but these units have had measurable differences in the 2HD and 3HD profiles (measured with REW and a voltage divider tapped off the speaker).
When I built one, years ago, I used the fan forced tunnel heatsink.
Like this one.
Nice.   The JLH I have is living with a much, much smaller conventional heatsink (it was made in the 70s)  but is running about 20C above ambient.
I didn't have full voltage on the fan so it ran slow and quiet.
I'll be watching this build with great interest. :-)
I'm currently going through the throes of picking the next class A kit to try and this one was on the short list. However, I have a large enclosure with large heatsinks so the F5 is looking good.
Keep the instalments coming :-)
Regards,
SS
Regards,
SS
Hi Sub Sonic,
I am running Pass Labs Aleph J amps. My system should b hooked up and going again in a few weeks if you want to listen to some different Pass Labs designs.
small update: tested the other channel, and all good.
one one channel using 40 - 45W at the powerpoint.
was using a low sensitivity sacrificial DSE speaker so no idea of the noise level yet, which will be important for the 110dB (103dB with LPAD) compression drivers I intend to drive with it.
next step,  drill holes in the big heatsink and mount it to the "Pioneerish" aluminium faceplate. there are big holes in the aluminium where I can mount the transistors directly on the heatsink, but hopefully the extra black aluminium will help anyway:
http://pix.minirig.org.au/main.php?g2_view=core.DownloadItem&g2_itemId=6025&g2_serialNumber=2
Hi zog,
Contemplating modest-power Class A to pair with full-range Fostex drivers in back-loaded horn. Currently using Quad2 monoblocks built in late 1950's/early 1960's, so a 1969 JLH seems appropriately old.
Do you find any problems with the SMPS? e.g. hum?
Thanks,
J
Right now I do BUT, I'm in the "quickly wire it together and get it working" phase.. I havent optimised the wiring at all, and used whatever junk cable for the line inputs, soon to be replaced with shielded cable.
I also wired up overly long leads to the power transistors to help while I tested the heatsink, and enclosure assembly stuff, which wouldnt help.
It also seems hyper sensitive to what kind of device I hook up to it, but again, wiring and layout is not the final form.
With 24 VDC it is consuming about 85W on the wall. I've dropped the SMPS down to 22VDC (the minimum, it has a trimpot to adjust) and and it's using 70W. I guess that means I'm closer to 8W of power, but that's fine.
Temperature with all 4 transistors on the large heatsink acceptable.
My first try at using an M3 "tap" to thread drilled holes in the heatsink worked out OK as well.
Between the two power transistors I measure 10.4VDC which is 47% of 22VDC, not exactly 50%, need to determine if "close enough is good enough", or get that to exactly half.
Only going by memory here..........but don't you have to take into account the voltage drop across the junction?
It'll do.   That's what the output capacitor is for.
The main areas for tweaking are the various capacitors and power supply options
On power supplies, the JLH at home has a vintage regulated power supply (separate box).
I've been itching to try a choke input supply but I've got to build my Hay bridge inductance meter first.
If you've not already noticed there's a pile of JLH stuff out there on the web, including an Australian one http://sound.au.com/tcaas/
(Some interesting distortion spectra images here )
Edited by thoglette
Yes, I linked that in the first post :cool:. As I was waiting 2 months for the $30 kit to arrive I think I googled every JLH web page and picture I could find.
Finally got the chassis assembled, it's a bit of a puzzle trying to get the power transistors mounted inside the front panel with the heatsink snug in such a way that I can disassemble it in future but I think I've figured it out. And the black aluminium front panel now acts as part of the heatsink.
I initially had a LOT of buzz and noise, but after carefully going through:
http://www.diyaudio.com/forums/diyaudio-com-articles/163575-audio-component-grounding-interconnection.html
and
http://sound.westhost.com/earthing.htm
I redid where the ground loop connector was, and more importantly studied the PCB details here:
http://www.aliexpress.com/item-img/SC-HOOD-JLH-1969-10W-10W-Class-A-amplifier-kit/754337698.html
and realised I had the audio input inverted (as the orientation directions on the PCB are covered once you solder on the connectors)
I now have it running silently with no signal, and sounding nice and clean.
Still need to drill the chassis for the PCBs and tidy up the wiring. But first to integrate it properly with the active system with some miniDSP adjustment so I can have a listen.
1901367_10203000052422196_1453234239_n.j
Ah, yes :o .
There's a lot out there, that's for sure.  Between the JLH and the various Hiraga there's months of reading....
Nice renaissance of a dead chassis.
:thumb:
Q: What material have you mounted the input RCA connectors on?
cool  :cool:  :thumb:
It's 28 degrees inside (on a 39 degree day) - I measure 57 degrees at the top of the heatsink, so cool enough I hope!
:thumb:
Yes the "Glenwood" of Korea seemed quite junky, but its chassis has worked out well. The blue plastic the RCA connectors is mounted on is a bit cut from a plastic paint scraper cut to size. This was chosen as it happened to be suitable, and within reach in the garage at the time.
  How right you are :)
I've been reading the JLH, Hiraga and now Pass threads, one of the Pass threads is over 1K pages long!!!! :rolleyes: Still working on that one. Lots of good info though!
SS
And it's finished. It sounds really good. And it runs more than quiet enough to be drive the compression drivers.
Looks suitably black and sinister with the lid on.
1184804_10203009364855001_2133389703_n.j
1507139_10203009364094982_1234511577_n.j
So... how does it sound? :)
Early days yet, no A/B level matched comparisons or measurements .. and I've swapped over from a $6 Class AB 15W chipamp that I've been tinkering with since Xmas, and I'm fully conscious "new toy" syndrome may be colouring my judgement here..
But so far GREAT. Luminous. Big. Pleasant.
Electric guitars sound wonderful.
(using this as the HF amp crossing over @ 600Hz, with a TA3020 Tripath amp, approx 120W, as the LF amp)
A lot of great guitar amps used horn speakers.
They added to the expense and some nong headed roadies didn't know how to mike them up.
(even though most of these high end amps had a line out.)
So are there any sonic advantages with 'traditional' toroidal transformer + regulated PSU over the SMPS option that Zog's gone for?
Has 'traditional' design been overtaken by technological advancement in SMPS design, or are they both good options but different?
I'm new to this game, and keen to learn.
Thanks for any advice
Edited by tassie tiger
Traditional would be EI cored transformers with split bobbins.
Torroids have some fundamental noise problems (best summed up by Rod Coleman about halfway down the first page of this DIYAudio thread
And SMPS still (and by definition) radiate bucket loads of noise.
As I've said elsewhere, I'm keen to try the JLH with both batteries power and with a choke input supply.
The later is having a bit of a renaissance in the tube world as it both generates less noise and self regulates much better than capacitance input supplies.
    • By thejt
      Item: Shanling MC-30 Music Centre (Valves)
      Price: $625 or $650 with Logitech Harmony 650 universal remote
      Item Condition: Excellent
      Reason for selling: Too much gear
      Payment Method: Pickup - Cash, Shipped - Direct Deposit
      I am the second owner of this locally delivered 240V unit and I am sure I will regret selling this later. Ask anyone who has ever come across one of these and they will back me up with how they were blown away by this little unit. The build quality is excellent, thick aluminium body and heavy transformers. The design is well thought out with the feet all featuring levelling. The sound it makes is lush and although it seems like it would not create a generous amount of sound at 3W (Class A) I can fill a lounge room with gorgeous sound without even going half way on the dial. This is without even using easy to drive speakers, I had used Quad 11L and Dynaudio Contour 1.32E which are both only about 86dB. It has a pre-out should you want more power, but I tried using a Quad 909 and preferred it direct. The unit actually provided more bass on its own. Feature wise, CD player, FM and AM radio, 3.5mm input and RCA input which should cover everything you could want.
      The original owner lost the remote but the unit can be operated from the controls on the device itself. Volume adjustment is a bit of a chore like that though so I picked up a Logitech universal unit which I can include for an extra $25 (cost $70). A common issue with many Shanling CD players is the occasion pause during cd playback but this is occurs only very occasionally and lasts about 1 - 2 seconds before resuming. The MC-30 has been otherwise faultless. I have the original double box so can ship at buyers risk if desired but note it is fairly heavy. Great chance to get into valves or Class A amplification without too much outlay. Questions welcome and I will try to answer best I can. Donation on sale to SNA. Please look at all the glowey bits in the pictures!
      Praise:
      https://www.stereophile.com/integratedamps/308shan/index.html
      http://www.charismaaudio.com/products/shanling/mc30.htm
    • By Highpower
      Item: Denon PMA-880R Class A Integrated Amplifier
      Price: $300
      Reason for selling: Accumulated too much hifi gear and about to move to a new house
      Extra Info: This Denon PMA-880R Optical Class A Integrated Amplifier complete with RC-156 remote control and Operating Instructions is in mint condition. This amplifier was made in Japan in 1993.  Amps made by Denon in this era were considered to be the best amps that Denon ever made. These amps hardly ever come up for sale.
      I have owned this amplifier from new and it has been very well looked after. The amplifier and remote control still look brand new and are unmarked. It's whole life has been in a cabinet behind a glass door, which is why it still looks brand new.
      This Class A integrated amplifier has a very clean, detailed and powerful output that is impressive for both analogue and digital sources. There are no crackles or hums present and it performs just as well as the day I purchased it.
      The PMA-880R has a solid power supply that uses a shielded toroidal transformer, and a pair of large 12,000uF capacitors for voltage smoothing and a very substantial heat sink. It features a source direct switch for tone controls bypass and optical connection between amplifier stages for detailed sound. Speakers can be connected via A, B, A B front switching. The speaker binding posts accommodate bare wires or banana plugs. The power rating is 2 x 75W RMS at 8 ohms or 2 x 120W at 4 ohms. The Denon PMA-880R uses an Optical class A circuit design for optimum sound quality. Source Direct can be used to bypass tone controls. The Denon PMA-880R accommodates both MM moving magnet and MC moving coil Phono options via front switching.
      The Denon PMA-880R has the following RCA inputs: Phono, CD, Tuner, Aux, DAT/Tape-1, DAT/Tape-2. The amp also has a Record Out Selector a headphone jack, and a loudness button.
      The specifications are as follows:
      Power output: 75 watts per channel into 8Ω (stereo)
      Frequency response: 20Hz to 20kHz
      Total harmonic distortion: 0.02%
      Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 76dB (MC), 94dB (MM), 110dB (line)
      Output: 150mV (line)
      Dimensions: 434 x 160 x 353mm
      Weight: 8.2kg
      Accessories: RC-156 remote control
    • By tominmelb
      Item: Unison Research Unico Secondo Hybrid Tube Amp
      Price:  $1800.00
      Item Condition: Mint
      Reason for selling: To fund other purchases.
      Payment Method: Pickup - Cash, Paypal.
      Extra Info:  Beautiful Italian made hybrid tube amp in mint condition.  Has optional phono card installed ($RRPP $4400).  Comes with all original packaging and remote.  From a smoke and pet free home (and a child free room)
    • By ZOOTYtooty
      Item: Threshold S200 power amplifier
      Price: $1200 Sale Pending payment
      Item Condition: Used
      Reason for selling: Need a matched pair for speakers with active 2-way crossover
      Extra Info: Here is a stunning Threshold S200 Stassis power amplifier. Rare and beautiful!
      It is in absolutely lovely condition and has just come out of 10Years storage, brought up to voltage slowly and is sounding superb!
      The manual is included and postage is possible at buyers expense.
      The voltage on the rear has a sticker from the UK 220V, but the transformer has 120v and 120v primary thus clearly a 240v transformer (picture included).
    • By Razuu
      Hi
      This is actually a reply to another SN member's review of his Luxman 509X Int Amp.
      After replying, I thought it would be nice to share it with other SN members. Just my thoughts on the three Luxman amps I have owned over the last few years.
      I have been lucky enough in the last few years to have own the 550AX Class A as my first Luxman Int Amp, then due to a house move, needed more power, I got the 590AXII Class A, now living most of my time in Thailand, I am enjoying the 509X Class AB. I have also listened to the 507uX Class AB extensively.
      My gear from the 550AX to 590AXII and 509X haven't changed - Macbook > JRiver or Roon App > Chord Hugo TT DAC (Cable = Audioquest Diamond USB from Mac to Hugo TT) > every Luxman Amp (Cables = MIT SL8 RCA interconnects) > Spendor D7 SPEAKERS (Cables MIT SL 9).
      Quick rating of each amp:
      1. 550AX Class A 20 watts pc. (Build - 8) - (Look - 10 - if you like the Retro style) - (Power/Drive - 8 - ONLY if you have a small room, efficient speakers & don't listen loud) - (Clarity/Details - 7) - (Quietness - 7) - (Soul/Emotion - 8)
      2. 590AXII Class A 30 watts pc. (Build - 9) - (Look - 10 - if you like the Retro style) - (Power/Drive - 8 - ONLY if you have a small/medium room & efficient speakers) - (Clarity/Details - 8) - (Quietness - 8) - (Soul/Emotion - 9)
      3. 509X Class AB 120 watts pc. (Build - 9.5) - (Look - 10 - if you like the Retro style) - (Power/Drive - 9.5 - Most room sizes and most speakers) - (Clarity/Details - 9.5) - (Quietness - 9.5) - (Soul/Emotion - 8)
      Quick summary of each amp:
      1. 550AX Class A 20 watts pc. Fantastic Class A Int Amp. Low power, which leads to other limitations. Only buy if you don't have enough money to buy the 590AXII for more Power and Soul/Emotion.
      2. 590AXII Class A 30 watts pc. Great Class A Int Amp. Still low power for larger rooms. BUT simply amazing tones that ooze Soul and Emotion especially in vocals and acoustic music. Luxman Class A Masterpiece.
      3. 509X Class AB 120 watts pc. Stunning Class AB Int Amp. Tons of power and punch. So quiet, so much details, so clean, etc. Only negative against the 590AXII - doesn't have that Luxman Class A Soul and Emotion. Against Class AB Amp in this price range, the 509X has very few to no rivals.
      My "Ultimate" Amp:
      *A Luxman because of the build quality, features and acceptable price. Compared to nearest & equal rival, Accuphase, Luxmans are a bargain.
      *A Luxman Class A Int Amp for the tone, soul and emotions that they produce.
      *A Luxman Class A 60 watts pc Int Amp!! - maybe impossible and imagine the heat!
      Play more music!
      To the 2 SN members who bought my 550AX and 590AXII, hope you are enjoying them.
      Photos of 550AX, 590AXII and 509X
