Cheesemonger
FS: Pioneer SA6500 MKII - Classic old school chunky amp
Item:  Pioneer SA6500 MKII amplifier
Price: $100 ONO
Item Condition: Full working order
Reason for selling: Upgrade
Am happy to post, delivery should be around $20-25.
We've enjoyed this amp, but have had to upgrade and downsize so it needs an enjoyable new home where it can be turned up loud.
Here are some notes I've found online:
'The Pioneer SA-6500 is a low distortion, high power, stereo integrated amplifier with wide dynamic range equalizer.
Combining advanced circuits with a new design concept provides no-nonsense musical performance at a pleasing price.
Precision CR tone circuit, a high performance equalizer amplifier for wide dynamic range, and simple to use basic features make the popularly priced SA-6500 even more appealing as a worthwhile investment in advanced Hi-Fi electronics.'
Power output: 30 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 40kHz
Total harmonic distortion: 0.1%
Damping factor: 30
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 72dB (MM), 93dB (line)
Output: 150mV (line)
Semiconductors: 2 x IC, 25 x transistors, 16 x diodes
Dimensions: 380 x 139 x 308mm
Weight: 7.6kg
post-141155-0-92788600-1390130513_thumb.
post-141155-0-72331000-1390130630_thumb.
post-141155-0-18125700-1390130723_thumb.
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By alexb
      Item: Little Dot Mk II Headphone Amplifier
      Price: $SOLD
      Item Condition: Mint
      Reason for selling: Selling head-fi rig
      Payment Method: Pickup, EFT, Cash, Paypal (buyer pays all transaction fees & postage)
      Great condition and one of the best value headphone amplifiers available. Australian variant with 220v power supply. Upgraded Value Electronic CV4010 KQDD/K and 6H6 VIII tubes.
      The device has a single volume knob on the front along with a blue LED and of course, the 6.3mm port. At the back you can find the input and output RCA pots as well as the power button. The specifications of the amp are as follows:
      Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Driver Tubes: 6JI Power Tubes: 6N6 Frequency Response: 20HZ - 50KHz (-1dB) THD+N: 0.1% (50mW into 300 ohms) Suitable Headphone Impedance: 32 - 600 ohms Pre-Amplifier Output Impedance: 10K ohms Power Output: 300mW into 300 ohms 200mW into 120 ohms 100mW into 32 ohms Average Power Usage: 28 watts Dimensions: 210mm (length) by 110mm (width) by 130mm (height) Weight: 2.5 kg or 5.5 lbs.
      The Little Dot MK II boasts a SEPP (single ended push pull) circuit (in similar vein to the rest of the MK-series tube amplifiers) greatly increases sound quality, dynamic range, output impedance, and harmonic distortion. The Little Dot MK II also provides gain control of 3, 5, and 10 via internal DIP switches for fine-tuning so you can maximize synergy with almost any headphone you have, whether it be 32 ohms or 600.
      Some cheap tube amps have what is called a hybrid design, where the power is provided by a transistor based circuit and the driver circuitry is tube based. Examples of these designs are the headphone amps with only a single vacuum tube (the driver tube). Not only does the Little Dot MK II have a fully tube based design (both power and driver elements are tube based) it actually has independent circuitry for the left and right channels.
      So essentially, you have 1 power tube and 1 driver tube for the left channel and 1 power tube and 1 driver tube for the right channel. This is called an SEPP design (think of it as 2 + 2 design).
    • By MGO
      Item: Vinyl Stuff - Ring Mat Carbon Fibre Brush $50
      Price:  $50 plus postage
      Item Condition: Excellent
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal, Bank TT
      RingMat Developments have made a business over decades making TT mats.  They work really well.
      The carbon fibre brush is only a few months old and used infrequently.
    • By sa2013
      Item: Marantz PM-KI Pearl Lite Integrated Amplifier
      Price: $870
      I had this amp for about 5 years. There are few very small and hardly noticeable scratches on the right side of the top panel (see photos), apart from that it’s in excellent condition, local buyers welcome to have a listen. I have the original box, manual and power cable. Prefer local buyer.
      Key Features
      Ken Ishiwata Edition Integrated Amplifier
      2x 70 Watts RMS (8 ohm)
      Full discrete Current Feedback amplifier technology
      Toroidal transformer
      Copper plated chassis
      Marantz Original HDAM-SA3
      Power Amp Direct mode
      Here's one of many reviews for both amp and CD player: https://www.techradar.com/au/reviews/audio-visual/hi-fi-and-audio/audio-systems/marantz-ki-pearl-lite-sacd-and-amp-714688/review
      Also for sale Marantz SA-Ki Pearl Lite SACD Player.
      Thanks for looking.
