wikeeboy
NO LONGER AVAILABLE: FS: Wyred 4 Sound SX-1000 Mono Amplifiers (Black) *Price Drop*
Item: Wyred 4 Sound SX-1000 Mono Amplifiers (Black)
Price: $1800 (Free postage Australia wide) $2,800RRP
Item Condition: As New
Reason for selling: Not using.
Extra Info: Comes in original packaging. Not long after buying these i found my dream amp, so these have had bugger all use.
These are W4S's current top of the tree mono's. 570w in 8ohm, 1,140w in 4ohm.
post-138411-0-17466500-1389600308_thumb.
post-138411-0-10774300-1389600315_thumb.
post-138411-0-45419400-1389600320_thumb.
post-138411-0-08026000-1389600327_thumb.
post-138411-0-73129700-1389600332_thumb.
post-138411-0-44946700-1389685897_thumb.
post-138411-0-74013100-1389685903_thumb.
post-138411-0-16817400-1389685914_thumb.
post-138411-0-67749100-1389685924_thumb.
post-138411-0-71538400-1389685932_thumb.
Edited by wikeeboy
Price drop to $1950, with shipping included Australia wide. items will be shipped in original shipping boxed/packaging.
Price Drop to $1,900. These are currently $2,800 in AUS and will rise as the dollar continues to slip!
Price drop to $1,850.
Price Drop to $1800. This is $400 below the retail on the SX 500w versions.
Sorry mate, i'll clean her out now!
This item has been withdrawn from sale or relisted.
    • By petersv
      Item: Wyred4Sound Remedy Reclocker + Gieseler Linear Power Supply
      Price: $475 (Shipping +$15, PayPal +3%)
      Item Condition: Used, very good condition
      Reason for selling: No longer required.
      Payment Method: Pickup - Cash, Paypal (+3%) , Bank Transfer
      Listing is for a Wyred4Sound Remedy Reclocker (purchased 20-Oct-2015) and a Gieseler Linear PSU (purchased 31-Dec-2015), original Australian printed invoices are included for both items.
      Used between a Sonos Connect and a Devialet 120 to great effect, reduced jitter was immediately noticable and converted the Connect into a high-performance device.
      Although the reviews for the Reclocker have generally been very positive, I've found that the performance jump added when using the Gieseler Linear PSU to the Reclocker took its performance into a whole new realm (a bigger jump than the reclocker itself out of the box!) , and once heard with it, couldn't recommend listening without it. I've found the performance jump gained with this combo scales well when using even better sources/dac, not just entry/mid level etc.
      Current RRP $870+
      Review:
      http://www.digitalaudioreview.net/2014/08/wyred4sound-remedy-spdif-reclocker-review/
      Website:
      https://wyred4sound.com/products/digital-converters/remedy-reclocker
      Reclocker Features (from website):
        Utilizes an incredible Femto-grade clock Superior jitter reduction Toslink and Coaxial digital inputs Toslink, Coaxial, BNC digital outputs 96kHz output sampling frequency* Digital inputs support up to 24/192kHz 9VDC power supply included 5 year warranty
      Gieseler Linear PSU:
      Description
      This linear low noise DC power supply is designed to improve the performance of digital audio accessory devices that are normally powered by small SMPS plug-packs. All the internal components are of high quality & are selected for reliability & sound quality where applicable. Capacitors are Nichicon Fine Gold, Panasonic or Elna Silmic II’s. It is powered by external IE core transformers. These have a distinct advantage over the usual Toroidal type as they have better isolation between the windings & lower bandwidth means less HF noise coming in via the mains. Also being external there is less radiated hum entering the power supply circuitry. Noise, hum & ripple levels are very low due to the common mode choke pre filtering & low noise Linear Technology high performance regulators. Also what helps to reduce noise as well is the use of Schottky diodes & a transformer LC snubber. The DC output cable/connection is an area that is often neglected; so I have gone to extra lengths here to get it right. The DC output on the supply uses a Neutrik 6 Amp XLR gold pin socket. The supplied DC cable uses a matching Neutrik gold pin plug hand soldered to a 10A lead with moulded DC barrel connector for ruggedness.
      Specifications
      Noise level is approximately 20 uV to 40 uV d. Ripple & hum rejection is approximately 100 dB. Short circuit & thermal protection.
      Website:
      http://gieseler.com.au/ProductsPage/index.html
    • By Dionysi73
      Hi everyone,
      I'm selling my home this year but it needs a little work first, so to fund the reno I've decided to sell my entire HT system. For sale are the following items:
      Krix Speakers (4 Ohms):
      Pair of Krix Neuphonix floorstanders
      Krix Epicentrix Centre Channel
      Pair of Acoustix rear bookshelf speakers + stands
      Atlantic Jarrah Finish
      Subs
      2x SVS PB-13 Ultra's
      Black Oak
      Pre Amp (Processor)
      Anthem AVM50V including Anthem Room Correction kit and RS-232 adaptor
      Power Amplifier
      Wyred4Sound 5.1 Channel (MC Multichannel) Power Amplifer - 250w RMS per channel / 500w RMS per channel (into 4 Ohms (Krix Rating)
      ** All Black finish
      Projector
      JVC DLA -HD950 - THX Certified / ISF Calibration
      Approaching 3,000 hours so will require its first lamp replacement soon.
      Projector Screen
      LP Morgan Rondo IR Remote 110" Electric Screen
      White
      Power:
      Thoroughbred Sequenced Power Interface (SPI)
      Power Cables
      3x RK Cable, Power cables for Thoroughbred SPI, Anthem processor, SVS (1 sub only)
      Speaker Cables
      1x 3m Clink Siren Multicore
      1x 2m Clink Siren Multicore
      http://clink.com.au/audio/speaker.htm
      HDMI
      10m Kordz EVS Series HDMI Cable (Projector to Anthem)
      Other Cables:
      Multi-Channel XLR cables (Processor to Amplifier)
      http://clink.com.au/audio/6channel.htm - same type of cable configuration but with quality XLRs instead of RCA's
      Clink (Cinema Link)10m XLR Cable for the rear SVS Sub
      All items are in perfect working order and in fantastic condition, well looked after. No pets, no kids and thankfully, no wife!
      Selling the lot complete: $14,000
      ** Pick up only - Melbourne area (Clarinda 3169)
      Please PM me if you're interested or require further details.
      Dion
    • By mikeymikey85
      Item: LOOKING TO PURCHASE NEW DAC. PREFERABLY WYRED4SOUND DAC 1 or 2.
      Price:
      Item Condition:
      Reason for selling:
    • By chefscuba70
      Item: Complete Wyred 4 Sound Music Server 2 package, incl LHL Pulse Dac, Core Audio Tech LPS & Samsung Galaxy Tab3.
      Price: $ 1850.00
      Item Condition: Very good.
      Reason for selling: Upgraded to Antipodes DX2
      Extra Info: Everything you need for a great sounding Digital File Playback system. Ideal for anyone wanting to enter the world of digital music. Easy to setup and use. Plays most digital files up to 24/192. Can demonstrate how good this combination sounds and also explain how it functions. Have boxes for all units so happy to assist the buyer with their choice of courier.
      W4S Music Server 2 - http://www.deephzaudio.com/Wyred 4 sound Music Server 2T product page.html
      I'm the original owner bought from Peter Thompson at Deep Hz Audio. You will need to speak to Peter whether this MS2 unit is comparable to the latest units as far as upgrading to SSD and 32bit audio if you wish to do so. This unit has a 2TB HDD (with about 1.3TB worth of music in Flac files) and 2GB memory. Music buffers into the memory before playback so no music plays directly from the hard drive, eliminating any lag/jitter issues. Rips CDs to internal HDD or simply transfer files over your network from another source. Comes with the original standard power pack.
      Core Audio Technology Kaia Gen 2 Linear Power Supply - http://www.theabsolutesound.com/articles/core-audio-announces-new-linear-power-supplies/
      A beast of a power supply. This took the sound quality of the MS2 to a much greater level of detail and openness with a blacker background. Honestly, the W4S MS2 with this LPS unit has a similar sound to my Antipodes DX2.
      Light Harmonic Labs Geek Pulse Dac - https://www.amazon.com/dp/B017VY2VI6/ref=emc_b_5_t
      Perfect condition. ESS9018K2M Core Dac IC. Can convert bit rates of 1 bit, 16 bit, 24 bit, or 32 bit. It decodes sample rates of 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz, 2.822 MHz, 3.072 MHz, 5.644 MHz, and 6.144 MHz. If asking price is met, I'll throw in an Analysis Plus Digital Crystal Coaxial Interconnect - https://www.sydneyhificastlehill.com.au/shop/cables/coaxial-cables/analysis-plus-digital-crystal/
      Samsung Galaxy Tab3 10.1 - http://www.samsung.com/uk/tablets/galaxy-tab-3-10-1-p5210zwabtu/
       running the Orange Squeeze app which is a third party app that looks and functions better than the standard squeezebox app.
    • By Turtle Rustler
      Item: Wyred 4 Sound Recovery USB Reclocker - Rev A
      Price: $90
      Reason for selling: NLR
      Extra Info: This is a great USB reclocker or "decrapifier" that cleans up the USB signal going into your DAC. The Recovery is very well reviewed but please note that this is a Rev A model without the new board. The Rev A doesn't work with some DAC's so check the Wyred4sound web site or the online forums to see if your DAC would be affected. You can also get a board upgrade done through Wyred4sound to fix the issue. Will post at buyers expense and comes in original packaging. Apologies for stock photos, can get actual images if required.
      Once again, Wyred 4 Sound offers a fantastic audio product at an affordable price! Based on the success of the Remedy and known benefits of jitter reduction in a digital signal, we're proud to present the Recovery USB reclocker (or "RUR" as it's been coined on the Computer Audiophile forum). As it's name implies, the Recovery restores the original integrity of the USB signal. Usage couldn't be simpler: just insert the Recovery between USB source and DAC and instantly enjoy the benefits of a clean signal and much improved sonic quality.
