davidsss
Turntable Basics Part 1 - The Turntable
Wow, I wrote this ages ago. I might try and find some reading on tonearms and see if I can come up with somehing. Bear in mind that if I do this I might throw some statements out there just to incite better informed people to either confirm my thoughts or correct me, I have no problem with this. I'll see if I can find some time.
I seemed to get most of it right when I wrote this so I should be fine :cool:
DS
Hey! how did I miss this fantastic thread David?
Can't wait for the 'arm' workings chapter.
Thanks david
I did not see the original David (probably becasue I did not want to get another excuse to get into another source/$sink) but I sure enjoyed the read tonite - your words form easy mental images
That reminds me I have to pick up from work next week my 'balance bench' (our lab/manufacturing facility is closing down ). Its a very thick and heavy slab of granite (prob 150-200kgs?) that will form part of a norpus vinyl setup one day - likely another rectangular hole through my floorboards onto a tall concrete pile cemented well into the ground. Excessive mass and true isolation from the 'surf' when the IB wind blows and rocks the timbers
Thanks for that - it really helped me understand the basic principals of a turntable.
Would love to see a write up on tonearms and cartridges :)
I did do another thread but I can't remember whether it was on arms or carts. I'll try and find it sometime.
DS
On Chrome I am not seeing 4 of the images (in sequence, #4, 5, 7, 8) in post #1 and one (in sequence, #3) in #2 -- don't know why?
Nice job David.
I suspect the pics are now gone as they were internet links. From memory I also wrote one on tonearms but someone else would need to do an explanation of cartridges. I don't know enough.
DS
Just a reminder, if you have any concerns about a post please report these privately to the moderator team using the report function rather than posting the concerns publicly in the thread
Hi David,
Post #1 says "Belt Drive: this is where the motor is separated from the platter and the platted (sic) is driven by a belt. The idea is really an obvious way of decoupling the motor from the platter ...". I think that the last sentence is confusing to the newcomer who this post is aimed at, because the function of the belt is to *couple* the motor to the platter/turntable.
My thoughts were something like “….The idea is that the belt can couple the motor's torque to the platter, but isolate some of the motor's vibration from the platter, and hence the LP too.â€
Hope this helps.
Doesn't the belt do a bit of both coupling and decoupling? It has to connect the motor to the platter and rotate the platter at correct speed but also not transmit motor vibrations
Yes, agree prof. I think that's what my suggested words say. cheers
The belt decouples the motor and any vibration from the platter while spinning at 33.3 or 45rpm.
Direct drive couples the motor to the platter.
David is 100% correct and we are polluting this thread again thanks to ....
  • "the motor", no, the belt actually *couples* the motor to the platter. Quite the opposite thing, really.
  • "any vibration", exaggeration, would be better to say "some vibration, if the belt is a soft rubber type".
It's only a very small suggested improvement to the original article. I'm surprised at how it is being received.
Certainly experienced turntable owners do, but they are not the audience. I was applying the 'outsider test', and I think it is a worthwhile small improvement.
ooooooo!!...this threads going "flat earth"!!!.....Keep it going!! :D
Wikipedia has a lot of information about vinyl records and turntables:
You find there the history of vinyl recordings and a lot of to the point information about records and turntables (and beautiful images of the groove itself). So I suppose it is a bit spoiled effort to tell the story one more time.
People who want to buy their first turntable mostly don’t start reading a lot about vinyl recordings and phono equipment. They buy a (second hand) turntable, cartridge, pre-amp and records. Anyway, after some time they get a bit curious about their choice. Was it a good buy? Probably it is this group of vinyl owners who are really interested in information about phono equipment. Because they want to buy something better, but what is better? Just a more expensive turntable and phono cartridge?
Oh my..... oh my-my... memories, from the corners of my mind... Thank you for the 'walk' down memory lane. It has been some time since...
Interesting to think of the status of Turntables in 2008 when David posted this to the amazing comback here in 2018. Wish I had stocked up on some cheap classics back then lol😂
