Topman_Chief
Oppo 105 or $1,500 AVR for audio quality?
I have an old Rotel RSX-1056 which is doing the DAC duty with incoming digital signals from Apple TV, Telstra T-Box and a cheap Blu-Ray player. The Rotel started struggling to identify the digital input (coax or optical) some time ago and now is failing less often than not.
So, I'd like to upgrade to something that can handle the DAC duties for both 2.0 and 5.1 duties. I'm currently thinking of either:
A. Oppo 105 into the analogue section of the Rotel RSX-1056, or
B. New AVR for approximately the same price as the Oppo ($1200-$1500, e.g. Rotel RSX-1550)
My main priority is two-channel sound quality. I'm currently running old Mission 734 floorstanders, looking to upgrade to something in the $3K range such as PSB Imagine T2. Some of the features of the Oppo 105 appeal, but really I can do everything I want at the moment via Apple TV and the crappy Blu-Ray player (I don't even own any Blu-Ray disks). I like the sound of the Rotel RSX-1056, and would hate to retire it just because of the digital section failing. I have been reading quite a bit on DACs lately and appreciate the difference they can make in a system so don't want to skimp there. Obviously I could add a stand-alone DAC later but this makes for a complicated living room arrangement. Music is generally ALAC files played (currently) via the Apple TV.
I guess the main question is: Would the Oppo 105 DAC section thoroughly outshine a $1500 AVR DAC section, or would a one-box solution sound just as good?
Any advice appreciated.
or get the Rotel fixed - should only cost a few hundred at most - money saved can do to those speakers.
Your unlikely to better  2ch sound of the Rotel for $1500 and the Oppo brings some ups and downs
the 105 seems a bit out of kilter with the rest of the system. I would try get the rotel fixed if dont have a lot of cash....or move on.
you could pick up a brand new 1550 for under $1500 so would just grab that instead.
http://www.ebay.com.au/itm/Rotel-RSX-1550-7-1-Home-Theater-Receiver-New-/290924489728?pt=AU_Electronics_Home_Audio_Tuners_Receivers&hash=item43bc736c00&_uhb=1
DACs are probably the most popular stuff sold in the SNA classified, there are plenty of good DAC around for less than $1500.  Eg there is a good Audio-GD Ref 5 for $650. I would buy that and with the rest going towards better speakers.
EXPERT advice above makes good sense
A comment though on oppo SQ
Keith /Cheekyboy bought 1 and immediately sold his Droplet!
Some great input - highly appreciated. I had planned to get the RSX-1056 looked at, but don't hold out great hopes of getting the digital input section fixed (and wouldn't mind a step-up in DAC and video capability anyway).
I know there are plenty of comments on the Oppo floating around, but if you had to choose a few "ups and downs" versus using AVR features, what would they be?
An AVR gives you the convenience of switching input sources and some of the extra features that come with even cheap ones today.  Things like basic automated correction/channel balance and sometimes DAB+ included. If you do not have a high quality disk player and or streamer then you might be better off wit the Oppo. Volume control can be a problem with just the Oppo for lower gain power amps. The Oppo DACs are about as good as you will get without spending more than the $1500 for a dedicated DAC.
With the Oppo you can always go to an AVReceiver/Preprocessor later, if you need more flexibility.
Thanks Peta. I'm pretty much laughing out loud now as this morning I had convinced myself that if the repair on the Rotel AVR wasn't successful then I would buy a newer AVR. Now I'm back on the fence, seeing the merits of the Oppo going into the analogue section of my old Rotel AVR, which would then take on pre and pro duties. That would overcome the issue of gain since it isn't just a power amp. Not a neat solution, but arguably more capable and better sound than a new AVR.
I have an Audio-gd 11.32 which I use at work with headphones. It is a lower level Audio-gd unit (but does have Sabre DACs) so gave it a run doing DAC duty into the Rotel analogue section and even that was a noticeable step up from the Rotel DAC.
Oh well, lets hope the repair is successful and I can put the money towards speakers.
peta makes some very good points there, I too do think there is a place for an av pre or avr in these cases :)
Smart man
Im a fan of the Oppo 105, but in your case it makes sense to fix or replace the amp.
Later on if you start collecting BD's or Hi Def files, then the Oppo might come into the picture.
    • By pdcoo7
      Item: Oppo BDP-93
      Price: 380 300 $250
      Item Condition: used
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal +3% or as friend, COD Only
      Extra Info: The Oppo BDP-93 needs no introduction. Simply superb build quality and great picture/sound quality.
      unit has been very well looked after and presents as new.
      Will be supplied with all original accessories.
      Will pack well if required but local pick up is preferred.
    • By Supe_3057
      Item: Rotel A12 Intergrated Amplifier, 12 months old
      Price: $900 ono $720.00 inclusive $20 Donation
      Item Condition: Excellent
      Reason for selling: Change in direction
      Extra Info: Item is in excellent condition minus a little dust. Have box and I think all the original packaging.
    • By stuj
      Item: OPPO HA-2 portable headphone amplifier
      Price: $200  ($10 Australia wide shipping) with donation to Stereonet on sale
      Item Condition:
      Reason for selling: NLR don’t need a mobile setup anymore
      Payment Method: Pickup - Cash, Paypal, (+3%) COD Only
       Second owner here but well looked after had only used a few times then not needed so has been in a drawer for a while.
      there is a slight mark on the leather case which was due to the previous owner connecting the device to the phone with some tape.
      Have all the cables and charger however no original box.
    • By glams
      Being new I’m not sure if I’m supposed to start a new topic or tag onto an old one, so here I am.
      We have a wonderful, if not old, stereo set-up with Rotel AMP and pre-amp, Yamaha multi CD player, an old turntable and Dali bookshelf speakers. I love using it, but the rest of the family just grabs the portable Bluetooth speaker and connects to their phones! In an attempt to use the digital technology and get a better sound than a portable Bluetooth speaker, I purchased an audio pro Addon C10. Much better sound – may need to get a second one!
      Anyway, the point of all this, apart from lamenting my old system, was to see if anyone knows of a sound bar for the TV that is compatible with audio pro gear. I cannot seem to find one. Audiopro have a gadget called a’Link 1’ but a person at one particular  store was not sure it would connect to a soundbar or a TV.
      Any ideas welcome! Maybe it’s as simple as using the Link 1?
    • By audio_file
      Item: Rotel RA-820
      Price: $150
      Item Condition: Scratched
      Reason for selling: Replaced
      Payment Method: Pickup - Cash, Paypal, Bank transfer
      Specifications from https://www.hifiengine.com/manual_library/rotel/ra-820.shtml:
      Power output: 25 watts per channel into 8Ω (stereo)
      Frequency response: 10Hz to 40kHz
      Total harmonic distortion: 0.4%
      Damping factor: 20
      Input sensitivity: 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 75dB (MM), 95dB (line)
      Speaker load impedance: 4Ω to 16Ω
      Dimensions: 430 x 66 x 271mm
      Weight: 5.5kg
      This was used for PC desktop speakers driving KEF Q1 speakers.
      I tried it on my Spendor SP2/3R2 and it had no problem driving these.
