ScottieZ
EOI : Entire System :(
Item's:
  • Entire audio setup!,
Speakers:
  • Sonus Faber Grand Piano Domus in Piano Black (Original, not 'home' version) - wooden shipping crate available.
  • Sonus Faber Wall Domus in Piano Black with original wall mounting hardware. - With original box
  • Sonus Faber Solo Home Center
  • Miller & Kreisel (MK) V-75 MKII 12†Sealed subwoofer.
Amplification:
  • Marantz SR7005 AV Receiver in matt black - original box
  • Rotel 1582 2-Channel power amp in matt black - original box
  • Rotel 1565 5-Channel power amp in matt black - original box
  • Audio Lab M-DAC in matt black - L2 Fusion edition (explained below)  - original box
Misc:
  • JIB High end interconnects and leads. - original box’s
  • Various Optical’s, HDMI’s & Power cords.
  • IR extenders
  • Equipment Rack
  • Perth, North of the river.
Price:
  • Sonus Faber Grand Piano Domus in Piano Black - $4,000 - RRP @ time, AUD 7,299.00
  • Sonus Faber Wall Domus in Piano Black - $1,600
  • Sonus Faber Solo Home Center, black rapped in leather - $600
  • Miller & Kreisel (MK) V-75 MKII 12†Sealed subwoofer - black - $500
  • Marantz SR7005 AV Receiver in matt black - original box - $1,300
  • Rotel 1582 2-Channel power amp in matt black - original box $1,300
  • Rotel 1565 5-Channel power amp in matt black - original box $1,100
  • Audio Lab M-DAC in matt black - L2 Fusion edition - $1,600
  • Equipment Rack - $150
  • JIB Stuff - $500 the lot.
  • JIB SB-004 High-end Hi-Fi Cable’s 4x3M. - Original box’s
  • JIB RCA interconnects pairs 1.5M’s - Original boxes
Or $10,000 for the lot, I will even set it all up for you and show you how to use it and throw in all the various HDMI's Power and optical cables.
Item Condition:
Used, but all in immaculate condition with no scratches etc., except for 1 ding to the corner of the rear wall speaker’s housing (not very noticeable) happened when installing :(.
All amp gear is about 1.8 ish years old, the speakers I bought from my old man I am the second owner all ways been respectably powered and not trashed.
Reason for selling:
Life throws us some bumps in the road… And I am needing the money over the audio nirvana.
Payment Method:
Pickup - Cash, Paypal, Bankcheque etc.
As all ways it would be nice to try sell it to someone as an entire kit to get them started in the world of Hi-FI & Home Cinema but I am keeping an open mind so for now I will float it as an EOI to test the waters on the off chance someone out there would buy the lot. Everything can be demoed still setup in my listening room I swear if someone was keen on an entire system and had the money to out lay at once I can guarantee one sit in the room and they would be sold! :)
The Audiolab M-DAC needs a special mention if you’re in the know you will know its received a lot of hype and if you know more the guy that created and designed it all split away from audio lab and started his own company ‘LakeWest’ my M-DAC was sent to his workshop and he modified it to have a Home Theatre bypass and paid to have all resistors in the analogue audio stage replaced with Vishay Naked Z-foil’s as it was later apparent by John at lakewest the that china manufacturing process substituted resistors from the original design scope which degraded the sound quality, even though it was still awesome the replacement with the Z-Foils and re-worked power supply rail’s has taken it to another level!.
The H/T bypass is great as I can have the M-DAC connected directly to my power amp and play music back in its purest form without any data manipulation (all bit-perfect) and the M-DAC its self really brings the music alive!, the modifications were not cheap as z-foils are expensive !, details below.
MDAC L1
“MDAC internal PSU section upgrade (this upgrades 6 of the PSU supply rails around the ESS DAC, reducing modulation spurie by up to x1000 (40dB) around the ESS DAC).â€
MDAC L2 - which includes the L1 upgrade which my unit has.
“Full rebuild (redesign) of the CROSS analogue stage, over 56 components changed in the Analogue section + MDAC L1. Major leap in sound quality. Vishay Naked Z-foil resistors (Toy/Fusion) During development/testing of MDAC L2, results have shown that certain components (resistors) can have a significant effect on sound quality when used in a feedback loop. This upgrade further enhances MDAC L2. Originally, only 4 resistors were considered to be critical, but the revelation around resistors itself led to the idea of replacing all "important" resistors in direct analog signal path by the Z-foil resistors.â€
You can no longer get your M-DAC modded by John because he's commenced work on the MDAC2 and does not have time to upgrade any more units.
The Marantz has not been used for amplification just as a pre-amp, HDMI switcher and other features like AirPlay (overkill I know but I was going to use the on board amps to power other external room speakers)
Summary:
In summary, this might not be the best of the best but to me and I am sure many others if they had this system,  it is the first audio setup I have had that I now say Movie Cinema's are a waste of time because the audio sounds appalling. When I am playing any form of music in 2-Channel playing live LP's for example, I get goose bumps imagining my self there because of the atmosphere and stage it recreates and how real it feels.. I quote from Wikipedia with the key words underlined.
"Goose bumps, may involuntarily develop when a person is cold or experiences strong emotions such as fear, nostalgia, pleasure, euphoria, awe"... surely if your system is recreating this you have a good combination of components regardless of price point or brand, and I am not easily impressed.
post-131796-0-77898200-1385197584_thumb.
post-131796-0-59928300-1385198344_thumb.
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040110-1.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040111-2.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040112-3.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040113-4.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040114-5.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040115-6.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040118-7.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040119-8.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040120-9.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040121-10.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040122-11.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040123-12.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/P1040124-13.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0002-1.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0004-2.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0007-4.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0010-5.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0012-6.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0014-7.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0016-8.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0017-9.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0019-10.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0020-11.jpg
https://dl.dropboxusercontent.com/u/721515/SonusFaber/IMG_0024-12.jpg
Edited by ScottieZ
Sad to see someone having to sell their whole system for the reasons you have stated. Hope things pick up somehow and you can withdraw a few items to hang onto. Otherwise, VGLWS!
    • By Bradyey
      Item: Rotel RB-990BX Power Amp
      Price: 600
      Item Condition: Very good (Used)
      Reason for selling: Upgraded to Monoblocks
      200w/ch into 8 Ohms,
      330w/ch into 4 Ohms.
      Seriously beefy, powerful amplifier in great condition.
      This amplifier has a beautiful sound. Tested and working wonderfully.
      Can demo in good condition, just let me know and I can hook it up.
      Pickup only sorry! Cannot ship due to weight and lack of original box.
    • By jackyrud
      Item: Sonus Faber Venere 2.5 Speakers Wood finish
      Price: $2300 $2100 + Postage
      Item Condition: Excellent  - 2 years old
      Reason for selling: Upgrade (maybe)
      Extra Info: Original boxes, plinths, spikes, grills included.
      Purchased brand new from KLAPP late 2017 $4000 RRP ($3500 for black or white).
      Stunning speakers and a great intro into Sonus Faber. Were Nominated for loudspeakers Of the year in Stereophile 2013
      Open to partial trades with Spendor D7, PMC, ProAc floorstanders (I will make up the difference)
         Sonus Faber Venere 2.5 loudspeaker | Stereophile.com
      WWW.STEREOPHILE.COM
       Sonus Faber Venere 2.5 loudspeaker Measurements | Stereophile.com
      WWW.STEREOPHILE.COM Sidebar 3: Measurements
      Photos: Advertisements without photos of the actual item will not be approved.
    • By Aaban
      Item: Rotel RB-1552
      Price: $1000
      Item Condition: 9.5/10
      Payment Method: Pickup - Cash, Bank Transfer
      Up for sale, been sitting in my warehouse for almost a year, forgot that I had it.
      Massive 120 watts per channel. XLR and RCA inputs.
      Micro scratch in front panel thanks to my wife's cleaning techniques, only cosmetic. You can see in the second picture.
      More info at http://rotel.com/product/rb-1552-mkii
      Selling because I got a more powerful Amp long ago. Price includes freight to anywhere in Australia, can negotiate if picked up from my store at Malaga, WA. I've got boxes, packaging, cables and user's manual in perfect confitions.
