Come off it, Paul. It's all about headroom, not continuous power. I know a couple of guys with those 750W Musical Fidelity 'supercharger' amps. Strangely enough they don't have 1000W speakers, and strangely enough they haven't blown their speakers up. But you would know that; you're no fool.
I'm absolutely gobsmacked by posts #38 and #39. Dissing on the OP's choice after he chose and bought the amp? Where were your bright and sparky opinions after posts #5 and #7? As Johnny Cash would have sung, Just the other side of nowhere
Now, if I look on the bright side, just as a total policy reversal for this thread, the Emotiva amp will open up some speaker options that are well suited to its output, that might not cruise so well on a 40W amp that goes best with 90+ dB/W speakers. The OP is asking for your enlightened input along these lines in another thread.
  • Replies 63
Popular Posts
speaker first then amp or avr, but still depend on music or HT, even music stll depend on which style you like, classic or pop ? 5000$ can do much better than just go for Emotiva.
I wouldn't worry about a receiver being 7.1. You can set any of these up as 5.1. The higher-end Denons will do the job, but I am sure there are others that will be recommended.
Here's some five channel power for you: http://www.getprice.com.au/Rotel-RMB1575-Amplifier.htm#more-details I'd also look at Marantz and Emotiva (if you don't mind shipping from the USA).
I actually find that pretty hard to believe. Perhaps not to someone's tonal taste because Emotiva (apparently) have a pretty flat frequency response, but I don't think there's a speaker that'll sound "not very good" with this choice of amp.
None of my designs will sound poor with Emotiva amps - I design speakers that don't require the electronics to alter the sound tonally. However, there are many speakers that will not sound very good with Emotiva amps. This is very subjective of course and no doubt many will disagree. There are many however, who know exactly what I'm talking about.
Many audiophiles with speakers that are slightly bright or forward in character choose to tame the sound elsewhere in the system, with turntables, valves, cables, amps. I don't favour this approach and instead prefer to use transparent and neutral electronics and with speakers that don't require adjustment or taming.
Having said this, Emotiva amps aren't the last word in technical performance. Their published measurements show very poor distortion measurements once one steps below power levels normally used in conventional passive speakers. I know little about the design of power amps, but I understand this points towards the bias settings which favour reliability over better sonics. Changing the biasing would cause the amp to run hotter and operate in class A mode more of the time.
That said, I am intending to demo LSK kits on an Emotiva power amp and surround processor. Ultimately, I expect I may also have something higher end to demo other products. I have not had the chance to do the critical listening involved and some of these designs are on the drawing board right now.
My experience has been that you can't rely much on your preconceptions about how things will sound. There are things you expect to sound average, that you can't pick at all blind. And there are things you don't expect to pick that defy your expectations.
I'm flabbergasted that you're gobsmacked.
Somebody gives advice that:
  • You should ideally choose an amp for speakers (not the other way around)
  • Choosing more power than you need is a generally bad idea
... and they're doing the wrong thing?
They're only "dissing his choice"  if he is actually going to run into the above problems.   If he truly does need or want the power, and has well matching speakers..... then fine.
I'd call any advice given about amplifiers before asking questions about speakers and listening levels pretty ill-conceived 'advice'.... and I think that needs to be called out.
At the top of the output range it is, sure ..... but much more importantly is what happens at average levels.
If you have 92 dB speakers, don't buy an amplifier with rubbish performance around 500 mW.
Edited by davewantsmoore
I've never come across driver damage from too much power. In fact the converse is true. When the power amp isn't delivering enough power, the clipping causes DC to be sent to the drivers. That seems to have damaged the drivers more frequently.
Try harder  (evil laugh).... but yes, most modern drivers are very robust.
Yep, a small amplifier clipping can hurt speakers.
Hello Newman
I don't think you are being fair to people offering different views.
I presume you know, that you are not comparing apples with apples re the Emotiva you recommend versus the MF 750K you refer to.
Just because they are both amplifiers, doesn't mean they are comparable.
I think it would be like comparing a Mazda 3 with a current AMG 630.
They are both 4 door sedans, they are both competent at what they are designed to do, but they are really designed for different markets and designed for different applications.
You are comparing the Emotiva with this http://www.stereophile.com/solidpoweramps/1208mf
If the Emotiva is the right choice for the OP, then good.
But the OP asked an open question on an open forum. He will get differing views.
Yours or others is not the only answer.
As always, it is up to the OP to wade through all the differing responses & act as he/she sees fit.
Graham
Make up your mind Dave, the OP's head must be spinning from reading your comments in isolation.
The OP clearly knew what sort of speakers he wanted when he asked for amp advice -- as we now know from his thread on speakers. He asked for the most powerful and when he gets it, only then, the posts come rolling in, "what did you buy that for?".
That's not helpful. Except maybe for his next amp purchase.  :P
And yet on 25 June, when he wrote in response to your question, that he is buying amp before speakers, you didn't 'call out' anything. And 4 days before that, you had suggested the Marantz MM8003. [edit: this all happened 3 months ago.]
His head must be so spinning! Well, mine is!  :lol:
Edited by Newman
i never saw anyone blow their speakers because too powerful amp, they blew it because listening too loud and too long outside their capabilities.
Hello Newman
Heh heh, you need to put Newman in italics, Jerry!
The comparison was in relation to the Emotiva blowing up speakers with its power. If the MF750K doesn't blow 'em up, that is a perfect example of why the Emotiva might also not do it.
I read all my comments.   What's to be confused about ?!?
Post #24 was attempting to nip that in the bud.    "Excessive power" ... and "depends on the speaker"
That's not helpful.
I disagree.   Objectively discussing the choices both past and future is helpful to the OP, and also everyone else reading along.
I tried to in post #30  (and previous in post #24)   ....   Did I do a very good job.  No.   I'm usually much more blunt and ranty than that   ;-)
Sure.... again I don't understand the confusion.
The discussion was tracking specifically around 5.1 receivers ... and using them as preamps ... and I suggested a multichannel power amp.
I'm glad to hear it, because there's room for only a certain number of gobsmackers in this forum.
Do keep in mind that I speak as an Emotiva owner - I speak from actual experience with their products. I think it is useful for the OP to hear from other Emotiva owners.
I provided a demo for one of my clients, using some Emotiva products. The intent was to facilitate a sale and said client intended to then go with a custom design. The potential buyer was seriously interested, and almost ready to buy sight unseen. He went away disappointed. My client originally auditioned his speakers with electronics that made them sound much more appealing.
My point is not to diss the choice after a purchase has been made, but to point out that now he needs to make a wise choice with the speakers.
Basic point is "pre-amplifier leading sound style, power-amplifier just give power". That was why so many different brands of amplifier. You only need a powerful amplifier when your speaker is very hard to drive. Such as ATC s-20, s-100, B&W 800 series, SPENDOR S-100, 5000$ just go for Emotiva. And you even not mention which speaker you want to drive. All I can say is just HOHO.
No, it is not a perfect example. It is a poor example.
Those different amps deliver power differently, especially when driven harder.
Anyway, It's all a bit moot as the OP has the amp he has.
Graham
Well obviously it depends on how you use it (either of them).   The devil is in the detail yet again.
2V output (typical source) direct to the MF750K ... will send 736watts to a 4ohm tweeter.  A rookie-mis-adventurer might easily end up with broken ears and shards of tweeter embedded in their eye.
Or. perhaps you turn the volume down on the source.... to get a more pleasant (still loud) level.
95dB peaks (20dB crest) at 4m with 90dB/6R speakers ... requires 0.5 watts ...  which is input V = 60mV  (MF750K is 2.5V sensitive with 29dB gain).   This reduces the SNR of the amplifier by nearly 2000x.   The amp has more like 88dB SNR now (rather than 120 quoted).......    The preceding device is also now outputting 60mV, which is no doubt going to increase it's SNR and relative distortion.
The numbers for the Emotiva amp are orders of magnitude worse, as we should reasonably expect  (It has 1.8v input with double the gain and 10dB less SNR)
Heaps more power than you need is often a disaster.   Often a more powerful amplifier is also more suited to driving difficult speaker loads .... but this is a completely separate problem to "power" which is dictated by the speaker in question, and how loud you want to play it.
Dave, you often remind us that 400W of amp only delivers 10 dB more SPL than a 40W amp..... so now you want to argue that amps fall apart 'disastrously' within a 10 dB range when you turn them down? For most amps the THD+N plot increases at very low power levels due to noise, with distortion below the noise. So the main issue is noise, and if we plug in our 400W amp and take a seat and can't hear the noise....
The case for using a 500W amp in a normal listening room with 85 dB/W speakers is valid, based on headroom needs and musical dynamics. We might run into issues with a 500W amp on 105 dB/W compression drivers on horns -- that is a total mismatch -- but for someone to buy a 400W amp with the plan to keep it for years, maybe using it with a 'normal' range of speakers over time, that is a plan I have no beef with.
Maybe I am just too relaxed about this.... :)
Sure, I have no problem with this.
The noise issue .... if you are feeding your amplifier 0.06 volts ... when it's circuit can take 2.5v... then you are going much closer to the noise of the amp....   You are also going (one would assume it has a typical 2v output) much close to the noise of the previous device.
... and you also have distortion at low power (below the noise floor).   From the scant work which has been done in that area, it seems like a very underestimated issue.
Might.    Yeah that is a fierce understatement there. :P   :thumb:
Using the numbers from my previous post (admittedly for the MF750K)  .... full output (@4m) of 120dB .... and a power requirement of 0.00008 watts  (80 microwatts!?) for the "average levels" example ....   Your 120dB (impressive!)  SNR has now dropped to 48dB.    ie.  14 million times worse.
It only sounds wrong when you drag the context or generalise  ;-)
Yes, it is... if the speaker can actually make acceptable sound at 100dB  (un?!likely for home audio?!)
... my only laboured point is that this power comes at a price which is often high fidelity.   It all depends on what you want or need.... which takes us full circle to the point that discussing amps without their loads is mostly nonsensical.
The real trick is that if you want high quality output at large levels, you will need high sensitivity .... and if you do this at home you will not need much power....   and if you want to do it with high quality, you will want an amp which does not have excessive power, otherwise you'll be needing to send it a signal which is too low.... and your amp, and the devices before it, will be (generally) delivering much less performance that they're capable of.
What!!! Are we stuck on the KEF LS50's again?   :P
Take another look at that JBL 590 and tell me it cannot sound good at 100 dB.
I'm calling it. I think Newman is a Trol, with a capital T.
When he runs out of answers on amplifiers, he changes the subject to speakers.
Why didn't I see it before!?
Graham
They are a prime example.   They have poor distortion numbers at 90dB/1m .... 100dB (or 106!!!) at the listening position is very large jump.   It can't be good.
The purpose of 500w here is murky at best.
It will do 100dB@1m on barely 5 watts ... At 4m this would be starting to approach the recommended amp power of 250 watts.
So you could perhaps infer from that "only just"...   but it's going to be all sorts of better.    Kinda like bringing a gun to a knife fight... where something with genuinely high sensitivity (approaching 100dB or higher) .... is like taking a tank to a karate tournament.
This all quickly comes backs to listening levels/distances....   These are massively loud levels.   X, Y and Z amplifier powers get thrown around all the time as being good or not .... but you can see from the numbers here, that speaker sensitivity and distance has an enormous effect.
So the questions before amplifiers, is always just how big IS your room, where and how will you listen, and how much power does your speaker need.   A sensitive speaker which needs 10 watts... changes to 1000 watts for a not sensitive speaker... for the same output.   So 200w (or whatever) is a fierce generalisation.
It's kinda like saying that a standard-sized claw hammer is a "good choice"  .... but not for building a model aeroplane, or demolishing a house.
Nope, not troll.     Speakers are where this thread should have headed from the first few posts unfortunately.   They are inextricably linked with amplifiers.    Speaking about amplifiers without speaker specifics is borderline nonsense.
  • Moderators
Gents... page 1 of this thread is a lovely, enthustiastic thread helping the OP choose an amp. (Good choice by the way, I have had Emotiva gear in the past and consider it some of the best value for money around in this hobby!)
Let's all stop quoting each other and squabbling. I've put everyone's toys back in the cot and ask you all politely not to throw them out again.
Al
