bmwheath
NEED HELP CHOOSING A PRE/PRO ROTEL/MARANTZ/DENON
Hi again guys. Im still having trouble choosing a pre/pro for my home theatre system and im looking for some help
I currently have:
ROTEL RMB 1095 AND RMB 1080 AMPS
PARADIGM STUDIO 60'S, 40'S AND CC690 CENTRE VERSION 4
ONKYO SR876 RECEIVER
SONY ES50 PROJECTOR AND 108' SCREENTECHNICS SCREEN
I will only ever be using my system for 5.2 or possible 7.2 channel and bypass for 2 channel listening which is very important to me.
Im looking to eliminate the onkyo receiver from my system and get a nice pre/pro to compliment my system.
Pre/pro's that have cought my eye are:
MARANTZ AV 7005
MARANTZ AV 7705
MARANTZ AV 8801
ROTEL RSP 1580 (WHICH I CAN GET FOR $2500, RETAIL OF ABOUT $4500)
I dont know much about Marantz model numbers so it gets a little confusing, and is there Denon pre/pro's that are up with these ones i have listed that i should consider?
Im looking to spend roughy around $1500-$2500 on either a new or used unit i dont mind either way.
Im sure the Rotel would blend in with the rest of my system like a glove, but how would the likes of Marantz/Denon/Parasound etc be?
* Would like all of the latest decoding and room correction etc/ The best audio and visual possible for my budget/
Any help very much appreciated, thanks guys. Heath.
Edited by bmwheath
htbpass applies to a 2ch analog pre amp so not a feature you'll find on any one of these. for the budget rule out the marantz 8801 as best you'd find it would be about twice your budget.
re denon their av processor released about 5 years ago and recently updated for 3D audyssey etc was a limited released and no longer available, it retailed for about 7 times your budget anyways was a cost no object thing. next one due in about 5 years as they bring out a flagship like it every 5 years :)
no parasound. in the other options neither will have full audyssey xt 32 whih is the most comprehensive/latest. so could prob go the marantz 7705 with older audyssey xt or go the rotel with no room eq though as you say would match up well with the rest of your amps :)
Thanks again for your input al! Im not sure what i was thinking then, yes i will also need to upgrade my current 2 channel pre amp (Rotel rc1082) as it doesnt have the HT bypass (spewing because i really like this pre amp). This being said can you think of any other pre/pro that would suit my system nicely that would meet my requirments. I have also been looking at the Emotiva XMC-1 which still waiting for a release date priced at $1499 so would be roughy $2000 landed here. Any opinions on the specs of the emo?
hi heath there are a couple of 2ch analog pre amps with ht bypass going on dtv in the for sale section, one the primare pre 30 and another a stello pre dac. not aware of rotel making a pre with htbypass. emotiva given their track record on pre amps and given poor quality components lack of after sales locally etc I wouldnt touch with a barge pole but thats a call you would need to make :)
Edited by :) al
ps according to the guys over at club rotel it would appear the rotel 1580 is rotels first 2ch amp with ht bypass
http://www.htguide.com/forum/showthread.php?36694-Rotel-RC-1580-HT-Bypass-(Tape-2)
just need to use the tape 2 input as ht bypass it seems :)
one going cheap here,
http://www.gumtree.com.au/s-ad/broadbeach/audio/rotel-pre-amplifier-rc-1580/1009175623
Edited by :) al
Hey al, yeah ive been looking at the Rotel rc 1580 pre amp with bypass ( its the newer version of the rc1082 i have now). Ive had no experience with Primare product but i havnt ready any bad reviews to date, what are your opinions on the PRE 30? Sound quality etc?
I recently swapped out my Denon AVR4810 for a Marantz AV8801 and I have to say even though I have yet to run Audyssey Auto EQ on the new machine, it is pretty impressive, despite the fact that I am using the same external amps for both units.
I was changing the speaker settings on the Denon a while back so the EQ data was lost and I never got around to running auto EQ again so it's pretty much a comparison of the pre/pro decoding capabilities of the 2 units.
I find that the Marantz seems incredibly good at channel steering. I never noticed how well the sounds pan across the speakers with the Denon, but the Marantz does it so well it's pretty impressive.
MARANTZ AV 7005
This is an old model. It has Audyssey MultiEQ XT but not XT32
MARANTZ AV 7701
This is merely a refreshed 7005 IMHO and it still doesn't have XT32.
MARANTZ AV 8801
This is the flagship and is based off the Denon 4520. It supports up to 11 channels processing with DTS NeoX and Audyssey DSX.
I'm gonna stick with my suggestion to by a brand new Onkyo TXNR818 for $1500. 3 years warranty (peace of mind) - and the latest XT32 processing power. Best of all, your resale value will be better than on a stand alone pre.
I haven't found a cheaper entry point to the world of XT32 yet.
Yep I'd agree you'd get better resale on an avr than processor, apart from the onkyo there the denon 4311 with xt32 can also recommend that can usually pick up well within budget :)
Otherwise if after an av pre pro pretty much limited to options already discussed.
Thanks Doggie, thats the sought of info i was after. I would love the AV8801 but just cant afford it right now as just bought a house and building a pool. What does the Audyssey XT32 do differently than the MultiEQ? Is there a Denon unit that compares to the AV8801?
Have you had any experience with Onkyo as a pre/pro to compare to Marantz or Denon?
Hey Juicester, the Onkyo TXNR818 is looking like my best option budget wise, and has XT32, the only reason i havnt bought the Onkyo yet is that i already have an Onkyo receiver (SR876) and not a big fan of the audio qualities, dont get me wrong they have LOTS of features and very well priced but just lack the audio quality im after.... the Marantz AV8801 is ideal but out of budget (unless someone hear is selling  a 2nd hand one cheap (DogdieHowser) lol : )
I certainly think it's (818) in the same ballpark in terms of audio quality as your other equipment. Furthermore, any small gain you might get for using one of the Marantz's, would be offset  (imho) by the fact that they don't have XT32.
Here's an article on the differences: http://www.audyssey.com/audio-technology/multeq#multeq-solutions
There are a few grades of Audyssey autoEQ. My 4810 had MultiEQ XT, while the new Denon 4520 (the AVR version of the 8801) has XT32.
XT32 offers a substantial increase in EQ resolution. There's a table here.
I used an Onkyo 875 as a preamp for the front 3 channels prior to the Denon 4810. I thought the Denon made the surround channels more discernable. But that could be because the Denon was a 9 channel amp (I was only using it to drive 4 channels, surround and surround back) while the Onkyo was a 7 channel amp (driving same number of channels) and the Denon was less stressed.
ps the new Onkyo model which replaces the 818 has just been announced and the news is not good. They've cut down the Audyssey from XT32 to XT. I predict a sudden increase in 818 demand. If that's what you are going for, better hurry.
ps I remember there was a group buy for the 8801 a while back in the dtv forums. The prices were surprisingly good! Not much more than what the guys in Singapore were paying IIRC.
Edited by DoggieHowser
I had a Onkyo 805 receiver that I was never happy with and recently went pre/pro/power option with Elektra and Integra 80.3 which is basically identical to a Onkyo pre/pro. I was a little concerned staying within the Onkyo family but I shouldn't have worried, the sound difference was chalk and cheese. Much clearer, dynamic and detailed now. I'd had the Elektra for a few weeks with my old receiver so can say the pre/pro made a bigger sound difference than the power amp.
    • By Supedeloop
      Item: Rotel A12 Intergrated Amplifier, 12 months old
      Price: $900 ono $720.00 inclusive $20 Donation
      Item Condition: Excellent
      Reason for selling: Change in direction
      Payment Method: Pickup - Cash
      Extra Info: Item is in excellent condition minus a little dust. Have box and I think all the original packaging.
    • By BradW
      G'day folks!
      New member and first post. 🙂
      Picked up a Marantz 1060 and wanted your thoughts on suitability for restoration. Doesn't look like it's been messed about with so I'm guessing all components are original and more than a little tired! Currently the RH channel is dead and adjusting the VR does not shift the DC offset from 2.2mv. LH channel adjusted fine to 7.5mv.
      I'd really value your opinions on weak points in this amp and where to begin troubleshooting. Happy to recap and upgrade electrolytics but any other components I should look to change out immediately?  I've a little experience with vintage Sansui but this is my first Marantz. I know the early Sansui AU series had an issue with noise transistors but I'm struggling to find articles on Marantz 1060 rebuilds. I'd rather not have to order a rebuild kit from the US as it would double the cost of my amp! Happy to source locally RS, Element 14 so if anyone has a rebuild parts list from these suppliers, that would be awesome.
      A couple of photos - fairly clean inside and have seen a lot worse! It's a lovely looking amp and from what I hear from 1 speaker, sounds warm but punchy.
      A big ask for my first post and grateful for any tips please.
      Brad
    • By So_Fresh_And_So_Clean
      Item: Marantz Model 140 Power Amplifier
      Price: $800 ono
      Item Condition: Good, working condition. All meters light up and function. Slight bend in bottom right corner of faceplate. Recently had transformer replaced, sounds great.
      Reason for selling: No longer required, as I have had to make space for two turntables and a mixer. Also selling a McIntosh C32 Preamplifier that this was paired with, see my other listing for info
      Payment Method: Pickup or ship at buyers expense - Cash, Paypal, COD, bank transfer
      Extra Info: US voltage on this unit. was plugged into the power inlet on the McIntosh C32 I am also selling, but otherwise can be used with a step up transformer.
    • By zakblue
      Item:  Marantz 460 Speakers
      Price: $50
      Item Condition: Good for age, vinyl finish peeling in places (could be reglued)
      Reason for selling: I really have too many speakers...
      Vintage Marantz speakers. Little picture on the front shows FR is flat from 80hz up as tested in anechoic chamber.
      Super laid back sounding.
    • By Tasso
      Item: MARANTZ AV8805
      Price: $4250
      Item Condition: EXCELLENT
      Reason for selling:  See text
      Extra Info:   Comes with original box and packaging and can be shipped safely anywhere in Australia
      This unit has not seen a lot of use and it operates flawlessly.   I have recently purchased a Lyndorf MP-50 and the Marantz is now for sale.
      I can ship anywhere and if you have any queries , please contact me.  Specs are below:
      AV8805The World’s First 13.2 Channel Full 4K Ultra HD Network AV Surround Pre-Amplifier with HEOS. Control Your Music with Amazon Alexa Voice Commands.
      MADE IN JAPAN
      The versatile Marantz AV8805 pre-amplifier redefines audiophile home cinema and music listening with an unprecedented 13.2 channel processing capability, and supports virtually any high-resolution multichannel audio format. Immerse yourself in three-dimensional audio with the latest surround formats like Dolby Atmos, DTS:X or Auro-3D. Enjoy enhanced audio quality supported by our proprietary current feedback and HDAM technology that passes signals through 15.2 channel XLR or 15.2 RCA outputs. Stream music throughout your home with HEOS multi-room listening and full wireless connectivity through the HEOS app or Amazon Alexa Voice Control, supported by Wi-Fi, Bluetooth and Apple Airplay. With the Marantz AV8805, you get incredible fidelity and unparalleled audio precision.
      Key Features
      13.2 channel processing with 15.2 channel XLR and RCA outputs and flexible pre-amplifier stages — ideal for the advanced home cinema enthusiast Enjoy immersive, three-dimensional sound with the latest surround formats including Dolby Atmos (up to 7.1.6 or 9.1.4), DTS:X and Auro-3D (up to 13.1) High-performance 192kHz/32bit D/A converters for all channels provide the highest resolution for music and movies Audyssey MultEQ XT32, LFC, Sub EQ HT, Dynamic Volume and DynamicEQ deliver equalization to best suit your listening environment Built-in Bluetooth and Wi-Fi with 2.4GHz/5GHz dual band support offer improved network stability even in Wi-Fi-crowded homes Listen from any room of your home with HEOS wireless music streaming technology and the HEOS app Ultimate visual quality with 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR, BT.2020, Dolby Vision and HLG (Hybrid Log Gamma) pass-through eARC (Enhanced Audio Return Channel) functionality via firmware update supports the most advanced surround and object-based audio formats, including Dolby Atmos and DTS:X via single HDMI connection between AVRs and compatible TVs Eight HDMI inputs, including one on the front, with full HDCP 2.2 support, plus three HDMI outputs (zones), plenty of inputs for your digital devices and the ability to support different video in different rooms Analog to HDMI conversion and SD to HD/4K Upscaling for legacy video sources, plus full HD and even Ultra HD video quality from existing DVDs or analog sources Stream music from AirPlay, Bluetooth, TuneIn Internet radio, Pandora, Spotify, SiriusXM, Amazon Prime Music, TIDAL and more via the HEOS app Network music streaming supported via DSD (2.8/5.6MHz), FLAC, ALAC and WAVsupport for high-resolution, Hi-Fi listening Installation and operation are seamless with the Setup Assistant and Marantz AVR Remote app Sophisticated Engineering
      The 13.2 channel AV8805 with 15.2 channel XLR and RCA outputs provide a flexible yet detailed pre-amplifier stage for the advanced home cinema enthusiast. Enjoy it with acoustically matching Marantz MM series power amplifiers, like the MM8077, and immerse yourself in three-dimensional audio provided by the latest integrated surround formats, including Dolby Atmos, DTS:X and Auro-3D. Auro-3D will be enabled via a future firmware update at no additional charge. Marantz proprietary HDAM technology combines matched-precision discrete circuit elements with ultra-wide-end response for a wider soundstage and refined musical reproduction while built-in Bluetooth, Wi-Fi streaming and HEOS support, plus Apple AirPlay compatibility, let you stream and enjoy your favorite audio wirelessly.
      Latest HDMI Connectivity; HDCP 2.2 Compatible
      The Marantz AV8805 is future-compatible, with the latest HDMI and HDCP 2.2 specifications on all eight HDMI inputs. AV8805 supports 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, High Dynamic Range (HDR) and 21:9 video, 3D, and BT.2020 pass-through on every input. It is compatible with 4K Ultra HD Blu-ray disc players, set-top boxes and other 4K Ultra HD sources. Dolby Vision compatibility, HLG (Hybrid Log Gamma), new HDR format for broadcasting and pass-through capability are also supported.
      Dolby Atmos
      Feel every dimension in Dolby Atmos with object-based audio formatting that creates a truly immersive listening experience. Enjoy a 7.1 surround sound speaker system and six additional overhead speakers or Dolby Atmos elevation speakers for the ultimate home theater experience — including Dolby Surround upmixer for legacy content.
      DTS:X
      DTS:X™ immersive audio places sound where it would occur naturally in space, creating a lifelike, multi-dimensional audio experience in the home. The included spatial remapping engine of DTS Neural:X™ offers improved immersion and heightened realism in all of your favorite movies.
      Auro-3D
      By fully immersing the listener in life-like sound, Auro-3D provides a more encapsulating surround sound experience thanks to dedicated height and overhead channels in addition to the regular channels. Auro-3D will be enabled via future firmware update at no additional charge.
      HDMI eARC Object-Based Audio Support
      eARC (Enhanced Audio Return Channel) supports the transmission of 3D audio from your TV apps with a single HDMI connection for the simplest setup. This feature will be enabled via a future firmware update.
      Built-in Bluetooth, Wi-Fi, and AirPlay Capability
      Featuring Bluetooth and Wi-Fi wireless streaming connectivity, the AV8805 is equipped with an advanced dual antenna transceiver system for robust streaming even in congested urban environments. Plus, with Apple AirPlay compatibility, you can enjoy listening to your favorite audio content wirelessly from your iOS devices such as an iPhone or iPad.
      HEOS: Your Perfect Solution for Wireless Multi-Room Music Streaming
      Built-in HEOS technology lets you enjoy your favorite music in any room of your home for a wireless, whole-home audio experience. Play the same song in every room, or select a different song for each connected room — the choice is yours. Also works with Amazon Alexa, providing cutting-edge voice control and incredible sound for all of your home entertainment. Enjoy music from Spotify, TuneIn Internet radio, Sound Cloud, Tidal, Napster, Deezer or your local music file libraries. With additional HEOS components like the HEOS speaker range or other HEOS-capable receivers, you can play all your music in one room or many.
      HEOS + Amazon Alexa
      Use your voice to stream your favorite music services to this HEOS-enabled AV Receiver. Ask Alexa to play music from Pandora, Spotify, Amazon Music and much more. Switch between inputs (Blu-ray, DVD, Media Player, etc.), turn volume up or down, pause, mute and play the next song — all with your voice.
      To start streaming with Alexa voice commands, open the Alexa app and select “Skills.” Add HEOS Home Entertainment to enable. Then, go to Smart Home in the Alexa app menu and choose Devices and Discover or say “Alexa, discover my devices.”
      With HEOS Home Entertainment and Alexa, you can stream to this product and any other HEOS-enabled device.
      Marantz 2016 AVR Remote
      Re-designed from the ground up, the Marantz 2016 AVR Remote app gives you unprecedented control over the latest generation of Marantz network AV Receivers, from iOS and Android phones and tablets. Along with many new features, the graphics and user interface have been completely overhauled: control power, volume, input and settings, or switch to the HEOS app to access an incredible range of music content and streaming services, all with full HEOS wireless multi-room control.
      Hi-Res Audio
      The AV8805 lets you discover the incredible fidelity of high-resolution audio tracks with the ability to decode up to 24-bit/192-kHz ALAC, FLAC and WAV lossless files as well as DSD 2.8MHz and 5.6MHz tracks (the audiophile format of SACD) via the front panel USB port and network sources. Or, listen to other popular file types such as MP3.
      Advanced 32-bit D/A Conversion On All Channels
      The Marantz AV8805 features premium grade AK4490 32-bit DACs on all channels and XLR input and outputs. There's a balanced XLR stereo input that's assignable as well as 15.2 balanced XLR outputs, which includes the two subwoofer outputs, front height/width outputs and overhead channels. This extensive balanced XLR compatibility ensures high-end performance in the home and the studio, while 15.2 pre-outs (RCA jacks) provide additional compatibility with multiple power amplifier types.
      High-Grade Audio Components
      The AV8805 features the latest Marantz proprietary HDAM (Hyper Dynamic Amplifier Module) components, which consist of matched-precision discrete selected circuit elements on a compact sub-board along with ultra-wide-band response (100 kHz, -3 dB) for an open soundstage with refined detail reproduction.
      Advanced Audyssey MultEQ XT32
      Equipped with the full Audyssey Platinum suite of advanced DSP algorithms, the AV8805 features Audyssey MultEQ XT32 automatic room acoustic correction. With the supplied measurement microphone, MultEQ XT32 analyzes each speaker's output (including the subwoofers) at up to eight measurement locations and generates precision digital filters that optimize each channel for the correct frequency and time domain response. Plus, the Audyssey MultEQ Editor app lets you view and adjust settings for detailed tuning and customize the sound more precisely to your room and tastes.
      The Audyssey MultEQ Editor App
      The AV8805 supports the brand-new Audyssey MultEQ Editor App. Go ‘under the hood’, view and adjust settings for detailed tuning, customize the sound more precisely to the specific problems in your room, and tailor the sound to your personal preferences.
      External Control Capabilities
      For remote control compatibility with other components in your home theater system, the AV8805 features an IR (infrared) remote control input and output on the rear panel, along with dual 12V trigger outputs. For direct connection to external home automation and control equipment, the AV8805 features an RS-232C serial port with Control4 SDDP (Simple Device Detection Protocol) and Crestron Connected certification for quick and easy integration with Control4 and Crestron home automation equipment.
      Dual Subwoofer Outputs
      A single subwoofer demands optimal placement to avoid audible peaks and dips in the low-frequency response at the main listening position. The AV8805 supports two subwoofers: used in different locations, these will even out the low-frequency response for more accurate bass anywhere in the room.
      Multi-source/Multi-room
      Whatever your family's entertainment needs, the AV8805 delivers: you can enjoy 13.2-channel surround sound in the main room, and at the same time play stereo sound from another source in a different part of the house. There are versatile configuration options thanks to the 13 channel processing capability.
      Smart TV Connectivity
      The Marantz AV8805 may be controlled with your Smart TV remote via the HDMI CEC functionality associated with your Smart TV. Simply set “HDMI Control” to ON in your receiver, then set “Smart Menu” to ON and begin controlling the AV8805 with your TV remote. The Smart Menu home screen provides you quick access to source and surround mode selections, the AVR's setup menu and four Smart Selects.
      Simple Smart Select Functions
      The AV8805 has four Smart Select buttons on the remote control: each stores a preferred setup – input, volume and Audyssey configuration – for a particular source. Push one button and the AV8805 can be perfectly configured for anything, from Blu-ray or your TV set-top box to your favorite Internet radio station.
      Easy To Setup, Easy To Use
      For easy installation, the AV8805's clear graphical on-screen display has an exclusive Setup Assistant, combining with the Quick Start guide to provide guidance and optimize critical settings for the best possible sound quality, whatever your configuration.
      More than 60 Years of Audiophile Heritage
      Founded in 1953, Marantz has a long and rich history of designing audio components embraced by music lovers and critical listeners around the world. Because Music Matters, the AV8805 carries on our long tradition of delivering a best-in-class listening experience for music and cinema.
