houdinifangs
Show us your tubes
Some inside and out shots for the toob aficionados.............sorry about the dust............
I use a long bristled paint brush to remove dust. Some nice components in there.
I have a pair of these expensive 50 year treasure 6SN7s. I'm thinking the next preamp build should use these up. The Grant Audio Psvane globes I have been using are over double the price of these ($570) but doesn't make them less of a tube.
I have two commission jobs to complete then maybe this could be the next. It would look like the others. I even bought an extra chassis last order thinking this maybe the way to go.
@mwhouston have you had many comparos with tubes vs the PS Vane units?
When my Time Machine arrives from Earle, it will have-
Sovtek 2A3
Tung Sol 6SL7
Svetlana 5U4g.
To 'PS Vane-up' the Weston Pre will be around 1400 to 1500 bucks. This will be fine but just wondering if you had any other alternative suggestions or omissions ('not worth while swapping that one' etc).
Sovtek 2A3
Tung Sol 6SL7
Svetlana 5U4g.
Over that last few years I have been a Psvane convert. If I buy any tubes they are Psvane these days. I'm not a big A/B man I like to listen to amps, tubes, preamps  etc. as they are with their own character. But I have swapped tubes in the past and found some big and good changes so I should at least try.
I can only say try then better Psvanes and see what you think.
Sophia 274B Aqua rectifiers for my Audio Note Kits Mentor preamp.
Very impressive.
ECC88, KT66 and 805 valves in AM 805 mono block
Sorry about the phone pic.
Edited by Gryffles
First post on this thread for 2019, so keeping things kicking along,,,,,,,,,,,,
Edited by Mendes
I have wanted to try some different 2a3’s in the Time Machine since purchasing it from another SNA member last year, so when these TJ Full Music Mesh Plates were recently advertised I decided to give them a go and I’m very happy I did. I also recently fitted some ex US Army issue 1944 made RCA JAN 6SL7GT’s which was a welcomed sq improvement over the high hour Tungsols that were fitted.
The Time Machine with these two changes in tubes is finally starting to have a warm valve sound to it that I was chasing as an alternative occasional listening option to the almost SS detailed sq delivery of the Primaluna’s that I enjoy 90% of the time.
I’m still blown away about how strong Earl’s 7watt Time Machine amp can sound.
cheers Terry
Edited by TerryO
cheers Terry
Looks pretty darn good.
cheers Terry
Pretty cool looking valves.   Love being able to see the filaments through the plates.
Loving the new edition.
My first tube amp and so happy with it.
Rolling some new 300B tubes that arrived yesterday.
Pretty good straight out of the box and now need to put some hours into them to evaluate properly....
Back from overseas today, miss my tubes... trying a new set of tubes for the new year. Sovtek 6AS7, Philips miniwatt 6EM7 and Telefunken GZ32.20190118_224645.jpeg
Welcome home Dennis...:thumb::hiccup
Been doing some tubular things in my system thread from here onwards-
could have also posted here but  am a lazy mahfar.
Got jealous since I hadn't posted in a while and took a nice angle of these guys, and wanted to try the new phone camera.IMG_20190126_123620.thumb.jpg.5a677022dd6491e4dbb135fc2f87c006.jpg
1 hour ago, Ihearmusic said:
More 300B goodness......
Finally finished the twins.20190126_090413.thumb.jpg.ff0a9b33521fcb72e131e2e588f3fe8b.jpg
Excellent.
I'm at the pointy end of commissioning the first of my completely hand-built 6 Channel SET monoblocs.  I started with a basic circuit and had Lucas of Black Art Audio custom wind all the iron apart from output transformers, and designed the chassis around them.
Here is the first amp undergoing some testing on my electronics bench.  Note the power supply sitting on the floor...it weighs about 100kg and has three umbilical cables up to the amplifier: one for services and startup/shutdown protocol control and indication; one for the ac filaments/heaters; one for high voltage DC.
I've really left no stone un-turned when designing and building this amp and at this stage there is not too much that I would change about its layout and operation.  All six channels are driven by 6e5p or 6e6p tubes in triode mode.  Each amplifier is designed and tuned for a specific frequency range and transducer to which it is directly connected.  No passive crossovers...electronic filters are included at the input of each channel.  Power tubes vary according to the intended load: full 6c33c for the bass channel; half 6C33C for mid-bass channel; half 6c33c for upper-bass channel; lower mids uses no power tube and is a single stage stage amp; mid-range can be adjusted for 2.5v and 4v DHT tubes such as 2a3, 45, YO186, RE604, KL71403 et cetera; the HF amp is direct coupled to the transformer integrated in the RAAL ribbon transducer and  again is a single stage triode.
Here it is in full glow late in the afternoon with curtains drawn.  Those two purple gas regulator tubes are for the unusual bias arrangement and enable this amp to be DC coupled.  I've got to find some time to measure and evaluate all the channels, and then finish building the second monobloc.
Crazy good!
