Bervy
Yamaha RX-V995 buzz in main channels
Been using this receiver as a basic stereo amp in my office running off the optical output of a Mac Pro - running ProAc clones.
Today it started buzzing in both channels, independent of volume knob, same on all sources. Could still hear the sources though, but the buzz is quite loud and doesn't change in volume with the source, but will change when balance is panned left & right.
I plugged he speakers into the B speaker output and it is the same.
Plugging the speakers into the surround channels and there is no buzz.
Any idea if this is a simple fix or is it time to upgrade?
Unplug everything, except the speakers. If the buzz persists, send the amp to the man. If not, plug each component in, one by one and see which one is causing the fault.
Like ZB says -- and turn it off every time to change connections.
Thanks for the replies.
Still has the buzz with nothing plugged into it.
Not changed by volume. On every source. On both A & B speaker outputs but not surround outputs. I can however pan the buzz left and right.
My brother is a tech (industrial not AV gear) and would be able to replace caps or similar if that is where the issue is.
So, given the symptoms, what is the usual culprit?
Thanks.
Thanks.
It could be one of about 100 things. There is no "usual culprit" in such cases. Send it to the man. If your brother is a tech, then he will require a service manual, appropriate test equipment and plenty of time. Focus on power supplies, blown earth tracks and loose screws.
Righto no worries.
This then brings me to the question is it worth it?
It's obviously going to cost a couple of hundred just to diagnose, then parts & repairs on top of that.
So do I do that or chuck it and buy something else?
Cheers.
Righto no worries.
Only you and your tech can answer that question.
No idea. Ask your tech.
Cheers.
I don't know. Your tech and yourself will need to make that decision.
Okay thanks.
Get your brother to have a look incase it is something obvious and a easy fix.
Otherwise I would buy something else to replace it instead of trying to get it fixed.
Something like this
http://www.synergyaudio.com/Cambridge-Audio/AV-Receivers/Cambridge-Audio-340R-A/V-Receiver-Silver--SN--0712-0328-/481/storeproductdetail.aspx
Edited by rocky500
Wow - is that amp really a $999 amp down to $199? If that's an okay amp I'll just buy that.
It looks they are the importers/distributors for Cambridge Audio.
I would say they have old stock they want to clear.
Have a look at the other gear they have in the clearance section. Something else might appeal to you better.
I have not heard the brand myself but seems to always get pretty good reviews and I don't think you could go wrong for the price. Also could be a step up from your old yamaha.
Edited by rocky500
That looks great too but I chose the first one as it has optical in. The one you picked there I don't think has it, so you would have to work out another way to plug in your Mac Pro.
There is something like this to give you optical. Not sure if there any good.
http://www.ebay.com.au/itm/New-Digital-Optical-Coaxial-Toslink-SPDIF-to-Analog-RCA-L-R-Audio-Converter-/370721433601?pt=LH_DefaultDomain_15&hash=item5650b82801
Edited by rocky500
Yeah just looking at exactly that. Looks like demo stock - has condition report etc. Still looks good though.
Thanks for your help Rocky500. Much appreciated.
    • By dastinger
      Hello everyone!   I wouldn't be asking for help if I hadn't tried everything I could think of, but this is messing with my mind for some time now and I can't stop thinking about it, mainly because I either find a solution or I resign to listen to music with a background buzz. I also know there are tons of threads like this. Believe me, I read a lot of them and many of the things I tried were suggested on those exact threads. I also know that this could probably be fixed with a ground wire, but is taking the tonearm apart of a one month old turntable really the only option? Would it 100% fix it? I would like to avoid losing the warranty as much as possible.   (HUGE READ AHEAD)   I'll try to keep it as short as possible, but I don't want to miss any detail. I tried a mountain of things and still couldn't fix it, so I'm hoping some of the more experienced users here could chime in and discuss ideas/share how they solved issues like this one.   My system is not the best, mainly because I'm using a home theatre receiver, but this shouldn't happen nevertheless:   TT: Rega Planar 1 w/ Rega Carbon (1 month old) Receiver: Marantz SR-73 (early 90s) Speakers: B&W DM305 (mid 90s?)   First of all, I want to point out that I'm not sure if the issue was present since I acquired the Planar 1 or if it developed in the mean time. I honestly can't pinpoint when I noticed it, but it was maybe a week and a half ago.   The issue is fairly simple. I have a high pitched buzz that I can hear when the volume is at 25%+ which is not loud at all. I'm writing this post listening to music using this exact setup, directly below my son's bedroom, dial is precisely on the 25% position and you can't hear a sound upstairs. House does not have the best isolation either.   Anyway, the buzz is there and gets louder when I turn the volume up. It also gets louder when I position my hand next to the cartridge or the back tip of the tonearm. For the ones who don't know, Rega does not use an external grounding wire like most manufacturers. Now, here's what I tried doing:   Move the TT away from the amp. To the front, sides and back. As far as the wiring lets me; Disconnect any other piece of equipment from the receiver leaving only the speakers and the TT; Change speaker wire (the one I was using was crap, now I upgraded); Unplugged TT from power outlet; Changed power strip/plugged directly to the wall (receiver); Tried it with headphones; Tried it with different receivers; Moved rooms AND floors; Tried setting up the amp and turntable on different bases; Unplugged everything connected to a power outlet on the same room; Turned off the lights.   Nothing solved it. NOTHING. It didn't even make it better. And yes, the TT doesn't need to be powered (or the power cord connected) for the issue to arise. Also, the buzz is constant and does not happen on any other input.   Now, here's what helped a little bit:   If I plug a RCA -> Jack cable to my aluminum phone, the buzz is reduced a bit; If I plug the turntable power cord directly to the receiver (it has a power outlet on the back), the buzz is further reduced.   BUT, it is still there and it's annoying, mainly if I want to listen to music using headphones.   Now, this is where things get worse (I guess). A friend brought his Pioneer PL-100 and Pioneer vintage amp to my place and we set it up on the exact same location:   Rega connected to his amp -> Buzz Pioneer PL-100 connected to his amp -> No buzz   So, issue might be on the turntable or my place, right? OK, let's take the turntable and my amp to his place. Different house, different area of the city (~3 km away). We got there, connected everything up and, you guessed it, same exact buzz.   So, case solved, it's the turntable! Well, not quite. The hi-fi shop I bought it in is a few meters away from his place so we decided to go there. Once we got there, we connected my receiver, my turntable and my headphones. Guess what, not a sound. There was a bit of hum, but only when the volume was raised above 75%. And it was not the same type of sound. At my place (and my friend's), it's a high pitched hiss/buzz mixed with a low one. At the store, there was only the low one, which is not half as annoying. And only noticeable at 75%+ volume, which I'll probably never use.   Btw, the electrical installation at my place is 15 years old. His is a year and a half. Both are grounded as far as we know, we're in Europe in case that helps (not the UK).   This has got a lot bigger than I thought and I think every piece of information needed is there. What would you do? I can't enjoy listening to music and I don't want to throw the €270 spent on the Planar 1 down the gutter. I can't even use the warranty because they'd probably test it at Rega and say there's no issue, just like it happened at the store (I watched the test being done, I listened myself).   So, any ideas? I'm at a loss and I can't get my head off of this, I could use some help.
    • By 3daysofrain
      Does anyone here use a TTPSU with their Rega? I've had one for a month or so and just noticed last night whilst the room was dead quiet that it emits a soft buzzing sound from it. It's not very loud and I've never noticed it before but in a quiet room with my ear to it it's definitely apparent.
      I've done some searches and couldn't find anything on it. Would just like to know if this is normal if someone can test for me. Thanks!
