alistairm
"Pop" when putting record clamp on
I've started (after changing equipment) to get a little "pop" in the right channel when I touch the metal part of the turntable clamp to the spindle.
This happens when there is no needle down. Seems like an earthing issue, or stray static electric problem? Not too sure... any suggestions?
Al
Is the bearing earthed? not sure if it should be.
I've had a similar thing happen since the weekend. Maybe a change of season?!
Do you have an anti-static gun (eg zerostat) that you could zap the turntable with prior to attaching the clamp?
Magical things those black disk spinners - aren't they. I would also suggest zapping yourself with a taser-gun before operating record playing machinery - it won't help with a pop, but you will probably have great difficulties hearing anything (let alone a small pop). :):thumb:
Guest yamaha_man
That "Pop" your hearing is Karma for not PM'n me about the amp stand before you listed it. :P
Decky is on the money here with the zap yourself suggestion.If your body becomes statically charged then,when you touch an earthed component a path is created for the 'pop' to occur.As to the cause of the charge build up; polypropylene carpet,rubber or synthetic soles are typical suspects.The worse case you can have have of this phenomenon is when you receive a small electric shock.The worst effect is when you are dealing with a statically charged car via a door handle.
Is there a simple way to "de-charge yourself" before touching the TT?
Can one earth the bearing?
Al
Yep just touch the chasis of a component before you touch the turntable
I have been thinking of seeing how hard it would be to earth the bearing on my TNT , I have a look and think about it , if I come up with a workable solution I'll get back to you
Warren
It's a good possibility that its static
But what puzzles me is, why just the right channel ?
Check for good connection of all wiring
Alistair
I am earthing the bearing on my TNT next Sunday , I will give you feedback on how it goes
Warren
