egosbar
potentiometer
was wondering if anyone can put me on the right track for a potentiometer similar to a volume knob which is usb and programable , im actually looking to program it to change numbers onscreen on the computer for a project
so i want to program it to go 65 minimum setting and have 20 incrememts as 1.5 each so max would be 95 , it would have to start at in postition minimum 7 oclock and end in maximum postition 5 oclock
this probably belongs in a computer forum but i dont want to join another forum
This isn't exactly what you're after..............but it's a great thing!
http://www.mackie.co...oducts/bigknob/
(I'll get with something you might be able to use later)
edit - this looks promising!
http://www.behringer.com/EN/Products/CONTROL1USB.aspx
Edited by LogicprObe
You want a digital rotary encoder rather that a potentiometer. As for one that's packaged and 'programmable'; you're on your own...
thanks guys its not for volume control , im doing a drill rig gui panel simulator and i want the potentiometer to change pressure digital settings as the increments in myu first post suggests , thanks for the replies im about to look at them now
as i said probably wrong forum but i didnt want to join another forum , and it will be like a volume knob and i guess the digital volume numbers should be programable in increments but i need it to start at 65 and ende at 95 with 20 increments
if you look at a volume control on small computer speakers thats what im after but as i said programable
Edited by egosbar
