Bus_Boy 56 Posted September 23, 2012 Share Posted September 23, 2012 (edited) Hi guys, I picked up a Loewe Xelos sl 37'' from an auction today, and i'm having a bit of trouble with it. It's an older model no hdmi ect, and it has a separate component unit that plugs into it, which has an sd card reader and a set of component inputs. Anyways when i plug the blu ray player in using the component cables the image is very blurry. I've tried changing the resolution from the blu ray player but it didn't make any difference. I don't know what the resolution capabilities of the tv are? Anyone have any ideas on why the picture is so fuzzy? Edited September 23, 2012 by Bus_Boy Quote Link to post Share on other sites
Upfront 1,954 Posted September 23, 2012 Share Posted September 23, 2012 It may be an RGB input rather than component. Same colours but different signal. Might need a better explanation of the "blurry" picture Quote Link to post Share on other sites
Bus_Boy 56 Posted September 23, 2012 Author Share Posted September 23, 2012 (edited) It looks like a lot of pixels are missing, sorry i can't be more specific, i'll get the camera out later and take some snaps someone might recognise the model Edited September 23, 2012 by Bus_Boy Quote Link to post Share on other sites
Saxon Hall 4,214 Posted September 23, 2012 Share Posted September 23, 2012 I would like to help so do you have the exact model number? Any searches I have done turn up HDMI equipped versions. Quote Link to post Share on other sites
Bus_Boy 56 Posted September 23, 2012 Author Share Posted September 23, 2012 On the back it says Xelos SL 37, and everything i have found indicates HDMI inputs also. But on the there are no inputs at all, just a separate signal box. Quote Link to post Share on other sites
Upfront 1,954 Posted September 23, 2012 Share Posted September 23, 2012 I've never had one of these tvs but on some models the input is switchable between RGB and component on both the DVD player and the tv. Both need to be the same. Does that make sense? Hope so. It's been a big weekend🺠Quote Link to post Share on other sites
LogicprObe 7,625 Posted September 23, 2012 Share Posted September 23, 2012 Does that make sense? Hope so. It's been a big weekendí ¼í½º At least you were Upfront about it! Quote Link to post Share on other sites
Saxon Hall 4,214 Posted September 23, 2012 Share Posted September 23, 2012 Does it have any SCART connectors? Quote Link to post Share on other sites
Bus_Boy 56 Posted September 23, 2012 Author Share Posted September 23, 2012 Does it have any SCART connectors? I think so i'm not familiar with scart, but i beleive this is the same as the one i just picked up http://www.kalaydo.de/kleinanzeigen/lcd-fernseher/lcd-fernseher-loewe-xelos-sl-37-hd/a/30455730/ Quote Link to post Share on other sites
Saxon Hall 4,214 Posted September 23, 2012 Share Posted September 23, 2012 Your Blu Ray player may be outputting a signal incompatible with your TV. For example it may be outputting a progressive signal to an interlaced only TV. You need to match the Blu Ray player to the TV. The reason I asked about the SCARTS is that I have A TV where you can assign either RGB or Component input to the SCART, AS you are using the seperate Component Inputs then maybe this is not relevant. Quote Link to post Share on other sites
cableconnoisseur 215 Posted September 23, 2012 Share Posted September 23, 2012 Hi guys, I picked up a Lowew Xelos sl 37'' from an auction today, and i'm having a bit of trouble with it. It's an older model no hdmi ect, and it has a separate component unit that plugs into it, which has an sd card reader and a set of component inputs. Anyways when i plug the blu ray player in using the component cables the image is very blurry. I've tried changing the resolution from the blu ray player but it didn't make any difference. I don't know what the resolution capabilities of the tv are? Anyone have any ideas on why the picture is so fuzzy? Dan, As long as your component cables are correctly plugged (RGB) into the unit, the next option is to check the resolution being 'output' by your blu ray player. My guess is that you have it outputting @ 1080p, when the Loewe's native resolution is most likely around 576i or 480p. Try resetting the output resolution (on the bluray player) to a lower figure and that ought to help fix the problem. Sure, you won't end up with the best picture quality, but even at 576/480 you'll have a fabulous picture. I use the above settings on my Panasonic CRT as well as an older Loewe when viewing HD material. Good luck !! Quote Link to post Share on other sites
Jventer 1,668 Posted September 23, 2012 Share Posted September 23, 2012 I had an old model and used the scart connections. There is no way I could figure out what to do without the manual. Every time I moved it took me at least half a day to get the TV and VCR and DVD working. See if you can get a manual somewhere. Loewe is sold by Len Wallis, maybe they can help. Quote Link to post Share on other sites
Bus_Boy 56 Posted September 23, 2012 Author Share Posted September 23, 2012 (edited) Dan, As long as your component cables are correctly plugged (RGB) into the unit, the next option is to check the resolution being 'output' by your blu ray player. My guess is that you have it outputting @ 1080p, when the Loewe's native resolution is most likely around 576i or 480p. Try resetting the output resolution (on the bluray player) to a lower figure and that ought to help fix the problem. Sure, you won't end up with the best picture quality, but even at 576/480 you'll have a fabulous picture. I use the above settings on my Panasonic CRT as well as an older Loewe when viewing HD material. Good luck !! I'll have to have another tinker with it tommorow. I tried changing the resolution on the brp right down the to lowest setting, but the image was still very choppy, also a bit of the image seems to be cut off from the bottom. Sounds works fine though!! I hope i can get a somewhat decent image out of it, it was a bit of an impulse buy, having seen the brand before and the price tags that go with it, no one was bidding and i said $200 and ending up getting it and thought i'd put it in the bedroom. It looks to have had minimal use and i'm sure it's just a setup issue that i'm not familiar with being a slightly older model, from 2006 i believe. Edited September 23, 2012 by Bus_Boy Quote Link to post Share on other sites
cableconnoisseur 215 Posted September 23, 2012 Share Posted September 23, 2012 Feel free to PM if you're still struggling today. I'd also try the settings on the TV (it may be preset to interlaced, but is receiving a progressive signal from the BRP) That is why you're getting a choppy pic, I think. Warm regards, Russ. PS: Nothing wrong with an impulse buy...........most of my A/V collection is. Quote Link to post Share on other sites
Jventer 1,668 Posted September 24, 2012 Share Posted September 24, 2012 Loewe for $200 - bargain! it is a good brand. Quote Link to post Share on other sites
Rob181 3,195 Posted September 24, 2012 Share Posted September 24, 2012 Hi guys, I picked up a Loewe Xelos sl 37'' from an auction today, and i'm having a bit of trouble with it. It's an older model no hdmi ect, and it has a separate component unit that plugs into it, which has an sd card reader and a set of component inputs. Anyways when i plug the blu ray player in using the component cables the image is very blurry. I've tried changing the resolution from the blu ray player but it didn't make any difference. I don't know what the resolution capabilities of the tv are? Anyone have any ideas on why the picture is so fuzzy? I own a Loewe Aventus that ised in the second TV room...still have all the documents...use a SCART cable and have never had an issue...even moving every year for the last 6 years. PM me if I can help out in any way...Rob Quote Link to post Share on other sites
Grumpy 2,669 Posted September 24, 2012 Share Posted September 24, 2012 A choppy picture could be a faulty cable connection issue either end including the antenna connection Quote Link to post Share on other sites
Ozcall 1,416 Posted September 24, 2012 Share Posted September 24, 2012 (edited) Hi BB , I have a Xelos 26 and it does have one HDMI INPUT. I wonder if the one you have was a grey import or brought over here by the owner. International Dynamics were the Loewe importer when the Xelos was new so I would give them a call : http://www.internati...ynamics.com.au/ PS : LOEWE'S are menu driven, from memory, you have to drill down through the menu's to 'Connections' and assign an input and the signal type it will recieve. Edited September 24, 2012 by Ozcall Quote Link to post Share on other sites
jamesg11 224 Posted September 24, 2012 Share Posted September 24, 2012 Hi BB , I have a Xelos 26 and it does have one HDMI INPUT. I wonder if the one you have was a grey import or brought over here by the owner. International Dynamics were the Loewe importer when the Xelos was new so I would give them a call : http://www.internati...ynamics.com.au/ PS : LOEWE'S are menu driven, from memory, you have to drill down through the menu's to 'Connections' and assign an input and the signal type it will recieve. Yep, way to go with this... The scart connectors at back offer different combinations of output - RGB, comp etc. you have to get the right one ... + set right ouput from BD player. Quote Link to post Share on other sites
Bus_Boy 56 Posted September 25, 2012 Author Share Posted September 25, 2012 Woo hoo got it sorted !!! I think i was getting mixed up using rgb out and component input, and not setting the output right from the blu ray player. Finally matched it up right, rgb output / input and changed the dics settings to rgb and voila theres the picture !! In the tv's settings though it's still saying the input signal is at 1920 x 1080, how it figures that though when it's resolution is only 1366 x 728 (or something like that..) I set the output on the blu ray to 1080i. Maybe i'll play around with it a bit more later but for now very happy !! Thanks guy's 1 Quote Link to post Share on other sites
cableconnoisseur 215 Posted September 25, 2012 Share Posted September 25, 2012 Everybody loves a happy ending...............Well Done !! 1 Quote Link to post Share on other sites
Rob181 3,195 Posted September 25, 2012 Share Posted September 25, 2012 Great to hear all is sorted...enjoy one of the best CRT TVs sold in AUS...Rob Quote Link to post Share on other sites
Aidas Ivanauskas 0 Posted January 6, 2018 Share Posted January 6, 2018 Can somebody help me? I bought LOEWE XELOS A 26, and there is no sound when it is connected to HDMI... I tried everything I cam imagine, but nothing helped. P.S. When it is connected to SCART - sound is OK. Quote Link to post Share on other sites
JSmith 1,949 Posted January 6, 2018 Share Posted January 6, 2018 2 minutes ago, Aidas Ivanauskas said: Can somebody help me? I bought LOEWE XELOS A 26, and there is no sound when it is connected to HDMI... I tried everything I cam imagine, but nothing helped. P.S. When it is connected to SCART - sound is OK. What device is sending the signal over HDMI to this TV and type of audio format? JSmith Quote Link to post Share on other sites
Aidas Ivanauskas 0 Posted January 6, 2018 Share Posted January 6, 2018 Quote Link to post Share on other sites
Aidas Ivanauskas 0 Posted January 6, 2018 Share Posted January 6, 2018 8 minutes ago, JSmith said: What device is sending the signal over HDMI to this TV and type of audio format? JSmith Quote Link to post Share on other sites
Aidas Ivanauskas 0 Posted January 6, 2018 Share Posted January 6, 2018 26 minutes ago, JSmith said: What device is sending the signal over HDMI to this TV and type of audio format? JSmith Quote Link to post Share on other sites
JSmith 1,949 Posted January 6, 2018 Share Posted January 6, 2018 4 minutes ago, Aidas Ivanauskas said: I mean what is sending to the TV, a bluray player or media streamer for example. It could be the TV is not recognising the audio format that is being sent... JSmith Quote Link to post Share on other sites
Aidas Ivanauskas 0 Posted January 6, 2018 Share Posted January 6, 2018 1 hour ago, JSmith said: What device is sending the signal over HDMI to this TV and type of audio format? JSmith TV via internet Quote Link to post Share on other sites
Aidas Ivanauskas 0 Posted January 14, 2018 Share Posted January 14, 2018 Any other ideas? Quote Link to post Share on other sites
JSmith 1,949 Posted January 15, 2018 Share Posted January 15, 2018 11 hours ago, Aidas Ivanauskas said: Any other ideas? Sure, I just need you to answer the questions from before. JSmith Quote Link to post Share on other sites
cwt 993 Posted January 15, 2018 Share Posted January 15, 2018 On 7/01/2018 at 3:04 AM, Aidas Ivanauskas said: TV via internet What is needed Aidas is where your hdmi input is coming from ; a pc ; NAS etc ; it doesn't have an Ethernet port... Its an old tv and it wont handle many modern codecs .. Its also an entry level loewe so wont have much in the way of decoding .. http://www.trustedreviews.com/reviews/loewe-xelos-a26-26in-lcd-tv Quote Link to post Share on other sites
Mat-with-one-t 1,294 Posted January 21, 2018 Share Posted January 21, 2018 On 07/01/2018 at 1:51 AM, Aidas Ivanauskas said: Can somebody help me? I bought LOEWE XELOS A 26, and there is no sound when it is connected to HDMI... I tried everything I cam imagine, but nothing helped. P.S. When it is connected to SCART - sound is OK. Hi mate. Our only telly is still a Xelos CRT (!), and I have had to much about with a tangle of connections and cables resembling upper reaches of the Amazon, but it’s all fine. I had an issue with no sound that turned out to be a powered scart-to-hdmi converter, where the connectors on the unit were a bit dodgy. It needed careful giggling, and when the sound returned, careful placement so they were not able to move again! Works fine now. As an aside, if anyone has a Xelos that suddenly dies, don’t chuck it. I’ve had mine die twice, and needed a 5c fuse replacement..... Quote Link to post Share on other sites
Rob181 3,195 Posted January 21, 2018 Share Posted January 21, 2018 14 minutes ago, Mat-with-one-t said: It needed careful giggling, Most have had a comedy on at the time... Quote Link to post Share on other sites
