Full Range
My Classic Sony TC-765 Reel 2 Reel
I was contemplating some sort of cover for my R2R, and I came across this site that makes to order to suit ones unit
Also the brand and model of ones machine can be added
Anyone have alternatives ?
http://hvmreelcovers.yolasite.com
mmmmmmmmmmmm%20019.jpg.opt375x452o0,0s37
Edited by Full Range
Hi Full, the Tape Deck discussions have stopped. What a pity. Thanks for the heads up on the cover. It looks interesting.
I found a Perspex dust cover for an RS1500 & I thought they looked great. Shows off the deck.
Has anyone bought any secondhand or new reels (without tape). If you have let me know the quality and the source.
Have a look here BW - http://www.casstape.com.au/Price_Lists/AUDIO_WEBSITE.pdf
Or the RMGI site for other distributors - http://www.rmgi.com.au
Today I just happened to be on business just a block away from Totally Technical in Bowen Hills Brisbane
They are stockists of RMGI audio tape and also repair equipment
I called in and purchased 2 pancakes of 1/4" tape to suit 10 1/2 " reels - Pancakes are tape without the reel and is the most economical way to purchase audio tape
All that's needed is to fit it to the nab and wind it on an empty reel
And you ask what was the price for brand new tape ?
Two pancakes cost $92.20 inc GST ( That's a lot better than 30 year old tape from eBay )
Let the recording begin :)
post-112724-0-09376000-1392981764_thumb.post-112724-0-48225800-1392981800_thumb.
post-112724-0-31134200-1392981778_thumb.post-112724-0-80667500-1392981824_thumb.
Mate nice picks of your R T R.
Here is a photo ( A sneak peak ;) ) with the new horn speakers set up
post-112724-0-18283800-1393065213_thumb.
A call out to see if any SNA members in Brisbane have the test equipment to check and adjust the Azimith on my heads
I can pay in superb coffee and a listening session of the system
Any takers
On 8/21/2012 at 1:13 AM, Full Range said:
Just a progress update for all
Called in to a shop and purchased some CRC - CO Contact Electrical Cleaner
I then went home and pulled the covers off the Reel2Reel and proceeded to clean just about everything including the head and mechanism area
All dials and switches were cleaned by spraying and turning/operating back and forth just to do a thorough job of it
Put it all together again and connected it up again for testing
Result is a roaring sucsess everithing works - in fact it's silky smooth
Currently sitting here on my iPad to post while listening to some music of the seventies
So now that it's a keeper I need to pull it apart again to give the dials and knobs along with face plates a good polish
I have noticed a little tarnish on some areas and some age residue on the chrome parts, especially the dials
Unless anyone has another method ? I will use Braso metal cleaner and buff them to a shiny luster
Thoughts anyone ?
2 hours ago, Steve Novak said:
Paul, I just bought a Sony TC-765 Reel to reel. I need the nab hubs with I gues spacers. Can you help me out? Thanks
A spacer is used to align the tape to the heads
If you use the steel reels that require a NAB hub to secure them
Then yes you will need a spacer between the reel and the drive hub
The spacer is a seperate item and is made of hard foam approx 1 to 1.5 mm thick
Best way to make one yourself is
First find a thin mouse mat
Remove the top plastic cover carefully
And the foam that's used on the underside of the mouse mat is then cut to the size of the motor drive hub
The spacer must be removed when using the plastic reels as they lock in with the spring star lock on the shaft
Cant help with the after market hubs
However I do have one set left of the original NOS Sony NAB hubs
@Full Range. Nice machine there and love the horns! I'm just about to start giving my TEAC rtr a clean. Cant seem to remove the knobs so I'll just have to give them a wipe down. What can I use to give the heads a clean? I assume just an alcohol based cleaner> Same with the rollers/guides?
I'm new to this so I don't want to use the wrong stuff...
M
M
Best I have found for cleaning heads is Isopropyl alcohol with some white magic foam
Same for the rollers
To rejuvenate the rollers you can use alcohol with very fine wet & dry sanding paper, brings them up like new, but only to be done while the rollers are spinning
The white magic foam with mild detergent is also fantastic on the rest of the unit as well
The knobs in these machines are generally secured in 3 ways and sometimes all methods are used on the same machine - depends on the size of the knob
1) An Allen key grub screw
2) Push in interference
3) D key push - sometimes with a spring steel holding key
Where do yet the magic foam from? Is that the same as Magic Eraser?
Yes same as Magic Eraser
I have found an Ebay source for the Reel spacer discs if you dont want to DIY as per my instructions in my earlier post
https://www.ebay.com.au/itm/281363948894
And a selection of NAB adapters
https://www.ebay.com.au/itm/282282673209
Awesome tape machine!
i have the Japanese version of it the TC-R7-2
Fairly easy to maintain, and great sound.
To really hear how good  this machines are you will need original tapes, who's is the only let down on the R2R subject.
There is some new masters available but "gulp" around 400US for a album...
That is the beauty of blank tapes - brand new tapes are available
You can record your own music to your taste and mix and match your favourites
Thank you @Full Range Yes, I guess I could do that..
I am waiting for one album I ordered, original master. Should be in my hands by next monday.
Thank you for the info on the Brisbane spot for new tape!
I also found these sites where you can buy new tapes. Some are a little pricey..
ABC Records (Jazz/Classical/Other) http://www.abcrecord.com
Acoustic Sounds: www.acousticsounds.com
Analog Mastering Services (Jazz/Rock/Classical) http://www.analogmaster.net
*Analogy Records (Jazz/Rock/Classical/Other) www.analogyrecords.org
Brilliance Music and Studios (in US, Contact Gary Koh at Genesis Advanced Technologies)
*Dangerous Analog (Jazz/Classical) www.dangerousanalog.com
Fone (Classical) see Elusive Disc
Groove Note (Jazz/Classical/Other) see Elusive Disc
Horch House (Jazz/Classical) http://www.analogarts.net
International Phonograph (Jazz) http://www.internationalphonographinc.com
Lutz Precision/MPS-Music (Jazz/Rock/Classical/Other) www.mps-music.com
MA Recordings ((in US, Contact Gary Koh at Genesis Advanced Technologies)
Master Tape Sound (Jazz/Rock/Classical/Other) http://www.unitedhomeaudio.com
Open Reel Records (Jazz/Rock/Classical/Other) www.openreelrecords.com
**Opus 3 (Jazz/Rock/Classical/Other) see Elusive Disc (http://www.opus3records.com)
Quinton Records (Jazz /Classical) http://www.quintonrecords.com
STS-digitalshop (Jazz/Classical/Rock) http://www.sts-digitalshop.nl/
The Tape Project (Jazz/Rock/Classical/Other) http://www.tapeproject.com
Tone-Pearl Records (Classical) http://www.tonepearls.com
Yarlung Records (Jazz /Classical/Other) www.yarlungrecords.com
Ultraanalogue Records (Classical) http://ultraanaloguerecordings.com
Lyn Stanley (special order) (Jazz)
Patricia Barber (special order) Jazz) http://www.premonitionrecords.com
Excellent list @vintagejapan
Just be aware to check the speed of your machine to equal the speed of the pre-recorded tape
Hi gents
Really interesting information. I’m in Perth and have exactly the same machine, bought it in 1992, but as it’s been in storage for  a quite a few years I found it badly damaged. The reel holders had cracked, brakes shot, insides all clogged up, etc etc.  With the help of a local 3D printer and lots of cleaning fluid, isopropyl alcohol and white lithium grease , have now put everything right and its working really well - except for intermittent playback on the right channel. The VU meters show recording is  good and through earphones the input sound great, I have carefully resoldered all the wiring to the heads as it had come apart,  so it’s not that, have ensured that the alignment of heads is bang on, cleaned and demagnetised the heads . The erase head works fine. The recording ,volume is a little low despite the vu meters set at max, but the intermittent right channel problem continues. Have a damaged the head, anyone know of an old machine going begging I can get my hands on for spare parts?
thanks in advance
George
George not sure what is damaged wrt to the head but you can get them relapped (machined)
From a non-owner’s perspective, this video was a good intro:
    • By Darn
      Item: Nakamichi RX-202 Tape Deck
      Price: $1200 ONO
      Item Condition: Excellent (just serviced)
      Reason for selling: Nor Required
      Extra Info:  This deck has seen very little use (you can tell by wear on heads and pinch rollers) and is in excellent cosmetic condition
                           The unit has been serviced by a Nakamichi trained tech. All the belts are brand new.
                           The auto-reverse switch is intermittent and could not be fixed - but then why would you want to miss the machine flipping the tape at the press of a button-
                           This is a joyous machine
    • By Audio Connection
      Item: Akai GXC-570, 3 Head Cassette Deck in excellent Condition
      Price: $800.
      Item Condition: Pre owned
      Reason for selling: Clearance
      Payment Method: Pickup - Cash, Credit card on pick up, Direct deposit
      Extra Info: Can freight at extra cost
      Akai 3-head, single compact cassette deck
      Track System: 4-track, 2-channel stereo
      Tape Speed: 4.76 cm/s
      Heads: 1 x combination record/playback, 1 x erase
      Motor: 2 x reel, 1 x capstan
      Tape Type: type I, CrO2, FeCr
      Noise Reduction: B
      Frequency Response: 30Hz to 19kHz  (FeCr tape)
      Signal to Noise Ratio: 62dB  (dolby
      Wow and Flutter: 0.06%
      Total Harmonic Distortion: 1%
      Input: 70mV (line), 0.3mV (mic)
      Output: 0.775V (line)
    • By simbot82
      Item: Nakamichi Dragon Tape Deck
      Price: $2200
      Item Condition: Professional Service
      Reason for selling:
      The Nakamichi Dragon is a legend amongst HIFI fans alike. You don't even need to be a Cassette junky to appreciate something like this.
      I won't bore you with the usual stats etc you know it all.
      Please see the pictures, ask your questions and buy with confidence. Unit has been serviced has follows:
      Remove jammed pinch roller assy’s, clean away old grease, lube and reassemble. Clean back tension felt and reel table surfaces. Check back tension reading. Within spec. Clean and demagnetize tape path Check and clean reel drive bush and idler. Replace stretched mode belt. Check azimuth belt and confirm fine Check EOT belt and confirm fine Lube capstan shaft bearings Clean cassette well Clean cassette door. Detail front panel/switches/back panel and mains lead/plug Following the service record and playback were tested on 3 typical tape types. Adjustments were made to the front panel 400Hz and bias by ear.
      Don't pass up the opportunity to buy this magnificent beast of a machine
    • By rocker4ever
      Teac X-3 Needs a belt. Got all the screws off the front panel and the parts that come off. Even took the back off.
      The front panel is loose on top/bottom  and both sides. Can get about 1/2 inch if pull lightly BUT seems like something in the middle by the heads is stopping it.
      A close look shows that it should lift right up from there. No need to take off the heads assembly. Tried looking for some screws from the back with no luck.
      Got a schematic and looked ... either I'm blind or somethings wrong. Can anyone tell me the exact procedure to get this panel off so I can put new belts on and see if anything else if needed. I would really appreciate it. Thanks guys.
    • By brenwa76
      Item: Nakamichi 480 (In need of service/repair)
      Price: $110 (EFT, Cash Pick up or Paypal + 2.6%)
      Item Condition: Physically good 7/10
      Reason for selling: No longer into cassettes
      Extra Info: Nakamichi 2 Head mid range tape deck. Worked fine but has been in dry storage for at least 5 years and now will not lift carriage to play although the motor is trying to and lights are on. Assume it's not a major repair job, but selling as is. No problem to ship it via courier, please contact me for a quote. Including a Denon 60 min Metal cassette tape, which I think i recorded an old LP on to several years ago and the original sales brochure.
