Full Range
My Classic Sony TC-765 Reel 2 Reel
I recently purchased a Classic Sony TC 765 Reel to Reel tape deck with many tapes to play classic 70s and 80s music
Based on info from the seller I will be the second owner
It will need some TLC externally as in a polish but overall it's in great condition
When tested - all worked OK however after the trip down from Noosa to my place in Brisbane it may have sustained some shaking to affect it on replay after connecting it up to my system
Every thing works like a charm and is quiet as a church mouse however it seems to have lost signal to the right channel
The VU meter also is not moving on that side
I have lived through the tape age and know about basic maintenance of these machines having used for some time a Revox back in the day
So far I have cleaned the heads and capstans ect that were relatively clean already
When I toggle the source to tape lever it crackles a little but does not activate into life the silent channel
So I am going to get some electronic cleaner in an aerosol can and after removing the panels give it a good clean to all the insides, while looking for loose wires, swollen capacitors ect
I am also calling on members that may provide information on spare parts source for them as they are hard to find apart from belt sets
Information also on heads that may be retrofitted from a similar model or different brand - just in case the playback head is the problem
Also any pimp my reel to reel info would be appreciated
P.S. I will post some photos soon
I can't offer any "pimp my reel to reel" advice, however if you don't have them the service manual and owners manual are here -
http://www.hifiengin...ny/tc-765.shtml
Edited by skippy124
Yes, I'd try cleaning all switches and pots with a good contact cleaner/lubricant in the hopes that this simple measure solves the problem.
It did for me with an Akai M10 RTR that had almost identical symptoms (totally disabled right channel - rec, monitor, playback and VU meter) and it turned out to be dirty contacts in a stereo/mono switch.
Although I understand the configuration of that particular switch relates specifically to that model Akai, maybe your Sony has something a bit similar.
Good luck. :)
Thank you both
Did I mention that it weighs 27 kilos
And tested my strength a little
Any pic's, I have an Ortari MX 55, it had a trip from Sydney to Melbourne with the result that a spindel got bent not fun. Graham on the forum would be one of the best areas of advice.
Sounds like a great machine.
Hopefully it's only a switch or a dry joint on a connector.
Posting a few of pictures as promised
Front View
Runs 7 inch Reels
post-112724-0-28331900-1344914229_thumb.
Closeup of front panel and buttons
post-112724-0-26282300-1344914284_thumb.
post-112724-0-42481500-1344914296_thumb.
A View of the back
post-112724-0-90168100-1344914472_thumb.
Edited by Full Range
Just a progress update for all
Called in to a shop and purchased some CRC - CO Contact Electrical Cleaner
I then went home and pulled the covers off the Reel2Reel and proceeded to clean just about everything including the head and mechanism area
All dials and switches were cleaned by spraying and turning/operating back and forth just to do a thorough job of it
Put it all together again and connected it up again for testing
Result is a roaring sucsess everithing works - in fact it's silky smooth
Currently sitting here on my iPad to post while listening to some music of the seventies
So now that it's a keeper I need to pull it apart again to give the dials and knobs along with face plates a good polish
I have noticed a little tarnish on some areas and some age residue on the chrome parts, especially the dials
Unless anyone has another method ? I will use Braso metal cleaner and buff them to a shiny luster
Thoughts anyone ?
Glad you got it going again. I was going to suggest it might have been a dodgy relay going on past experiences. Some machines also have plug in type modules with edge strip connectors
that could need a clean and re-tension. Often just reseating cards will fix the problems. The knobs and dials clean up very nicely in an ultrasonic bath.
I had a gut feeling that all it would have been is some dust or dirt that came loose during transport to my house ( some 120 km away
Still its a good thing that all components inside the unit is ***** and span now
Now on to the beautifying task and polishing job
Test day 2
All morning and into to afternoon it was playing non stop without issue
Someone with knowledge of the Sony TC 765 as to what NAB Hub Adaptors will fit from a generic brand or another brand so I can fit and play 10" reels
I have searched on the net without sucsess
Looking at an online users manual that the Sony has a rear spacer washer - see here - http://www.obsoletemedia.com/tapedecks/manuals/sonytc765/html/07.htm
I can make a rear spacer if need be but need suitable DES hubs first
Looking at the link I would say your best option for Nab hub adaptors to suit your Sony would be the TEAC TZ-612. These have a removable metal shim that acts as a spacer for the thinner metal reels. They go for big money on Ebay but you can still buy them new from TEAC in the states for less than half what most sellers on Ebay ask for them. There is the postage issue but at least your getting new units. The standard Revox units will also work but you would need to adjust the spindle (reel table) heights to suit using these.
Edited by gamve
I've got a Sony TC-630 circa 1970 which has some transport issues. Was a great machine when working. I've been in contact with these guys and they have been very helpful and communicative. http://broadcastworkshop.com/
In Melbourne but worth a call at least. Good luck!
Ok that link doesn't work for some reason, but try googling it. Here's their contact info
Broadcast Workshop, 476 Victoria Street, North Melbourne, Victoria, Australia, 3051 Ph: +61 (0)3 9329 7655 Fax: +61 (0)3 9328 3866 Email: info@broadcastworkshop.com
Edited by stewyh
Another option would be Serg at Audio Oz, super nice guy an a quarter of the price. Mine is booked in next week.
Another member used Broadcast W and after a lot of money, then sent it to Serg, he is happy now.
By the way, I am not affiliated in any way.
Good luck,
Greg
Good call on Serg PP, very helpful great knowlege.
Will be useing him to calibrate the 1/2 & 1/4 track Ortari's.
This beautiful Sony TC765 Reel2Reel tape deck is now all fully serviced
All the knobs are polished to look there best
And it plays superbly
Knobs before a polish
post-112724-0-62536600-1371538712_thumb.
A look at the heads
post-112724-0-55911100-1371538776_thumb.
To polish the pitted and tarnished knobs I used a combination of white magic sponge and brasso
post-112724-0-49243900-1371538840_thumb.
All polished and lit up ready to go
post-112724-0-81648200-1371539003_thumb.
post-112724-0-93777500-1371539063_thumb.
Gorgeous!
You inspire me to do something about my Akai R2R, although not as resplendent with knobs and dials :)
Gorgeous!
It took about 3 hours and most of that was polishing
Now I need to source some 10" X 1/4 Reels full or empty
The large reels make this deck look even cooler akin to mags on a car
An arty type photo to test my ipad photographic skills
post-112724-0-87526000-1371540667_thumb.
This is an interesting thread...the R2R machines are gorgeous. One question though, what do you play on them?
M
M
One can purchase many artists retail tapes, some old just like records and a few organisations are releasing new material
With the correct amp / preamp that has both the play and record connections, one can transfer any music from record, CD, Radio ect to tape
Most tape players have a two speed record / play system
The slower speed setting increases the playtime on the tape
So it's possible to record a few hours of music dependent on tape length per reel
Edit
I forgot to mention that one can record on both sides of the tape - effectively doubling your recording session
Here are some updated photos
The Sony TC765 is now in its new position and 10.5" reels fitted ( doing a room revamp on spouses orders ;) )
post-112724-0-40817900-1381275723_thumb.post-112724-0-33936700-1381275750_thumb.post-112724-0-33039000-1381275794_thumb.post-112724-0-10899000-1381275829_thumb.
Uncle there is a lot of taoe out there the only ones to bother with are the 15 ips safe masters or the new tape Project etc
Haveing said that you might just find a gem yester year but be extremly careful.
The sound is amazing on a pro machine at 15ips and master tape.
    • By Darn
      Item: Nakamichi RX-202 Tape Deck
      Price: $1200 ONO
      Item Condition: Excellent (just serviced)
      Reason for selling: Nor Required
      Extra Info:  This deck has seen very little use (you can tell by wear on heads and pinch rollers) and is in excellent cosmetic condition
                           The unit has been serviced by a Nakamichi trained tech. All the belts are brand new.
                           The auto-reverse switch is intermittent and could not be fixed - but then why would you want to miss the machine flipping the tape at the press of a button-
                           This is a joyous machine
    • By Audio Connection
      Item: Akai GXC-570, 3 Head Cassette Deck in excellent Condition
      Price: $800.
      Item Condition: Pre owned
      Reason for selling: Clearance
      Payment Method: Pickup - Cash, Credit card on pick up, Direct deposit
      Extra Info: Can freight at extra cost
      Akai 3-head, single compact cassette deck
      Track System: 4-track, 2-channel stereo
      Tape Speed: 4.76 cm/s
      Heads: 1 x combination record/playback, 1 x erase
      Motor: 2 x reel, 1 x capstan
      Tape Type: type I, CrO2, FeCr
      Noise Reduction: B
      Frequency Response: 30Hz to 19kHz  (FeCr tape)
      Signal to Noise Ratio: 62dB  (dolby
      Wow and Flutter: 0.06%
      Total Harmonic Distortion: 1%
      Input: 70mV (line), 0.3mV (mic)
      Output: 0.775V (line)
    • By simbot82
      Item: Nakamichi Dragon Tape Deck
      Price: $2200
      Item Condition: Professional Service
      Reason for selling:
      The Nakamichi Dragon is a legend amongst HIFI fans alike. You don't even need to be a Cassette junky to appreciate something like this.
      I won't bore you with the usual stats etc you know it all.
      Please see the pictures, ask your questions and buy with confidence. Unit has been serviced has follows:
      Remove jammed pinch roller assy’s, clean away old grease, lube and reassemble. Clean back tension felt and reel table surfaces. Check back tension reading. Within spec. Clean and demagnetize tape path Check and clean reel drive bush and idler. Replace stretched mode belt. Check azimuth belt and confirm fine Check EOT belt and confirm fine Lube capstan shaft bearings Clean cassette well Clean cassette door. Detail front panel/switches/back panel and mains lead/plug Following the service record and playback were tested on 3 typical tape types. Adjustments were made to the front panel 400Hz and bias by ear.
      Don't pass up the opportunity to buy this magnificent beast of a machine
    • By rocker4ever
      Teac X-3 Needs a belt. Got all the screws off the front panel and the parts that come off. Even took the back off.
      The front panel is loose on top/bottom  and both sides. Can get about 1/2 inch if pull lightly BUT seems like something in the middle by the heads is stopping it.
      A close look shows that it should lift right up from there. No need to take off the heads assembly. Tried looking for some screws from the back with no luck.
      Got a schematic and looked ... either I'm blind or somethings wrong. Can anyone tell me the exact procedure to get this panel off so I can put new belts on and see if anything else if needed. I would really appreciate it. Thanks guys.
    • By brenwa76
      Item: Nakamichi 480 (In need of service/repair)
      Price: $110 (EFT, Cash Pick up or Paypal + 2.6%)
      Item Condition: Physically good 7/10
      Reason for selling: No longer into cassettes
      Extra Info: Nakamichi 2 Head mid range tape deck. Worked fine but has been in dry storage for at least 5 years and now will not lift carriage to play although the motor is trying to and lights are on. Assume it's not a major repair job, but selling as is. No problem to ship it via courier, please contact me for a quote. Including a Denon 60 min Metal cassette tape, which I think i recorded an old LP on to several years ago and the original sales brochure.
