chexton
Best A/V Receiver and setup for simple Apple TV + Samsung Series 6 + Two Speakers
Hi all,
It's been a while since I dabbled with home audio so I'm a bit out of date. I'm helping my parents with a simple setup in their bedroom and these are the core components:
Samsung Series 6 TV
Apple TV
Two speakers
Here are the two primary use-cases:
1. Watch TV (standard tuner) or watch the Apple TV. In either even the sound will go via the television.
2. Steam music to the AppleTV via AirPlay.
In the latter situation, it'd be ideal not to have to turn the TV on.
I don't think I need an A/V Receiver at all as there are so few components but I do need something to drive the two speakers.
Here's what I currently have in mind:
Apple TV (HDMI) -> Samsung via HDMI (handles audio and video unless I'm much mistaken)
Samsung -> AudioSource AMP100 or similar
Apple TV (TOSLINK out) -> AudioSourceAMP100 Input 2
If this setup sounds logical, I'd appreciate advice on:
A. Does anyone have experience with the AudioSource AMP series, is it any good?
B. When watching the Apple TV (not listening) the AudioSource will receive the same output from the Apple TV direct and via the Samsung. Will the two input system on the AudioSource work in such a way that Input 1 will be prioritised and it'll ignore Input 2 (this sounds too good to be true).
Thanks all!
Chris
If you are wanting to send audio to the AudioSource amp you will need a DAC also I don't like the chances of playing music without the TV on as this has a lot to do with the firmware on the ATV, some allow it some don't. I've played with a few of these setups and it is really a hit and miss.
Safe bet:
1) Apple TV -> HDMI -> Samsung -> Optical Out -> DAC -> Input 2 on amp.
Once you have that working then try:
2) Apple TV -> HDMI -> Samsung
2a)Apple TV -> Optical -> DAC -> Input 2
1) Gives you all audio from the TV (HDTV+Apple TV) to the amp
2) Sends picture to the amp on HDMI
2a) Sends audio to the amp on optical
I should be sleeping though so double check my jibberish
Have you got a budget in mind? I figure you want as cheap as possible, so i'll advise along those lines
Firstly, check if your TV has analogue audio out. I've got a series 5 samsung and it's only got optical, which means you might also need a DAC for the TV audio.
As far as DAC's go you can get cheap and nasty ones like this for about $50 http://www.jaycar.com.au/productView.asp?ID=AC1603. But i've never tried one, and suspect nasty is the key word.
It sounds crazy but your best bet for budget price might be a 5CH AV receiver. An entry level might be around $300 to $400 new, but cheaper if 2nd hand. I I guess the sound quality would be on par with the audiosource amp + cheap DAC's.
By the time you get the stereo amp and a couple of dacs (or one with 2 inputs) and required cables you'll be up for similar $$.
An AV receiver has the added benefits of tuner, remote control, simplicity of setup and fewer cables. I'd look at Yamaha, Pioneer, Onkyo, Denon etc. If you're ok with 2nd hand then there should be plenty of affordable options
A 2 CH receiver with HDMI inputs/output would be perfect, but I don't know if anyone makes them. If they do then they're probably more expensive than 5CH due to economies of scale.
I have two apple tv's. On my main system it is connected to my AVR via HDMI.
On my bedroom system I have done what you want to do. I have HDMI directly to the TV and then toslink into a dac/amp which is connected to two speakers.
I have not tried playing airplay with the tv off.
You may need a dac. (I have played mp3 music from an ipod without a dac and with a dac and on my cheap amps I cant hear the difference. I use a dac/amp as I have an ipod dock as well and I listen high bitrate music e.g. flac and aiff with which I can hear the differences)
I think it would be a good idea to buy a second hand av receiver. You can buy an older one which does not have hdmi but that has toslink.
If you want something small look at desktop amps.
If you don't have your speakers as yet, consider a pair of active Audioengine A5s at ~$400, aktimate micro/mini, or cheap active monitors along the lines of the Behringer 1030As, or 2030As. Best bet would be to HDMI to TV, optical out from TV to a cheap DAC along the lines of a fiio d3 for ~$30, then RCA into the monitors. Though, this will not allow you to stream via airplay without the TV on.
If you already have speakers, the Denon AVR-1713 is pretty hard to beat at $530. Solid feature set and will do everything you want. Even supports airplay on its own.
Hmm, keeping it simple and comparatively compact, how about:
* use optical out from both Apple TV and Samsung TV
* connect that into a simple optical switch box (Jaycar/ebay) for choosing which input is active
* connect the optical out into a DAC (may be able to eliminate the switch box if you can find a DAC with multiple optical inputs)
* Then DAC outputs connect into an amplifier (Depending on your speakers, you may be able to get away with one of the class T amps)
It's a pity Emotiva don't seem to be selling their XDA-1 DAC any more, it would have been just the thing for this kind of setup.
The amplifier mentioned in the original post is going to be problematic since it doesn't look like it will work on our 240V power supply, judging by the back panel. What sort of speakers are you planning on running with this setup? In particular, the impedance and sensitivity ratings will help to work out how beefy an amplifier is required.
yep, I was also about to suggest optical out from ATV. It will spit out audio over both HDMI and optical at the same time so the TV can stay off.
Alternative to an optical switchbox is a coax to optical converter. I'm planning on using one for my Dacmagic so I can connect 2 optical sources. I bought one of these for $16 (http://dx.com/p/opti...r-128793?item=2) , it arrived today so I'll test over the weekend. Not sure if it's a good idea sound quality wise but worth a crack.
EDIT: just gave the budget optical/coax converter a go and to my ears it seems to do a good job. Comparing apple lossless file by both direct USB connection to DAC and wifi to ATV -> opt/coax converter -> DAC. Maybe with hi res files, or a better dac the difference would be more noticeable but for me it's fine.
anyway...not sure any of this advice is necessary. OP seems to be missing in action.
Edited by manchu
damn!!! one of my rare serious posts too
:unsure:
if op has gone missing, this is exactly the sort of setup I want too.
I have hit my hurdle with the DAC, as mentioned I can get the fiio d3 for ~$30 and it just gets more expensive from there. If those DAC's are ok I can get my stereo amp with 5-7 analogue input and just buy a fiio for each input I want. My "problem" is I have purchased my speakers already (vaf signature i90) and I don't know if it is silly to put such a cheap component after spending so much on speakers, opinions on this welcome !!! hopefully this along the same lines as what the op was looking for.
got a good condition sclx71 i'd part with for $600....
    • By vunn
      Item Condition: Used but in excellent condition Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Harrison State: Australian Capital Territory Payment Method: PayPal, Bank transfer, Cash Reason for selling: No longer required Further information:
      Regretly let them go after 10 years serving me well. I paired them with Italian Pathos Classic One which is listing for sale also. They are very sweet French taste, vocal, rhythm, dynamic etc are so surprisingly well controlled. I have original shipping box. Flat rate shipping is $60.00 to any destination in Oz. I also listing on Ebay. Will donate after sales.
      Description: Two-way, reflex-loaded loudspeaker for use with stands 20–30" H (not included). Drive-units: 1" titanium-dome tweeter in molded horn enclosure, 6.3" coated pulp-cone woofer. Crossover frequency: 2.5kHz. Frequency response: 50Hz–20kHz, ±3dB. Impedance: 8 ohms nominal, 4.4 ohms minimum. Sensitivity: 90dB/W/m.
      Dimensions: 16.5" (420mm) H by 7.9" (200mm) W by 13.2" (335mm) D. Shipping weight: 41 lbs (18.7kg).
      Review:
      https://www.stereophile.com/standloudspeakers/408tri/index.html
      PLEASE READ
    • By sum1
      Item Condition: Brand New in Box Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Beverly Hills 2209 State: New South Wales Payment Method: EFT, Cash on Pickup, Paypal with fees on the buyer unless sent as a personal payment Reason for selling: Android phone Further information:
      Now i know what you are thinking. What's an Apple product doing here
      Got this item as part of a lucky draw.  Brand New Item in sealed condition.
      Thinking of using it for my Android phone but it seems that Android does not have a good AAC bluetooth support so got put off by it
      https://www.soundguys.com/dont-use-airpods-android-20767/
      Postage will be at your cost. Let me know of your postcode so i can give a quote from Auspost.
      I will re-use the postage box that comes direct from Apple so it should be transported in a safe condition.
      Since the item was purchased direct from Apple you will get the warranty directly from them.
      The following info below is a copy and paste from Apple warranty page.  Warranty and technical support info below
      Eligible for an AppleCare product
      Purchase an AppleCare product to get additional repair coverage and technical support.
      Valid Purchase Date
      A validated purchase date lets Apple quickly find your product and provide the help you need.
      Telephone Technical Support: Active
      Your product is eligible for complimentary telephone technical support.
      Estimated Expiration Date: September 27, 2020
      Repairs and Service Coverage: Active
      Your product is covered for eligible hardware repairs and service under Apple’s Limited Warranty.
      Estimated Expiration Date: June 28, 2021
    • By groqld
      Item: RX-V3085
      Price Range: 1000 - 1250
      Item Condition: New or Used
      Extra Info: hi looking to upgrade my RX-V2700
      Would prefer Pickup in Brisbane North Region.
    • By mfroes
      Hi Guys,
      another newbie question.
      I've been after some speaker wire. i've seen people use cat5/cat6 and all that but i think i'd just stick to standard speaker wires.
      I'll be using the furthest speaker with about 17-18m because of how the speaker wire needs to be routed.
      All speakers are rated at 150W but the Front ones that are rated at 250W.
      the amp will be set under the TV and the only wires to be routed to the right will be the front right and the Surround right
      all other ones will have to be routed through the left  passing from the TV through Subwoofer, front left, surround left, back left and back right (about 17m)
      unfortunately the house is rented and i cannot drill foor/wall/ceiling.
      I've read online that i would need 14 Gauge wiring for the speakers but didnt say anything about distance. was just power and ohms.
      Would it be ok to use 12Gauge instead of 14 gauge? would that have any implications ?
      or better to just stick with 14 gauge?
      would anyone have any suggestions on wire to buy that wouldnt be that expensive?
      what are the thoughts on ugly?
      https://www.selby.com.au/brands/ugly-cable/ugly-12-awg-speaker-cable-420-strands-ug12.html
      have anyone used knukonceptz ?
      http://www.knukonceptz.com/home-theater/speaker-wire/kord-speaker-wire/sp/kord-ultra-flex-12-gauge-speaker-wire-100/
      I think i'll need in total about 70-75m of wiring so can get expensive fast.
      the idea is to use banana plugs for everything.
      i would probably use the same wire with RCA connector for the sub.
      current setup:
      Front: NHT C4
      Centre: Gale 20
      Back & Surround: Axis LS28
      Subwoofer: Sound Dynamics THS-10
                               TV
      FL   S                C                     FR
      SL                                              SR
      BL                                             BR
      distance from amp:
      C(enter): 3-4m to be able to route through the tv unit
      S(ub):  4m
      FL: 5m
      FR: 6m
      SL: 10m
      SR: 12m
      BL: 14m
      BR: 18m
    • By vunn
      Item Condition: Excellent as new, No box, Walnut Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Harrison State: Australian Capital Territory Payment Method: Paypal (free friend&family, +3%, Cash on Pickup, Bank transfer Reason for selling: Not used Further information:
      This Klipsch center is highly recommend for home theatre system. I purchased about 2 years ago but used only few times since bought a Thiel SC4 to make it a centre with my Thiel sc2.4 as front. Prefer local pick up or can ship at buyer’s expenses.
      RRP: 1,090 in Digital Cinema
      https://www.digitalcinema.com.au/klipsch-rp-440c-reference-premiere-centre-channel-speaker.html
      Reviews are here:
      http://centerspeakerzone.com/klipsch-rp-440c-review/
      PLEASE READ
