svenr
Speaker wall mounts - what to buy?
Sirs,
I'm after a pair of decent speaker wall mounts / brackets. The speakers are 4kg with 150mm x 150mm footprint. I'll use an adapter plate that screws onto existing base threads (originally used for spikes when they lived on a shelf) to fix the speakers to the mounting plate of the bracket.
Any suggestions what manufacturer / type to buy?
Thanks a lot: Sven
I got something similar to these from Jaycar.
Mine didn't handle this much weight though and seem to be superceded.
http://www.jaycar.co...SUBCATID=1011#4
edit - I've used these for LCD's..........they'd work for speakers OK.
http://www.anyware.com.au/BT-LCD-502.aspx
Closer fit.........
http://www.anyware.com.au/BT-LCD201S.aspx
Edited by LogicprObe
I personally dont like the look of speakers sitting on/in a bracket. If it were me, I'd find a bracket that can screw into the back of the speaker so it "floats" off the wall - Selby seem to have a few that do this.
You know that unless the speaker is designed for wall mounting that you'll need to eq it a little as the wall acts as a baffle which will boost bass
That's why I linked the LCD mounts........I have used this close fit one.
Still swivels and tilts..............the ones I have are black.
The arm can bring them out from the wall though.
http://ijk.com.au/branch/ijk/product_info.php?cPath=85_558&products_id=114257
Maybe a ceiling mount might be better?
http://www.anyware.com.au/BT-LCD504A.aspx
